    4. HomeKit Fehler beim installieren
      w_tom last edited by
      leider ist es nicht möglich das HomeKit zu installieren.
      Folgende Fehlermeldung kommt:
      $ ./iobroker add homekit2
      npm install iobroker.homekit2 –production --prefix "/opt/iobroker" (System call)
      In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
      #include <dns_sd.h>^
      compilation terminated.
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      gyp
      ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2gyp
      ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      gyp
      ERR! System Linux 4.9.24-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp
      ERR! cwd /opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdnsgyp ERR! node -v v4.8.3
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      npm
      ERR!
      Linux 4.9.24-v7+npm
      ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit2" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.3
      npm ERR! npm v2.15.11
      npm ERR! code ELIFECYCLE
      npm ERR! mdns@2.3.3 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm
      ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mdns package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs mdnsnpm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls mdns
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
      Was muss ich machen ???</dns_sd.h>
      • Dutchman
        @w_tom:
        gyp
        ERR! build error
        gyp
        gyp
        gyp ERR! not ok
        npm
        ERR!
        Linux 4.9.24-v7+npm
        npm ERR!
        npm
        npm ERR!
        Was muss ich machen ???</dns_sd.h> `
        Homekit wurde schon ne zeit nicht weiterentwikkelt, warum nicht Yahka ?
        ~Dutch
