    4. (gelöst) Zigbee kein pairing mehr
    • kBrausew
      kBrausew last edited by kBrausew
      Seit heute kann ich keine neuen Geräte mehr anlernen... mittags noch zwei angelernt ... abends spinnt ein Switch, hat sich nicht mehr anlernen lassen. Drei weitere geholt, alle samt ohne Erfolg 😞
      Start:
      2023-02-08 23:12:57.868 - info: zigbee.0 (331) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
      2023-02-08 23:12:57.878 - info: zigbee.0 (331) Unable to disable LED, unsupported function.
      2023-02-08 23:12:57.895 - info: zigbee.0 (331) --> transmitPower : high
      2023-02-08 23:12:57.932 - info: zigbee.0 (331) Currently 26 devices are joined:
      2023-02-08 23:12:58.026 - info: zigbee.0 (331) 0x7cb03eaa0a094d4d (addr 33434): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.034 - info: zigbee.0 (331) 0x7cb03eaa0a09abb0 (addr 9919): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.036 - info: zigbee.0 (331) 0xd0cf5efffe475d62 (addr 19612): SZ-SRN12N - SmartThings Smart siren (Router)
      2023-02-08 23:12:58.038 - info: zigbee.0 (331) 0x00158d00077da93c (addr 50393): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
      2023-02-08 23:12:58.040 - info: zigbee.0 (331) 0x00124b002265b7a8 (addr 31930): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
      2023-02-08 23:12:58.042 - info: zigbee.0 (331) 0x00158d000534d617 (addr 20466): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
      2023-02-08 23:12:58.050 - info: zigbee.0 (331) 0xec1bbdfffea030c8 (addr 3371): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
      2023-02-08 23:12:58.052 - info: zigbee.0 (331) 0x7cb03eaa00b04827 (addr 13714): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.054 - info: zigbee.0 (331) 0x7cb03eaa0a09293e (addr 33305): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.055 - info: zigbee.0 (331) 0x7cb03eaa0a0a2f31 (addr 65187): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.057 - info: zigbee.0 (331) 0x7cb03eaa0a0a8630 (addr 56572): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.059 - info: zigbee.0 (331) 0x7cb03eaa0a09ea67 (addr 50044): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.060 - info: zigbee.0 (331) 0x7cb03eaa0a09565d (addr 15753): AB3257001NJ - OSRAM Smart+ plug (Router)
      2023-02-08 23:12:58.062 - info: zigbee.0 (331) 0x086bd7fffe5b710e (addr 58264): LXN59-2S7LX1.0 - Nue / 3A Smart light relay - 2 gang (Router)
      2023-02-08 23:12:58.065 - info: zigbee.0 (331) 0x001788010649ed53 (addr 29112): 9290019758 - Philips Hue motion outdoor sensor (EndDevice)
      2023-02-08 23:12:58.068 - info: zigbee.0 (331) 0x000d6f000e1b7766 (addr 34211): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
      2023-02-08 23:12:58.070 - info: zigbee.0 (331) 0x00158d0005373f21 (addr 62793): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
      2023-02-08 23:12:58.072 - info: zigbee.0 (331) 0x842e14fffeef6110 (addr 59663): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
      2023-02-08 23:12:58.073 - info: zigbee.0 (331) 0xec1bbdfffea02abc (addr 8625): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
      2023-02-08 23:12:58.076 - info: zigbee.0 (331) 0x5c0272fffec3668b (addr 22711): SEA801-Zigbee/SEA802-Zigbee - Saswell Thermostatic radiator valve (EndDevice)
      2023-02-08 23:12:58.078 - info: zigbee.0 (331) 0x0017880108f5d071 (addr 31244): 324131092621 - Philips Hue dimmer switch (EndDevice)
      2023-02-08 23:12:58.081 - info: zigbee.0 (331) 0x540f57fffe838677 (addr 25969): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
      2023-02-08 23:12:58.082 - info: zigbee.0 (331) 0xec1bbdfffea025ad (addr 57090): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
      2023-02-08 23:12:58.085 - info: zigbee.0 (331) 0x000d6f000e1b76be (addr 3115): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
      2023-02-08 23:12:58.087 - info: zigbee.0 (331) 0x00124b0025120647 (addr 18071): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
      2023-02-08 23:12:58.088 - info: zigbee.0 (331) 0x00124b00250024eb (addr 30074): SNZB-01 - SONOFF Wireless button (EndDevice)
      2023-02-08 23:12:58.089 - info: zigbee.0 (331) Zigbee started
      2023-02-08 23:13:19.957 - warn: zigbee.0 (331) DeviceAvailability:Failed to ping 0x7cb03eaa0a0a8630 Plug 01
      2023-02-08 23:14:13.177 - info: zigbee.0 (331) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyS0"}]
      Dann pairing:
      2023-02-08 23:16:47.685 - info: zigbee.0 (331) Zigbee: allowing new devices to join.
      2023-02-08 23:18:19.021 - info: zigbee.0 (331) Zigbee: stop joining
      2023-02-08 23:21:47.393 - warn: zigbee.0 (331) DeviceAvailability:Failed to ping 0x7cb03eaa0a09abb0 Plug 01
      sonst nix mehr zu sehen und jederzeit reproduzierbar.
      Was habe ich schon gemacht:
      • Neustart RasPi
      • SoftReset: Instanz stoppen, Stick abziehen 30 sec, starten
      Alles ohne Erfolg bis jetzt
      Adapter: v1.8.10
      Hardware: Sonoff_Zigbee_3.0_USB_Dongle_Plus ( sollte der 'P' sein?)
      Einstellungen:
      Die Geräte funktionieren alle soweit, nur keine Neuen ...
      Nachtrag: Habe mal "State Cleanup" ausgeführt ganz am Anfang der Misere...
        Thomas Braun Most Active @kBrausew last edited by
        @kbrausew
        Firmware des Sticks ist steinalt. Bring die mal in die Jetztzeit.
        kBrausew 1 Reply Last reply Reply Quote 0
        • kBrausew
          kBrausew @Thomas Braun last edited by
          @thomas-braun sagte in Zigbee kein pairing mehr:
          Mach ich !!
          Hat ja aber nix damit zu tun das ich mittags noch anlernen konnte?
            @kbrausew
            Gerätepfad auf /dev/serial/by-id/wasauchimmer umstellen. Adapterneustart schaut wie im Log aus?
            • kBrausew
              @kbrausew
              wie erwartet, geht nicht: Bin im Docker-Container...
              Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_94978dabb593eb11b7a7194f3d98b6d1-if00-port0'"
              • kBrausew
                ich hätte noch den ConBee II ... soll ich den mal ausprobieren oder mach ich da noch mehr kaputt
                • Asgothian
                  Asgothian Developer @kBrausew last edited by Asgothian
                  @kbrausew sagte in Zigbee kein pairing mehr:
                  Ja
                  Bitte auf die Stable version vom Adapter zurück gehen und prüfen ob damit ein Anlernen möglich ist.
                  Mir ist keine Verbindung zwischen Firmware / Pfad zur Einbindung des Sticks und der Möglichkeit in den Pairing mode zu gehen bekannt. Auch der State Cleanup sollte diesen Effekt nicht erzeugen, da nur States gelöscht werden die nicht weiter "verbunden" sind.
                  Bekommst Du den Countdown wenn der Pairing mode gestartet wird ?
                  A.
                  • kBrausew
                    kBrausew @Asgothian last edited by
                    @asgothian sagte in Zigbee kein pairing mehr:
                    Ja
                    Kann ich erst heute abend...
                    War nur ein Tippfehler 😞 gestern Nacht, es ist die 1.8.10
                    A.
                    Ja, der Countdown wird angezeigt
                    • kBrausew
                      Hab dann doch mal meinen Sohn überzeugt den ConBee-Stick in die RasPi zu stecken 🙂
                      Log
                      2023-02-09 10:46:01.869 - info: zigbee.0 (319) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.3, js-controller: 4.0.23
                      2023-02-09 10:46:02.009 - info: zigbee.0 (319) delete old Backup files. keep only last 10
                      2023-02-09 10:46:02.011 - info: zigbee.0 (319) Starting Zigbee npm ...
                      2023-02-09 10:46:02.707 - info: zigbee.0 (319) Installed Version: iobroker.zigbee@1.8.10
                      2023-02-09 10:46:02.771 - info: zigbee.0 (319) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
                      2023-02-09 10:46:14.916 - info: zigbee.0 (319) Unable to disable LED, unsupported function.
                      2023-02-09 10:46:14.948 - info: zigbee.0 (319) --> transmitPower : high
                      2023-02-09 10:46:15.156 - info: zigbee.0 (319) Unable to set transmit power, unsupported function.
                      2023-02-09 10:46:15.168 - info: zigbee.0 (319) Currently 26 devices are joined:
                      2023-02-09 10:46:15.304 - info: zigbee.0 (319) 0x7cb03eaa0a094d4d (addr 33434): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.311 - info: zigbee.0 (319) 0x7cb03eaa0a09abb0 (addr 9919): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.313 - info: zigbee.0 (319) 0xd0cf5efffe475d62 (addr 19612): SZ-SRN12N - SmartThings Smart siren (Router)
                      2023-02-09 10:46:15.315 - info: zigbee.0 (319) 0x00158d00077da93c (addr 50393): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                      2023-02-09 10:46:15.317 - info: zigbee.0 (319) 0x00124b002265b7a8 (addr 31930): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
                      2023-02-09 10:46:15.319 - info: zigbee.0 (319) 0x00158d000534d617 (addr 20466): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
                      2023-02-09 10:46:15.321 - info: zigbee.0 (319) 0xec1bbdfffea030c8 (addr 3371): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
                      2023-02-09 10:46:15.323 - info: zigbee.0 (319) 0x7cb03eaa00b04827 (addr 13714): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.325 - info: zigbee.0 (319) 0x7cb03eaa0a09293e (addr 33305): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.327 - info: zigbee.0 (319) 0x7cb03eaa0a0a2f31 (addr 65187): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.329 - info: zigbee.0 (319) 0x7cb03eaa0a0a8630 (addr 56572): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.331 - info: zigbee.0 (319) 0x7cb03eaa0a09ea67 (addr 50044): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.332 - info: zigbee.0 (319) 0x7cb03eaa0a09565d (addr 15753): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2023-02-09 10:46:15.334 - info: zigbee.0 (319) 0x086bd7fffe5b710e (addr 58264): LXN59-2S7LX1.0 - Nue / 3A Smart light relay - 2 gang (Router)
                      2023-02-09 10:46:15.337 - info: zigbee.0 (319) 0x001788010649ed53 (addr 29112): 9290019758 - Philips Hue motion outdoor sensor (EndDevice)
                      2023-02-09 10:46:15.340 - info: zigbee.0 (319) 0x000d6f000e1b7766 (addr 34211): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                      2023-02-09 10:46:15.343 - info: zigbee.0 (319) 0x00158d0005373f21 (addr 62793): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
                      2023-02-09 10:46:15.344 - info: zigbee.0 (319) 0x842e14fffeef6110 (addr 59663): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
                      2023-02-09 10:46:15.346 - info: zigbee.0 (319) 0xec1bbdfffea02abc (addr 8625): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
                      2023-02-09 10:46:15.349 - info: zigbee.0 (319) 0x5c0272fffec3668b (addr 22711): SEA801-Zigbee/SEA802-Zigbee - Saswell Thermostatic radiator valve (EndDevice)
                      2023-02-09 10:46:15.351 - info: zigbee.0 (319) 0x0017880108f5d071 (addr 31244): 324131092621 - Philips Hue dimmer switch (EndDevice)
                      2023-02-09 10:46:15.355 - info: zigbee.0 (319) 0x540f57fffe838677 (addr 25969): GS361A-H04 - Siterwell Radiator valve with thermostat (EndDevice)
                      2023-02-09 10:46:15.356 - info: zigbee.0 (319) 0xec1bbdfffea025ad (addr 57090): HG06336 - Lidl Silvercrest smart window and door sensor (EndDevice)
                      2023-02-09 10:46:15.358 - info: zigbee.0 (319) 0x000d6f000e1b76be (addr 3115): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                      2023-02-09 10:46:15.360 - info: zigbee.0 (319) 0x00124b0025120647 (addr 18071): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                      2023-02-09 10:46:15.362 - info: zigbee.0 (319) 0x00124b00250024eb (addr 30074): SNZB-01 - SONOFF Wireless button (EndDevice)
                      2023-02-09 10:46:15.363 - info: zigbee.0 (319) Zigbee started
                      Dann nach kurzer Zeit
                      2023-02-09 10:47:04.423 - info: zigbee.0 (319) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"}]
                      2023-02-09 10:48:17.746 - warn: zigbee.0 (319) DeviceAvailability:Failed to ping 0x086bd7fffe5b710e LXN59-2S7LX1.0
                      2023-02-09 10:48:17.748 - warn: zigbee.0 (319) DeviceAvailability:Failed to ping 0x7cb03eaa0a09abb0 Plug 01
                      2023-02-09 10:48:17.749 - warn: zigbee.0 (319) DeviceAvailability:Failed to ping 0x7cb03eaa00b04827 Plug 01
                      2023-02-09 10:48:17.750 - warn: zigbee.0 (319) DeviceAvailability:Failed to ping 0x7cb03eaa0a09293e Plug 01
                      2023-02-09 10:50:15.807 - info: zigbee.0 (319) List of port: [{"path":"/dev/ttyUSB0"},{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"}]
                      2023-02-09 10:52:32.516 - warn: zigbee.0 (319) Device query for '0x7cb03eaa00b04827' blocked
                      2023-02-09 10:52:33.685 - warn: zigbee.0 (319) Device query for '0x7cb03eaa00b04827' blocked
                      2023-02-09 10:52:44.325 - warn: zigbee.0 (319) Failed to read state '"power_on_behavior"'of '0x7cb03eaa0a09293e' after query with '{"code":134}'
                      2023-02-09 10:52:44.768 - warn: zigbee.0 (319) Device query for '0x7cb03eaa0a09293e' blocked
                      2023-02-09 10:52:45.817 - warn: zigbee.0 (319) Device query for '0x7cb03eaa0a09293e' blocked
                      2023-02-09 10:52:55.878 - warn: zigbee.0 (319) Device query for '0x7cb03eaa0a09abb0' blocked
                      2023-02-09 10:53:31.797 - warn: zigbee.0 (319) Failed to read state '"state"'of '0x7cb03eaa00b04827' after query with '{}'
                      2023-02-09 10:53:36.040 - warn: zigbee.0 (319) Device query for '0x00158d00077da93c' blocked
                      2023-02-09 10:53:55.798 - warn: zigbee.0 (319) Failed to read state '"state"'of '0x7cb03eaa0a09abb0' after query with '{}'
                      2023-02-09 10:53:57.728 - warn: zigbee.0 (319) Device query for '0x7cb03eaa00b04827' blocked
                      2023-02-09 10:54:00.257 - warn: zigbee.0 (319) Device query for '0x7cb03eaa0a09abb0' blocked
                      2023-02-09 10:54:31.800 - warn: zigbee.0 (319) Failed to read state '"on_time"'of '0x7cb03eaa00b04827' after query with '{}'
                      2023-02-09 10:54:55.807 - warn: zigbee.0 (319) Failed to read state '"on_time"'of '0x7cb03eaa0a09abb0' after query with '{}'
                      2023-02-09 10:55:31.814 - warn: zigbee.0 (319) Failed to read state '"off_wait_time"'of '0x7cb03eaa00b04827' after query with '{}'
                      2023-02-09 10:55:55.816 - warn: zigbee.0 (319) Failed to read state '"off_wait_time"'of '0x7cb03eaa0a09abb0' after query with '{}'
                      2023-02-09 10:56:31.824 - warn: zigbee.0 (319) Failed to read state '"power_on_behavior"'of '0x7cb03eaa00b04827' after query with '{}'
                      2023-02-09 10:56:55.826 - warn: zigbee.0 (319) Failed to read state '"power_on_behavior"'of '0x7cb03eaa0a09abb0' after query with '{}'
                      ... pairing geht leider nicht Remote 😉 heute Abend geht's weiter...
                      • Asgothian
                        Wenn du Glück hast ist nichts passiert. Wenn Du Pech hast haben einige Geräte die Änderung des Koordinators übernommen, andere Nicht. Dann geht mit dem Conbee das meiste nicht, und mit dem Sonoff dann auch nicht.
                        Ich hatte das "Ja" gemeint das du damit mehr kaputt machen kannst. Leider waren Frage und Antwort da uneindeutig.
                        War nur ein Tippfehler gestern Nacht, es ist die 1.8.10
                        von Github oder die letzte Stable aus dem ioBroker repository ?
                        Je nach dem welche du hast macht es Sinn die jeweils andere zu installieren und nocheinmal zu probieren.
                        A.
                        kBrausew 1 Reply Last reply Reply Quote 1
                        • kBrausew
                          kBrausew @Asgothian last edited by kBrausew
                          ... un-uneindeutig ist meine Sprache und hat mir schon so manche Mehrarbeit eingebracht ... hier scheint es sich in grenzen zu halten, aus der ferne würde ich behaupten das sich nur zwei sehr gut zugängliche Devices nicht mehr verbinden 😉 ... heute Abenden kann ich mehr sagen
                          Ein Gutes hat es mal schon: Die die Gehen haben einen deutlich höheren Link
                          wenn's Pairing heute Abend mit dem ConBee II nicht geht probiere ich das aus und scheibs
                          • kBrausew
                            ... einer hat gepaired ... leider gehen meine OSRAM-Plugs immer alle gleichzeitig aus in regelmäßigen abständen ...
                            muss aber noch besser analysieren was ich hier Posten soll/kann
                            • Asgothian
                              Das ist ein Zeichen dafür das die Plugs Probleme haben. Du kannst versuchen sie neu zu fairen - manchmal hilft das. Meistens leider nicht. Ich hab inzwischen alle Osram Plugs beseitigt.
                              A.
                              • kBrausew
                                @asgothian
                                sind die OSRAM mini Switch genauso "gut" wie die Plugs?
                                • Asgothian
                                  @kbrausew kann ich nicht sagen - davon hatte ich nie welche
                                  • kBrausew
                                    So, erst mal fertig: 2 von 8 Osram-Plug definitiv defekt. Zwei weitere sollte man beobachten aber wahrscheinlich gehen die demnächst über den Jordan 😞
                                    Von vier Mini-Switch gehen zwei nicht mehr, von meinen Ersatz aus der Vorratskammer lassen sich zwei nicht Pairen.
                                    Und jetzt kommts: Alle die nicht gehen sind die Weißen, Graue gehen problemlos - Zufall?, ich hoffe es 😉
                                    Philips Hue Dimmer switch lässt sich pairen, geht aber dann nicht... beim der Übernahme vor einer Woche vom deConz nach ioB-ZA ging er definitiv... bis gestern ?? (Ja, Reset auch gemacht...)
                                    Ich bin jetzt mal durch (in jeglicher Hinsicht 😉 )
                                    Bedanke mich für eure Unterstützung recht herzlich uns schließe mit "gelöst"
                                    Alles was bleibt: Eine Empfehlumg für Plug und Switch am ioB-ZA - Das wäre mehr als nett.
                                    • kBrausew
                                      BTW: Ich bleib bei ConBee II Stick... wenn die Linkwerte stimmen ist das um Faktor 2 besser als der Sonoff; aber wer weiß ?
                                      800
