    4. Iobroker startet nicht mehr
      SR277 last edited by
      leider habe ich keinen Zugriff mehr auf den Iobroker. Kann mir jemand helfen?
      Danke schonmal!
      code_text
      ```pi@raspberrypi:~ $ iob start admin
      Uncaught Rejection: /opt/iobroker/node_modules/source-map/lib/base64-vlq.js:91
      0 var di'it;
      SyntaxError: Unexpected token 'var'
          at wrapSafe (internal/modules/cjs/loader.js:1001:16)
          at Module._compile (internal/modules/cjs/loader.js:1049:27)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          at Module.load (internal/modules/cjs/loader.js:950:32)
          at Function.Module._load (internal/modules/cjs/loader.js:790:12)
          at Module.require (internal/modules/cjs/loader.js:974:19)
          at require (internal/modules/cjs/helpers.js:93:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/source-map/lib/source-map-generator.js:8:17)
          at Module._compile (internal/modules/cjs/loader.js:1085:14)
        Thomas Braun Most Active @SR277 last edited by
        @sr277
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
        sagt?
          SR277 @Thomas Braun last edited by
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          pi@raspberrypi:~ $ uname -m &&type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v14.18.3
          v14.18.3
          6.14.15
          6.14.15
          4.0.23
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
          tty
          /home/pi
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
          Reading package lists... Done
          nodejs:
            Installed: 14.18.3-deb-1nodesource1
            Candidate: 14.21.2-deb-1nodesource1
            Version table:
               14.21.2-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
           *** 14.18.3-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
            @sr277
            Bring das erstmal auf nodeJS@16.
            Siehe meine Signatur.
              Das sieht hier schon sehr komisch aus.
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
              │ │ │ ├── github-from-package@0.0.0
              │   ├── github-url-from-git@1.5.0
              │   ├─┬ new-github-release-url@1.0.0
              npm ERR! peer dep missing: @types/express@^4.17.13, required by http-proxy-middleware@2.0.2
              npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                @sr277
                Nö, alles i. O.
                  SR277 @Thomas Braun last edited by SR277
                  So habe es installiert.
                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v16.19.0
                  v16.19.0
                  8.19.3
                  8.19.3
                  4.0.23
                  pi
                  tty
                  /home/pi
                  Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                  nodejs:
                    Installed: 16.19.0-deb-1nodesource1
                    Candidate: 16.19.0-deb-1nodesource1
                    Version table:
                   *** 16.19.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  Fehler besteht aber weiterhin:
                   Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  0 var di'it;
                      at Object.compileFunction (node:vm:360:18)
                      at wrapSafe (node:internal/modules/cjs/loader:1094:15)
                      at Module._compile (node:internal/modules/cjs/loader:1129:27)
                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      at Module.load (node:internal/modules/cjs/loader:1043:32)
                      at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      at Module.require (node:internal/modules/cjs/loader:1067:19)
                      at require (node:internal/modules/cjs/helpers:103:18)
                      at Module._compile (node:internal/modules/cjs/loader:1165:14)
                    @sr277
                    cd /opt/iobroker
                    npm ls source-map
                      pi@raspberrypi:/opt/iobroker $ npm ls source-map
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├─┬ iobroker.alexa2@3.12.0
                      │ └─┬ source-map-support@0.5.21
                      │   └── source-map@0.6.1
                      └─┬ iobroker.iot@1.11.5
                        └─┬ jsdom@19.0.0
                          └─┬ escodegen@2.0.0
                            └── source-map@0.6.1 deduped
                        @sr277
                        Lange das System nicht mehr abgestaubt...
                        iob stop
                        iob fix
                        iob restart
                          pi@raspberrypi:~ $ iob stop
                          pi@raspberrypi:~ $ iob fix
                          library: loaded
                          Library version=2022-12-09
                              Welcome to the ioBroker installation fixer!
                              Script version: 2022-12-22
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/4)
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Installed gcc-c++
                              Checking ioBroker user and directory permissions (2/4)
                          Created /etc/sudoers.d/iobroker
                              Database maintenance (3/4)
                          Checking for uncompressed JSONL databases... This might take a while!
                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                          Compressed 2 JSONL files. Done
                              Checking autostart (4/4)
                          Enabling autostart...
                          Autostart enabled!
                              Your installation was fixed successfully
                              Run iobroker start to start ioBroker again!
                          pi@raspberrypi:~ $ iob restart
                            @sr277
                            iobroker status
                              pi@raspberrypi:~ $ iobroker status
                               Objects database error: read ECONNRESET
                              0 var di'it;
                                @sr277
                                Keine Ahnung.
                                iob update
                                funktioniert vermutlich auch nicht?
                                  Ne das gleiche. 😞
                                  pi@raspberrypi:~ $ iob update
                                  0 var di'it;
                                    @sr277
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.alexa2
                                    sudo -H -u iobroker npm install iobroker.iot
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.alexa2
                                      npm WARN old lockfile
                                      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                      npm WARN old lockfile This is a one-time fix-up, please be patient...
                                      added 12 packages, removed 121 packages, and changed 31 packages in 1m
                                      137 packages are looking for funding
                                        run `npm fund` for details
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.iot
                                      added 2 packages, removed 1 package, and changed 1 package in 13s
                                      138 packages are looking for funding
                                      Blöde Frage: Wie bekomme ich beim nächsten Befehl das "/opt/iobroker $" wieder weg?
                                        @sr277
                                        iob status
                                          pi@raspberrypi:/opt/iobroker $ iob status
                                           States database error: connect ECONNREFUSED 127.0.0.1:9000
                                           redis get system.host.raspberrypi.alive, error - Connection is closed.
                                           redis get system.host.raspberrypi.plugins.sentry.enabled, error - Connection is closed.
                                          0 var di'it;
                                            Homoran Global Moderator Administrators @SR277 last edited by
                                            @sr277 sagte in Iobroker startet nicht mehr:
                                            warum?
                                            da bist du richtig!
                                            1607
