    4. Adapter-Update
    Adapter-Update
    • Lenny.CB
      Lenny.CB Most Active last edited by
      habe mal grad das Update vom js-controller auf 1.0.0 gemacht…
      hier mal das Log. Muss ich mir Sorgen machen? So schaut es neuerdings generell aus wenn ich was updaten will...
      ! root@odroid64:/opt/iobroker# sudo iobroker upgrade self
      ! npm install iobroker.js-controller@1.0.0 –production --prefix "/opt/iobroker" (System call)
      ! npm WARN addRemoteGit Error: not found: git
      ! npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      ! npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
      ! npm WARN addRemoteGit git://github.com/noopkat/browser-serialport.git#api-updates resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
      ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
      ! npm WARN addRemoteGit git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
      ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
      ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
      ! ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
      ! compilation terminated.
      ! make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
      ! gyp ERR! build error
      ! gyp ERR! stack Error: make failed with exit code: 2
      ! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! gyp ERR! stack at emitTwo (events.js:106:13)
      ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      ! gyp ERR! System Linux 3.14.79-110
      ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      ! gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      ! gyp ERR! node -v v6.10.2
      ! gyp ERR! node-gyp -v v3.4.0
      ! gyp ERR! not ok
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/avrgirl-arduino/node_modules/browser-serialport):
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules/avrgirl-arduino/node_modules/stk500):
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      ! Host "odroid64" (linux) updated
      ! Execute: chmod 777 -R /opt/iobroker
      ! Chmod finished. Restart controller
      ! Starting node restart.js
      • Lenny.CB
        @Homoran:
        sudo apt-get install git
        das brauchts aber noch nicht lang?
          Einige adapter haben es schon immer gebraucht, deswegen hab ich es eh drauf.
          Und mir ist es nicht aufgefallen.
