    4. Zigbee 1.8.7 errors im Log
    • ESP8266
      ESP8266 last edited by ESP8266
      Habe den Zigbee Adapter vor drei Tagen auf 1.8.7 geupgradet.
      Jetzt kommen immer mal errors im Log.
      zigbee.0
      	2022-12-05 14:00:03.342	error	Error 225 on send command to 0x847127fffe8f3279. Error: Error: Command 0x847127fffe8f3279/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      	2022-12-05 14:00:00.640	error	Error 225 on send command to 0x84fd27fffe93d9f2. Error: Error: Command 0x84fd27fffe93d9f2/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      	2022-12-05 13:59:43.028	error	Error 225 on send command to 0x00158d00053cc50d. Error: Error: Command 0x00158d00053cc50d/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      	2022-12-05 13:59:42.961	error	Error 225 on send command to 0x00158d00053c3cf6. Error: Error: Command 0x00158d00053c3cf6/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      	2022-12-05 13:59:11.655	error	Error 225 on send command to 0x84fd27fffe9b3baf. Error: Error: Command 0x84fd27fffe9b3baf/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      	2022-12-05 13:59:11.591	error	Error 225 on send command to 0x84fd27fffe93d9f2. Error: Error: Command 0x84fd27fffe93d9f2/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      zigbee.0
      zigbee.0
      zigbee.0
      	2022-12-05 13:58:59.150	error	Error 225 on send command to 0xbc33acfffee60b3b. Error: Error: Command 0xbc33acfffee60b3b/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      Obwohl soweit alles zu funktionieren scheint. Update: Nein es wir verzögert geschaltet.
      Stick wurde schon mal getrennt.
      Gerade festgestellt, auch bei der Version 1.8.3. das gleiche Problem.
      Langsame Reaktion beim ein/auschalten der Lampen, dabei kommt es zu den errors.
      Scheinbar war das System durcheinander.....derzeit keine errrors mehr im Log.
      • Asgothian
        Asgothian Developer @ESP8266 last edited by
        @esp8266 sagte in Zigbee 1.8.7 errors im Log:
        Das system war nicht durcheinander. Das System hat Dir gemeldet das es Probleme mit dem Funknetz hat.
        Siehe auch:
        https://www.zigbee2mqtt.io/guide/faq/#common-error-codes (leider nur auf englisch)
        Je nach der Funkauslastung bei Dir kann der Effekt also erneut auftreten.
        A.
        ESP8266 1 Reply Last reply Reply Quote 2
        • ESP8266
          ESP8266 @Asgothian last edited by
          @asgothian , eventuell muss ich mal den Kanal wechseln. Danke für den Hinweis....werde mal in der Fritte die Wlan Nachbarkanäle beobachten.
          • Asgothian
            @esp8266
            Bitte auch andere 2.4 GHz Störquellen betrachten:
            • DECT Telefone
            • Proprietäre 2.4 GHz Kopfhörer / Tastatur/Maus Kombinationen etc.
            A.
