    4. Twinkly Adapter bleibt gelb
      base last edited by Homoran
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Diskstation
      Arbeitsspeicher: 11 GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 14.18.3
      Nodejs-Version: 14.18.3
      NPM-Version: 6.14.15
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      ich bekommen meinen Twinkly Adapter nicht mehr zum laufen. Hab ihn schon deinstalliert und gedowngradet, den Twinkly zurückgsetzt, IP geändert, alles ohne Erfolg...
      twinkly.0
      2022-12-25 13:54:57.340	info	Startup complete
      twinkly.0
      2022-12-25 13:54:57.340	debug	[poll] Finished polling...
      twinkly.0
      2022-12-25 13:54:57.339	debug	[poll] Twinkly not connected!
      twinkly.0
      2022-12-25 13:54:57.338	debug	[checkConnection] Twinkly is not available!
      twinkly.0
      2022-12-25 13:54:57.283	debug	[poll] Start polling...
      twinkly.0
      2022-12-25 13:54:57.281	debug	[processObjectChanges] No tasks to process!
      twinkly.0
      2022-12-25 13:54:57.280	debug	[processObjectChanges] Prepare tasks of objects update
      twinkly.0
      2022-12-25 13:54:57.278	debug	[processObjectChanges] Add instance objects
      twinkly.0
      2022-12-25 13:54:57.277	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
      twinkly.0
      2022-12-25 13:54:57.115	debug	[processObjectChanges] Get existing objects
      twinkly.0
      2022-12-25 13:54:57.050	debug	[syncConfig] config network: false
      twinkly.0
      2022-12-25 13:54:57.049	debug	[syncConfig] config mqtt: true
      twinkly.0
      2022-12-25 13:54:57.049	debug	[syncConfig] config details: true
      twinkly.0
      2022-12-25 13:54:57.048	debug	[syncConfig] config interval: 60
      twinkly.0
      2022-12-25 13:54:57.047	debug	[syncConfig] config devices: [{"enabled":true,"name":"Twinkly","host":"192.168.1.125","stateOn":"color"}]
      twinkly.0
      2022-12-25 13:54:57.018	info	starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.twinkly, node: v14.18.3, js-controller: 4.0.23
      twinkly.0
      2022-12-25 13:54:56.579	debug	Plugin sentry Initialize Plugin (enabled=true)
      twinkly.0
      2022-12-25 13:54:56.291	debug	States connected to redis: 127.0.0.1:9000
      twinkly.0
      2022-12-25 13:54:56.194	debug	States create User PubSub Client
      twinkly.0
      2022-12-25 13:54:56.193	debug	States create System PubSub Client
      twinkly.0
      2022-12-25 13:54:56.153	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      twinkly.0
      2022-12-25 13:54:56.096	debug	Objects connected to redis: 127.0.0.1:9001
      twinkly.0
      2022-12-25 13:54:56.090	debug	Objects client initialize lua scripts
      twinkly.0
      2022-12-25 13:54:55.964	debug	Objects create User PubSub Client
      twinkly.0
      2022-12-25 13:54:55.962	debug	Objects create System PubSub Client
      twinkly.0
      2022-12-25 13:54:55.960	debug	Objects client ready ... initialize now
      twinkly.0
      2022-12-25 13:54:55.901	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      M Homoran 2 Replies Last reply Reply Quote 0
        MCU @base last edited by
        @base sagte in Twinkly Adapter bleibt gelb:
        14.18.3
        Empfohlene node-Version ist die v16.
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          base last edited by
          bin jetzt auf v16. Adapter bleibt weiterhin gelb...
            MCU @base last edited by MCU
            @base Wie sind denn die Einstellungen im twinkly-Adapter?
            Per App ist die Lichterkette steuerbar?
            Sind beide Geräte im gleichen Netzwerk? WLAN 2.4 GHz!
            Twinkly App -> Geräte -> Einstellungen -> Netzwerk?
              Homoran Global Moderator Administrators @base last edited by
              Hardwaresystem:
              Diskstation
              in Verbindung mit
              Betriebssystem:
              Ubuntu/Windows/Mac
              gibt mehr Fragen als Antworten.
              was sagt iob diag?
                base @Homoran last edited by
                muss das Thema jetzt vor Weihnachten nochmal aufgreifen. Nachdem ich das System vor kurzem neu aufgesetzt habe besteht der Fehler leider weiterhin. Via App habe ich über das Netzwerk Zugriff. Auch kann ich den Controller anpingen.
                iob diag:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                Hardware Vendor : Synology
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v9.0.1
                Virtualization  : Docker
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 15:46:13 up 19 days, 19:25,  0 user,  load average: 2.78, 3.00, 2.72
                CPU threads: 4
                *** Time and Time Zones ***
                Thu Dec  7 14:46:13 UTC 2023
                Thu Dec  7 15:46:13 CET 2023
                CET +0100
                Etc/UTC
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:             12G        8.4G        993M        105M        3.4G        4.0G
                Swap:           9.6G        4.6G        5.0G
                Total:           21G         12G        6.0G
                        11822 M total memory
                         8002 M used memory
                         3724 M active memory
                         4442 M inactive memory
                          947 M free memory
                          311 M buffer memory
                         2973 M swap cache
                         9143 M total swap
                         4372 M used swap
                         4771 M free swap
                *** FILESYSTEM ***
                Filesystem             Type   Size  Used Avail Use% Mounted on
                none                   aufs   2.7T  1.9T  826G  70% /
                tmpfs                  tmpfs   64M     0   64M   0% /dev
                tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
                shm                    tmpfs   64M     0   64M   0% /dev/shm
                /dev/mapper/cachedev_1 ext4   2.7T  1.9T  826G  70% /opt/iobroker
                tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
                tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
                tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
                TARGET             SOURCE  FSTYPE OPTIONS
                /                  none  aufs   rw,relatime,si=d721e7829fc3c919,dio,dirperm1
                |-/opt/iobroker    /dev/mapper/cachedev_1[/docker/iobrokerv5_data]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
                |-/etc/resolv.conf /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
                |-/etc/hostname    /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/hostname]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
                `-/etc/hosts       /dev/mapper/cachedev_1[/@docker/containers/62306c2389bc6acd8ca0695df501e6acea1b88c2621a9f13832fa54f04e9f120/hosts]  ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
                /var:
                34M     /var/
                32M     /var/lib
                19M     /var/lib/apt/lists
                19M     /var/lib/apt
                13M     /var/lib/dpkg/info
                /opt/iobroker/backups:
                81M     /opt/iobroker/backups/
                4.0K    /opt/iobroker/backups/influxDB_2020_12_12-02_00_26_backupiobroker
                4.0K    /opt/iobroker/backups/influxDB_2020_12_11-02_00_27_backupiobroker
                4.0K    /opt/iobroker/backups/influxDB_2020_12_10-02_00_25_backupiobroker
                4.0K    /opt/iobroker/backups/influxDB_2020_12_09-02_00_27_backupiobroker
                /opt/iobroker/iobroker-data:
                771M    /opt/iobroker/iobroker-data/
                604M    /opt/iobroker/iobroker-data/files
                115M    /opt/iobroker/iobroker-data/backup-objects
                90M     /opt/iobroker/iobroker-data/files/echarts.admin
                78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                34M     /opt/iobroker/iobroker-data/objects.jsonl
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.18.2
                /usr/bin/node           v18.18.2
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                /usr/bin/corepack       0.19.0
                nodejs:
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                     18.19.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                 *** 18.18.2-1nodesource1 500
                        100 /var/lib/dpkg/status
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0+dfsg1-1 500
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                No problems detected
                Errors in npm tree:
                npm ERR! code ELSPROBLEMS
                npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@7.1.6
                npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-12-07T14_46_20_632Z-debug-0.log
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.16
                admin:          6.12.0
                javascript:     7.1.6
                Adapters from github:   6
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker_v5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : iobroker_v5                              -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : iobroker_v5                              - disabled
                + system.adapter.backitup.0               : backitup              : iobroker_v5                              -  enabled
                  system.adapter.ble.0                    : ble                   : iobroker_v5                              - disabled
                + system.adapter.bring.0                  : bring                 : iobroker_v5                              -  enabled
                + system.adapter.countdown.0              : countdown             : iobroker_v5                              -  enabled
                  system.adapter.daswetter.0              : daswetter             : iobroker_v5                              -  enabled
                + system.adapter.denon.0                  : denon                 : iobroker_v5                              -  enabled
                  system.adapter.devices.0                : devices               : iobroker_v5                              - disabled
                + system.adapter.discovery.0              : discovery             : iobroker_v5                              -  enabled
                  system.adapter.dwd.0                    : dwd                   : iobroker_v5                              -  enabled
                + system.adapter.echarts.0                : echarts               : iobroker_v5                              -  enabled
                + system.adapter.enigma2.0                : enigma2               : iobroker_v5                              -  enabled
                  system.adapter.flot.0                   : flot                  : iobroker_v5                              - disabled
                + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker_v5                              -  enabled
                  system.adapter.fullybrowser.0           : fullybrowser          : iobroker_v5                              - disabled
                + system.adapter.harmony.0                : harmony               : iobroker_v5                              -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker_v5                              -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker_v5                              -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker_v5                              -  enabled, port: 0
                  system.adapter.ical.0                   : ical                  : iobroker_v5                              -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker_v5                              -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : iobroker_v5                              - disabled
                  system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker_v5                              - disabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker_v5                              - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker_v5                              - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker_v5                              -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker_v5                              -  enabled, port: 8086
                + system.adapter.influxdb.1               : influxdb              : iobroker_v5                              -  enabled, port: 8087
                + system.adapter.info.0                   : info                  : iobroker_v5                              -  enabled
                + system.adapter.iot.0                    : iot                   : iobroker_v5                              -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker_v5                              -  enabled
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker_v5                              -  enabled, port: 54321
                + system.adapter.mihome.0                 : mihome                : iobroker_v5                              -  enabled, port: 9898, bind: 192.168.1.120
                + system.adapter.mytime.0                 : mytime                : iobroker_v5                              -  enabled
                + system.adapter.mytime.1                 : mytime                : iobroker_v5                              -  enabled
                + system.adapter.ping.0                   : ping                  : iobroker_v5                              -  enabled
                + system.adapter.pollenflug.0             : pollenflug            : iobroker_v5                              -  enabled
                + system.adapter.pvforecast.0             : pvforecast            : iobroker_v5                              -  enabled
                  system.adapter.pvforecast.1             : pvforecast            : iobroker_v5                              - disabled
                  system.adapter.rtspStream.0             : rtspStream            : iobroker_v5                              - disabled, port: 554
                + system.adapter.sayit.3                  : sayit                 : iobroker_v5                              -  enabled
                + system.adapter.senec.0                  : senec                 : iobroker_v5                              -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker_v5                              -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker_v5                              -  enabled
                + system.adapter.simple-api.0             : simple-api            : iobroker_v5                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.snmp.0                   : snmp                  : iobroker_v5                              -  enabled
                + system.adapter.sonoff.0                 : sonoff                : iobroker_v5                              -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker_v5                              -  enabled
                  system.adapter.sql.0                    : sql                   : iobroker_v5                              - disabled, port: 0
                + system.adapter.statistics.0             : statistics            : iobroker_v5                              -  enabled
                + system.adapter.synology.0               : synology              : iobroker_v5                              -  enabled, port: 5001
                + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker_v5                              -  enabled
                + system.adapter.telegram.0               : telegram              : iobroker_v5                              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.terminal.0               : terminal              : iobroker_v5                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                + system.adapter.text2command.0           : text2command          : iobroker_v5                              -  enabled
                + system.adapter.tr-064.0                 : tr-064                : iobroker_v5                              -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : iobroker_v5                              -  enabled
                + system.adapter.twinkly.0                : twinkly               : iobroker_v5                              -  enabled
                + system.adapter.upnp.0                   : upnp                  : iobroker_v5                              -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : iobroker_v5                              - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker_v5                              - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker_v5                              - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker_v5                              - disabled
                  system.adapter.vis-history.0            : vis-history           : iobroker_v5                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker_v5                              - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker_v5                              -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker_v5                              - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker_v5                              - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker_v5                              -  enabled
                  system.adapter.vis-metro.0              : vis-metro             : iobroker_v5                              - disabled
                  system.adapter.vis-players.0            : vis-players           : iobroker_v5                              - disabled
                  system.adapter.vis-plumb.0              : vis-plumb             : iobroker_v5                              - disabled
                  system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker_v5                              - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker_v5                              - disabled
                  system.adapter.vis-weather.0            : vis-weather           : iobroker_v5                              - disabled
                  system.adapter.vis.0                    : vis                   : iobroker_v5                              -  enabled
                + system.adapter.web.0                    : web                   : iobroker_v5                              -  enabled, port: 8082, bind: 192.168.1.120, run as: admin
                + system.adapter.worx.0                   : worx                  : iobroker_v5                              -  enabled
                + system.adapter.ws.0                     : ws                    : iobroker_v5                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                Adapter    "ble"          : 0.13.4   , installed 0.13.4
                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "denon"        : 1.15.4   , installed 1.15.4
                Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
                Adapter    "harmony"      : 1.3.0    , installed 1.3.0
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.16   , installed 5.0.16
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                Adapter    "synology"     : 3.0.1    , installed 3.0.1
                Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                Adapter    "text2command" : 3.0.2    , installed 3.0.2
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-icontwo"  : 0.98.0   , installed 0.97.1 [Updatable]
                Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "worx"         : 2.3.4    , installed 2.3.4
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Objects and States
                Objects:        22170
                States:         19042
                Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                Reading package lists...
                Pending Updates: 5
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       183619990  -
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       183627488  -
                tcp        0      0 127.0.0.11:36422        0.0.0.0:*               LISTEN      0          183606762  -
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       183612197  -
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       183612171  -
                tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       183620056  -
                tcp        0      0 192.168.1.120:8082      0.0.0.0:*               LISTEN      1000       184474196  -
                tcp6       0      0 :::8087                 :::*                    LISTEN      1000       183643690  -
                tcp6       0      0 :::8088                 :::*                    LISTEN      1000       183649454  -
                tcp6       0      0 :::61991                :::*                    LISTEN      1000       183637426  -
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       183901599  -
                tcp6       0      0 :::8084                 :::*                    LISTEN      1000       184473591  -
                udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1000       308708822  -
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       183654037  -
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       183654036  -
                udp        0      0 127.0.0.11:45171        0.0.0.0:*                           0          183606761  -
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       318795020  -
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       183637427  -
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       183624888  -
                udp        0      0 0.0.0.0:38624           0.0.0.0:*                           1000       183646509  -
                udp        0      0 0.0.0.0:40335           0.0.0.0:*                           1000       183646510  -
                2023-12-07 15:38:17.656  - info: host.iobroker_v5 stopInstance system.adapter.twinkly.0 send kill signal
                2023-12-07 15:38:17.902  - info: twinkly.0 (24461) terminating
                2023-12-07 15:38:17.904  - info: twinkly.0 (24461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-12-07 15:38:18.606  - info: host.iobroker_v5 instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-07 15:38:20.902  - info: host.iobroker_v5 instance system.adapter.twinkly.0 started with pid 19716
                2023-12-07 15:38:23.638  - info: twinkly.0 (19716) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.18.2, js-controller: 5.0.16
                2023-12-07 15:38:24.129  - info: twinkly.0 (19716) Startup complete
                2023-12-07 15:40:00.108  - info: host.iobroker_v5 instance system.adapter.dwd.0 started with pid 19918
                2023-12-07 15:40:06.229  - info: host.iobroker_v5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-07 15:42:22.991  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] connection closed: closed
                2023-12-07 15:42:35.315  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] connected with secret 1701960155314_670
                2023-12-07 15:43:39.038  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] reconnected. Old secret 1701960155314_670. New secret1701960219038_8074
                2023-12-07 15:44:42.756  - info: sonoff.0 (522) Client [SonoffS20LogitechBTAdapter] reconnected. Old secret 1701960219038_8074. New secret 1701960281472_8737
                2023-12-07 15:45:00.148  - info: host.iobroker_v5 instance system.adapter.dwd.0 started with pid 21081
                2023-12-07 15:45:04.245  - info: host.iobroker_v5 instance system.adapter.daswetter.0 started with pid 21108
                2023-12-07 15:45:06.229  - info: host.iobroker_v5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-07 15:45:15.916  - info: host.iobroker_v5 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-07 15:45:48.461  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends publish. Ignore! Actual secret is 1701960281472_8737
                2023-12-07 15:45:48.462  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends publish. Ignore! Actual secret is 1701960281472_8737
                2023-12-07 15:45:48.462  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends subscribe. Ignore! Actual secret is 1701960281472_8737
                2023-12-07 15:45:48.463  - warn: sonoff.0 (522) Old client SonoffS20LogitechBTAdapter with secret 1701960219038_8074 sends pingreq. Ignore! Actual secret is 1701960281472_8737
                ======================= SUMMARY =======================                        v.2023-10-10
                model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHzKernel          : x86_64
                Userland        : amd64Docker          : v9.0.1
                Installation:           Docker
                Kernel:                 x86_64Userland:               amd64
                Timezone:               Etc/UTCUser-ID:                0
                X-Server:               false
                Pending OS-Updates:     5
                Pending iob updates:    1
                Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                        /usr/bin/npm            9.8.1
                                        /usr/bin/npx            9.8.1
                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                MEMORY:
                Mem:             12G        8.4G        862M        105M        3.6G        4.0G
                Total:           21G         12G        5.9G
                Active iob-Instances:   49
                ioBroker Core:          js-controller           5.0.16
                Objects type: jsonl
                States  type: jsonl
                Objects:                22170
                States:                 19042
                Size of iob-Database:
                22M     /opt/iobroker/iobroker-data/states.jsonl
                  da habe ich keinerlei Aktien drin. ist mir zu kompliziert
                  • wollerosekaufe
                    wollerosekaufe last edited by
                    hab mir den adapter spaßhalber einmal angesehen.
                    wenn ich den starte, einfach mal mit 127.0.0.1 als MQTT, sieht der debug log bei mir völlig anders aus:
                    twinkly.0
                    	2023-12-08 17:57:48.747	error	[test.interview.fw] Error: connect ECONNREFUSED 127.0.0.1:80
                    twinkly.0
                    	2023-12-08 17:57:48.744	debug	[test.request.GET] Error: "connect ECONNREFUSED 127.0.0.1:80", code="ECONNREFUSED", status=null, config="{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/json","X-Auth-Token":"","User-Agent":"axios/1.6.2","Content-Length":"4","Accept-Encoding":"gzip, compress, deflate, br"},"baseURL":"http://127.0.0.1/xled/v1/","url":"fw/version","method":"get","data":"null"}", stack="Error: connect ECONNREFUSED 127.0.0.1:80 at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:606:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at Socket.socketErrorListener (node:_http_client:501:9) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12)"
                    twinkly.0
                    	2023-12-08 17:57:48.140	debug	[test.request.GET] path="fw/version", body="null", headers="{}"
                    twinkly.0
                    	2023-12-08 17:57:48.090	debug	[test.ping] Ping result for 127.0.0.1: true in 0.130ms
                    twinkly.0
                    	2023-12-08 17:57:48.033	debug	[ping.probe] System command: /bin/ping -n -w 2 -c 1 127.0.0.1
                    twinkly.0
                    	2023-12-08 17:57:48.028	debug	[poll] Start polling...
                    twinkly.0
                    	2023-12-08 17:57:48.024	debug	[processObjectChanges] No tasks to process!
                    twinkly.0
                    	2023-12-08 17:57:48.021	debug	[processObjectChanges] Prepare tasks of objects update
                    twinkly.0
                    	2023-12-08 17:57:48.018	debug	[processObjectChanges] Add instance objects
                    twinkly.0
                    	2023-12-08 17:57:48.016	debug	[processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
                    twinkly.0
                    	2023-12-08 17:57:47.852	debug	[processObjectChanges] Get existing objects
                    twinkly.0
                    	2023-12-08 17:57:47.783	debug	[syncConfig] config network: false
                    twinkly.0
                    	2023-12-08 17:57:47.782	debug	[syncConfig] config mqtt: false
                    twinkly.0
                    	2023-12-08 17:57:47.781	debug	[syncConfig] config details: false
                    twinkly.0
                    	2023-12-08 17:57:47.780	debug	[syncConfig] config interval: 60
                    twinkly.0
                    	2023-12-08 17:57:47.777	debug	[syncConfig] config devices: [{"enabled":true,"name":"test","host":"127.0.0.1","stateOn":"color"}]
                    twinkly.0
                    	2023-12-08 17:57:47.728	info	starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v18.19.0, js-controller: 5.0.17
                    bei dir besteht der halbe log aus redis/objects, vom networking kommt wenig bis nix. wundert mich etwas...
                    wie sieht das bei dir denn aus wenn du mal eine zweite instanz aufmachst und dasselbe probierst?
                    "das mit docker" mag zwar vlt. nicht SO kompliziert sein, aber wie @homoran schon andeutet 😄 ohne exakte infos (networking) geht da nichts voran.
                    würde ins blaue hineinraten dass du in docker kein (host-)network definiert hast - oder der port f. twinkly fehlt (scheint über 80 zu gehen?! O_o)
                      base last edited by
                      @wollerosekaufe
                      vielen Dank, ich habe keine Ahnung was da im Docker definiert ist. Hab mich bei der Insatallation an die Anleitung von smarthome.buanet.de gehalten. Sonst funktioniert ja alles und der Adapter hat ja auch mal funktioniert. Hab jetzt das Script von @patrickbs96 https://github.com/patrickbs96/script.twinkly ausprobiert, damit kann ich die Lichterkette erstmal steuern.
                      patrickbs96 1 Reply Last reply Reply Quote 0
                      • patrickbs96
                        patrickbs96 Developer @base last edited by
                        @base komisch das der Adapter bei dir nicht mehr funktioniert aber stattdessen das Skript. Ich hatte damals den Adapter anhand des Skripts erstellt.
                        Die Datenpunkte für eine Lichterkette werden erst erstellt, wenn eine Verbindung zu der Kette aufgebaut werden konnte. Entferne sonst mal den Haken bei "Ping für Erreichbarkeit verwenden", vielleicht klappt das ja
                          base @patrickbs96 last edited by
                          @patrickbs96 geht leider auch nicht. Hab den Adapter nochmal deinstalliert und den Ping rausgenommen - ohne Erfolg. Es werden keine Datenpunkte angelegt.
                          Bei den Datenpunkten vom Script funktionieren alle ausser der "connected" State.
                            der-eine last edited by
                            Hallo zusammen, Hallo @patrickbs96,
                            wollte jetzt auch den Twinkly-Adapter installieren leider bleibt er bei mir auch gelb.
                            Meine Fehlermeldung ist aber eine andere und komme hier leider auch nicht weiter.
                            Hab auch ein Github Issue eröffnet.
                            Wäre super, wenn mir jemand dabei helfen könnte.
                            Danke.
                            Versions:
                            iobroker-Admin: 6.12.0
                            Adapter version: 1.0.14
                            JS-Controller version: 5.0.16
                            Node version: 16.17.0
                            Operating system: Debian 11 bullseye
                            Twinkly Version: 2.8.18
                            2023-12-14 12:11:51.101 - info: host.ioBroker "system.adapter.twinkly.0" enabled
                            2023-12-14 12:11:51.400 - info: host.ioBroker instance system.adapter.twinkly.0 started with pid 1474
                            2023-12-14 12:11:52.152 - debug: twinkly.0 (1474) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2023-12-14 12:11:52.212 - debug: twinkly.0 (1474) Objects client ready ... initialize now
                            2023-12-14 12:11:52.213 - debug: twinkly.0 (1474) Objects create System PubSub Client
                            2023-12-14 12:11:52.214 - debug: twinkly.0 (1474) Objects create User PubSub Client
                            2023-12-14 12:11:52.366 - debug: twinkly.0 (1474) Objects client initialize lua scripts
                            2023-12-14 12:11:52.370 - debug: twinkly.0 (1474) Objects connected to redis: 127.0.0.1:9001
                            2023-12-14 12:11:52.450 - debug: twinkly.0 (1474) Redis States: Use Redis connection: 127.0.0.1:9000
                            2023-12-14 12:11:52.483 - debug: twinkly.0 (1474) States create System PubSub Client
                            2023-12-14 12:11:52.484 - debug: twinkly.0 (1474) States create User PubSub Client
                            2023-12-14 12:11:52.546 - debug: twinkly.0 (1474) States connected to redis: 127.0.0.1:9000
                            2023-12-14 12:11:52.600 - debug: twinkly.0 (1474) Plugin sentry Initialize Plugin (enabled=true)
                            2023-12-14 12:11:52.831 - info: twinkly.0 (1474) starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v16.17.0, js-controller: 5.0.16
                            2023-12-14 12:11:52.860 - debug: twinkly.0 (1474) [syncConfig] config devices: [{"enabled":true,"name":"Girlande","host":"192.168.20.100","stateOn":"color"}]
                            2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config interval: 60
                            2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config details: true
                            2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config mqtt: false
                            2023-12-14 12:11:52.861 - debug: twinkly.0 (1474) [syncConfig] config network: true
                            2023-12-14 12:11:52.890 - debug: twinkly.0 (1474) [processObjectChanges] Get existing objects
                            2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Remove all connections listed in config ==> Deletes all old connections
                            2023-12-14 12:11:53.167 - debug: twinkly.0 (1474) [processObjectChanges] Add instance objects
                            2023-12-14 12:11:53.168 - debug: twinkly.0 (1474) [processObjectChanges] Prepare tasks of objects update
                            2023-12-14 12:11:53.169 - debug: twinkly.0 (1474) [processObjectChanges] No tasks to process!
                            2023-12-14 12:11:53.170 - debug: twinkly.0 (1474) [poll] Start polling...
                            2023-12-14 12:11:53.171 - debug: twinkly.0 (1474) [ping.probe] System command: /bin/ping -n -w 2 -c 1 192.168.20.100
                            2023-12-14 12:11:53.183 - error: twinkly.0 (1474) [Girlande.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
                            2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [checkConnection] Girlande is not available!
                            2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Girlande not connected!
                            2023-12-14 12:11:53.228 - debug: twinkly.0 (1474) [poll] Finished polling...
                            2023-12-14 12:11:53.229 - info: twinkly.0 (1474) Startup complete
                              Thomas Braun Most Active @der-eine last edited by
                              @der-eine
                              node: v16.17.0
                              Veraltet, abgekündigt.
                              Bring das auf nodejs@18.
                              Per
                              iob nodejs-update
                                @der-eine
                                type -p ping
                                sudo -u iobroker ping iobroker.net
                                sagt?
                                  der-eine @Thomas Braun last edited by
                                  @thomas-braun sagte in Twinkly Adapter bleibt gelb:
                                  Update mach ich dann. Danke.
                                  Hier die Ausgabe
                                  daniel@ioBroker:~$ type -p ping
                                  /usr/bin/ping
                                  daniel@ioBroker:~$ sudo -u iobroker ping iobroker.net
                                  [sudo] password for daniel:
                                  daniel@ioBroker:~$
                                    @der-eine sagte in Twinkly Adapter bleibt gelb:
                                    Mach es jetzt. Ist überfällig.
                                      @der-eine
                                      ping iobroker.net
                                        ping iobroker.net
                                          der-eine @Thomas Braun last edited by der-eine
                                          Last login: Thu Dec 14 19:03:34 CET 2023 on tty1
                                          daniel@ioBroker:~$ node -v
                                          v18.19.0
                                          daniel@ioBroker:~$
                                            @der-eine
                                            Also dürfen user nicht pingen.
                                            Was ist das da genau für eine Umgebung?
                                            iob diag
                                            in der Langfassung.
                                            2602
