    4. BLE Adapter funktioniert nach Node Update auf v16 nicht mehr
      tiego last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspian
      Node-Version: v16.18.1
      Nodejs-Version: v16.18.1
      NPM-Version: 8.19.2
      Installationsart: Skript
      Image genutzt: Nein
      Hallo, Habe heute von der Node Version 10 auf die Version 16 geupdatet laut Anleitung.
      Alle Adapter funktionieren ohne Problem nur der BLE 0.13 läst sich nicht mehr starten bzw. installieren.
      Log:
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@8.19.2
      2 info using node@v16.18.1
      3 timing npm:load:whichnode Completed in 0ms
      4 timing config:load:defaults Completed in 5ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
      6 timing config:load:builtin Completed in 5ms
      7 timing config:load:cli Completed in 5ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
      10 timing config:load:project Completed in 4ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:validate Completed in 2ms
      16 timing config:load:credentials Completed in 3ms
      17 timing config:load:setEnvs Completed in 3ms
      18 timing config:load Completed in 31ms
      19 timing npm:load:configload Completed in 31ms
      20 timing npm:load:mkdirpcache Completed in 3ms
      21 timing npm:load:mkdirplogs Completed in 1ms
      22 verbose title npm install AlCalzone/ioBroker.ble
      23 verbose argv "install" "AlCalzone/ioBroker.ble"
      24 timing npm:load:setTitle Completed in 3ms
      25 timing config:load:flatten Completed in 9ms
      26 timing npm:load:display Completed in 12ms
      27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
      28 verbose logfile /home/iobroker/.npm/_logs/2022-12-13T21_49_12_357Z-debug-0.log
      29 timing npm:load:logFile Completed in 19ms
      30 timing npm:load:timers Completed in 0ms
      31 timing npm:load:configScope Completed in 0ms
      32 timing npm:load Completed in 73ms
      33 timing arborist:ctor Completed in 3ms
      34 silly logfile start cleaning logs, removing 3 files
      35 silly logfile done cleaning log files
      36 timing idealTree:init Completed in 1946ms
      37 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      38 timing idealTree:userRequests Completed in 2932ms
      39 silly idealTree buildDeps
      40 silly fetch manifest iobroker.ble@AlCalzone/ioBroker.ble
      41 silly placeDep ROOT iobroker.ble@0.13.0 OK for: iobroker.inst@3.0.0 want: AlCalzone/ioBroker.ble
      42 silly fetch manifest @abandonware/noble@^1.9.2-15
      43 silly fetch manifest iobroker-react-components@^1.0.0
      44 http fetch GET 200 https://registry.npmjs.org/iobroker-react-components 1071ms (cache revalidated)
      45 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fnoble 1829ms (cache revalidated)
      46 timing idealTree:#root Completed in 3155ms
      47 silly placeDep ROOT @abandonware/noble@1.9.2-15 OK for: iobroker.ble@0.13.0 want: ^1.9.2-15
      48 silly placeDep ROOT iobroker-react-components@1.0.0 OK for: iobroker.ble@0.13.0 want: ^1.0.0
      49 silly fetch manifest debug@^4.3.1
      50 silly fetch manifest node-addon-api@^3.2.0
      51 silly fetch manifest @abandonware/bluetooth-hci-socket@^0.5.3-8
      52 http fetch GET 200 https://registry.npmjs.org/debug 97ms (cache revalidated)
      53 http fetch GET 200 https://registry.npmjs.org/node-addon-api 796ms (cache revalidated)
      54 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fbluetooth-hci-socket 1749ms (cache revalidated)
      55 timing idealTree:node_modules/iobroker.ble Completed in 1791ms
      56 silly placeDep ROOT @abandonware/bluetooth-hci-socket@0.5.3-8 OK for: @abandonware/noble@1.9.2-15 want: ^0.5.3-8
      57 silly placeDep node_modules/@abandonware/noble debug@4.3.4 OK for: @abandonware/noble@1.9.2-15 want: ^4.3.1
      58 silly placeDep node_modules/@abandonware/noble node-addon-api@3.2.1 OK for: @abandonware/noble@1.9.2-15 want: ^3.2.0
      59 silly fetch manifest @mapbox/node-pre-gyp@^1.0.5
      60 silly fetch manifest debug@^4.3.2
      61 silly fetch manifest ms@2.1.2
      62 http fetch GET 200 https://registry.npmjs.org/ms 84ms (cache revalidated)
      63 http fetch GET 200 https://registry.npmjs.org/@mapbox%2fnode-pre-gyp 1750ms (cache revalidated)
      64 timing idealTree:node_modules/@abandonware/noble Completed in 1822ms
      65 silly placeDep ROOT @mapbox/node-pre-gyp@1.0.10 OK for: @abandonware/bluetooth-hci-socket@0.5.3-8 want: ^1.0.5
      66 silly placeDep node_modules/@abandonware/bluetooth-hci-socket debug@4.3.4 OK for: @abandonware/bluetooth-hci-socket@0.5.3-8 want: ^4.3.2
      67 silly fetch manifest detect-libc@^2.0.0
      68 silly fetch manifest make-dir@^3.1.0
      69 silly fetch manifest nopt@^5.0.0
      70 silly fetch manifest npmlog@^5.0.1
      71 silly fetch manifest rimraf@^3.0.2
      72 http fetch GET 200 https://registry.npmjs.org/nopt 109ms (cache revalidated)
      73 http fetch GET 200 https://registry.npmjs.org/detect-libc 116ms (cache revalidated)
      74 http fetch GET 200 https://registry.npmjs.org/npmlog 176ms (cache revalidated)
      75 http fetch GET 200 https://registry.npmjs.org/rimraf 191ms (cache revalidated)
      76 http fetch GET 200 https://registry.npmjs.org/make-dir 902ms (cache revalidated)
      77 timing idealTree:node_modules/@abandonware/bluetooth-hci-socket Completed in 929ms
      78 silly placeDep ROOT detect-libc@2.0.1 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^2.0.0
      79 silly placeDep ROOT make-dir@3.1.0 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^3.1.0
      80 silly placeDep ROOT nopt@5.0.0 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^5.0.0
      81 silly placeDep ROOT npmlog@5.0.1 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^5.0.1
      82 silly placeDep ROOT rimraf@3.0.2 OK for: @mapbox/node-pre-gyp@1.0.10 want: ^3.0.2
      83 silly fetch manifest semver@^6.0.0
      84 silly fetch manifest abbrev@1
      85 silly fetch manifest are-we-there-yet@^2.0.0
      86 silly fetch manifest console-control-strings@^1.1.0
      87 silly fetch manifest gauge@^3.0.0
      88 silly fetch manifest set-blocking@^2.0.0
      89 silly fetch manifest glob@^7.1.3
      90 http fetch GET 200 https://registry.npmjs.org/abbrev 127ms (cache revalidated)
      91 http fetch GET 200 https://registry.npmjs.org/semver 132ms (cache revalidated)
      92 http fetch GET 200 https://registry.npmjs.org/console-control-strings 140ms (cache revalidated)
      93 http fetch GET 200 https://registry.npmjs.org/glob 164ms (cache revalidated)
      94 http fetch GET 200 https://registry.npmjs.org/gauge 187ms (cache revalidated)
      95 http fetch GET 200 https://registry.npmjs.org/are-we-there-yet 316ms (cache revalidated)
      96 http fetch GET 200 https://registry.npmjs.org/set-blocking 331ms (cache revalidated)
      97 timing idealTree:node_modules/@mapbox/node-pre-gyp Completed in 396ms
      98 timing idealTree:node_modules/detect-libc Completed in 0ms
      99 timing idealTree:node_modules/iobroker-react-components Completed in 0ms
      100 silly placeDep node_modules/make-dir semver@6.3.0 OK for: make-dir@3.1.0 want: ^6.0.0
      101 timing idealTree:node_modules/make-dir Completed in 5ms
      102 silly placeDep ROOT abbrev@1.1.1 OK for: nopt@5.0.0 want: 1
      103 timing idealTree:node_modules/nopt Completed in 5ms
      104 timing idealTree:node_modules/abbrev Completed in 0ms
      105 silly placeDep ROOT are-we-there-yet@2.0.0 OK for: npmlog@5.0.1 want: ^2.0.0
      106 silly placeDep ROOT console-control-strings@1.1.0 OK for: npmlog@5.0.1 want: ^1.1.0
      107 silly placeDep ROOT gauge@3.0.2 OK for: npmlog@5.0.1 want: ^3.0.0
      108 silly placeDep ROOT set-blocking@2.0.0 OK for: npmlog@5.0.1 want: ^2.0.0
      109 silly fetch manifest delegates@^1.0.0
      110 silly fetch manifest readable-stream@^3.6.0
      111 silly fetch manifest aproba@^1.0.3 || ^2.0.0
      112 silly fetch manifest color-support@^1.1.2
      113 silly fetch manifest has-unicode@^2.0.1
      114 silly fetch manifest wide-align@^1.1.2
      115 http fetch GET 200 https://registry.npmjs.org/delegates 143ms (cache revalidated)
      116 http fetch GET 200 https://registry.npmjs.org/has-unicode 153ms (cache revalidated)
      117 http fetch GET 200 https://registry.npmjs.org/color-support 161ms (cache revalidated)
      118 http fetch GET 200 https://registry.npmjs.org/wide-align 158ms (cache revalidated)
      119 http fetch GET 200 https://registry.npmjs.org/readable-stream 171ms (cache revalidated)
      120 http fetch GET 200 https://registry.npmjs.org/aproba 810ms (cache revalidated)
      121 timing idealTree:node_modules/npmlog Completed in 836ms
      122 silly placeDep ROOT delegates@1.0.0 OK for: are-we-there-yet@2.0.0 want: ^1.0.0
      123 silly placeDep node_modules/are-we-there-yet readable-stream@3.6.0 OK for: are-we-there-yet@2.0.0 want: ^3.6.0
      124 silly fetch manifest string_decoder@^1.1.1
      125 http fetch GET 200 https://registry.npmjs.org/string_decoder 65ms (cache revalidated)
      126 timing idealTree:node_modules/are-we-there-yet Completed in 87ms
      127 timing idealTree:node_modules/console-control-strings Completed in 0ms
      128 timing idealTree:node_modules/delegates Completed in 0ms
      129 silly placeDep ROOT aproba@2.0.0 OK for: gauge@3.0.2 want: ^1.0.3 || ^2.0.0
      130 silly placeDep ROOT color-support@1.1.3 OK for: gauge@3.0.2 want: ^1.1.2
      131 silly placeDep ROOT has-unicode@2.0.1 OK for: gauge@3.0.2 want: ^2.0.1
      132 silly placeDep ROOT wide-align@1.1.5 OK for: gauge@3.0.2 want: ^1.1.2
      133 timing idealTree:node_modules/gauge Completed in 27ms
      134 timing idealTree:node_modules/aproba Completed in 0ms
      135 timing idealTree:node_modules/color-support Completed in 0ms
      136 timing idealTree:node_modules/has-unicode Completed in 0ms
      137 silly placeDep node_modules/rimraf glob@7.2.3 OK for: rimraf@3.0.2 want: ^7.1.3
      138 silly fetch manifest minimatch@^3.1.1
      139 http fetch GET 200 https://registry.npmjs.org/minimatch 52ms (cache revalidated)
      140 timing idealTree:node_modules/rimraf Completed in 63ms
      141 timing idealTree:node_modules/set-blocking Completed in 0ms
      142 timing idealTree:node_modules/wide-align Completed in 0ms
      143 silly placeDep node_modules/@abandonware/bluetooth-hci-socket ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      144 timing idealTree:node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug Completed in 5ms
      145 timing idealTree:node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms Completed in 0ms
      146 silly placeDep node_modules/@abandonware/noble ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      147 timing idealTree:node_modules/@abandonware/noble/node_modules/debug Completed in 4ms
      148 timing idealTree:node_modules/@abandonware/noble/node_modules/ms Completed in 0ms
      149 timing idealTree:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 0ms
      150 silly placeDep node_modules/are-we-there-yet string_decoder@1.3.0 OK for: readable-stream@3.6.0 want: ^1.1.1
      151 silly fetch manifest safe-buffer@~5.2.0
      152 http fetch GET 200 https://registry.npmjs.org/safe-buffer 48ms (cache revalidated)
      153 timing idealTree:node_modules/are-we-there-yet/node_modules/readable-stream Completed in 55ms
      154 silly placeDep node_modules/are-we-there-yet safe-buffer@5.2.1 OK for: string_decoder@1.3.0 want: ~5.2.0
      155 timing idealTree:node_modules/are-we-there-yet/node_modules/string_decoder Completed in 5ms
      156 timing idealTree:node_modules/are-we-there-yet/node_modules/safe-buffer Completed in 0ms
      157 timing idealTree:node_modules/make-dir/node_modules/semver Completed in 0ms
      158 silly placeDep node_modules/rimraf minimatch@3.1.2 OK for: glob@7.2.3 want: ^3.1.1
      159 silly fetch manifest brace-expansion@^1.1.7
      160 http fetch GET 200 https://registry.npmjs.org/brace-expansion 54ms (cache revalidated)
      161 timing idealTree:node_modules/rimraf/node_modules/glob Completed in 62ms
      162 silly placeDep node_modules/rimraf brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
      163 timing idealTree:node_modules/rimraf/node_modules/minimatch Completed in 6ms
      164 timing idealTree:node_modules/rimraf/node_modules/brace-expansion Completed in 1ms
      165 timing idealTree:buildDeps Completed in 9265ms
      166 timing idealTree:fixDepFlags Completed in 18ms
      167 timing idealTree Completed in 14195ms
      168 timing reify:loadTrees Completed in 14198ms
      169 timing reify:diffTrees Completed in 55ms
      170 silly reify moves {}
      171 timing reify:retireShallow Completed in 3ms
      172 timing reify:createSparse Completed in 48ms
      173 timing reify:loadBundles Completed in 0ms
      174 verbose reify failed optional dependency /opt/iobroker/node_modules/xpc-connection
      175 silly reify mark deleted [ '/opt/iobroker/node_modules/xpc-connection' ]
      176 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
      177 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
      178 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
      179 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
      180 timing reifyNode:node_modules/xpc-connection Completed in 40ms
      181 timing reifyNode:node_modules/osx-temperature-sensor Completed in 39ms
      182 timing reifyNode:node_modules/fsevents Completed in 39ms
      183 timing reifyNode:node_modules/wide-align Completed in 804ms
      184 timing reifyNode:node_modules/has-unicode Completed in 804ms
      185 timing reifyNode:node_modules/abbrev Completed in 806ms
      186 timing reifyNode:node_modules/rimraf/node_modules/brace-expansion Completed in 812ms
      187 timing reifyNode:node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms Completed in 812ms
      188 timing reifyNode:node_modules/@abandonware/noble/node_modules/ms Completed in 812ms
      189 timing reifyNode:node_modules/rpi-gpio/node_modules/ms Completed in 813ms
      190 timing reifyNode:node_modules/aproba Completed in 820ms
      191 timing reifyNode:node_modules/set-blocking Completed in 820ms
      192 timing reifyNode:node_modules/console-control-strings Completed in 821ms
      193 timing reifyNode:node_modules/npmlog Completed in 821ms
      194 timing reifyNode:node_modules/make-dir Completed in 821ms
      195 timing reifyNode:node_modules/button-events Completed in 827ms
      196 timing reifyNode:node_modules/async-retry Completed in 827ms
      197 timing reifyNode:node_modules/color-support Completed in 838ms
      198 timing reifyNode:node_modules/are-we-there-yet/node_modules/string_decoder Completed in 848ms
      199 timing reifyNode:node_modules/rimraf/node_modules/minimatch Completed in 855ms
      200 timing reifyNode:node_modules/rimraf Completed in 858ms
      201 timing reifyNode:node_modules/rpi-gpio-buttons Completed in 858ms
      202 timing reifyNode:node_modules/are-we-there-yet/node_modules/safe-buffer Completed in 865ms
      203 timing reifyNode:node_modules/delegates Completed in 870ms
      204 timing reifyNode:node_modules/detect-libc Completed in 867ms
      205 timing reifyNode:node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug Completed in 873ms
      206 timing reifyNode:node_modules/@abandonware/noble/node_modules/debug Completed in 873ms
      207 timing reifyNode:node_modules/are-we-there-yet Completed in 877ms
      208 timing reifyNode:node_modules/nopt Completed in 876ms
      209 timing reifyNode:node_modules/async-retry/node_modules/retry Completed in 878ms
      210 timing reifyNode:node_modules/rimraf/node_modules/glob Completed in 887ms
      211 timing reifyNode:node_modules/make-dir/node_modules/semver Completed in 896ms
      212 timing reifyNode:node_modules/rpi-gpio/node_modules/debug Completed in 895ms
      213 timing reifyNode:node_modules/unix-dgram Completed in 898ms
      214 timing reifyNode:node_modules/rpi-gpio Completed in 898ms
      215 timing reifyNode:node_modules/diskusage Completed in 903ms
      216 timing reifyNode:node_modules/iobroker-react-components Completed in 931ms
      217 timing reifyNode:node_modules/bluetooth-hci-socket Completed in 937ms
      218 timing reifyNode:node_modules/gauge Completed in 944ms
      219 timing reifyNode:node_modules/node-dht-sensor Completed in 962ms
      220 timing reifyNode:node_modules/@abandonware/bluetooth-hci-socket Completed in 997ms
      221 timing reifyNode:node_modules/are-we-there-yet/node_modules/readable-stream Completed in 1012ms
      222 timing reifyNode:node_modules/epoll Completed in 1019ms
      223 timing reifyNode:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 1036ms
      224 timing reifyNode:node_modules/usb/node_modules/node-addon-api Completed in 1036ms
      225 timing reifyNode:node_modules/@mapbox/node-pre-gyp Completed in 1048ms
      226 timing reifyNode:node_modules/es6-promise Completed in 1049ms
      227 timing reifyNode:node_modules/node-dht-sensor/node_modules/node-addon-api Completed in 1152ms
      228 timing reifyNode:node_modules/@abandonware/noble Completed in 1168ms
      229 timing reifyNode:node_modules/usb Completed in 1914ms
      230 http fetch GET 200 https://codeload.github.com/AlCalzone/ioBroker.ble/tar.gz/a9201048d6bfa5e27f82ea083f70903e858cf0e7 1262ms (cache miss)
      231 timing reify:rollback:createSparse Completed in 230ms
      232 timing reify:rollback:retireShallow Completed in 0ms
      233 timing command:install Completed in 289616ms
      234 verbose stack Error: git dep preparation failed
      234 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
      234 verbose stack     at ChildProcess.emit (node:events:513:28)
      234 verbose stack     at maybeClose (node:internal/child_process:1100:16)
      234 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
      235 verbose cwd /opt/iobroker
      236 verbose Linux 5.10.103-v7l+
      237 verbose node v16.18.1
      238 verbose npm  v8.19.2
      239 error code 1
      240 error git dep preparation failed
      241 error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
      242 error npm WARN using --force Recommended protections disabled.
      242 error npm WARN deprecated uuid@3.3.3: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      242 error npm ERR! code 1
      242 error npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonexcYOzD/node_modules/@abandonware/noble
      242 error npm ERR! command failed
      242 error npm ERR! command sh -c -- node-gyp rebuild
      242 error npm ERR! node:internal/modules/cjs/loader:988
      242 error npm ERR!   throw err;
      242 error npm ERR!   ^
      242 error npm ERR!
      242 error npm ERR! Error: Cannot find module 'object-assign'
      242 error npm ERR! Require stack:
      242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js
      242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js
      242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js
      242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js
      242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js
      242 error npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js
      242 error npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
      242 error npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:833:27)
      242 error npm ERR!     at Module.require (node:internal/modules/cjs/loader:1057:19)
      242 error npm ERR!     at require (node:internal/modules/cjs/helpers:103:18)
      242 error npm ERR!     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)
      242 error npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1155:14)
      242 error npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
      242 error npm ERR!     at Module.load (node:internal/modules/cjs/loader:1033:32)
      242 error npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:868:12)
      242 error npm ERR!     at Module.require (node:internal/modules/cjs/loader:1057:19) {
      242 error npm ERR!   code: 'MODULE_NOT_FOUND',
      242 error npm ERR!   requireStack: [
      242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',
      242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',
      242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',
      242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',
      242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',
      242 error npm ERR!     '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'
      242 error npm ERR!   ]
      242 error npm ERR! }
      242 error
      242 error npm ERR! A complete log of this run can be found in:
      242 error npm ERR!     /home/iobroker/.npm/_logs/2022-12-13T21_49_30_437Z-debug-0.log
      243 verbose exit 1
      244 timing npm Completed in 290011ms
      245 verbose unfinished npm timer reify 1670968152752
      246 verbose unfinished npm timer reify:unpack 1670968167097
      247 verbose unfinished npm timer reifyNode:node_modules/iobroker.ble 1670968167103
      248 verbose code 1
      249 error A complete log of this run can be found in:
      249 error     /home/iobroker/.npm/_logs/2022-12-13T21_49_12_357Z-debug-0.log
      Könnt Ihr mir bitte helfen den Fehler zu finden und zu beheben?
      danke
        Thomas Braun Most Active @tiego last edited by Thomas Braun
        @tiego
        cd /opt/iobroker
        npm ls object-assign
        sagt?
        Bei nodejs schaut's wie aus?
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Edit: Typo
          holgerwolf @Thomas Braun last edited by holgerwolf
          @tiego
          Ich muss das mal von tiego wieder hochholen. Er hat sich ja nicht mehr gemeldet. Aber ich laufe mit BLE 0.13 und Node 16.x auch in das obige Problem.
          Hier die Ausgabe:
           npm la object-assign
          npm ERR! Cannot read properties of undefined (reading 'description')
          npm ERR!     /home/iobroker/.npm/_logs/2022-12-20T07_49_59_077Z-debug-0.log
          0 verbose cli /usr/local/bin/node /usr/local/bin/npm
          1 info using npm@8.19.3
          2 info using node@v16.19.0
          3 timing npm:load:whichnode Completed in 3ms
          4 timing config:load:defaults Completed in 39ms
          5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 20m
          s
          6 timing config:load:builtin Completed in 24ms
          7 timing config:load:cli Completed in 39ms
          8 timing config:load:env Completed in 7ms
          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 26ms
          10 timing config:load:project Completed in 47ms
          11 timing config:load:file:/home/iobroker/.npmrc Completed in 4ms
          12 timing config:load:user Completed in 10ms
          13 timing config:load:file:/usr/local/etc/npmrc Completed in 2ms
          14 timing config:load:global Completed in 4ms
          15 timing config:load:validate Completed in 29ms
          16 timing config:load:credentials Completed in 20ms
          17 timing config:load:setEnvs Completed in 21ms
          18 timing config:load Completed in 252ms
          19 timing npm:load:configload Completed in 256ms
          20 timing npm:load:mkdirpcache Completed in 22ms
          21 timing npm:load:mkdirplogs Completed in 6ms
          22 verbose title npm la object-assign
          23 verbose argv "la" "object-assign"
          24 timing npm:load:setTitle Completed in 23ms
          25 timing config:load:flatten Completed in 68ms
          26 timing npm:load:display Completed in 111ms
          28 verbose logfile /home/iobroker/.npm/_logs/2022-12-20T07_49_59_077Z-debug-0.lo
          g
          29 timing npm:load:logFile Completed in 123ms
          30 timing npm:load:timers Completed in 1ms
          31 timing npm:load:configScope Completed in 1ms
          32 timing npm:load Completed in 568ms
          33 timing config:load:flatten Completed in 25ms
          34 timing arborist:ctor Completed in 17ms
          35 silly logfile start cleaning logs, removing 3 files
          36 silly logfile done cleaning log files
          , updated: node_modules/iobroker.discovery
          38 timing command:la Completed in 20984ms
          39 verbose stack TypeError: Cannot read properties of undefined (reading 'descri
          ption')
          39 verbose stack     at getHumanOutputItem (/usr/local/lib/node_modules/npm/lib/
          commands/ls.js:339:35)
          39 verbose stack     at visit (/usr/local/lib/node_modules/npm/lib/commands/ls.j
          s:160:15)
          39 verbose stack     at visitNode (/usr/local/lib/node_modules/npm/node_modules/
          treeverse/lib/breadth.js:37:25)
          39 verbose stack     at next (/usr/local/lib/node_modules/npm/node_modules/treev
          erse/lib/breadth.js:23:19)
          39 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/treeverse/l
          ib/breadth.js:25:31
          39 verbose stack     at processTicksAndRejections (node:internal/process/task_qu
          eues:96:5)
          39 verbose stack     at async LL.exec (/usr/local/lib/node_modules/npm/lib/comma
          nds/ls.js:122:20)
          39 verbose stack     at async module.exports (/usr/local/lib/node_modules/npm/li
          b/cli.js:78:5)
          40 verbose cwd /opt/iobroker
          41 verbose Linux 5.15.76+
          42 verbose node v16.19.0
          43 verbose npm  v8.19.3
          44 error Cannot read properties of undefined (reading 'description')
          45 verbose exit 1
          46 timing npm Completed in 24052ms
          47 verbose code 1
          48 error A complete log of this run can be found in:
          48 error     /home/iobroker/.npm/_logs/2022-12-20T07_49_59_077Z-debug-0.log
          armv6l
          Kein Docker
          /usr/local/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v16.19.0
          v16.19.0
          8.19.3
          4.0.23
          iobroker
          iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
          tty
          /etc/apt/sources.list.d
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          nodejs:
            Installed: (none)
            Candidate: 12.22.12~dfsg-1~deb11u1
            Version table:
               12.22.12~dfsg-1~deb11u1 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package
          Bin kurzzeit mal wieder zurück auf ne alte Node Version. Da gehts dann wieder. Noch ne Idee?
          Codierknecht Glasfaser 2 Replies Last reply Reply Quote 0
          • Codierknecht
            Codierknecht Developer Most Active @holgerwolf last edited by
            @holgerwolf sagte in BLE Adapter funktioniert nach Node Update auf v16 nicht mehr:
            Wie alt?
            Das aktuelle Docker-Image wird z.B. mit Node.js 16.18 ausgeliefert.
            Die 16.19 könnte etwas zu neu sein.
            • Glasfaser
              Glasfaser @holgerwolf last edited by
              /usr/local/bin/node
              /usr/local/bin/npm
              Noch ne Idee?
              alles im falschen Verzeichniss installiert .
              siehe im HowTo von Thomas wie man es beseitigt .
              H Thomas Braun 2 Replies Last reply Reply Quote 0
                holgerwolf @Glasfaser last edited by
                @glasfaser Das ist mein Slave System nur für BLE und läuft auf nem Raspi Zero. Sorry, die Info hatte ich vergessen.
                  Thomas Braun Most Active @Glasfaser last edited by
                  @glasfaser
                  Ist der Sonderfall für armv6. Das passt.
                    Ich habs so nicht hinbekommen.
                    Dachte ich installier jetzt erstmal die neuen node.js Versionen und dann den ble Adapter.
                    Jetzt bringt der aber beim Starten den Error "noble.on is not a function". Die zusätzlich benötigten Libraries (bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin) hatte vorab installiert. rebuild habe ich auch ohne Fehler erneut ausgeführt.
                    Zu dem noble.on Fehler finde ich überhaupt nix...
                      TDCroPower last edited by
                      ich häng mich mal hier dran, meine BLE Datenpunkte werden aktuell ebenfalls nicht aktualisiert.
                      Nutze aktuell auch das Docker Image 7.2.0 mit NodeJS v16.18.1
                      root@rpi4-8GB:/opt/iobroker# npm la object-assign
                      npm ERR!     /opt/iobroker/.npm/_logs/2022-12-20T23_31_09_035Z-debug-0.log
                      root@rpi4-8GB:/opt/iobroker# uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      aarch64
                      Docker-Installation
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.18.1
                      v16.18.1
                      8.19.2
                      4.0.24
                      root
                      root
                      /opt/iobroker
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                      1 package can be upgraded. Run 'apt list --upgradable' to see it.
                      nodejs:
                        Installed: 16.18.1-deb-1nodesource1
                        Candidate: 16.19.0-deb-1nodesource1
                        Version table:
                           16.19.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                       *** 16.18.1-deb-1nodesource1 100
                              100 /var/lib/dpkg/status
                              500 http://deb.debian.org/debian-security bullseye-security/main arm64 Packages
                           12.22.5~dfsg-2~11u1 500
                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        Thomas Braun Most Active @TDCroPower last edited by Thomas Braun
                        @tdcropower
                        Und warum Docker auf einem Raspberry 4? Manche Dinge werde ich wohl nie verstehen...
                        Meld dich wenigstens nicht als root an, beim Raspberry gibt es ja eine User-Verwaltung.
                          holgerwolf @holgerwolf last edited by
                          @AlCalzone
                          Hast du noch ne Idee zu dem noble Error? Habe das Gefühl, dass durch die Neuinstallation direkt mit 16.x irgendwas fehlt. Vielleicht installier ich nochmal neu mit ner alten Node Version und dann erst die Updates... Betrifft zum Glück nur den Slave für den Aussensensor.
                            holgerwolf @holgerwolf last edited by holgerwolf
                            Da am wohl Einiges durch das node Update durcheinander. Es gibt eine neue Version vom ble Adapter auf Guthub:
                            https://github.com/AlCalzone/ioBroker.ble
                              Thomas Braun Most Active @holgerwolf last edited by
                              Naja, alte Deps wohl. Muss natürlich auch regelmäßig nachgezogen werden.
                                TDCroPower @Thomas Braun last edited by TDCroPower
                                @thomas-braun ganz einfach, durch Docker bleibt das Raspberry OS soweit fast komplett original und kann ohne Probleme aktualisiert werden ohne das irgendwie was zerschoßen wird.
                                Hatte damals einen OrangePi auf dem Unifi Controller nicht installiert werden konnte, da einige Abhängigkeiten auf Armbian nicht vorhanden sind/waren... welche habe nicht mehr im Kopf, war aber ein Krampf diese zu lösen.
                                Da bin ich damals auf Docker umgestiegen und will es NIE mehr missen.
                                Ich kann meine docker-compose Config auf jeden Host/OS umziehen und es läuft sofort.
                                Gerade bei ioBroker ist es so simpel vor einem Update ein Fullbackup zu erstellen, indem man einfach den Container stoppt, das Container Verzeichnis kopiert und dann seine Spielereien testet... falls was kaputt geht einfach das Verzeichnis wieder zurück rollen und alles ist prima... dauert nur einige Sekunden!
                                Vertrau dem BackItUp Adapter bei sowas nicht mehr zu 100%, hat oft mal nicht alles funktioniert, wenn man ein Backup wieder einspielen wollte (das Yahka Adapter Files Problem zum Beispiel 😉 ).
                                Zum User root, dieser ist nur im Container eingeloggt, ist der default wenn man per Portainer in den Container sich einloggt... aber für dich gerne als iobroker User der im Container eigentlich genutzt wird...
                                iobroker@rpi4-8GB:~$ pwd
                                /opt/iobroker
                                iobroker@rpi4-8GB:~$ ls -l
                                total 672
                                drwxrwxr-x   2 iobroker iobroker   4096 Apr  6  2022 backups
                                -rwxrwxrwx   1 iobroker iobroker    131 Mär 30  2022 INSTALLER_INFO.txt
                                lrwxrwxrwx   1 iobroker iobroker     22 Mär 30  2022 iob -> /opt/iobroker/iobroker
                                -rwxr-xr-x   1 iobroker iobroker    178 Dez 21 01:06 iobroker
                                -rwxr-xr-x   1 iobroker iobroker    178 Dez 20 23:54 iobroker.bak
                                drwxrwxr-x  11 iobroker iobroker   4096 Dez 21 16:04 iobroker-data
                                drwxrwxr-x   2 iobroker iobroker   4096 Dez 21 16:30 log
                                drwxrwxr-x 593 iobroker iobroker  24576 Dez 21 01:12 node_modules
                                -rw-rwxr--   1 iobroker iobroker    987 Dez 21 01:12 package.json
                                -rw-rwxr--   1 iobroker iobroker 633949 Dez 21 01:12 package-lock.json
                                iobroker@rpi4-8GB:~$ npm ls object-assign
                                iobroker.inst@3.0.0 /opt/iobroker
                                ├─┬ iobroker.ble@0.13.1
                                │ └─┬ @abandonware/noble@1.9.2-18
                                │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-9
                                │     └─┬ @mapbox/node-pre-gyp@1.0.10
                                │       └─┬ npmlog@5.0.1
                                │         └─┬ gauge@3.0.2
                                │           └── object-assign@4.1.1 deduped
                                └─┬ iobroker.zigbee@1.8.9
                                  └─┬ zigbee-herdsman@0.14.80
                                    └─┬ mz@2.7.0
                                • SpikeNbg
                                  SpikeNbg last edited by
                                  @tdcropower Dein Post ist zwar schon älter, aber ich hab grad das gleiche Problem und bin durch die Suche drauf gestoßen.. Bei mir werden ebenfalls die Werte (z.B. Temperatur, Luftfeuchtigkeit) vom ble nicht aktualisiert, wobei der rssi Wert z.B. schon aktualisiert wird.
                                  Habe dazu jetzt gesehen, dass es einen Bug gibt: https://github.com/AlCalzone/ioBroker.ble/issues/518
                                  (hier nur zur Info, wenn jemand ebenfalls auf das Problem stößt und sich, wie ich, an den Bug für Updates dran hängen will) 🍻
                                  t1m02k16 created this issue in AlCalzone/ioBroker.ble
                                  open Verbindungs- und aktualisierungs Probleme #518
                                  werner2000x 1 Reply Last reply Reply Quote 0
                                  • werner2000x
                                    werner2000x @SpikeNbg last edited by
                                    @spikenbg Ich habe jetzt auch nach update auf bullseye und Node auf v16 Probleme mit dem BLE Adapter.
                                    Es kommen keine Geräte herein. der "driverstate steht auf "powerOff" und connection auf "fail".
                                    ble_log.txt
                                      Thomas Braun Most Active @werner2000x last edited by Thomas Braun
                                      @werner2000x
                                      setcap durchgeführt? Siehe Readme des Adapters.
                                      rfkill
                                      sagt?
                                      • werner2000x
                                        werner2000x @Thomas Braun last edited by
                                        @thomas-braun ```
                                        rfkill
                                        ID TYPE DEVICE SOFT HARD
                                        0 wlan phy0 blocked unblocked
                                        1 bluetooth hci0 blocked unblocked
                                          @werner2000x
                                          rfkill unblock bluetooth
                                          ggf. mit
                                          sudo rfkill unblock bluetooth
                                          • werner2000x
                                            @thomas-braun sagte in BLE Adapter funktioniert nach Node Update auf v16 nicht mehr:
                                            Ja, Danke. Der Adapter ist jetzt grün und sucht nach Geräten. 😉
                                            742
