    4. Einbindung von Geräten
    5. Smartmeter mit Hitchi und Norax 3D+
    • Kay Schwass
      Kay Schwass last edited by wendy2702
      IOBroker IOBroker
      Hardwaresystem: NUC
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Node-Version: 16.19.0
      Nodejs-Version: 00.00.00
      NPM-Version: 8.19.3
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Kein
      Mein Hichi TTL - IR Lesekopf bring nach der Eingabe des PIN am Norax 3D+ nur noch folgede Fehler .
      Vor der Eingabe hat alles normal funktioniert.
      smartmeter.0
      2023-02-08 18:43:01.614	warn	No or too long answer from Serial Device after last request.
      smartmeter.0
      2023-02-08 18:43:01.614	debug	Error: No or too long answer from Serial Device after last request.
      smartmeter.0
      2023-02-08 18:43:01.613	debug	MESSAGE TIMEOUT TRIGGERED
      smartmeter.0
      2023-02-08 18:43:01.611	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b00000000000000" -> null
      smartmeter.0
      2023-02-08 18:43:01.611	debug	ADD NEW DATA (233 + NEW 1)
      smartmeter.0
      2023-02-08 18:43:01.602	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b000000000000" -> null
      smartmeter.0
      2023-02-08 18:43:01.601	debug	ADD NEW DATA (232 + NEW 1)
      smartmeter.0
      2023-02-08 18:43:01.599	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b0000000000" -> null
      smartmeter.0
      2023-02-08 18:43:01.599	debug	ADD NEW DATA (231 + NEW 1)
      smartmeter.0
      2023-02-08 18:43:01.594	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b00000000" -> null
      smartmeter.0
      2023-02-08 18:43:01.594	debug	ADD NEW DATA (230 + NEW 1)
      smartmeter.0
      2023-02-08 18:43:01.583	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b000000" -> null
      smartmeter.0
      2023-02-08 18:43:01.583	debug	ADD NEW DATA (229 + NEW 1)
      smartmeter.0
      2023-02-08 18:43:01.578	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b0000" -> null
      usw...
      MOD EDIT: LOG IN CODE TAGS GESETZT </>
        Homoran Global Moderator Administrators @Kay Schwass last edited by
        @kay-schwass wie sind die Einstellungen?
        Kay Schwass 2 Replies Last reply Reply Quote 0
        • Kay Schwass
          Kay Schwass @Homoran last edited by
          • Kay Schwass
            @homoran Hallo, wie geschrieben - Vor Eingabe des PIN am Norax hat es noch funktioniert.
              @kay-schwass sagte in Smartmeter mit Hitchi und Norax 3D+:
              hängt jetzt am USB?
              Kay Schwass 1 Reply Last reply Reply Quote 0
              • wendy2702
                wendy2702 last edited by
                Lesekopf nicht richtig positioniert?
                Abfrageintervall zu kurz für den erweiterten Datensatz?
                Erweiterung nochmal deaktiviert und geschaut ob es dann wieder geht? Wenn ja unterstütz der Adapter das eventuell noch nicht
                optische Schnittstelle unterstützt SML Protokoll, an das FNN Lastenheft BZ angepasst
                Vielleicht kann der Adapter Entwickler @apollon77 da etwas zu sagen
                • Kay Schwass
                  @homoran Ja, am FTDI Adapter
                  • apollon77
                    apollon77 @wendy2702 last edited by
                    @wendy2702 sagte in Smartmeter mit Hitchi und Norax 3D+:
                    Nein, wenn der serielle Timeout ... 2s ist halt kurz ... überleg wieviele Zeichen da kommen und die baudrate. Setz auf 20s und schau was passiert und wie lange es dauert.
                    Es ist ja auch so ... Wenn er liesst dann liesst er. Wenn er aber zb die ersten 10 byte der nachricht verpasst hat dann muss er warten bis die vollständig gesendet wurde und dann die nächste kommt und die fertig ist. Also Faktisch muss die serielle wartezeit 2xsendezeit plus die Pause zwischen den nachrichten lang sein
                    • wendy2702
                      wendy2702 @apollon77 last edited by
                      @apollon77 Nur um das klar zu stellen.
                      Ich hab das Problem nicht. Das hat @Kay-Schwass
                      Kay Schwass 1 Reply Last reply Reply Quote 1
                      • Kay Schwass
                        Kay Schwass @wendy2702 last edited by
                        @wendy2702 Heute morgen geht es 🙂
                        Wahrscheinlich war es wohl die Wartezeit, ich habe Sie auf 10sec korrigiert.
                        Danke !
                          @kay-schwass das würde passen, da nach der PIN Eingabe ja das lange Datentelegramm kommt. Das benötigt entsprechend mehr Zeit als vorher das reduzierte Datentelegramm.
                          hichi ttl - ir lesekopf no or too long answer smartmeter hichi norax 3d+
                          464
