    2. English
    3. Visualization
    4. Not able to start VIS after recent power loss. SOLVED
      ap2017 last edited by ap2017
      Not able to start VIS after recent power loss, getting the following messages
      URIError: Failed to decode param '%web_protocol%://192.168.1.74:%web_port%/vis/edit.html'
          at decodeURIComponent (<anonymous>)
          at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
          at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
          at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
          at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
          at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
          at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
          at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
          at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
          at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
        Homoran Global Moderator Administrators @ap2017 last edited by
        @ap2017 Maybe that the filesystem is corrupted and nothing will work anymore.
        But we won't think of the worst case for now.
        please post iobroker list instances
        A 2 Replies Last reply Reply Quote 1
          ap2017 @Homoran last edited by
          @homoran said in Not able to start VIS after recent power loss:
          Here we go:
          ap@AP-Tiny:~$ iobroker list instances
          + system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  -  enabled
          + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : AP-Tiny                                  -  enabled
            system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
            system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
          + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
            system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
            system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
          + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
          + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
          + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
            system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as: admin
            system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
            system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
            system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
            system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
            system.adapter.web.0                    : web                   : AP-Tiny                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
          + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
          + instance is alive
          ap@AP-Tiny:~$
            @homoran Actually, you got me thinking. Web.o was off. When I turned it on VIS started to work! Thanks
              @ap2017 sagte in Not able to start VIS after recent power loss. SOLVED:
              Web.o was off
              that was what I wanted to see. But
              you got me thinking
              is the better way!
              vis
