    3. Tester
    4. Test c&p iob diag
    Test c&p iob diag
      Test C&P iob diag
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2022.12.29
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture:   aarch64
      Docker:         false
      Virtualization: none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       01:14:47 up 10 days, 10:38,  3 users,  load average: 0.13, 0.21, 0.25
      CPU threads: 4
      *** Time and Time Zones ***
      Thu Dec 29 00:14:47 UTC 2022
      Thu Dec 29 01:14:47 CET 2022
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      echad
      /home/echad
      echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        2.5G        3.2G        0.0K        2.2G        5.3G
      Swap:            99M          0B         99M
      Total:          8.0G        2.5G        3.3G
               7855 M total memory
               2458 M used memory
                715 M active memory
               3407 M inactive memory
               3236 M free memory
                216 M buffer memory
               1943 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4      110G  7.1G   99G   7% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     1.6G  880K  1.6G   1% /run
      /dev/sda1      vfat      253M   31M  222M  13% /boot
      tmpfs          tmpfs     786M  4.0K  786M   1% /run/user/1000
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.3G    /var/
      880M    /var/cache
      865M    /var/cache/apt
      761M    /var/cache/apt/archives
      753M    /var/log
      /opt/iobroker/backups:
      /opt/iobroker/iobroker-data:
      311M    /opt/iobroker/iobroker-data/
      187M    /opt/iobroker/iobroker-data/files
      101M    /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.806bf48a.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
      8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v19.3.0
      /usr/bin/node           v19.3.0
      /usr/bin/npm            9.2.0
      nodejs:
        Installed: 19.3.0-deb-1nodesource1
        Candidate: 19.3.0-deb-1nodesource1
        Version table:
       *** 19.3.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           18.12.1-deb-1nodesource1 501
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
           16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
           14.21.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   7
      Adapter State
      + system.adapter.admin.0                  : admin                 : chet                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : chet                                     -  enabled
        system.adapter.alias-manager.0          : alias-manager         : chet                                     - disabled
      + system.adapter.backitup.0               : backitup              : chet                                     -  enabled
        system.adapter.ble.0                    : ble                   : chet                                     - disabled
        system.adapter.cloud.0                  : cloud                 : chet                                     - disabled
      + system.adapter.echarts.0                : echarts               : chet                                     -  enabled
      + system.adapter.firetv.0                 : firetv                : chet                                     -  enabled
      + system.adapter.followthesun.0           : followthesun          : chet                                     -  enabled
      + system.adapter.govee.0                  : govee                 : chet                                     -  enabled
      + system.adapter.history.0                : history               : chet                                     -  enabled
        system.adapter.ical.0                   : ical                  : chet                                     -  enabled
        system.adapter.iceroad.0                : iceroad               : chet                                     - disabled
      + system.adapter.info.0                   : info                  : chet                                     -  enabled
      + system.adapter.iot.0                    : iot                   : chet                                     -  enabled
      + system.adapter.javascript.0             : javascript            : chet                                     -  enabled
        system.adapter.midea.0                  : midea                 : chet                                     - disabled
        system.adapter.mihome-cloud.0           : mihome-cloud          : chet                                     - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : chet                                     -  enabled, port: 54321
      + system.adapter.mihome.0                 : mihome                : chet                                     -  enabled, port: 9898, bind: 0.0.0.0
      + system.adapter.miio.0                   : miio                  : chet                                     -  enabled
      + system.adapter.nina.0                   : nina                  : chet                                     -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : chet                                     -  enabled
      + system.adapter.parcel.0                 : parcel                : chet                                     -  enabled
      + system.adapter.pi-hole.0                : pi-hole               : chet                                     -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : chet                                     -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : chet                                     -  enabled, port: 45000, bind: 0.0.0.0
        system.adapter.samsung.0                : samsung               : chet                                     - disabled
      + system.adapter.simple-api.0             : simple-api            : chet                                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : chet                                     -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
        system.adapter.switchbot-ble.0          : switchbot-ble         : chet                                     - disabled
      + system.adapter.switchbot-hub.0          : switchbot-hub         : chet                                     -  enabled
      + system.adapter.tado.0                   : tado                  : chet                                     -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : chet                                     -  enabled
      + system.adapter.tr-064.0                 : tr-064                : chet                                     -  enabled
      + system.adapter.tradfri.0                : tradfri               : chet                                     -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : chet                                     -  enabled
      + system.adapter.tuya.0                   : tuya                  : chet                                     -  enabled
      + system.adapter.web.0                    : web                   : chet                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : chet                                     -  enabled
      + system.adapter.ws.0                     : ws                    : chet                                     -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : chet                                     -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
      + instance is alive
      ioBroker-Repositories
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.5.9    , installed 2.5.9
      Adapter    "ble"          : 0.13.1   , installed 0.13.1
      Adapter    "cloud"        : 4.3.1    , installed 4.3.1
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "followthesun" : 0.4.0    , installed 0.4.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "iceroad"      : 1.1.2    , installed 1.1.2
      Adapter    "info"         : 1.9.24   , installed 1.9.24
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "midea"        : 0.0.7    , installed 0.1.0
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
      Adapter    "miio"         : 0.0.13   , installed 0.0.13
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
      Adapter    "parcel"       : 0.0.23   , installed 0.0.23
      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "sainlogic"    : 0.9.0    , installed 0.9.0
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "socketio"     : 6.3.3    , installed 6.3.3
      Adapter    "tado"         : 0.4.3    , installed 0.4.3
      Adapter    "tankerkoenig" : 3.2.4    , installed 3.2.4
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 2.1.0    , installed 2.1.0
      Adapter    "tuya"         : 3.11.4   , installed 3.11.4
      Adapter    "web"          : 5.4.1    , installed 5.4.1
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.3.4    , installed 2.3.4
      Adapter    "zigbee"       : 1.8.9    , installed 1.8.9
      Objects and States
      Objects:        9266
      States:         7388
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:7 http://packages.azlux.fr/debian bullseye InRelease
      Hit:8 https://cli.github.com/packages stable InRelease
      Hit:9 https://packages.grafana.com/oss/deb stable InRelease
      Hit:10 https://deb.nodesource.com/node_14.x bullseye InRelease
      Hit:11 https://repos.influxdata.com/debian bullseye InRelease
      Hit:12 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:13 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:14 https://deb.volian.org/volian scar InRelease
      Hit:15 https://deb.nodesource.com/node_19.x bullseye InRelease
      Hit:16 https://packages.redis.io/deb bullseye InRelease
      Get:18 https://pkgs.tailscale.com/stable/debian bullseye InRelease
      Hit:17 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Fetched 5545 B in 3s (1771 B/s)
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1001       2545037    329663/io.sainlogic
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12591      554/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          11758      568/dnsmasq
      tcp        0      0 100.93.118.24:41687     0.0.0.0:*               LISTEN      0          15841      647/tailscaled
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       2544658    329445/adb
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       2541338    329196/iobroker.js-
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       2542660    329196/iobroker.js-
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       5204120    677604/io.ws.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      1001       2543592    329734/io.socketio.
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2543534    329719/io.simple-ap
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2541692    329214/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5205095    677616/io.web.0
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       3183579    414819/io.nuki-exte
      tcp6       0      0 fd7a:115c:a1e0:ab:41687 :::*                    LISTEN      0          15842      647/tailscaled
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12593      554/sshd: /usr/sbin
      tcp6       0      0 :::53                   :::*                    LISTEN      0          11760      568/dnsmasq
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11639      397/avahi-daemon: r
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       2541458    329328/io.mihome.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5990534    773342/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5990535    773342/io.tuya.0
      udp        0      0 0.0.0.0:39588           0.0.0.0:*                           1001       6000070    329794/io.tradfri.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          11757      568/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11895      799/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       2541446    329313/io.mihome-va
      udp        0      0 0.0.0.0:45231           0.0.0.0:*                           1001       2544056    329603/io.miio.0
      udp        0      0 0.0.0.0:49456           0.0.0.0:*                           108        11641      397/avahi-daemon: r
      udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          17653      647/tailscaled
      udp6       0      0 :::5353                 :::*                                108        11640      397/avahi-daemon: r
      udp6       0      0 :::39054                :::*                                108        11642      397/avahi-daemon: r
      udp6       0      0 :::53                   :::*                                0          11759      568/dnsmasq
      udp6       0      0 :::546                  :::*                                0          11917      799/dhcpcd
      udp6       0      0 :::41641                :::*                                0          17652      647/tailscaled
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @Thomas Braun last edited by
        Skript v.2022.12.29
        *** BASE SYSTEM ***
        Docker: false
        Release: 11
        Codename: bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        echad
        /home/echad
        X-Server: false
        Desktop:
        Terminal: tty
        *** MEMORY ***
        total used free shared buff/cache available
        Swap: 99M 0B 99M
             7855 M total memory
             2458 M used memory
              715 M active memory
             3236 M free memory
              216 M buffer memory
             1943 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
        *** FILESYSTEM ***
        Filesystem Type Size Used Avail Use% Mounted on
        tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
        /var:
        2.3G /var/
        880M /var/cache
        865M /var/cache/apt
        753M /var/log
        /usr/bin/npm 9.2.0
        nodejs:
        Version table:
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        admin: 6.3.5
        javascript: 6.1.4
        Adapter State
        • system.adapter.admin.0 : admin : chet - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.alexa2.0 : alexa2 : chet - enabled
        • system.adapter.backitup.0 : backitup : chet - enabled
        • system.adapter.echarts.0 : echarts : chet - enabled
        • system.adapter.firetv.0 : firetv : chet - enabled
        • system.adapter.followthesun.0 : followthesun : chet - enabled
        • system.adapter.govee.0 : govee : chet - enabled
        • system.adapter.history.0 : history : chet - enabled
        • system.adapter.info.0 : info : chet - enabled
        • system.adapter.iot.0 : iot : chet - enabled
        • system.adapter.javascript.0 : javascript : chet - enabled
        • system.adapter.mihome-vacuum.0 : mihome-vacuum : chet - enabled, port: 54321
        • system.adapter.mihome.0 : mihome : chet - enabled, port: 9898, bind: 0.0.0.0
        • system.adapter.miio.0 : miio : chet - enabled
        • system.adapter.nina.0 : nina : chet - enabled
        • system.adapter.nuki-extended.0 : nuki-extended : chet - enabled
        • system.adapter.parcel.0 : parcel : chet - enabled
        • system.adapter.pi-hole.0 : pi-hole : chet - enabled
        • system.adapter.rpi2.0 : rpi2 : chet - enabled
        • system.adapter.sainlogic.0 : sainlogic : chet - enabled, port: 45000, bind: 0.0.0.0
        • system.adapter.simple-api.0 : simple-api : chet - enabled, port: 8087, bind: 0.0.0.0, run as: admin
        • system.adapter.socketio.0 : socketio : chet - enabled, port: 8086, bind: 0.0.0.0, run as: admin
        • system.adapter.switchbot-hub.0 : switchbot-hub : chet - enabled
        • system.adapter.tado.0 : tado : chet - enabled
        • system.adapter.tankerkoenig.0 : tankerkoenig : chet - enabled
        • system.adapter.tr-064.0 : tr-064 : chet - enabled
        • system.adapter.tradfri.0 : tradfri : chet - enabled
        • system.adapter.trashschedule.0 : trashschedule : chet - enabled
        • system.adapter.tuya.0 : tuya : chet - enabled
        • system.adapter.web.0 : web : chet - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        • system.adapter.whatsapp-cmb.0 : whatsapp-cmb : chet - enabled
        • system.adapter.ws.0 : ws : chet - enabled, port: 8084, bind: 0.0.0.0, run as: admin
        • system.adapter.zigbee.0 : zigbee : chet - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
        • instance is alive
        beta : http://download.iobroker.net/sources-dist-latest.json
        stable : http://download.iobroker.net/sources-dist.json
        Adapter "alias-manager": 1.2.6 , installed 1.2.6
        Adapter "simple-api" : 2.7.2 , installed 2.7.2
        Objects and States
        Objects: 9266
        States: 7388
        Pending Updates: 0
        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
        tcp6 0 0 fd7a:115c:a1e0🆎41687 :::* LISTEN 0 15842 647/tailscaled
          Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
          Copy text starting here:
                                  v.2024-07-21
           Static hostname: chet
                 Icon name: computer
          Operating System: Debian GNU/Linux trixie/sid
                    Kernel: Linux 6.6.31+rpt-rpi-v8
              Architecture: arm64
          User-ID:                1000
          Display-Server:         false
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/nodejs         v22.5.1
          /usr/bin/node           v22.5.1
          /usr/bin/corepack       0.29.2
          Recommended versions are nodejs 20.15.1 and npm 10.7.0
          MEMORY:
          Mem:            8.2G        2.8G        726M        872K        4.9G        5.4G
          Swap:           209M          0B        209M
          Total:          8.4G        2.8G        936M
          Active iob-Instances:   38
          Upgrade policy: none
          ioBroker Core:          js-controller           6.0.9
                                  admin                   7.0.17
          Objects type: jsonl
          States  type: jsonl
          Objects:                11112
          States:                 8907
          Size of iob-Database:
          29M     /opt/iobroker/iobroker-data/objects.jsonl
          4.6M    /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          31.7k
          79.8k
