    2. English
    3. Visualization
    4. Vis does not start (Terminated (NO_ERROR): Without reason)
      MahMahoritos last edited by
      Hello. I am learning the smart home with the zigbee and ioBroker.
      I installed an official docker image, connected the devices, turned on the Telegram bot, wrote some JS scripts, but I can't start vis.
      It just does not start, and the reasons are not specified in the logs. I didn't find any information by searching the forum.
      Logs are listed below, please help, how do I install and run vis?
      What am I doing:
      0) remove vis and all related drivers, remove the web server - so I try to make a "clean" installation
      1. install vis
        1.1) the web server was installed automatically and have status "started"
        1.2) vis did not start
      2. add the license code in vis settings, check was fine
      3. restart iis
        3.1) vis did not start
        That's it, there are no further ideas. Immediately after installation, it was the same, vis never worked on my server
      host.iobroker
      		2022-12-20 22:42:18.437	info	instance system.adapter.vis.0 terminated while should be started once
      vis.0
      	10212	2022-12-20 22:42:17.883	info	Terminated (NO_ERROR): Without reason
      vis.0
      	10212	2022-12-20 22:42:16.937	info	vis license is OK.
      vis.0
      	10212	2022-12-20 22:42:16.338	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.23
      vis.0
      	10212	2022-12-20 22:42:16.279	debug	States connected to redis: 127.0.0.1:9000
      vis.0
      	10212	2022-12-20 22:42:16.264	debug	States create User PubSub Client
      vis.0
      	10212	2022-12-20 22:42:16.263	debug	States create System PubSub Client
      vis.0
      	10212	2022-12-20 22:42:16.255	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      vis.0
      	10212	2022-12-20 22:42:16.235	debug	Objects connected to redis: 127.0.0.1:9001
      vis.0
      	10212	2022-12-20 22:42:16.199	debug	Objects client initialize lua scripts
      vis.0
      	10212	2022-12-20 22:42:16.168	debug	Objects create User PubSub Client
      vis.0
      	10212	2022-12-20 22:42:16.167	debug	Objects create System PubSub Client
      vis.0
      	10212	2022-12-20 22:42:16.154	debug	Objects client ready ... initialize now
      vis.0
      	10212	2022-12-20 22:42:16.079	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      admin.0
      	1929	2022-12-20 22:42:01.591	info	<== Disconnect system.user.admin from ::ffff:192.168.12.2 devices
      • liv-in-sky
        liv-in-sky @MahMahoritos last edited by liv-in-sky
        @mahmahoritos
        under special circumstances it helps to downgrade to vis version 1.4.0 and restart the server - if it is running after the downgrade make an update to latest version again
        iobroker upgrade iobroker.vis@1.4.0
        by the way - you should also try to install the web socket adapter and in the setting of the web adapter choose the web-socket adapter (ws0) for the connection
          MahMahoritos @liv-in-sky last edited by
          @liv-in-sky said in Vis does not start (Terminated (NO_ERROR): Without reason):
          iobroker.vis@1.4.0
          Tried this, nothing changed. All settings of adapters are default (exept license of vis.0 and link to ws.0 in web.0)
          I never tried to use iobroker commands in CLI before, only in admin webpage, so I read some docs. During installation of custom version of vis I mention in the logs that vis tried to connect redis, but there is no redis instance in the docker image
          host.iobroker
          		2023-01-11 22:37:02.921	info	instance system.adapter.vis.0 terminated while should be started once
          vis.0
          	1453	2023-01-11 22:37:02.376	info	Terminated (NO_ERROR): Without reason
          vis.0
          	1453	2023-01-11 22:37:01.668	info	vis license is OK.
          vis.0
          	1453	2023-01-11 22:37:01.106	info	starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
          vis.0
          	1453	2023-01-11 22:37:01.016	debug	States connected to redis: 127.0.0.1:9000
          vis.0
          	1453	2023-01-11 22:37:00.968	debug	States create User PubSub Client
          vis.0
          	1453	2023-01-11 22:37:00.967	debug	States create System PubSub Client
          vis.0
          	1453	2023-01-11 22:37:00.960	debug	Redis States: Use Redis connection: 127.0.0.1:9000
          vis.0
          	1453	2023-01-11 22:37:00.942	debug	Objects connected to redis: 127.0.0.1:9001
          vis.0
          	1453	2023-01-11 22:37:00.896	debug	Objects client initialize lua scripts
          vis.0
          	1453	2023-01-11 22:37:00.871	debug	Objects create User PubSub Client
          vis.0
          	1453	2023-01-11 22:37:00.870	debug	Objects create System PubSub Client
          vis.0
          	1453	2023-01-11 22:37:00.868	debug	Objects client ready ... initialize now
          vis.0
          	1453	2023-01-11 22:37:00.830	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          admin.0
          	172	2023-01-11 22:34:44.074	info	<== Disconnect system.user.admin from ::ffff:192.168.12.2 web
          Is redis required for vis? I didn't found this in any tutorial or docs... May be this is the reason that vis does not start?
          • liv-in-sky
            @mahmahoritos
            what is the output of the command:
            iobroker status
            what is happening when you open the vis editor with a browser ?did you try it with the address ?
            http://192.168.178.59:8082/vis/edit.html?project#view
              iobroker status
              root@iobroker:/opt/iobroker# iobroker status
              Objects type: jsonl
              States  type: jsonl
              My address is http://127.0.0.1:8082/vis/edit.html (I am not at home now, so I connected via ssh tunnel, ports 8081 and 8082 are forwarded)
              Nothing is happening - there is no connection
              • liv-in-sky
                @mahmahoritos I'm sorry - maybe docker and the forwarding is making some trouble - we need somebody else to solve this problem - I don't use iobroker like you 😞
                • wendy2702
                  wendy2702 last edited by
                  What is the output of
                   iob list instances
                    MahMahoritos @wendy2702 last edited by
                    iob list instances
                    root@iobroker:/opt/iobroker# iob list instances
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.devices.0                : devices               : iobroker                                 - disabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                    + instance is alive
                    Also tried to connect to vis (8082 port) from home network - result is the same
                    • wendy2702
                      @mahmahoritos If you are using a official Docker image, which one?
                      Did you open the Port 8082 to be able to access VIS ?
                      I guess you missed to open the port 8082 at Docker config. Default is only 8081 if I remember correct.
                        @wendy2702
                        You are absolutely right! I'm noob...
                        services:
                          iobroker:
                            container_name: iobroker
                            image: buanet/iobroker:latest-v7
                            hostname: iobroker
                            restart: always
                            ports:
                              - "8081:8081"
                            volumes:
                              - iobrokerdata:/opt/iobroker
                            environment:
                              - TZ=Asia/Yekaterinburg
                            devices:
                              - "/dev/ttyUSB0:/dev/ttyUSB0"
                        I added "8082:8082" string and after recreating container demo page started!
                        Thank you a lot!
                        • wendy2702
                          wendy2702 @MahMahoritos last edited by
                          @mahmahoritos You are welcome
                          1253
