    4. Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter
    • V
      V8Turbo last edited by
      Hallo, habe einen Sofar Solar HYD10 KTL Wechselrichter + Pylontech Force H2 Akkus und möchte gern den Wechselrichter an ioBroker mit dem Modbus Adapter einbinden. Habe mir schon den USB -> RS485 Adapter bei Amazon bestellt und angeschlossen. Wird auch vom Raspberry erkannt. Nur leider funktioniert es nicht... Habe mir schon die HEX in DEC Adressen umgerechnet... +/- stimmt auch.
      Meldung im LOG
      modbus.0
      2023-01-12 08:45:33.506	info	Connected to slave
      modbus.0
      2023-01-12 08:45:33.293	info	Can not execute task "add" for ID undefined: The id is empty! Please provide a valid id. ({"name":"add","obj":{"type":"state","common":{"name":"L1","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":-35377,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}}
      modbus.0
      2023-01-12 08:45:33.223	error	Invalid object: {"type":"state","common":{"name":"L1","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":-35377,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
      modbus.0
      2023-01-12 08:45:33.221	error	Invalid data holdingRegisters/0: {"_address":"4624","name":"Voltage_Line_L1","description":"L1","unit":"V","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":-35377,"deviceId":1,"fullId":"modbus.0.0"}
      modbus.0
      2023-01-12 08:45:33.217	error	Invalid holdingRegisters address: -35377
      _address name description unit type len factor offset formula role room poll wp cw isScale
      4624 Voltage_Line_L1 L1 V int16be 1 1 0 level true
      Kann jemand helfen ?
      • Glasfaser
        Glasfaser last edited by Glasfaser
        @v8turbo sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
        4624 Voltage
        Abgefragt wird
        -35377
        was hast du bei " Aliases benutzen " !? in der Instanzeinstellung
        • V
          @glasfaser
          Aliases benutzen ist der haken gesetzt ?
          • V
            V8Turbo @V8Turbo last edited by V8Turbo
            • V
              • V
                So bin jetzt mit einer aktuelleren Liste weiter gekommen... Für alle die es Interessiert hier Angehangen. Die Adressen in DEC umrechnen dann bekomme ich zumindest Werte. Leider habe ich wohl aber ein Kommunicationsproblem (?).
                modbus.0
                2023-01-12 11:52:27.690	info	Disconnected from slave
                modbus.0
                2023-01-12 11:52:26.690	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
                modbus.0
                2023-01-12 11:52:26.689	error	Request timed out.
                modbus.0
                2023-01-12 11:52:26.688	warn	Error: undefined
                modbus.0
                2023-01-12 11:52:21.763	error	unknown function code: 0x0, 0x0
                modbus.0
                2023-01-12 11:52:21.741	error	Wrong CRC for frame: 255,1,3,46,9,40,0,219
                modbus.0
                2023-01-12 11:52:21.685	debug	[DevID_1/holdingRegs] Poll address 1165 - 23 registers
                Hier komplett...
                v6.3.5
                12
                10
                Log-Größe: 25.6 KB
                Zeit
                debug
                Nachricht
                modbus.0
                2023-01-12 11:50:15.660	debug	Cleaning up request fifo.
                modbus.0
                2023-01-12 11:50:15.658	debug	Clearing timeout of the current request.
                modbus.0
                2023-01-12 11:50:15.654	info	Disconnected from slave
                modbus.0
                2023-01-12 11:50:14.652	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.0
                2023-01-12 11:50:14.651	error	Request timed out.
                modbus.0
                2023-01-12 11:50:14.649	warn	Error: undefined
                modbus.0
                2023-01-12 11:50:09.726	error	unknown function code: 0x0, 0x0
                modbus.0
                2023-01-12 11:50:09.704	error	Wrong CRC for frame: 255,1,3,46,9,38,0,221
                modbus.0
                2023-01-12 11:50:09.647	debug	[DevID_1/holdingRegs] Poll address 1165 - 23 registers
                modbus.0
                2023-01-12 11:50:09.645	debug	[DevID_1] Poll start ---------------------
                modbus.0
                2023-01-12 11:50:03.538	debug	[DevID_1/holdingRegs] Poll address 1165 DONE
                modbus.0
                2023-01-12 11:50:03.452	debug	[DevID_1/holdingRegs] Poll address 1165 - 23 registers
                modbus.0
                2023-01-12 11:50:03.452	debug	Initialization of scale factors done!
                modbus.0
                2023-01-12 11:50:03.450	debug	[DevID_1] Poll start ---------------------
                modbus.0
                2023-01-12 11:50:03.449	info	Connected to slave
                modbus.0
                2023-01-12 11:50:03.440	debug	connect to serial /dev/ttyUSB0 with 9600
                modbus.0
                2023-01-12 11:50:03.142	debug	Add holdingRegisters._Voltage_Phase_T: {"_id":"holdingRegisters._Voltage_Phase_T","type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":1187,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                modbus.0
                2023-01-12 11:50:03.142	debug	Add holdingRegisters._Voltage_Phase_S: {"_id":"holdingRegisters._Voltage_Phase_S","type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":1176,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                modbus.0
                2023-01-12 11:50:03.141	debug	Add holdingRegisters._Voltage_Phase_R: {"_id":"holdingRegisters._Voltage_Phase_R","type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":1165,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                modbus.0
                2023-01-12 11:50:03.141	debug	Initialize Objects for holdingRegs: [{"_address":1165,"name":"Voltage_Phase_R","description":"","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1165,"deviceId":1,"id":"holdingRegisters._Voltage_Phase_R"},{"_address":1176,"name":"Voltage_Phase_S","description":"","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1176,"deviceId":1,"id":"holdingRegisters._Voltage_Phase_S"},{"_address":1187,"name":"Voltage_Phase_T","description":"","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1187,"deviceId":1,"id":"holdingRegisters._Voltage_Phase_T"}]
                modbus.0
                2023-01-12 11:50:03.140	debug	Initialize Objects for inputRegs: []
                modbus.0
                2023-01-12 11:50:03.139	debug	Initialize Objects for coils: []
                modbus.0
                2023-01-12 11:50:03.138	debug	Initialize Objects for disInputs: []
                SOFAR-G3 External Modbus Protocol-EN-V1.10 (20220622).xlsx
                • Glasfaser
                  Glasfaser @V8Turbo last edited by
                  @v8turbo
                  Ich kann dir bei deinem Wechselrichter nicht weiterhelfen .
                  aber du stocherst nur rum ... ich würde das nicht mit ioBroker machen .
                  Mache es so , mit einem Windows Programm QModMaster , zuerst alles raussuchen :
                  https://forum.iobroker.net/post/829310
                  • V
                    @glasfaser said in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                    QModMaster
                    Naja die Adressen habe ich jetzt ja, diese passen. Hab jetzt von allen 3 Phasen die Voltage ausgelesen und die speichert es auch korrekt in den Objekten. Ich denke es ist hier ein Einstellungsproblem beim RS 485 Adapter ?!
                    Brauche ich den einen Widerstand ? Habe vom Wechselrichter zum Raspi / Adapter ca. 40m Leitung Cat 7. Die ist aber 2x offen mit wago Klemmen.
                    • wendy2702
                      @v8turbo Bei 40m ist ein Widerstand eigentlich kein muss.
                      Ich denke eher es liegt an den Kommunikations Einstellungen.
                      Woher kommst du z.B. auf 9600Baud ?
                      Was ist mit Parity, Bits etc?
                      Bei Modbus RTU über RS485 kann es erforderlich sein das du zwischen den Registern keine Lücke bei der Abfrage haben darfst.
                      Beispiel: Du benötigst Register 1,2, 6,7,8 Dann muss du 3,4,5 auch eintragen.
                      Habe ich das richtig gesehen das der WLAN kann? Wenn ja, was geht über WLAN?
                      V Glasfaser 2 Replies Last reply Reply Quote 0
                      • V
                        @wendy2702 Über WLAN ist der mit der Cloud verbunden, Solarman PV heißt die APP. Mehr geht nicht (?).
                        Einstellung
                        TCP Serial = Serial
                        Port = /dev/ttyUSB0
                        Baud = 9600
                        Data bits = 8
                        Stop bits = 1
                        Parity = none
                        Device ID = 1
                        General
                        Do not align addresses to 16 bits
                        Data polling = 1000 ms
                        Reconnect delay = 10000 ms
                        Read timeout = 4000 ms
                        Pulse time = 1000 ms
                        Wait time = 100 ms
                        Max read request length (float) = 60
                        Max read request length (booleans) = 60
                        Read interval = 150 ms
                        Write interval = 150 ms
                        Alle anderen haben keinen haken
                        • V
                          V8Turbo @wendy2702 last edited by
                          @wendy2702 said in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                          Bei Modbus RTU übner RS485 kann es erforderlich sein das du zwischen den Registern keine Lücke bei der Abfrage haben darfst.
                          Heißt ich muss alle Abfragen ?
                          • Glasfaser
                            Glasfaser @wendy2702 last edited by
                            @wendy2702 sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                            Er meint das , wenn du in der Instanzeinstellung den Poll nicht angehakt hast , bei 3,4,5
                            Was ist mit nur einer RegisterAbfrage ( die anderen löschen ) in der Instanzeinstellung , kommt die gleiche Meldung
                            • V
                              Also alle Zahlen von 1 - 1056 und dann 1057-1156 usw. eintragen oder wie meinst du das ?
                              Hatte noch das hier gefunden, ist das immernoch so ?
                              https://forum.iobroker.net/topic/22126/adapter-modbus-mehrere-geräte-ids-timeout-beim-auslesen-von-mehr-als-einen-teilnehmern/17
                              • V
                                V8Turbo @Glasfaser last edited by V8Turbo
                                @glasfaser auch mit einem Register noch das gleiche...
                                modbus.0
                                2023-01-12 15:37:45.699	debug	Cleaning up request fifo.
                                modbus.0
                                2023-01-12 15:37:45.698	debug	Clearing timeout of the current request.
                                modbus.0
                                2023-01-12 15:37:45.694	info	Disconnected from slave
                                modbus.0
                                2023-01-12 15:37:44.693	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                                modbus.0
                                2023-01-12 15:37:44.690	error	Request timed out.
                                modbus.0
                                2023-01-12 15:37:44.689	warn	Error: undefined
                                modbus.0
                                2023-01-12 15:37:40.681	debug	[DevID_1/holdingRegs] Poll address 1056 - 1 registers
                                modbus.0
                                2023-01-12 15:37:40.681	debug	Initialization of scale factors done!
                                modbus.0
                                2023-01-12 15:37:40.679	debug	[DevID_1] Poll start ---------------------
                                modbus.0
                                2023-01-12 15:37:40.678	info	Connected to slave
                                modbus.0
                                2023-01-12 15:37:40.669	debug	connect to serial /dev/ttyUSB0 with 2400
                                Sporadisch läuft alles durch, dann geht es wieder 3,4,5x nicht
                                • wendy2702
                                  wendy2702 @V8Turbo last edited by
                                  Wieso jetzt 2400 ?
                                  Die Werte müssen sich mit den Kommunikations Einstellungen vom WR decken.
                                  • V
                                    @wendy2702 habe rum probiert. Der WR hat 9600 eingestellt.
                                    • Glasfaser
                                      Glasfaser @Glasfaser last edited by
                                      @V8Turbo
                                      @glasfaser sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                                      Was war hiermit
                                      • V
                                        @glasfaser siehe 2 Beiträge weiter oben...
                                        "@glasfaser auch mit einem Register noch das gleiche..."
                                        • Glasfaser
                                          Glasfaser @V8Turbo last edited by Glasfaser
                                          dann würde ich erstmal nur mit einem weitermachen !
                                          Das Problem ist du wechselst immer hin und her .
                                          • Welche aktuellen Einstellungen hast du in der Instanz
                                          • einen aktuellen ioBroker Log mit nur einem Register wo ein Fehler kommt ..
                                          • wird auch der Wert im Datenpunkt geschrieben , ist er auch richtig !?
                                          • V
                                            @glasfaser Anbei die aktuellen Werte. Der WR ist auch auf 9600 eingestellt.
                                            Im Holding Register ist jetzt nur ein Eintrag
                                            1412	Voltage_PV1		V	uint16be	1	0,1	0		state		true	false	false	false
                                            Aktuelles Log von gerade Ebend.
                                            modbus.0
                                            2023-01-13 07:32:40.268	debug	Cleaning up request fifo.
                                            modbus.0
                                            2023-01-13 07:32:40.267	debug	Clearing timeout of the current request.
                                            modbus.0
                                            2023-01-13 07:32:40.263	info	Disconnected from slave
                                            modbus.0
                                            2023-01-13 07:32:39.566	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:39.565	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:39.263	warn	Poll error count: 2 code: {"err":"timeout","timeout":4000}
                                            modbus.0
                                            2023-01-13 07:32:39.262	error	Request timed out.
                                            modbus.0
                                            2023-01-13 07:32:39.261	warn	Error: undefined
                                            modbus.0
                                            2023-01-13 07:32:35.291	error	Wrong CRC for frame: 255,2,3,2,4,172,254,249
                                            modbus.0
                                            2023-01-13 07:32:35.259	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:35.258	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:35.255	info	Connected to slave
                                            modbus.0
                                            2023-01-13 07:32:35.249	debug	connect to serial /dev/ttyUSB0 with 9600
                                            modbus.0
                                            2023-01-13 07:32:29.251	debug	Cleaning up request fifo.
                                            modbus.0
                                            2023-01-13 07:32:29.250	debug	Clearing timeout of the current request.
                                            modbus.0
                                            2023-01-13 07:32:29.248	info	Disconnected from slave
                                            modbus.0
                                            2023-01-13 07:32:28.550	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:28.549	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:28.248	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                                            modbus.0
                                            2023-01-13 07:32:28.247	error	Request timed out.
                                            modbus.0
                                            2023-01-13 07:32:28.246	warn	Error: undefined
                                            modbus.0
                                            2023-01-13 07:32:24.277	error	Wrong CRC for frame: 255,2,3,2,7,173,63,201
                                            modbus.0
                                            2023-01-13 07:32:24.244	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:24.243	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:23.740	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                                            modbus.0
                                            2023-01-13 07:32:23.707	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:23.706	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:23.704	info	Connected to slave
                                            modbus.0
                                            2023-01-13 07:32:23.695	debug	connect to serial /dev/ttyUSB0 with 9600
                                            modbus.0
                                            2023-01-13 07:32:17.697	debug	Cleaning up request fifo.
                                            modbus.0
                                            2023-01-13 07:32:17.696	debug	Clearing timeout of the current request.
                                            modbus.0
                                            2023-01-13 07:32:17.693	info	Disconnected from slave
                                            modbus.0
                                            2023-01-13 07:32:16.995	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:16.994	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:16.693	warn	Poll error count: 2 code: {"err":"timeout","timeout":4000}
                                            modbus.0
                                            2023-01-13 07:32:16.692	error	Request timed out.
                                            modbus.0
                                            2023-01-13 07:32:16.690	warn	Error: undefined
                                            modbus.0
                                            2023-01-13 07:32:12.721	error	Wrong CRC for frame: 3,2,4,250,126,199,255,2,3
                                            modbus.0
                                            2023-01-13 07:32:12.688	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:12.687	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:12.686	info	Connected to slave
                                            modbus.0
                                            2023-01-13 07:32:12.677	debug	connect to serial /dev/ttyUSB0 with 9600
                                            modbus.0
                                            2023-01-13 07:32:06.678	debug	Cleaning up request fifo.
                                            modbus.0
                                            2023-01-13 07:32:06.677	debug	Clearing timeout of the current request.
                                            modbus.0
                                            2023-01-13 07:32:06.675	info	Disconnected from slave
                                            modbus.0
                                            2023-01-13 07:32:05.976	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:05.975	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:05.673	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                                            modbus.0
                                            2023-01-13 07:32:05.673	error	Request timed out.
                                            modbus.0
                                            2023-01-13 07:32:05.672	warn	Error: undefined
                                            modbus.0
                                            2023-01-13 07:32:01.668	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:01.667	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:01.165	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                                            modbus.0
                                            2023-01-13 07:32:01.133	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:01.132	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:00.627	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                                            modbus.0
                                            2023-01-13 07:32:00.589	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:32:00.588	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:32:00.587	info	Connected to slave
                                            modbus.0
                                            2023-01-13 07:32:00.579	debug	connect to serial /dev/ttyUSB0 with 9600
                                            modbus.0
                                            2023-01-13 07:31:54.579	debug	Cleaning up request fifo.
                                            modbus.0
                                            2023-01-13 07:31:54.578	debug	Clearing timeout of the current request.
                                            modbus.0
                                            2023-01-13 07:31:54.576	info	Disconnected from slave
                                            modbus.0
                                            2023-01-13 07:31:53.879	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:31:53.877	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:31:53.576	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                                            modbus.0
                                            2023-01-13 07:31:53.573	error	Request timed out.
                                            modbus.0
                                            2023-01-13 07:31:53.572	warn	Error: undefined
                                            modbus.0
                                            2023-01-13 07:31:49.604	error	unknown function code: 0x20, 0xa0
                                            modbus.0
                                            2023-01-13 07:31:49.564	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                                            modbus.0
                                            2023-01-13 07:31:49.564	debug	Initialization of scale factors done!
                                            modbus.0
                                            2023-01-13 07:31:49.562	debug	[DevID_2] Poll start ---------------------
                                            modbus.0
                                            2023-01-13 07:31:49.561	info	Connected to slave
                                            modbus.0
                                            2023-01-13 07:31:49.554	debug	connect to serial /dev/ttyUSB0 with 9600
                                            99
                                            17789
