    4. Probleme mit Proxmox auf Nuc
      kaschperle83 last edited by
      Hallo ich betreibe Proxmox auf einem Nuc. Jetzt hat er sich innerhalb von wenigen Tagen zweimal aufgehängt. Hier der Log vom heutigen "ende". Was könnte das sein ?
      Nov 23 16:55:11 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 16:55:11 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:00:80:ee:70/00:00:0a:00:00/40 tag 0 ncq dma 8192 out
               res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x50 (ATA bus error)
      Nov 23 16:55:11 local kernel: ata1.00: status: { DRDY }
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:20:08:ed:70/00:00:0a:00:00/40 tag 4 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:28:d0:ed:70/00:00:0a:00:00/40 tag 5 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:30:d8:c3:80/00:00:0a:00:00/40 tag 6 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:38:f8:c3:80/00:00:0a:00:00/40 tag 7 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:40:a8:c6:80/00:00:0a:00:00/40 tag 8 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/20:48:20:c5:80/00:00:0a:00:00/40 tag 9 ncq dma 16384 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:50:60:ee:70/00:00:0a:00:00/40 tag 10 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:58:18:c7:80/00:00:0a:00:00/40 tag 11 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/20:60:b8:ee:70/00:00:0a:00:00/40 tag 12 ncq dma 16384 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:68:30:c8:80/00:00:0a:00:00/40 tag 13 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/10:e0:f0:c4:80/00:00:0a:00:00/40 tag 28 ncq dma 8192 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/20:e8:d8:c6:80/00:00:0a:00:00/40 tag 29 ncq dma 16384 out
      Nov 23 16:55:11 local kernel: ata1.00: cmd 61/40:f0:20:c4:80/00:00:0a:00:00/40 tag 30 ncq dma 32768 out
      Nov 23 16:55:11 local kernel: ata1: hard resetting link
      Nov 23 16:55:11 local kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
      Nov 23 16:55:11 local kernel: ata1.00: configured for UDMA/133
      Nov 23 16:55:11 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 16:55:11 local kernel: ata1: EH complete
      Nov 23 16:57:54 local kernel: ata1.00: exception Emask 0x0 SAct 0x800000 SErr 0x40000 action 0x6 frozen
      Nov 23 16:57:54 local kernel: ata1: SError: { CommWake }
      Nov 23 16:57:54 local kernel: ata1.00: failed command: READ FPDMA QUEUED
      Nov 23 16:57:54 local kernel: ata1.00: cmd 60/00:b8:00:08:10/01:00:00:00:00/40 tag 23 ncq dma 131072 in
               res 40/00:01:06:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
      Nov 23 16:57:54 local kernel: ata1.00: status: { DRDY }
      Nov 23 16:57:54 local kernel: ata1: hard resetting link
      Nov 23 16:57:54 local kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
      Nov 23 16:57:54 local kernel: ata1.00: configured for UDMA/133
      Nov 23 16:57:54 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 16:57:54 local kernel: ata1: EH complete
      Nov 23 16:57:54 local pve-firewall[967]: firewall update time (19.960 seconds)
      Nov 23 16:57:54 local pvestatd[966]: status update time (32.424 seconds)
      Nov 23 16:59:47 local kernel: ata1.00: exception Emask 0x0 SAct 0x40 SErr 0x40000 action 0x6 frozen
      Nov 23 16:59:47 local kernel: ata1: SError: { CommWake }
      Nov 23 16:59:47 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 16:59:47 local kernel: ata1.00: cmd 61/08:30:08:d9:84/00:00:0b:00:00/40 tag 6 ncq dma 4096 out
               res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
      Nov 23 16:59:47 local kernel: ata1.00: status: { DRDY }
      Nov 23 16:59:47 local kernel: ata1: hard resetting link
      Nov 23 16:59:47 local kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
      Nov 23 16:59:47 local kernel: ata1.00: configured for UDMA/133
      Nov 23 16:59:47 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 16:59:47 local kernel: ata1: EH complete
      Nov 23 16:59:47 local pve-firewall[967]: firewall update time (12.933 seconds)
      Nov 23 16:59:47 local pvestatd[966]: status update time (23.329 seconds)
      Nov 23 17:03:13 local kernel: ata1: limiting SATA link speed to 3.0 Gbps
      Nov 23 17:03:13 local kernel: ata1.00: exception Emask 0x10 SAct 0x80e00ff0 SErr 0x4040000 action 0xe frozen
      Nov 23 17:03:13 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:03:13 local kernel: ata1: SError: { CommWake DevExch }
      Nov 23 17:03:13 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:20:08:16:90/00:00:07:00:00/40 tag 4 ncq dma 4096 out
               res 50/00:00:00:00:00/00:00:00:00:00/a0 Emask 0x10 (ATA bus error)
      Nov 23 17:03:13 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:28:50:18:90/00:00:07:00:00/40 tag 5 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:30:60:18:90/00:00:07:00:00/40 tag 6 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:38:08:19:90/00:00:07:00:00/40 tag 7 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/10:40:20:19:90/00:00:07:00:00/40 tag 8 ncq dma 8192 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:48:88:14:91/00:00:07:00:00/40 tag 9 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:50:c8:17:94/00:00:07:00:00/40 tag 10 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:58:28:10:d0/00:00:07:00:00/40 tag 11 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:a8:00:10:10/00:00:01:00:00/40 tag 21 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:b0:38:10:10/00:00:01:00:00/40 tag 22 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:b8:08:10:90/00:00:07:00:00/40 tag 23 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1.00: cmd 61/08:f8:80:10:90/00:00:07:00:00/40 tag 31 ncq dma 4096 out
      Nov 23 17:03:13 local kernel: ata1: hard resetting link
      Nov 23 17:03:13 local kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
      Nov 23 17:03:13 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:03:13 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:03:13 local kernel: ata1: EH complete
      Nov 23 17:05:08 local kernel: ata1.00: exception Emask 0x0 SAct 0x1000000 SErr 0x40000 action 0x6 frozen
      Nov 23 17:05:08 local kernel: ata1: SError: { CommWake }
      Nov 23 17:05:08 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:05:08 local kernel: ata1.00: cmd 61/08:c0:08:80:9c/00:00:07:00:00/40 tag 24 ncq dma 4096 out
               res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
      Nov 23 17:05:08 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:05:08 local kernel: ata1: hard resetting link
      Nov 23 17:05:08 local kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
      Nov 23 17:05:08 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:05:08 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:05:08 local kernel: ata1: EH complete
      Nov 23 17:05:09 local pvestatd[966]: status update time (21.686 seconds)
      Nov 23 17:05:30 local kernel: ata1.00: exception Emask 0x50 SAct 0x200000 SErr 0x40c0800 action 0xe frozen
      Nov 23 17:05:30 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:05:30 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 17:05:30 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:05:30 local kernel: ata1.00: cmd 61/18:a8:10:30:3d/00:00:17:00:00/40 tag 21 ncq dma 12288 out
      Nov 23 17:05:30 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:05:30 local kernel: ata1: hard resetting link
      Nov 23 17:05:30 local kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
      Nov 23 17:05:30 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:05:30 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:05:30 local kernel: ata1: EH complete
      Nov 23 17:07:23 local kernel: ata1.00: exception Emask 0x0 SAct 0x10 SErr 0x40000 action 0x6 frozen
      Nov 23 17:07:23 local kernel: ata1: SError: { CommWake }
      Nov 23 17:07:23 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:07:23 local kernel: ata1.00: cmd 61/08:20:38:10:10/00:00:01:00:00/40 tag 4 ncq dma 4096 out
               res 40/00:00:00:00:00/00:00:00:00:00/a0 Emask 0x4 (timeout)
      Nov 23 17:07:23 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:07:23 local kernel: ata1: hard resetting link
      Nov 23 17:07:24 local kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
      Nov 23 17:07:24 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:07:24 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:07:24 local kernel: ata1: EH complete
      Nov 23 17:07:24 local pve-firewall[967]: firewall update time (16.929 seconds)
      Nov 23 17:07:24 local pvestatd[966]: status update time (24.372 seconds)
      Nov 23 17:08:34 local kernel: ata1: limiting SATA link speed to 1.5 Gbps
      Nov 23 17:08:35 local kernel: ata1.00: exception Emask 0x50 SAct 0x10 SErr 0x40c0800 action 0xe frozen
      Nov 23 17:08:35 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:08:35 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 17:08:35 local kernel: ata1.00: failed command: READ FPDMA QUEUED
      Nov 23 17:08:35 local kernel: ata1.00: cmd 60/00:20:00:08:10/01:00:00:00:00/40 tag 4 ncq dma 131072 in
      Nov 23 17:08:35 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:08:35 local kernel: ata1: hard resetting link
      Nov 23 17:08:35 local kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
      Nov 23 17:08:35 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:08:35 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:08:35 local kernel: ata1: EH complete
      Nov 23 17:08:54 local kernel: ata1.00: exception Emask 0x50 SAct 0x4 SErr 0x40c0800 action 0xe frozen
      Nov 23 17:08:54 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:08:54 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 17:08:54 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:08:54 local kernel: ata1.00: cmd 61/08:10:58:2f:3a/00:00:08:00:00/40 tag 2 ncq dma 4096 out
      Nov 23 17:08:54 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:08:54 local kernel: ata1: hard resetting link
      Nov 23 17:08:55 local kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
      Nov 23 17:08:55 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:08:55 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:08:55 local kernel: ata1: EH complete
      Nov 23 17:09:37 local kernel: ata1.00: exception Emask 0x10 SAct 0x38 SErr 0x4050000 action 0xe frozen
      Nov 23 17:09:37 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:09:37 local kernel: ata1: SError: { PHYRdyChg CommWake DevExch }
      Nov 23 17:09:37 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:09:37 local kernel: ata1.00: cmd 61/08:18:10:56:74/00:00:16:00:00/40 tag 3 ncq dma 4096 out
               res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
      Nov 23 17:09:37 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:09:37 local kernel: ata1.00: cmd 61/08:20:e0:44:0d/00:00:18:00:00/40 tag 4 ncq dma 4096 out
      Nov 23 17:09:37 local kernel: ata1.00: cmd 61/08:28:50:20:98/00:00:16:00:00/40 tag 5 ncq dma 4096 out
      Nov 23 17:09:37 local kernel: ata1: hard resetting link
      Nov 23 17:09:38 local kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
      Nov 23 17:09:38 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:09:38 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:09:38 local kernel: ata1: EH complete
      Nov 23 17:09:40 local kernel: ata1.00: exception Emask 0x50 SAct 0x806000 SErr 0x40c0800 action 0xe frozen
      Nov 23 17:09:40 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:09:40 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 17:09:40 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:09:40 local kernel: ata1.00: cmd 61/80:68:80:b2:3d/00:00:08:00:00/40 tag 13 ncq dma 65536 out
      Nov 23 17:09:40 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:09:40 local kernel: ata1.00: cmd 61/80:70:00:b3:3d/00:00:08:00:00/40 tag 14 ncq dma 65536 out
      Nov 23 17:09:40 local kernel: ata1.00: cmd 61/30:b8:50:b2:3d/00:00:08:00:00/40 tag 23 ncq dma 24576 out
      Nov 23 17:09:40 local kernel: ata1: hard resetting link
      Nov 23 17:09:40 local kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
      Nov 23 17:09:40 local kernel: ata1.00: configured for UDMA/133
      Nov 23 17:09:40 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:09:40 local kernel: ata1: EH complete
      Nov 23 17:10:05 local kernel: ata1.00: limiting speed to UDMA/100:PIO4
      Nov 23 17:10:05 local kernel: ata1.00: exception Emask 0x50 SAct 0x4000 SErr 0x40c0800 action 0xe frozen
      Nov 23 17:10:05 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:10:05 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 17:10:05 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:10:05 local kernel: ata1.00: cmd 61/18:70:f0:37:3d/00:00:17:00:00/40 tag 14 ncq dma 12288 out
      Nov 23 17:10:05 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:10:05 local kernel: ata1: hard resetting link
      Nov 23 17:10:06 local kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
      Nov 23 17:10:06 local kernel: ata1.00: configured for UDMA/100
      Nov 23 17:10:06 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:10:06 local kernel: ata1: EH complete
      Nov 23 17:12:46 local kernel: ata1.00: exception Emask 0x50 SAct 0x4040 SErr 0x40c0800 action 0xe frozen
      Nov 23 17:12:46 local kernel: ata1.00: irq_stat 0x00000040, connection status changed
      Nov 23 17:12:46 local kernel: ata1: SError: { HostInt CommWake 10B8B DevExch }
      Nov 23 17:12:46 local kernel: ata1.00: failed command: WRITE FPDMA QUEUED
      Nov 23 17:12:46 local kernel: ata1.00: cmd 61/20:30:b8:34:34/00:00:08:00:00/40 tag 6 ncq dma 16384 out
      Nov 23 17:12:46 local kernel: ata1.00: status: { DRDY }
      Nov 23 17:12:46 local kernel: ata1.00: cmd 61/08:70:d0:2f:3a/00:00:08:00:00/40 tag 14 ncq dma 4096 out
      Nov 23 17:12:46 local kernel: ata1: hard resetting link
      Nov 23 17:12:46 local kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
      Nov 23 17:12:46 local kernel: ata1.00: configured for UDMA/100
      Nov 23 17:12:46 local kernel: ahci 0000:00:17.0: port does not support device sleep
      Nov 23 17:12:46 local kernel: ata1: EH complete
      -- Reboot --
        Matt77CHE last edited by
        Hallo @kaschperle83
        Ich betreibe auch einen NUC mit Proxmox - Bin jetzt aber nicht so der Hirsch darauf....
        Was ich rausgefunden habe (Internet) scheint das was mit der ssd zu tun zu haben. Einer schrieb, dass es wegen einem defekten SATA-Kabel dazu gekommen war....
        Gruss
        Matt
          Thomas Braun Most Active @kaschperle83 last edited by
          @kaschperle83 sagte in Probleme mit Proxmox auf Nuc:
          Das kommt aus der Hardware-Ecke. Dateisystem defekt, Speichermedium defekt, Kabel defekt usw.
