    4. Installation
    5. iobroker upgrade self Fehlermeldung
      khschmidt last edited by khschmidt
      bekomme folgende Fehlermeldung:
      pi@raspberrypi:~ $ iobroker upgrade self
      Update js-controller from @3.1.6 to @4.0.23
      NPM version: 8.19.2
      npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker"        (System call)
       Objects 127.0.0.1:51044 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["met        a.objects.features.useSets"]
       States 127.0.0.1:37436 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["met        a.states.protocolVersion"]
       Objects 127.0.0.1:51044 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["met        a.objects.protocolVersion"]
       Objects 127.0.0.1:51044 Error from InMemDB: Error: scan NOT SUPPORTED
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c -- node iobroker.js setup first
      npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
      npm ERR!         throw e;
      npm ERR!         ^
      npm ERR!
      npm ERR! ReplyError: Error scan NOT SUPPORTED
      npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      npm ERR! Emitted 'error' event on ScanStream instance at:
      npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
      npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
      npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
      npm ERR!     at processTicksAndRejections (node:internal/process/task_queues:96:5) {
      npm ERR!   command: {
      npm ERR!     name: 'scan',
      npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm ERR!   }
      npm ERR! }
      npm ERR!     /home/iobroker/.npm/_logs/2022-12-05T14_20_04_160Z-debug-0.log
      Starting node restart.js
      kann da jemand weiterhelfen, Raspberry pi3, raspian buster
      • crunchip
        crunchip Forum Testing Most Active @khschmidt last edited by
        @khschmidt sagte in iobroker upgrade self Fehlermeldung:
        https://forum.iobroker.net/topic/52886/js-controller-4-0-x-jetzt-für-alle-user-im-stable
