    4. Admin GUI crashes JS Controller
      hioniq42 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: VM on Synology
      Arbeitsspeicher: 8GB
      Festplattenart: HDD
      Betriebssystem: Ubuntu
      Node-Version: 16.18.1
      Nodejs-Version: 16.18.1
      NPM-Version: 8.19.2
      Installationsart: Skript
      Image genutzt: Nein
      Dear Community,
      I recently updated my system to the latest versions of node, nodeJS, JS-Controller, NPM etc. Since then, whenever I start the admin interface in any browser, it crashes the JS controller. The core system comes up again and everything else works fine (Scripts, IOT Integration, VIS, ...). I tried downgrades of the admin adapter, but it didn't help. I also searched the forum and GitHub but could not find anything similiar. Maybe someone out here has an idea.
      Thank you!
      Florian
        Thomas Braun Most Active @hioniq42 last edited by
        @hioniq42
        iobroker stop
        iobroker fix
        iobroker start
        Then please post the output of
        iobroker diag
          hioniq42 @Thomas Braun last edited by
          Thank you for the quick response. I did the stop/fix/start several times before with no luck. This is the output from the diganose command (with stop/fix/start executed right before). Problem is still the same.
                                  v.2022-12-13
          Operatingsystem:        Ubuntu 22.04.1 LTS
          Installation:           microsoft
          Timezone:               Europe/Berlin
          User-ID:                1000
          X-Server:               true
          Pending OS-Updates:     0
          Nodejs-Installation:    /usr/bin/nodejs         v16.18.1
                                  /usr/bin/node           v16.18.1
                                  /usr/bin/npm            8.19.2
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.2.23
          Objects type: jsonl
          States  type: jsonl
          Pending iob updates:    1
          Active repo(s): stable
          Objects:                78677
          States:                 73856
          Size of iob-Database:
          48M     /opt/iobroker/iobroker-data/objects.jsonl
          17M     /opt/iobroker/iobroker-data/states.jsonl
          I also had a look into the log messages right after calling the admin UI but for me there is no meaningful information except the fact that everything falls into pieces:
          2022-12-19 21:34:45.885  - info: unifi.0 (387391) cleaned everything up...
          2022-12-19 21:34:45.899  - info: fullybrowser.0 (388048) cleaned everything up...
          2022-12-19 21:34:45.911  - info: javascript.0 (384789) Stop script script.js.Aktienkurse
          2022-12-19 21:34:45.882  - error: sonnen.0 (386920) States database error: read ECONNRESET
          2022-12-19 21:34:45.894  - info: admin.1 (384406) terminating http server on port 8080
          2022-12-19 21:34:45.901  - info: simple-api.0 (388366) terminating http server on port 8087
          2022-12-19 21:34:45.931  - info: info.0 (387970) cleaned everything up...
          2022-12-19 21:34:45.923  - info: hm-rpc.2 (386075) binrpc -> 192.168.x.x:8701/ init ["xmlrpc_bin://192.168.x.x:12001",""]
          2022-12-19 21:34:45.900  - info: hm-rpc.3 (386737) binrpc -> 192.168.x.x:2001/ init ["xmlrpc_bin://192.168.x.x:12002",""]
          2022-12-19 21:34:45.903  - error: admin.2 (384556) States database error: read ECONNRESET
          2022-12-19 21:34:45.943  - error: backitup.0 (388528) States database error: read ECONNRESET
          I was wondering if there is a way to change the debug level of an instance through CLI?
          thank you so far
          Florian
            Homoran Global Moderator Administrators @hioniq42 last edited by
            @hioniq42 warum jetzt hier auf englisch?
              hioniq42 @Homoran last edited by
              Entschuldigung, das war reine Gewohnheit. Weiter auf deutsch 🙂
              @Thomas-Braun
              Mir ist im System-Log (/var/logs/syslog) noch folgendes aufgefallen:
              21:34:45 iobroker systemd[1]: iobroker.service: Main process exited, code=dumped, status=11/SEGV
                hioniq42 @hioniq42 last edited by
                So, ein paar neue Erkenntnisse, nachdem ich mich durch die Coredumps gearbeitet habe, wo folgendes zu finden ist:
                ProblemType: Crash
                Architecture: amd64
                Date: Tue Dec 20 11:07:29 2022
                DistroRelease: Ubuntu 22.04
                ExecutablePath: /usr/bin/node
                ExecutableTimestamp: 1667561607
                ProcCmdline: iobroker.js-controller
                ProcEnviron: Error: [Errno 13] Permission denied: 'environ'
                ProcMaps: Error: [Errno 13] Permission denied: 'maps'
                ProcStatus:
                Dass hier zwei Berechtigungsprobleme (Zeile 8&9) bestehen, überrascht mich. Müsste das nicht genau mit iobroker fix behoben werden?
                  @hioniq42 sagte in Admin GUI crashes JS Controller:
                  überrascht mich.
                  Mich nicht, wenn da mit sudo und/oder vollem root-Account herumgefuhrwerkt wurde.
                    Dafür habe ich einen Standard-User "iobroker" und sudo nur bei absoluter Notwendigkeit. Und ist doch auch etwas seltsam, dass dann nur bei der Admin GUI Probleme auftreten, sonst aber alles sauber läuft.
                      der Systemuser heisst bereits iobroker
