    2. English
    3. ioBroker general
    4. iObroker not accessible
    • Vraanaa
      Vraanaa last edited by
      I faced with the problem with iObroker. I cant access it anymore. I tried to go trough command line to do update but there is strange info comes:
      I was looked at this Folder - and there was no iobroker.js-controller/iobroker.js - really dont know wahts happen - everything was working fine.
        Thomas Braun Most Active @Vraanaa last edited by Thomas Braun
        @vraanaa
        Try reinstalling
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        And please do not provide screenshots from terminal but post the text embedded in CodeTags.
        Vraanaa 1 Reply Last reply Reply Quote 0
        • Vraanaa
          Vraanaa @Thomas Braun last edited by
          @thomas-braun thank you for your reply
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.17
          > unix-dgram@2.0.6 install /opt/iobroker/node_modules/unix-dgram
          > node-gyp rebuild
          make: Ulazak u direktorij '/opt/iobroker/node_modules/unix-dgram/build'
            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
          In file included from ../../nan/nan.h:60,
                           from ../src/unix_dgram.cc:5:
          /home/iobroker/.cache/node-gyp/14.21.1/include/node/node.h:793:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                 (node::addon_register_func) (regfunc),                          \
          /home/iobroker/.cache/node-gyp/14.21.1/include/node/node.h:827:3: note: in expansion of macro 'NODE_MODULE_X'
             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
           NODE_MODULE(unix_dgram, Initialize)
            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
            COPY Release/unix_dgram.node
          make: Izlazak iz direktorija '/opt/iobroker/node_modules/unix-dgram/build'
          > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
          npm WARN iobroker No description
          npm WARN iobroker No repository field.
          npm WARN iobroker No README data
          npm WARN iobroker No license field.
          npm ERR! code ELIFECYCLE
          npm ERR! errno 24
          npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
          npm ERR! Exit status 24
          npm ERR!
          npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR!     /home/iobroker/.npm/_logs/2022-12-11T11_39_21_489Z-debug.log
            @vraanaa
            First upgrade your nodejs to version 16.
            Vraanaa 2 Replies Last reply Reply Quote 0
            • Vraanaa
              Vraanaa @Thomas Braun last edited by Vraanaa
              @thomas-braun I did but it didnt update - strange - I stopped iobroker before:
              Edit - sorry I forgot to run sudo apt install -y nodejs
              pi@raspberrypi:~ $ node -v
              v14.21.1
              pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
              ## Installing the NodeSource Node.js 16.x repo...
              ## Populating apt-get cache...
              + apt-get update
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
              Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Reading package lists... Done
              ## Confirming "buster" is supported...
              + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
              ## Adding the NodeSource signing key to your keyring...
              + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
              gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
              ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
              + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
              + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
              ## Running `apt-get update` for you...
              + apt-get update
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
              ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
              ## You may also need development tools to build native addons:
                   sudo apt-get install gcc g++ make
              ## To install the Yarn package manager, run:
                   curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                   echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                   sudo apt-get update && sudo apt-get install yarn
              v14.21.1
              pi@raspberrypi:~ $
                @vraanaa
                What does this command do?
                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                • Vraanaa
                  @thomas-braun now is on version 16
                  v16.18.1
                  pi@raspberrypi:~ $ iobroker start
                  pi@raspberrypi:~ $ iobroker update
                  node:internal/modules/cjs/loader:988
                    throw err;
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                      at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      at node:internal/main/run_main_module:22:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  pi@raspberrypi:~ $ iobroker fix
                  library: loaded
                  Library version=2022-06-15
                  ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                  pi@raspberrypi:~ $
                    @vraanaa
                    The 'Buster' release has reached its End of Life.
                    Please install the actual stable Release 'Bullseye'
                    • Vraanaa
                      @thomas-braun thank you for you help so far - can you help me little bit with this Bullseye? How exactly I should install it?
                        @vraanaa
                        In german language only:
                        https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                        But I'm sure that there are plenty of instructions out there in English or even your native language.
                        • Vraanaa
                          @thomas-braun kein problem - ich kann auch Deutch verstehen 👍
                          Vielen Dank - probiere ich und melde.
                          So nach Bullseye instalation soll alles OK sein oder muss ich noch ewas anderes zu tun?
                            @vraanaa
                            Nein, der iobroker wird nach einem Upgrade auf Bullseye immer noch kaputt sein. Aber dann ist die Basis schonmal aktuell und stabil.
                            • Vraanaa
                              @thomas-braun I did all as per manual. can we check if everything is ok before next steps?
                                @vraanaa
                                what is the feedback to this chain of commands?
                                • Vraanaa
                                  pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                  armv7l
                                  Kein Docker
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.18.1
                                  v16.18.1
                                  8.19.2
                                    throw err;
                                    requireStack: []
                                  pi@raspberrypi:~ $
                                    @vraanaa sagte in iObroker not accessible:
                                    • Vraanaa
                                      @thomas-braun kommt diese
                                      pi@raspberrypi:~ $ whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                      x11
                                      LXDE-pi
                                      /home/pi
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:3 https://dl.yarnpkg.com/debian stable InRelease
                                      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Building dependency tree... Done
                                      All packages are up to date.
                                      nodejs:
                                        Installed: 16.18.1-deb-1nodesource1
                                        Candidate: 16.18.1-deb-1nodesource1
                                        Version table:
                                       *** 16.18.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                              100 /var/lib/dpkg/status
                                           12.22.12~dfsg-1~deb11u1 500
                                      pi@raspberrypi:~ $
                                        @vraanaa
                                        Turn the Desktop OFF.
                                        A server is running headless. Always.
                                        • Vraanaa
                                          @thomas-braun meinst du dass ich remote vnc desktop benutzen nicht?
                                          kann ich auch durch putty zum ssh gehen.
                                            @vraanaa
                                            Nein, auch kein remote DESKTOP.
                                            NO DESKTOP.
                                            sudo raspi-config
                                            Menu:
                                            1 System Options
                                            S5 Boot / Auto Login
                                            B1 Console
                                            3481
