    4. Installation
    5. Nach Restore wird der VIS Adapter nicht gestartet gelöst
      hansmeier last edited by hansmeier
      Hallo ! Ich bräuchte mal eure Unterstützung beim Umzug vom RPi4 in einen Proxmox Container.
      Nach dem Restore meines Backups wird der VIS Adapter als einziger nicht installiert.
      Es kommt zu einer Fehleraussage:
      Zeit
      info
      Nachricht
      host.ioBrokerUbuntu2204
      2023-01-19 13:48:44.901	error	Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      2023-01-19 13:48:43.901	info	iobroker npm-install: exit 25
      2023-01-19 13:48:42.889	error	iobroker npm-install: host.ioBrokerUbuntu2204 Cannot install iobroker.vis@1.4.15: 6
      vis.0
      2023-01-19 13:48:42.301	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      vis.0
      2023-01-19 13:48:42.301	info	terminating
      vis.0
      2023-01-19 13:48:41.798	error	Not exists
      vis.0
      2023-01-19 13:48:41.798	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
      vis.0
      2023-01-19 13:48:41.797	error	unhandled promise rejection: Not exists
      vis.0
      2023-01-19 13:48:41.797	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      vis.0
      2023-01-19 13:48:41.710	info	vis license is OK.
      vis.0
      2023-01-19 13:48:41.617	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.23
      2023-01-19 13:48:38.862	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
      2023-01-19 13:48:38.862	info	iobroker npm-install: NPM version: 8.19.3
      2023-01-19 13:48:37.871	info	iobroker install vis@1.4.15 using installedVersion
      2023-01-19 13:48:37.871	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
      2023-01-19 13:48:36.871	info	iobroker npm-install: exit 25
      2023-01-19 13:48:35.859	error	iobroker npm-install: host.ioBrokerUbuntu2204 Cannot install iobroker.vis@1.4.15: 6
      vis.0
      2023-01-19 13:48:35.275	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      vis.0
      2023-01-19 13:48:35.274	info	terminating
      vis.0
      2023-01-19 13:48:34.773	error	Not exists
      vis.0
      2023-01-19 13:48:34.773	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (node:internal/timers:468:21)
      vis.0
      2023-01-19 13:48:34.772	error	unhandled promise rejection: Not exists
      vis.0
      2023-01-19 13:48:34.771	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      vis.0
      2023-01-19 13:48:34.684	info	vis license is OK.
      vis.0
      2023-01-19 13:48:34.595	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.23
      host.i
      Adapter und Instanzen sehen so aus:
      root@ioBrokerUbuntu2204:~#  iobroker update -1
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.5.10   , installed 2.5.10
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "denon"        : 1.13.4   , installed 1.13.4
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "shelly"       : 6.0.0    , installed 6.2.4
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "tankerkoenig" : 3.1.0    , installed 2.1.1  [Updatable]
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      root@ioBrokerUbuntu2204:~# iobroker list adapters
      system.adapter.admin                   : admin          - v6.3.5
      system.adapter.alexa2                  : alexa2         - v3.23.2
      system.adapter.backitup                : backitup       - v2.5.10
      system.adapter.broadlink2              : broadlink2     - v2.1.5
      system.adapter.chromecast              : chromecast     - v2.3.1
      system.adapter.cloud                   : cloud          - v4.3.0
      system.adapter.deconz                  : deconz         - v1.3.21
      system.adapter.denon                   : denon          - v1.13.4
      system.adapter.device-reminder         : device-reminder - v1.2.9
      system.adapter.discovery               : discovery      - v3.1.0
      system.adapter.dwd                     : dwd            - v2.8.3
      system.adapter.echarts                 : echarts        - v1.0.12
      system.adapter.firetv                  : firetv         - v1.0.0
      system.adapter.flot                    : flot           - v1.11.0
      system.adapter.fritzbox                : fritzbox       - v0.2.1
      system.adapter.fullybrowser            : fullybrowser   - v2.1.2
      system.adapter.harmony                 : harmony        - v1.2.2
      system.adapter.history                 : history        - v2.2.4
      system.adapter.hue                     : hue            - v3.7.1
      system.adapter.ical                    : ical           - v1.13.2
      system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
      system.adapter.icons-icons8            : icons-icons8   - v0.0.1
      system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
      system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
      system.adapter.influxdb                : influxdb       - v3.2.0
      system.adapter.info                    : info           - v1.9.19
      system.adapter.javascript              : javascript     - v6.1.4
      system.adapter.mihome                  : mihome         - v1.4.0
      system.adapter.mqtt                    : mqtt           - v4.0.7
      system.adapter.nut                     : nut            - v1.1.3
      system.adapter.openweathermap          : openweathermap - v0.3.3
      system.adapter.paw                     : paw            - v0.3.2
      system.adapter.ping                    : ping           - v1.5.3
      system.adapter.reolink                 : reolink        - v0.1.1
      system.adapter.rpi2                    : rpi2           - v1.3.2
      system.adapter.samsung                 : samsung        - v0.5.11
      system.adapter.scenes                  : scenes         - v2.3.9
      system.adapter.shelly                  : shelly         - v6.2.4
      system.adapter.simple-api              : simple-api     - v2.7.2
      system.adapter.smartmeter              : smartmeter     - v3.3.4
      system.adapter.socketio                : socketio       - v4.2.0
      system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
      system.adapter.telegram                : telegram       - v1.15.2
      system.adapter.tr-064                  : tr-064         - v4.2.17
      system.adapter.trashschedule           : trashschedule  - v2.0.3
      system.adapter.upnp                    : upnp           - v1.0.21
      system.adapter.vis                     : vis            - v1.4.15
      system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.3.0
      system.adapter.vis-icontwo             : vis-icontwo    - v0.90.0
      system.adapter.vis-inventwo            : vis-inventwo   - v3.3.1
      system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
      system.adapter.vis-metro               : vis-metro      - v1.2.0
      system.adapter.vis-players             : vis-players    - v0.1.6
      system.adapter.vis-plumb               : vis-plumb      - v1.0.2
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
      system.adapter.vis-weather             : vis-weather    - v2.5.6
      system.adapter.weatherunderground      : weatherunderground - v3.1.6
      system.adapter.web                     : web            - v4.3.0
      system.adapter.yahka                   : yahka          - v0.13.1
      system.adapter.yeelight-2              : yeelight-2     - v1.1.2
      system.adapter.yr                      : yr             - v5.3.0
      root@ioBrokerUbuntu2204:~#  iobroker list instances
      + system.adapter.admin.0                  : admin                 : ioBrokerUbuntu2204                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.1                 : alexa2                : ioBrokerUbuntu2204                       - disabled
      + system.adapter.backitup.0               : backitup              : ioBrokerUbuntu2204                       -  enabled
        system.adapter.broadlink2.0             : broadlink2            : ioBrokerUbuntu2204                       - disabled
        system.adapter.cloud.0                  : cloud                 : ioBrokerUbuntu2204                       - disabled
        system.adapter.deconz.0                 : deconz                : ioBrokerUbuntu2204                       - disabled, port: 80
        system.adapter.denon.0                  : denon                 : ioBrokerUbuntu2204                       - disabled
        system.adapter.device-reminder.0        : device-reminder       : ioBrokerUbuntu2204                       - disabled
        system.adapter.discovery.0              : discovery             : ioBrokerUbuntu2204                       - disabled
        system.adapter.dwd.0                    : dwd                   : ioBrokerUbuntu2204                       - disabled
        system.adapter.echarts.0                : echarts               : ioBrokerUbuntu2204                       - disabled
        system.adapter.firetv.0                 : firetv                : ioBrokerUbuntu2204                       - disabled
        system.adapter.flot.0                   : flot                  : ioBrokerUbuntu2204                       - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : ioBrokerUbuntu2204                       - disabled
        system.adapter.harmony.0                : harmony               : ioBrokerUbuntu2204                       - disabled
        system.adapter.history.0                : history               : ioBrokerUbuntu2204                       - disabled
        system.adapter.hue.0                    : hue                   : ioBrokerUbuntu2204                       - disabled, port: 80
        system.adapter.ical.0                   : ical                  : ioBrokerUbuntu2204                       - disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBrokerUbuntu2204                       - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBrokerUbuntu2204                       - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBrokerUbuntu2204                       - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBrokerUbuntu2204                       - disabled
        system.adapter.influxdb.0               : influxdb              : ioBrokerUbuntu2204                       - disabled, port: 8086
        system.adapter.info.0                   : info                  : ioBrokerUbuntu2204                       - disabled
        system.adapter.javascript.0             : javascript            : ioBrokerUbuntu2204                       - disabled
        system.adapter.mihome.0                 : mihome                : ioBrokerUbuntu2204                       - disabled, port: 9898, bind: 0.0.0.0
        system.adapter.mqtt.0                   : mqtt                  : ioBrokerUbuntu2204                       - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : ioBrokerUbuntu2204                       - disabled
        system.adapter.ping.0                   : ping                  : ioBrokerUbuntu2204                       - disabled
        system.adapter.reolink.0                : reolink               : ioBrokerUbuntu2204                       - disabled
        system.adapter.rpi2.0                   : rpi2                  : ioBrokerUbuntu2204                       - disabled
        system.adapter.samsung.0                : samsung               : ioBrokerUbuntu2204                       - disabled
        system.adapter.scenes.0                 : scenes                : ioBrokerUbuntu2204                       - disabled
        system.adapter.shelly.0                 : shelly                : ioBrokerUbuntu2204                       - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : ioBrokerUbuntu2204                       - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : ioBrokerUbuntu2204                       - disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : ioBrokerUbuntu2204                       - disabled, port: 8084, bind: 192.168.178.92, run as: admin
        system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerUbuntu2204                       - disabled
        system.adapter.telegram.0               : telegram              : ioBrokerUbuntu2204                       - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : ioBrokerUbuntu2204                       - disabled
        system.adapter.trashschedule.0          : trashschedule         : ioBrokerUbuntu2204                       - disabled
        system.adapter.upnp.0                   : upnp                  : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-players.0            : vis-players           : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBrokerUbuntu2204                       - disabled
        system.adapter.vis.0                    : vis                   : ioBrokerUbuntu2204                       - disabled
        system.adapter.web.0                    : web                   : ioBrokerUbuntu2204                       - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yeelight-2.0             : yeelight-2            : ioBrokerUbuntu2204                       - disabled
        system.adapter.yr.0                     : yr                    : ioBrokerUbuntu2204                       - disabled
      Ich konnte alle anderen Adapter starten, und habe auch mal händisch die fehlende VIS-Instanz hinzugefügt, aber starten läßt die sich leider nicht.
      Auf dem Host habe wahlweise Debian 11 oder Ubuntu 2204 installiert, der Fehler bleibt gleich.
      Auf meinem RPi 4 war die 32 Bit Version von Bullseye installiert.
      Ich vermute einen Versionen-Konflikt mit anderen Adaptern ?
      Was kann ich tun ?
      Danke für eure Unterstützung.
      Thomas Braun B 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @hansmeier last edited by
        @hansmeier sagte in Nach Backitup-Restore wird der VIS Adapter nicht gestartet:
        Auch im Container: NIE als root herumkaspern.
        Zu vis: Zuerst vis installieren, DANN erst das Backup einspielen.
          badsnoopy667 @hansmeier last edited by
          @hansmeier
          Hatte ich auch letztens. Entweder so machen wie @Thomas-Braun gesagt hat, oder folgendes probieren, das hat bei mir geholfen:
          iobroker upgrade vis@1.4.0
          Damit installierst Du die alte Version von Vis, die geht dann wieder und danach kannst Du VIS über den Admin Adapter wieder auf die aktuelle Version upgraden.
            Vielen Dank euch beiden.
            Habe die Snapshot Funktion von Proxmox genutzt und schnell noch mal alles neu installiert. Zunächst WEB Adapter , dann VIS Adapter installiert und dann den Rest per Backup.
            Hat geholfen ! Danke.
              @hansmeier
              Hast du auch einen Standard-User angelegt?
              Wie gesagt: root shell ist verboten!
                hansmeier @Thomas Braun last edited by
                @thomas-braun Nein, habe ich noch nicht. Wie gehe ich da vor ?
                  Thomas Braun Most Active @hansmeier last edited by Thomas Braun
                  @hansmeier
                  Steht hier drin:
                  https://www.iobroker.net/#de/documentation/install/proxmox.md
                  @apollon77 Denkst du an den PR? 😄
