    4. invalid UTF-8 sequence - Web Socket
      Fritzo81 last edited by Fritzo81
      |Hardwaresystem:| Raspi 4 |
      |Arbeitsspeicher:| 4GB |
      |Festplattenart:| SD-Karte |
      |Betriebssystem:| Linux |
      |Node-Version:| 16.19.0 |
      |Nodejs-Version:| 16.19.0 |
      |NPM-Version:| 8.19.3 |
      |Installationsart:| Manuell |
      |Image genutzt:| Nein |
      Hallo Zusammen, da ich leider den Fehler mit dem nicht editierbaren Vis habe (Verbindungsfehler) wollte ich den Web Socket nehmen.
      Sobald ich dann umschalte, socketio aus und Web Socket ein und dann auf Vis zugreifen will bekomme ich nachfolgenden Fehler im Log.
      Weis ein zufällig von euch Rat?
      code_text
      ```host.raspberrypi
      2023-01-03 00:13:49.899	error	instance system.adapter.ws.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2023-01-03 00:13:49.899	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
      host.raspberrypi
      2023-01-03 00:13:49.899	error	Caught by controller[0]: at Socket.emit (node:events:513:28)
      host.raspberrypi
      2023-01-03 00:13:49.899	error	Caught by controller[0]: at Socket.socketOnData (/opt/iobroker/node_modules/ws/lib/websocket.js:1272:35)
      host.raspberrypi
      2023-01-03 00:13:49.899	error	Caught by controller[0]: at Receiver.Writable.write (node:internal/streams/writable:336:10)
      host.raspberrypi
      2023-01-03 00:13:49.899	error	Caught by controller[0]: at _write (node:internal/streams/writable:332:10)
      host.raspberrypi
      2023-01-03 00:13:49.899	error	Caught by controller[0]: at writeOrBuffer (node:internal/streams/writable:391:12)
      host.raspberrypi
      2023-01-03 00:13:49.898	error	Caught by controller[0]: at Receiver._write (/opt/iobroker/node_modules/ws/lib/receiver.js:83:10)
      host.raspberrypi
      2023-01-03 00:13:49.898	error	Caught by controller[0]: at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:148:22)
      host.raspberrypi
      2023-01-03 00:13:49.898	error	Caught by controller[0]: at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:446:17)
      host.raspberrypi
      2023-01-03 00:13:49.898	error	Caught by controller[0]: at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:519:18)
      host.raspberrypi
      2023-01-03 00:13:49.897	error	Caught by controller[0]: Error: Invalid WebSocket frame: invalid UTF-8 sequence
      ws.0
      2023-01-03 00:13:49.608	error	Exception-Code: WS_ERR_INVALID_UTF8: Invalid WebSocket frame: invalid UTF-8 sequence
      ws.0
      2023-01-03 00:13:49.607	error	Error: Invalid WebSocket frame: invalid UTF-8 sequence at Receiver.dataMessage (/opt/iobroker/node_modules/ws/lib/receiver.js:519:18) at Receiver.getData (/opt/iobroker/node_modules/ws/lib/receiver.js:446:17) at Receiver.startLoop (/opt/iobroker/node_modules/ws/lib/receiver.js:148:22) at Receiver._write (/opt/iobroker/node_modules/ws/lib/receiver.js:83:10) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Receiver.Writable.write (node:internal/streams/writable:336:10) at Socket.socketOnData (/opt/iobroker/node_modules/ws/lib/websocket.js:1272:35) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12)
      ws.0
      2023-01-03 00:13:49.599	error	uncaught exception: Invalid WebSocket frame: invalid UTF-8 sequence|Systemdata| Bitte Ausfüllen|
      web socket
