    4. Proxmox
    5. Brauche Hilfe bei proxmox v6 zu v7
      saeft_2003 Most Active last edited by
      ich versuche gerade proxmox von v6 auf v7 ohne Neuinstallation anzuheben. Meine source.list und pve-enterprise.list sieht so aus. Ich habe nur buster durch bullseye ersetzt.
      deb http://ftp.debian.org/debian bullseye main contrib
      deb http://ftp.debian.org/debian bullseye-updates main contrib
      # PVE pve-no-subscription repository provided by proxmox.com,
      # NOT recommended for production use
      deb http://download.proxmox.com/debian/pve bullseye pve-no-subscription
      # security updates
      deb http://security.debian.org bullseye-security main contrib
      #non-free
      deb http://deb.debian.org/debian bullseye main contrib non-free
      deb-src http://deb.debian.org/debian bullseye main contrib non-free
      deb http://deb.debian.org/debian-security/ bullseye/updates main contrib non-free
      deb-src http://deb.debian.org/debian-security/ bullseye/updates main contrib non-free
      deb http://deb.debian.org/debian bullseye-updates main contrib non-free
      deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
      deb https://enterprise.proxmox.com/debian/pve bullseye pve-enterprise
      apt update ergibt folgendes:
      Hit:1 http://download.proxmox.com/debian/pve bullseye InRelease
      Hit:2 http://security.debian.org bullseye-security InRelease
      Hit:3 http://ftp.debian.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye InRelease
      Hit:5 http://ftp.debian.org/debian bullseye-updates InRelease
      Ign:6 http://deb.debian.org/debian-security bullseye/updates InRelease
      Hit:7 http://deb.debian.org/debian bullseye-updates InRelease
      Err:8 https://enterprise.proxmox.com/debian/pve bullseye InRelease
        401  Unauthorized [IP: 212.224.123.70 443]
      Err:9 http://deb.debian.org/debian-security bullseye/updates Release
        404  Not Found [IP: 151.101.242.132 80]
      Reading package lists... Done
      E: Failed to fetch https://enterprise.proxmox.com/debian/pve/dists/bullseye/InRelease  401  Unauthorized [IP: 212.224.123.70 443]
      E: The repository 'https://enterprise.proxmox.com/debian/pve bullseye InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      E: The repository 'http://deb.debian.org/debian-security bullseye/updates Release' does not have a Release file.
      Und apt dist-upgrade folgendes:
      84 upgraded, 124 newly installed, 19 to remove and 0 not upgraded.
      Need to get 533 MB of archives.
      After this operation, 756 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Err:1 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libcom-err2 amd64 1.46.5-2~bpo11+2
        Temporary failure resolving 'download.proxmox.com'
      Err:2 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libpve-cluster-api-perl all 7.3-1
      Ign:3 http://ftp.debian.org/debian bullseye/main amd64 base-files amd64 11.1+deb11u6
      Err:4 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libpve-cluster-perl all 7.3-1
      Err:5 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 pve-cluster amd64 7.3-1
      Err:3 http://deb.debian.org/debian bullseye/main amd64 base-files amd64 11.1+deb11u6
        Temporary failure resolving 'debian.map.fastlydns.net' Temporary failure resolving 'ftp.debian.org'
      Ign:6 http://ftp.debian.org/debian bullseye/main amd64 debianutils amd64 4.11.2
      Err:7 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 librados2-perl amd64 1.3-1
      Err:8 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libpve-u2f-server-perl amd64 1.1-2
      Err:6 http://deb.debian.org/debian bullseye/main amd64 debianutils amd64 4.11.2
      Ign:9 http://ftp.debian.org/debian bullseye/main amd64 bash amd64 5.1-2+deb11u1
      Err:10 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libproxmox-rs-perl amd64 0.2.1
      Err:9 http://deb.debian.org/debian bullseye/main amd64 bash amd64 5.1-2+deb11u1
      Ign:11 http://ftp.debian.org/debian bullseye/main amd64 bsdmainutils all 12.1.7+nmu3
      Err:12 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 proxmox-backup-client amd64 2.3.1-1
      Err:13 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libpve-guest-common-perl all 4.2-3
      Err:11 http://deb.debian.org/debian bullseye/main amd64 bsdmainutils all 12.1.7+nmu3
      Err:14 http://download.proxmox.com/debian/pve bullseye/pve-no-subscription amd64 libpve-http-server-perl all 4.1-5
      Ign:15 http://ftp.debian.org/debian bullseye/main amd64 bsdextrautils amd64 2.36.1-8+deb11u1
      Könnt ihr mir helfen und sagen wo mein Fehler liegt?
      • crunchip
        crunchip Forum Testing Most Active @saeft_2003 last edited by crunchip
        @saeft_2003 https://forum.proxmox.com/threads/the-repository-https-enterprise-proxmox-com-debian-pve-bullseye-inrelease-is-not-signed.98927/
        @saeft_2003 sagte in Brauche Hilfe bei proxmox v6 zu v7:
        du hast doch gar keine enterprise, hast du die nicht deaktiviert, bzw gelöscht?
        kannst du über die Gui direkt entfernen
          saeft_2003 Most Active @crunchip last edited by
          @crunchip
          danke ich habe gerade nochmal geschaut in der alten buster pve-enterprise.list da war das mit # auskomentiert.
          Jetzt habe ich aber weiterhin das Problem das mit apt dist-upgrade die Pakete nicht runtergeladen werden können. Der host hat internet.
          • crunchip
            sicher?
              saeft_2003 Most Active @crunchip last edited by saeft_2003
              @crunchip
              wie kann ich das zweifelsfrei festestellen. die cloud adapter in der iobroker vm sind grün und er kann die pakete lesen:
              starting apt-get update
              Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
              TASK OK
              ich hab nur in den network interfaces die mac adresse hinzugefügt, weil die sich sonst angeblich ändern würde beim update.
              auto vmbr0
              iface vmbr0 inet static
              	address 192.168.178.101/24
              	hwaddress 1c:69:7a:a5:4c:d4
              	gateway 192.168.178.1
              	bridge-ports eno1
              	bridge-stp off
              	bridge-fd 0
              crunchip D 3 Replies Last reply Reply Quote 0
              • crunchip
                in der iobroker vm
                ist ja auch ne VM und läuft daher eigenständig
                • crunchip
                  ich hab damals nichts extra eingetragen, hatte soweit ich mich erinnere nur ifupdown2 nachinstalliert
                    @crunchip
                    ich weiß jetzt warum proxmox nicht ins internet kommt!
                    es liegt daran das die unifi vm offline ist. ich konnte gerade ifupdown2 nur installieren wie die unifi vm online war.
                    zum update auf v7 sollen doch alle vms deaktiviert sein!?
                    Du hast doch auch unifi wie hast du das gemacht?
                      darkiop Most Active @saeft_2003 last edited by
                      Grundsätzlich, ein einfacher Ansatz:
                      ping 8.8.8.8
                      ping google.de
                      Bekommst du beim Ersten ping einen reply und keinen beim Zweiten -> deine Namensauflösung funktioniert nicht (evtl. ist deine VM dafür zuständig :))
                      Bekommst du beim Ersten und Zweiten ping einen reply -> alles i.O.
                      Wenn deine Namensauflösung nicht funktioniert, die Ausgabe von den beiden hier mal zeigen
                      nslookup google.de
                      cat /etc/resolv.conf
                      • crunchip
                        Kann mich nicht daran erinnern eine Maschine dafür gestoppt zu haben
                          saeft_2003 Most Active @darkiop last edited by saeft_2003
                          @darkiop
                          Danke für deine Hilfe. Mit laufender unifi VM sieht es so aus.
                          84AB444A-9AF4-4A53-B869-87371FA7D9AD.png F3DD77F3-C624-42F4-9BE3-D1AA669B13D2.png
                          Oder meintest du das ich das machen soll wenn die unifi VM gestoppt ist?!
                          Edit: Mit gestoppter unifi VM ändert sich nichts
                          8ED68186-BDBC-4903-83CD-65BAE4A96E8F.png B629B880-4D29-40AF-85C1-ACB8EF113D75.png
                            @saeft_2003
                            OK, du hast also eine Verbindung nach "draußen" 🙂 Widerspricht aber eigentlich den Ausgaben aus deinem Post ...
                            Teste mal bitte
                            nslookup download.proxmox.com
                            nslookup ftp.debian.org
                            Sollte so ausschauen:
                            Server:         8.8.8.8
                            Address:        8.8.8.8#53
                            Non-authoritative answer:
                            download.proxmox.com    canonical name = download.cdn.proxmox.com.
                            download.cdn.proxmox.com        canonical name = de.eu.cdn.proxmox.com.
                            de.eu.cdn.proxmox.com   canonical name = de.cdn.proxmox.com.
                            Address: 212.224.123.70
                            Address: 2a01:7e0:0:424::249
                            Server:         8.8.8.8
                            Address:        8.8.8.8#53
                            ftp.debian.org  canonical name = debian.map.fastlydns.net.
                            Address: 146.75.118.132
                            Address: 2a04:4e42:8d::644
                              @darkiop
                              nslookup sieht bei mir so aus… da ist die ip vom USG drin und nicht von google. Gut nicht gut?
                              root@pve:~# nslookup download.proxmox.com
                              Server:         192.168.178.1
                              Address:        192.168.178.1#53
                              download.cdn.proxmox.com        canonical name = ch.eu.cdn.proxmox.com.
                              ch.eu.cdn.proxmox.com   canonical name = de.cdn.proxmox.com.
                              root@pve:~# nslookup ftp.debian.org
                              Address: 151.101.242.132
                              Address: 2a04:4e42:39::644
                              root@pve:~#
                                @saeft_2003 Kein Problem, deine USG leitet diese Anfrage an den in der USG eingetragenen DNS weiter.
                                Das sieht aber alles sauber aus. Hast das Upgrade nochmal versucht?
                                  @darkiop
                                  Nein hab mich noch nicht getraut. Will ich eigentlich machen wenn ich etwas Zeit habe falls alles schief geht und ich proxmox neu aufsetzen muss und backups einspielen muss…
                                    ich wollte mein proxmox testsystem anheben auf v7 ab hier ist nichts mehr passiert und proxmox ist nicht mehr erreichbar...
                                    Unpacking python-six (1.16.0-2) over (1.12.0-1) ...
                                    Preparing to unpack .../134-spl_2.1.6-pve1_all.deb ...
                                    Unpacking spl (2.1.6-pve1) over (2.0.7-pve1) ...
                                    Preparing to unpack .../135-strace_5.10-1_amd64.deb ...
                                    Unpacking strace (5.10-1) over (4.26-0.2) ...
                                    Preparing to unpack .../136-tcpdump_4.99.0-2+deb11u1_amd64.deb ...
                                    Unpacking tcpdump (4.99.0-2+deb11u1) over (4.9.3-1~deb10u2) ...
                                    Preparing to unpack .../137-time_1.9-0.1_amd64.deb ...
                                    Unpacking time (1.9-0.1) over (1.7-25.1+b1) ...
                                    Preparing to unpack .../138-unzip_6.0-26+deb11u1_amd64.deb ...
                                    Unpacking unzip (6.0-26+deb11u1) over (6.0-23+deb10u3) ...
                                    Preparing to unpack .../139-usb.ids_2022.05.20-0+deb11u1_all.deb ...
                                    Unpacking usb.ids (2022.05.20-0+deb11u1) over (2019.07.27-0+deb10u1) ...
                                    Preparing to unpack .../140-usbutils_1%3a013-3_amd64.deb ...
                                    Unpacking usbutils (1:013-3) over (1:010-3) ...
                                    Preparing to unpack .../141-zfs-initramfs_2.1.6-pve1_all.deb ...
                                    Unpacking zfs-initramfs (2.1.6-pve1) over (2.0.7-pve1) ...
                                    Preparing to unpack .../142-zfsutils-linux_2.1.6-pve1_amd64.deb ...
                                    Unpacking zfsutils-linux (2.1.6-pve1) over (2.0.7-pve1) ...
                                    Preparing to unpack .../143-zfs-zed_2.1.6-pve1_amd64.deb ...
                                    Unpacking zfs-zed (2.1.6-pve1) over (2.0.7-pve1) ...
                                    Setting up libnetfilter-log1:amd64 (1.0.1-3) ...
                                    Setting up memtest86+ (5.01-3.1) ...
                                    Generating grub configuration file ...
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27015: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27028: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27041: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27054: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27115: /usr/sbin/grub-probe
                                    Found linux image: /boot/vmlinuz-5.15.74-1-pve
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27230: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27244: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27257: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 27270: /usr/sbin/grub-probe
                                    Found linux image: /boot/vmlinuz-5.4.203-1-pve
                                    Found initrd image: /boot/initrd.img-5.4.203-1-pve
                                    Found linux image: /boot/vmlinuz-5.4.114-1-pve
                                    Found initrd image: /boot/initrd.img-5.4.114-1-pve
                                    Found linux image: /boot/vmlinuz-5.4.106-1-pve
                                    Found initrd image: /boot/initrd.img-5.4.106-1-pve
                                    Found linux image: /boot/vmlinuz-5.4.103-1-pve
                                    Found initrd image: /boot/initrd.img-5.4.103-1-pve
                                    Found linux image: /boot/vmlinuz-5.0.21-5-pve
                                    Found initrd image: /boot/initrd.img-5.0.21-5-pve
                                    Found linux image: /boot/vmlinuz-5.0.15-1-pve
                                    Found initrd image: /boot/initrd.img-5.0.15-1-pve
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28147: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28214: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28227: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28240: /usr/sbin/grub-probe
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28253: /usr/sbin/grub-probe
                                    Found memtest86+ image: /boot/memtest86+.bin
                                    Found memtest86+ multiboot image: /boot/memtest86+_multiboot.bin
                                    Warning: os-prober will be executed to detect other bootable partitions.
                                    Its output will be used to detect bootable binaries on them and create new boot entries.
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28585: grub-probe
                                    grub-probe: error: disk `lvmid/d6vUe1-VmEL-SEgR-sIoS-IGLg-l441-4JTJ9F/UxkIqX-7fZT-iWgh-YcIu-0Qfh-Rnfd-GXLmxI' not found.
                                    File descriptor 3 (pipe:[102825]) leaked on vgs invocation. Parent PID 28831: /usr/sbin/grub-probe
                                    /usr/sbin/grub-probe: error: disk `lvmid/d6vUe1-VmEL-SEgR-sIoS-IGLg-l441-4JTJ9F/UxkIqX-7fZT-iWgh-YcIu-0Qfh-Rnfd-GXLmxI' not found.
                                    Found Ubuntu 21.04 (21.04) on /dev/mapper/pve-vm--1500--disk--0
                                    Adding boot menu entry for UEFI Firmware Settings ...
                                    done
                                    crunchip Feuersturm 2 Replies Last reply Reply Quote 0
                                    • crunchip
                                      eventuell hilft https://forum.proxmox.com/threads/upgrade-pve-6-x-to-7-x-grub-issues.92118/page-2#post-456434
                                      bzw
                                      https://forum.proxmox.com/threads/usr-sbin-grub-probe-error-disk-lvmid-not-found.106390/
                                        @crunchip
                                        Danke, da ich dem englischen nicht sooo mächtig bin fällt es mir schwer da zu folgen.
                                        Ich installiere jetzt auf dem Testsystem neu und schaue weiter…
                                        D crunchip 2 Replies Last reply Reply Quote 0
                                          @saeft_2003
                                          Du solltest dir auch mal überlegen ob die nicht die Gelegenheit nutzt und einfach Proxmox neu aufsetzt und dann deine Backups einspielst. Das ist in kurzer Zeit erledigt und danach hast auch wieder ein frisches System.
                                          Bevor das aber machst, zeig uns mal noch wie du deine Backups aktuell machst, damit hier auch nichts schief geht 🙂
                                          Lokale Backups liegen unter:
                                          /var/lib/vz/dump
                                          PS: Ich schaue wahrscheinlich erst heute Abend wieder hier rein.
                                          • crunchip
                                            @saeft_2003 du musst dies ausführen
                                            laut Beschreibung um den Fehler zu beheben, dein logisches Laufwerk um z.b 2G erweitern, danach Update Grub erneut ausführen
                                            81.0k
                                            9469
