    4. Fehler installation RaspberryPi 3
      surfducato last edited by
      Moin,
      ich habe gerade versucht ioBroker auf einem RaspberryPi 3 zu installieren. Ich habe mich an Folgende Anleitung gehalten: http://www.iobroker.net/?page_id=5106&lang=de
      Leider bekomme ich folgende Fehlermeldungen. Habt ihr eine Idee was da los ist?
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker --unsafe-perm
      > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.discovery --production --prefix /opt/iobroker
      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.3 (node-v46 ABI) (falling back to source compile with node-gyp)
      npm install iobroker.admin --production --prefix /opt/iobroker
      npm install iobroker.js-controller --production --prefix /opt/iobroker
      host.raspberrypi error: this adapter does not allow multiple instances on one host
      npm ERR! Linux 4.9.24-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v4.8.3
      npm ERR! npm  v2.15.11
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@1.0.0 install: `node iobroker.js setup first`
      npm ERR! Exit status 21
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.0.0 install script 'node iobroker.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node iobroker.js setup first
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs iobroker.js-controller
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller'
      npm ERR! error rolling back     at Error (native)
      npm ERR! error rolling back  { [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller']
      npm ERR! error rolling back   errno: -39,
      npm ERR! error rolling back   code: 'ENOTEMPTY',
      npm ERR! error rolling back   syscall: 'rmdir',
      npm ERR! error rolling back   path: '/opt/iobroker/node_modules/iobroker.js-controller' }
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/node_modules/iobroker/npm-debug.log
      Write "./iobroker start" to start the ioBroker
      module.js:327
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js'
          at Function.Module._resolveFilename (module.js:325:15)
          at Function.Module._load (module.js:276:25)
          at Module.require (module.js:353:17)
          at require (internal/module.js:12:17)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker:2:1)
          at Module._compile (module.js:409:26)
          at Object.Module._extensions..js (module.js:416:10)
          at Module.load (module.js:343:32)
          at Function.Module._load (module.js:300:12)
          at Function.Module.runMain (module.js:441:10)
      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
      iobroker@1.0.0 node_modules/iobroker
      âââ yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, require-directory@2.1.1, cliui@3.2.0, string-width@1.0.2, os-locale@1.4.0, read-pkg-up@1.0.1)
      pi@raspberrypi:/opt/iobroker $</anonymous>
        Jetzt noch mal als root ausgeführt. Jedoch läuft das noch immer nicht sauber durch.
        > node lib/setup.js
        npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser requires debug@'2.2.0' but will load
        npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug,
        npm WARN unmet dependency which is version 2.3.3
        : Datei oder Verzeichnis nicht gefunden
        root@raspberrypi:/opt/iobroker#
