    4. Problem beim Update von Adaptern/Modulen/Controller
    • corny456
      corny456 last edited by
      Guten morgen zusammen,
      ich hab seit geraumer Zeit das Problem das ich weder irgendwelche Adapter noch den JS-Controller aktualisiert bekomme.
      Führe ich ein Update durch so läuft dieses ohne erkennbare Probleme durch und meldet auch keinen Fehler nur aktualisiert er besagtes Paket nicht.
      root@automation-pi ~ # iob upgrade telegram -y
      Update telegram from @1.14.1 to @1.15.2
      host.automation-pi Adapter "system.adapter.telegram.0" is stopped.
      NPM version: 8.19.3
      Installing iobroker.telegram@1.15.2... (System call)
      upload [52] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
      upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
      upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_react_index_js.44097ea5.chunk.js.map custom/static/js/node_modules_react_index_js.44097ea5.chunk.js.map application/json
      upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.7d6c2204.chunk.js.map custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.7d6c2204.chunk.js.map application/json
      upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js application/javascript
      upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js.map custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.1908e054.chunk.js.map application/json
      upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js application/javascript
      upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js.map custom/static/js/vendors-node_modules_mui_material_AccordionDetails_index_js-node_modules_mui_material_Accordi-290e0d.34d0c251.chunk.js.map application/json
      upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js application/javascript
      upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Button_index_js-node_modules_mui_material_DialogActions_ind-4e43be.983b7c90.chunk.js.map application/json
      upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js application/javascript
      upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.a78a67bc.chunk.js.map application/json
      upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js application/javascript
      upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js.map custom/static/js/vendors-node_modules_mui_material_utils_createSvgIcon_js.16e151f1.chunk.js.map application/json
      upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js application/javascript
      upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.7ee8cc9f.chunk.js.map application/json
      upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js application/javascript
      upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.8d322beb.chunk.js.map application/json
      upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js application/javascript
      upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.97b12c54.chunk.js.map application/json
      upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonConfig.json jsonConfig.json application/json
      upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
      upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
      upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
      host.automation-pi Adapter "system.adapter.telegram.0" is started
      Erst wenn ich das ganze mit --debug ausführe schmeißt er eine Reihe Error auf die ich leider keinen Rat weis.
      root@automation-pi ~ # iob upgrade telegram -y --debug
      NPM version: 8.19.3
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/serialport
      npm ERR! command failed
      npm ERR! command sh -c -- node-gyp rebuild
      npm ERR! make: Entering directory '/opt/iobroker/node_modules/serialport/build'
      npm ERR!   CXX(target) Release/obj.target/serialport/src/serialport.o
      npm ERR! make: Leaving directory '/opt/iobroker/node_modules/serialport/build'
      npm ERR! gyp info it worked if it ends with ok
      npm ERR! gyp info using node-gyp@9.1.0
      npm ERR! gyp info using node@16.19.0 | linux | arm
      npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
      npm ERR! gyp info spawn /usr/bin/python3
      npm ERR! gyp info spawn args [
      npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
      npm ERR! gyp info spawn args   'binding.gyp',
      npm ERR! gyp info spawn args   '-f',
      npm ERR! gyp info spawn args   'make',
      npm ERR! gyp info spawn args   '-I',
      npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/serialport/build/config.gypi',
      npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
      npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.19.0/include/node/common.gypi',
      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
      npm ERR! gyp info spawn args   '-Dvisibility=default',
      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.19.0',
      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.19.0/<(target_arch)/node.lib',
      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/serialport',
      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
      npm ERR! gyp info spawn args   '--depth=.',
      npm ERR! gyp info spawn args   '--no-parallel',
      npm ERR! gyp info spawn args   '--generator-output',
      npm ERR! gyp info spawn args   'build',
      npm ERR! gyp info spawn args   '-Goutput_dir=.'
      npm ERR! gyp info spawn args ]
      npm ERR! gyp info spawn make
      npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
      npm ERR!    v8::String::Utf8Value path(info[0]->ToString());
      npm ERR!                                                 ^
      npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.0/include/node/node.h:73,
      npm ERR!                  from ../../nan/nan.h:56,
      npm ERR!                  from ../src/./serialport.h:6,
      npm ERR!                  from ../src/serialport.cpp:1:
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3048:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
      npm ERR!    V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
      npm ERR!                                             ^~~~~~~~
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3048:44: note:   candidate expects 1 argument, 0 provided
      npm ERR! ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
      npm ERR!    v8::Local<v8::Object> options = info[1]->ToObject();
      npm ERR!                                                      ^
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3060:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’
      npm ERR!    V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
      npm ERR!                                             ^~~~~~~~
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3060:44: note:   candidate expects 1 argument, 0 provided
      npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
      npm ERR!        ^~~~~~~~~~~~~
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!    data->callback.Call(2, argv);
      npm ERR!                               ^
      npm ERR! In file included from ../src/./serialport.h:6,
      npm ERR! ../../nan/nan.h:1742:3: note: declared here
      npm ERR!    Call(int argc, v8::Local<v8::Value> argv[]) const {
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
      npm ERR!                                                      ^
      npm ERR!                                             ^~~~~~~~
      npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
      npm ERR!        ^~~~~~~~~~~~~~~
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!    data->callback.Call(1, argv);
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
      npm ERR!                                                      ^
      npm ERR!                                             ^~~~~~~~
      npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
      npm ERR!      results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
      npm ERR!        ^
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
      npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
      npm ERR!                                      ^~~
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3961:37: note:   candidate expects 3 arguments, 2 provided
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
      npm ERR!    V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
      npm ERR!                                      ^~~
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/v8.h:3964:37: note:   candidate expects 3 arguments, 2 provided
      npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
      npm ERR!      results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
      npm ERR!        ^
      npm ERR!                                      ^~~
      npm ERR!                                      ^~~
      npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
      npm ERR!      results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
      npm ERR!        ^
      npm ERR!                                      ^~~
      npm ERR!                                      ^~~
      npm ERR! ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
      npm ERR!        ^~~~~~~~~~~~~~~~~~~~
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
      npm ERR!      results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
      npm ERR!        ^
      npm ERR!                                      ^~~
      npm ERR!                                      ^~~
      npm ERR! ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm ERR!    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
      npm ERR! ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      npm ERR!                               ^
      npm ERR!    ^~~~
      npm ERR! ../src/serialport.cpp: At global scope:
      npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
      npm ERR!  SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
      npm ERR!                             ^
      npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
      npm ERR!  SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      npm ERR!                               ^
      npm ERR! ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
      npm ERR!    void init(v8::Handle<v8::Object> target) {
      npm ERR!                  ^~~~~~
      npm ERR! ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
      npm ERR! ../src/serialport.cpp:460:17: note: suggested alternative: ‘JobHandle’
      npm ERR!                  ^~~~~~
      npm ERR!                  JobHandle
      npm ERR! ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
      npm ERR!                                   ^
      npm ERR! ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
      npm ERR!                                     ^~~~~~
      npm ERR! ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
      npm ERR!                                     ^~~~~~
      npm ERR!                                     tzset
      npm ERR! In file included from ../../nan/nan.h:56,
      npm ERR! ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
      npm ERR!  NODE_MODULE(serialport, init);
      npm ERR!                          ^~~~
      npm ERR! /home/iobroker/.cache/node-gyp/16.19.0/include/node/node.h:887:36: note: in definition of macro ‘NODE_MODULE_X’
      npm ERR!        (node::addon_register_func) (regfunc),                          \
      npm ERR!                                     ^~~~~~~
      npm ERR! ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
      npm ERR! ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
      npm ERR!                          ^~~~
      npm ERR!                                     ^~~~~~~
      npm ERR! make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Error 1
      npm ERR! gyp ERR! build error
      npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
      npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)
      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
      npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)
      npm ERR! gyp ERR! System Linux 5.10.103-v7l+
      npm ERR! gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/serialport
      npm ERR! gyp ERR! node -v v16.19.0
      npm ERR! gyp ERR! node-gyp -v v9.1.0
      npm ERR! gyp ERR! not ok
      npm ERR!     /home/iobroker/.npm/_logs/2023-02-15T09_16_52_990Z-debug-0.log
      Egal welches Modul ich versuche zu aktualisieren scheint er immer ein Problem mit dem Serialport Modul zu haben. Ich erkenne aber nicht ob es an dem Modul liegt oder ob es eine Folgeerscheinung des eigentlichen Problems ist.
      iob fix Läuft ohne Fehler durch hilft aber nichts.
      Danke euch schon mal für die Hilfe.
      Systemdata
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Raspbian 10 (buster)
      Node-Version: v16.19.0
      Nodejs-Version: v16.19.0
      NPM-Version: 8.19.3
      Installationsart: Skript
      Image genutzt: Nein
        arteck Developer Most Active @corny456 last edited by
        @corny456 was sagt den
        iob diag
        corny456 1 Reply Last reply Reply Quote 1
        • corny456
          corny456 @arteck last edited by
          @arteck said in Problem beim Update von Adaptern/Modulen/Controller:
          iob diag
          diag sagt:
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Model		: Raspberry Pi 4 Model B Rev 1.1
          Architecture: 	armv7l
          Docker: 	false
          Virtualization: none
          Distributor ID:	Raspbian
          Description:	Raspbian GNU/Linux 10 (buster)
          Release:	10
          Codename:	buster
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           10:56:53 up 10:51,  2 users,  load average: 1.50, 1.40, 1.45
          CPU threads: 4
          *** Time and Time Zones ***
          Wed Feb 15 09:56:53 UTC 2023
          Wed Feb 15 10:56:53 CET 2023
          CET +0100
          Europe/Berlin
          *** User and Groups ***
          root
          /root
          root
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:           3.9G        1.8G        1.3G        175M        727M        1.9G
          Swap:          4.1G         67M        4.0G
          Total:         8.0G        1.9G        5.4G
                   3888 M total memory
                   1828 M used memory
                    375 M active memory
                   2032 M inactive memory
                   1333 M free memory
                     77 M buffer memory
                    649 M swap cache
                   4095 M total swap
                     67 M used swap
                   4028 M free swap
          *** FILESYSTEM ***
          /dev/root      ext4      110G   11G   95G  11% /
          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
          tmpfs          tmpfs     1.9G  980K  1.9G   1% /dev/shm
          tmpfs          tmpfs     1.9G  179M  1.8G  10% /run
          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
          tmpfs          tmpfs      10M     0   10M   0% /opt/iobroker/tmp
          /dev/sda1      vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     389M     0  389M   0% /run/user/0
          Messages in dmesg:
          Show mounted filesystems (real ones only):
          TARGET        SOURCE    FSTYPE OPTIONS
          /             /dev/sda2 ext4   rw,noatime
          |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          5.1G	/var/
          699M	/var/log
          264M	/var/cache
          259M	/var/cache/apt
          200M	/var/cache/apt/archives
          /opt/iobroker/backups:
          116M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          493M	/opt/iobroker/iobroker-data/
          179M	/opt/iobroker/iobroker-data/backup-objects
          144M	/opt/iobroker/iobroker-data/files
          48M	/opt/iobroker/iobroker-data/files/javascript.admin
          32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          79M	/opt/iobroker/iobroker-data/states.jsonl
          73M	/opt/iobroker/iobroker-data/objects.jsonl
          12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
          11M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.235e4edd.js.map
          7.5M	/opt/iobroker/iobroker-data/objects.json.migrated
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v16.19.0
          /usr/bin/node 		v16.19.0
          /usr/local/bin/npm 		8.19.3
          /usr/local/bin/npx 		8.19.3
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u2 500
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	4.0.23
          admin: 		6.2.23
          javascript: 	6.0.3
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @serialport/parser-byte-length@9.0.7 /opt/iobroker/node_modules/@serialport/parser-byte-length
          npm ERR! extraneous: @serialport/parser-cctalk@9.0.7 /opt/iobroker/node_modules/@serialport/parser-cctalk
          npm ERR! extraneous: @serialport/parser-delimiter@9.0.7 /opt/iobroker/node_modules/@serialport/parser-delimiter
          npm ERR! extraneous: @serialport/parser-readline@9.0.7 /opt/iobroker/node_modules/@serialport/parser-readline
          npm ERR! extraneous: @serialport/parser-ready@9.0.7 /opt/iobroker/node_modules/@serialport/parser-ready
          npm ERR! extraneous: @serialport/parser-regex@9.0.7 /opt/iobroker/node_modules/@serialport/parser-regex
          npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
          npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
          npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
          npm ERR! extraneous: ansi-bgblack@0.1.1 /opt/iobroker/node_modules/ansi-bgblack
          npm ERR! extraneous: ansi-bgblue@0.1.1 /opt/iobroker/node_modules/ansi-bgblue
          npm ERR! extraneous: ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/ansi-bgcyan
          npm ERR! extraneous: ansi-bggreen@0.1.1 /opt/iobroker/node_modules/ansi-bggreen
          npm ERR! extraneous: ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/ansi-bgmagenta
          npm ERR! extraneous: ansi-bgred@0.1.1 /opt/iobroker/node_modules/ansi-bgred
          npm ERR! extraneous: ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/ansi-bgwhite
          npm ERR! extraneous: ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/ansi-bgyellow
          npm ERR! extraneous: ansi-black@0.1.1 /opt/iobroker/node_modules/ansi-black
          npm ERR! extraneous: ansi-blue@0.1.1 /opt/iobroker/node_modules/ansi-blue
          npm ERR! extraneous: ansi-bold@0.1.1 /opt/iobroker/node_modules/ansi-bold
          npm ERR! extraneous: ansi-colors@0.2.0 /opt/iobroker/node_modules/ansi-colors
          npm ERR! extraneous: ansi-cyan@0.1.1 /opt/iobroker/node_modules/ansi-cyan
          npm ERR! extraneous: ansi-dim@0.1.1 /opt/iobroker/node_modules/ansi-dim
          npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/ansi-gray
          npm ERR! extraneous: ansi-green@0.1.1 /opt/iobroker/node_modules/ansi-green
          npm ERR! extraneous: ansi-grey@0.1.1 /opt/iobroker/node_modules/ansi-grey
          npm ERR! extraneous: ansi-hidden@0.1.1 /opt/iobroker/node_modules/ansi-hidden
          npm ERR! extraneous: ansi-inverse@0.1.1 /opt/iobroker/node_modules/ansi-inverse
          npm ERR! extraneous: ansi-italic@0.1.1 /opt/iobroker/node_modules/ansi-italic
          npm ERR! extraneous: ansi-magenta@0.1.1 /opt/iobroker/node_modules/ansi-magenta
          npm ERR! extraneous: ansi-red@0.1.1 /opt/iobroker/node_modules/ansi-red
          npm ERR! extraneous: ansi-reset@0.1.1 /opt/iobroker/node_modules/ansi-reset
          npm ERR! extraneous: ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/ansi-strikethrough
          npm ERR! extraneous: ansi-underline@0.1.1 /opt/iobroker/node_modules/ansi-underline
          npm ERR! extraneous: ansi-white@0.1.1 /opt/iobroker/node_modules/ansi-white
          npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/ansi-wrap
          npm ERR! extraneous: ansi-yellow@0.1.1 /opt/iobroker/node_modules/ansi-yellow
          npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/arr-flatten
          npm ERR! extraneous: arr-swap@1.0.1 /opt/iobroker/node_modules/arr-swap
          npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
          npm ERR! extraneous: async-retry@1.3.1 /opt/iobroker/node_modules/async-retry
          npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
          npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
          npm ERR! extraneous: buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/buffer-alloc-unsafe
          npm ERR! extraneous: buffer-alloc@1.2.0 /opt/iobroker/node_modules/buffer-alloc
          npm ERR! extraneous: buffer-fill@1.0.0 /opt/iobroker/node_modules/buffer-fill
          npm ERR! extraneous: button-events@1.0.2 /opt/iobroker/node_modules/button-events
          npm ERR! extraneous: choices-separator@2.0.0 /opt/iobroker/node_modules/choices-separator
          npm ERR! extraneous: clone-deep@1.0.0 /opt/iobroker/node_modules/clone-deep
          npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
          npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/collection-visit
          npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/commander
          npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
          npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/copy-descriptor
          npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decompress-response
          npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/define-property
          npm ERR! extraneous: engine.io-client@3.5.2 /opt/iobroker/node_modules/engine.io-client
          npm ERR! extraneous: engine.io-parser@2.2.1 /opt/iobroker/node_modules/engine.io-parser
          npm ERR! extraneous: engine.io@3.5.0 /opt/iobroker/node_modules/engine.io
          npm ERR! extraneous: epoll@2.0.10 /opt/iobroker/node_modules/epoll
          npm ERR! extraneous: error-symbol@0.1.0 /opt/iobroker/node_modules/error-symbol
          npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
          npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
          npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/for-in
          npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/for-own
          npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
          npm ERR! extraneous: info-symbol@0.1.0 /opt/iobroker/node_modules/info-symbol
          npm ERR! missing: iobroker.adguard@0.0.8, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.alarm@3.1.1, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.device-reminder@1.2.9, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.mobile@^1.0.1, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.modbus@5.0.5, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.signal-cmb@0.1.7, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.tankerkoenig@2.1.1, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.traccar@0.0.12, required by iobroker.inst@2.0.3
          npm ERR! missing: iobroker.vis-colorpicker@^1.2.0, required by iobroker.inst@2.0.3
          npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/is-accessor-descriptor
          npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/is-data-descriptor
          npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/is-descriptor
          npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
          npm ERR! extraneous: is-number@6.0.0 /opt/iobroker/node_modules/is-number
          npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/is-plain-object
          npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
          npm ERR! extraneous: isarray@2.0.1 /opt/iobroker/node_modules/isarray
          npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/isobject
          npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
          npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/kind-of
          npm ERR! extraneous: koalas@1.0.2 /opt/iobroker/node_modules/koalas
          npm ERR! extraneous: lazy-cache@2.0.2 /opt/iobroker/node_modules/lazy-cache
          npm ERR! extraneous: log-ok@0.1.1 /opt/iobroker/node_modules/log-ok
          npm ERR! extraneous: log-utils@0.2.1 /opt/iobroker/node_modules/log-utils
          npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/map-visit
          npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
          npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/mixin-object
          npm ERR! extraneous: mkdirp@0.5.1 /opt/iobroker/node_modules/mkdirp
          npm ERR! extraneous: moment-timezone@0.5.34 /opt/iobroker/node_modules/moment-timezone
          npm ERR! extraneous: node-dht-sensor@0.4.3 /opt/iobroker/node_modules/node-dht-sensor
          npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
          npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
          npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/object-copy
          npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/object-visit
          npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
          npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
          npm ERR! extraneous: pointer-symbol@1.0.0 /opt/iobroker/node_modules/pointer-symbol
          npm ERR! extraneous: prebuild-install@6.1.2 /opt/iobroker/node_modules/prebuild-install
          npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
          npm ERR! extraneous: prompt-actions@3.0.2 /opt/iobroker/node_modules/prompt-actions
          npm ERR! extraneous: prompt-base@4.1.0 /opt/iobroker/node_modules/prompt-base
          npm ERR! extraneous: prompt-checkbox@2.2.0 /opt/iobroker/node_modules/prompt-checkbox
          npm ERR! extraneous: prompt-choices@4.1.0 /opt/iobroker/node_modules/prompt-choices
          npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
          npm ERR! extraneous: prompt-question@5.0.2 /opt/iobroker/node_modules/prompt-question
          npm ERR! extraneous: prompt-radio@1.2.1 /opt/iobroker/node_modules/prompt-radio
          npm ERR! extraneous: put@0.0.6 /opt/iobroker/node_modules/put
          npm ERR! extraneous: radio-symbol@2.0.0 /opt/iobroker/node_modules/radio-symbol
          npm ERR! extraneous: readline-ui@2.2.3 /opt/iobroker/node_modules/readline-ui
          npm ERR! extraneous: readline-utils@2.2.3 /opt/iobroker/node_modules/readline-utils
          npm ERR! extraneous: rpi-gpio-buttons@2.0.1 /opt/iobroker/node_modules/rpi-gpio-buttons
          npm ERR! extraneous: rpi-gpio@2.1.7 /opt/iobroker/node_modules/rpi-gpio
          npm ERR! invalid: serialport@9.0.7 /opt/iobroker/node_modules/serialport
          npm ERR! extraneous: set-getter@0.1.0 /opt/iobroker/node_modules/set-getter
          npm ERR! extraneous: set-value@3.0.1 /opt/iobroker/node_modules/set-value
          npm ERR! extraneous: shallow-clone@1.0.0 /opt/iobroker/node_modules/shallow-clone
          npm ERR! extraneous: simple-get@3.1.0 /opt/iobroker/node_modules/simple-get
          npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
          npm ERR! extraneous: socket.io-client@2.4.0 /opt/iobroker/node_modules/socket.io-client
          npm ERR! extraneous: socket.io-parser@3.3.1 /opt/iobroker/node_modules/socket.io-parser
          npm ERR! extraneous: socket.io@2.4.1 /opt/iobroker/node_modules/socket.io
          npm ERR! extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
          npm ERR! extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
          npm ERR! extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
          npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/static-extend
          npm ERR! extraneous: strip-color@0.1.0 /opt/iobroker/node_modules/strip-color
          npm ERR! extraneous: success-symbol@0.1.0 /opt/iobroker/node_modules/success-symbol
          npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
          npm ERR! extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
          npm ERR! extraneous: sync-exec@0.6.2 /opt/iobroker/node_modules/sync-exec
          npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
          npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
          npm ERR! extraneous: terminal-paginator@2.0.2 /opt/iobroker/node_modules/terminal-paginator
          npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/time-stamp
          npm ERR! extraneous: to-buffer@1.1.1 /opt/iobroker/node_modules/to-buffer
          npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/to-object-path
          npm ERR! extraneous: toggle-array@1.0.1 /opt/iobroker/node_modules/toggle-array
          npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
          npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
          npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
          npm ERR! extraneous: warning-symbol@0.1.0 /opt/iobroker/node_modules/warning-symbol
          npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
          npm ERR! extraneous: window-size@1.1.1 /opt/iobroker/node_modules/window-size
          npm ERR! extraneous: ws@7.4.6 /opt/iobroker/node_modules/ws
          npm ERR!     /root/.npm/_logs/2023-02-15T09_57_19_152Z-debug-0.log
          Adapters from github: 	0
          Adapter State
          + system.adapter.admin.0                  : admin                 : automation-pi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.alexa2.0                 : alexa2                : automation-pi                            -  enabled
          + system.adapter.backitup.0               : backitup              : automation-pi                            -  enabled
          + system.adapter.cloud.0                  : cloud                 : automation-pi                            -  enabled
          + system.adapter.discovery.0              : discovery             : automation-pi                            -  enabled
            system.adapter.fullybrowser.0           : fullybrowser          : automation-pi                            - disabled
          + system.adapter.hue.0                    : hue                   : automation-pi                            -  enabled, port: 443
          + system.adapter.influxdb.0               : influxdb              : automation-pi                            -  enabled, port: 443
          + system.adapter.info.0                   : info                  : automation-pi                            -  enabled
          + system.adapter.iot.0                    : iot                   : automation-pi                            -  enabled
          + system.adapter.javascript.0             : javascript            : automation-pi                            -  enabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : automation-pi                            - disabled, port: 54321
          + system.adapter.mqtt.0                   : mqtt                  : automation-pi                            -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : automation-pi                            -  enabled, port: 8883, bind: 0.0.0.0
          + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : automation-pi                            -  enabled, port: 16021
          + system.adapter.nut.0                    : nut                   : automation-pi                            -  enabled
          + system.adapter.pushover.0               : pushover              : automation-pi                            -  enabled
          + system.adapter.s7.0                     : s7                    : automation-pi                            -  enabled
          + system.adapter.shelly.0                 : shelly                : automation-pi                            -  enabled, port: 1882, bind: 192.168.151.10
          + system.adapter.simple-api.0             : simple-api            : automation-pi                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : automation-pi                            -  enabled
          + system.adapter.sonoff.0                 : sonoff                : automation-pi                            -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : automation-pi                            -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : automation-pi                            -  enabled
          + system.adapter.unifi.0                  : unifi                 : automation-pi                            -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : automation-pi                            - disabled
            system.adapter.vis.0                    : vis                   : automation-pi                            -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : automation-pi                            -  enabled
          + system.adapter.web.0                    : web                   : automation-pi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : automation-pi                            -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.2.23 [Updatable]
          Adapter    "alexa2"       : 3.23.2   , installed 3.21.0 [Updatable]
          Adapter    "backitup"     : 2.5.12   , installed 2.5.4  [Updatable]
          Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
          Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
          Adapter    "hue"          : 3.7.1    , installed 3.7.1
          Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
          Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
          Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
          Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.6  [Updatable]
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "nanoleaf-lightpanels": 1.3.1, installed 1.3.1
          Adapter    "nut"          : 1.5.1    , installed 1.5.1
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "s7"           : 1.3.14   , installed 1.3.13 [Updatable]
          Adapter    "shelly"       : 6.3.1    , installed 6.0.0  [Updatable]
          Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "telegram"     : 1.15.2   , installed 1.14.1 [Updatable]
          Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
          Adapter    "unifi"        : 0.5.10   , installed 0.5.10
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
          Adapter    "web"          : 4.3.0    , installed 4.3.0
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          Adapter    "ws"           : 1.3.0    , installed 1.3.0
          Objects and States
          Objects: 	135750
          States: 	129134
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
          Hit:4 https://repos.influxdata.com/debian buster InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          19804      596/codesyscontrol.
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16926      598/sshd
          tcp        0      0 192.168.151.10:1882     0.0.0.0:*               LISTEN      1001       4217754    28597/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          18500      567/mosquitto
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       4249042    28627/io.sonoff.0
          tcp        0      0 0.0.0.0:11740           0.0.0.0:*               LISTEN      0          14282      596/codesyscontrol.
          tcp        0      0 0.0.0.0:1217            0.0.0.0:*               LISTEN      0          14023      585/codesysedge.bin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4192764    28024/iobroker.js-c
          tcp        0      0 127.0.0.1:4840          0.0.0.0:*               LISTEN      0          19693      596/codesyscontrol.
          tcp        0      0 192.168.151.10:4840     0.0.0.0:*               LISTEN      0          19692      596/codesyscontrol.
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4182944    28024/iobroker.js-c
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4231875    28310/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4217724    28749/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16928      598/sshd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       4217652    28766/io.simple-api
          tcp6       0      0 :::1883                 :::*                    LISTEN      0          18501      567/mosquitto
          udp        0      0 192.168.151.10:49152    0.0.0.0:*                           0          19927      596/codesyscontrol.
          udp        0      0 192.168.151.10:34964    0.0.0.0:*                           0          19926      596/codesyscontrol.
          udp        0      0 192.168.151.10:161      0.0.0.0:*                           0          19928      596/codesyscontrol.
          udp        0      0 192.168.151.255:1740    0.0.0.0:*                           0          14049      596/codesyscontrol.
          udp        0      0 192.168.151.10:1740     0.0.0.0:*                           0          14048      596/codesyscontrol.
          udp        0      0 192.168.151.255:1743    0.0.0.0:*                           0          18510      585/codesysedge.bin
          udp        0      0 192.168.151.10:1743     0.0.0.0:*                           0          18509      585/codesysedge.bin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4217487    28760/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13794      364/avahi-daemon: r
          udp        0      0 0.0.0.0:52022           0.0.0.0:*                           108        13796      364/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4247847    28707/io.nanoleaf-l
          udp6       0      0 :::5353                 :::*                                108        13795      364/avahi-daemon: r
          udp6       0      0 :::38174                :::*                                108        13797      364/avahi-daemon: r
          2023-02-15 10:11:18.218  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 killing pid 28215
          2023-02-15 10:11:18.998  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-02-15 10:11:21.381  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 started with pid 29365
          2023-02-15 10:11:50.226  - info: host.automation-pi "system.adapter.mihome-vacuum.0" disabled
          2023-02-15 10:11:50.227  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
          2023-02-15 10:11:50.237  - error: mihome-vacuum.0 (29365) Socket Close
          2023-02-15 10:11:50.247  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 send kill signal
          2023-02-15 10:11:51.326  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 killing pid 29365
          2023-02-15 10:11:52.586  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-02-15 10:15:10.977  - info: host.automation-pi "system.adapter.telegram.0" disabled
          2023-02-15 10:15:10.978  - info: host.automation-pi stopInstance system.adapter.telegram.0 (force=false, process=true)
          2023-02-15 10:15:10.999  - info: host.automation-pi stopInstance system.adapter.telegram.0 send kill signal
          2023-02-15 10:15:12.483  - info: host.automation-pi stopInstance system.adapter.telegram.0 killing pid 28404
          2023-02-15 10:15:13.763  - info: host.automation-pi instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
          2023-02-15 10:16:02.470  - info: host.automation-pi "system.adapter.telegram.0" enabled
          2023-02-15 10:16:07.360  - info: host.automation-pi instance system.adapter.telegram.0 started with pid 29466
          2023-02-15 10:16:49.601  - info: host.automation-pi "system.adapter.telegram.0" disabled
          2023-02-15 10:16:49.604  - info: host.automation-pi stopInstance system.adapter.telegram.0 (force=false, process=true)
          2023-02-15 10:16:50.498  - info: host.automation-pi stopInstance system.adapter.telegram.0 send kill signal
          2023-02-15 10:16:51.797  - info: host.automation-pi instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
          2023-02-15 10:17:37.187  - info: host.automation-pi "system.adapter.telegram.0" enabled
          2023-02-15 10:17:38.657  - info: host.automation-pi instance system.adapter.telegram.0 started with pid 29570
          2023-02-15 10:18:27.288  - error: unifi.0 (28621) Error: Login required. Check username and password.
          2023-02-15 10:53:00.601  - info: host.automation-pi instance system.adapter.weatherunderground.0 started with pid 29730
          2023-02-15 10:53:46.395  - info: host.automation-pi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          		     v.2023-01-02
          Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
          Installation: 		Native
          Timezone: 		Europe/Berlin
          User-ID: 		0
          X-Server: 		false
          Pending OS-Updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
          ioBroker Core: 		js-controller 		4.0.23
          			admin 			6.2.23
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Status admin:
          Pending iob updates: 	16
          Objects: 		135750
          States: 		129134
          Size of iob-Database:
          7.5M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
          2.3M	/opt/iobroker/iobroker-data/states.json.migrated
          2.3M	/opt/iobroker/iobroker-data/states.json.bak.migrated
          0	/opt/iobroker/iobroker-data/states.json.broken
            Thomas Braun Most Active @corny456 last edited by Thomas Braun
            @corny456
            Die alte Leier...
            NICHT als root herumkaspern, nodeJS sauber senkrecht per Paketmanager installieren, Buster beerdigen, Bullseye installieren.
            • werner2000x
              werner2000x last edited by werner2000x
              @thomas-braun Ich kann seit heute keine Adapter mehr aktualisieren.
              Bei drei Updates von Adaptern bekomme ich folgenden Fehler:
              host.raspberrypi
              2023-02-23 18:12:32.344	error	iobroker host.raspberrypi Cannot install iobroker.echarts@1.4.9: 217
              host.raspberrypi
              2023-02-23 18:11:08.729	error	iobroker host.raspberrypi Cannot install iobroker.text2command@3.0.1: 217
              host.raspberrypi
              2023-02-23 18:10:15.435	error	iobroker host.raspberrypi Cannot install iobroker.backitup@2.6.2: 217
              und mit "iob diag" folgendes
              js-controller:  4.0.24
              admin:          6.3.6
              javascript:     "javascript" not found
              npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
              npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
              npm ERR!     /home/pi/.npm/_logs/2023-02-23T17_20_26_124Z-debug-0.log
              Adapters from github:   1
              Hat jemand eine Idee?log230223.txt
                Thomas Braun Most Active @werner2000x last edited by
                @werner2000x
                Bitte jeweils vollständig posten, Eingabezeile inklusive.
                • werner2000x
                  werner2000x last edited by Homoran
                  Nach Befehl iob diag erhalte ich folgende Ausgabe:
                  Skript v.2023-01-02
                  *** BASE SYSTEM ***
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Docker:         false
                  Release:        10
                  Codename:       buster
                  VERSION_ID="10"
                  ID=raspbian
                  ID_LIKE=debian
                   18:20:02 up 14 min,  2 users,  load average: 0.85, 0.82, 0.81
                  CPU threads: 4
                  Thu Feb 23 17:20:02 UTC 2023
                  Thu Feb 23 18:20:02 CET 2023
                  CET +0100
                  Europe/Berlin
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth lpadmin gpio i2c spi iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:           7.9G        2.0G        5.1G        9.0M        839M        6.2G
                  Swap:           99M          0B         99M
                  Total:         8.0G        2.0G        5.2G
                           7898 M total memory
                           1996 M used memory
                            314 M active memory
                           2398 M inactive memory
                           5062 M free memory
                            128 M buffer memory
                            710 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /dev/root      ext4      117G   21G   92G  19% /
                  devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                  tmpfs          tmpfs     3.9G  9.5M  3.9G   1% /run
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                  /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                  Messages in dmesg:
                  [Thu Feb 23 18:05:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Thu Feb 23 18:05:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                  [Thu Feb 23 18:05:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Thu Feb 23 18:05:15 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                  /             /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  4.3G    /var/
                  2.9G    /var/cache/apt
                  2.9G    /var/cache
                  2.8G    /var/cache/apt/archives
                  719M    /var/log
                  1.8G    /opt/iobroker/backups/
                  296K    /opt/iobroker/backups/scripte
                  268K    /opt/iobroker/backups/scripte/Meine_Geräte
                  252K    /opt/iobroker/backups/Meine_Geräte
                  8.0K    /opt/iobroker/backups/scripte/common
                  1.6G    /opt/iobroker/iobroker-data/
                  761M    /opt/iobroker/iobroker-data/node-red/node_modules
                  601M    /opt/iobroker/iobroker-data/files
                  531M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow
                  197M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow.so.2.5.0
                  41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                  33M     /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow_framework.so.2.5.0
                  33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                  23M     /opt/iobroker/iobroker-data/objects.jsonl
                  /usr/bin/nodejs         v14.21.3
                  /usr/bin/node           v14.21.3
                  /usr/bin/npm            9.5.0
                  /usr/bin/npx            9.5.0
                  nodejs:
                    Installed: 14.21.3-deb-1nodesource1
                    Candidate: 14.21.3-deb-1nodesource1
                    Version table:
                   *** 14.21.3-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                  Temp directories causing npm8 problem: 1
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.6
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
                    system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                  + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
                    system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                  + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                  + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
                  + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                  + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                  + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                  + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
                  + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                  + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                    system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                    system.adapter.km200.0                  : km200                 : raspberrypi                              - disabled
                    system.adapter.material.0               : material              : raspberrypi                              - disabled
                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.198.39
                  + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                  + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                    system.adapter.rainbird.0               : rainbird              : raspberrypi                              - disabled
                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                    system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
                    system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              - disabled
                  + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                    system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                  + system.adapter.tuya.1                   : tuya                  : raspberrypi                              -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                    system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                    system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                    system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
                  + instance is alive
                  Active repo(s): beta
                  Used repository: beta
                  Adapter    "admin"        : 6.3.6    , installed 6.3.6
                  Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                  Adapter    "backitup"     : 2.6.2    , installed 2.6.1  [Updatable]
                  Adapter    "ble"          : 0.13.3   , installed 0.13.3
                  Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                  Adapter    "cloud"        : 4.3.1    , installed 4.3.1
                  Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                  Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
                  Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                  Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                  Adapter    "devices"      : 1.1.2    , installed 1.1.2
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Adapter    "echarts"      : 1.4.9    , installed 1.4.7  [Updatable]
                  Adapter    "ems-esp"      : 1.22.0   , installed 1.22.0
                  Adapter    "energymanager": 1.4.1    , installed 1.4.1
                  Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                  Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                  Adapter    "ical"         : 1.13.2   , installed 1.13.2
                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                  Adapter    "info"         : 1.9.26   , installed 1.9.26
                  Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
                  Adapter    "iot"          : 1.14.3   , installed 1.14.3
                  Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
                  Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                  Controller "js-controller": 4.0.24   , installed 4.0.24
                  Adapter    "km200"        : 2.0.3    , installed 2.0.3
                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                  Adapter    "meross"       : 1.15.0   , installed 1.15.0
                  Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                  Adapter    "parser"       : 1.3.2    , installed 1.3.2
                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                  Adapter    "rainbird"     : 0.2.2    , installed 0.2.2
                  Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                  Adapter    "socketio"     : 6.3.3    , installed 6.3.3
                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                  Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                  Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                  Adapter    "text2command" : 3.0.1    , installed 3.0.0  [Updatable]
                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                  Adapter    "tuya"         : 3.14.1   , installed 3.14.1
                  Adapter    "vis"          : 1.4.16   , installed 1.4.16
                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                  Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
                  Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                  Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                  Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                  Adapter    "vw-connect"   : 0.0.60   , installed 0.0.60
                  Adapter    "web"          : 5.5.0    , installed 5.5.0
                  Adapter    "ws"           : 2.3.5    , installed 2.3.5
                  Objects and States
                  Objects:        21475
                  States:         18373
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://apt.grafana.com stable InRelease
                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                  Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
                  Pending Updates: 0
                  Proto Recv-Q Send-Q Local Address           Foreign Address         State
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN
                  tcp        0      0 192.168.198.39:8081     0.0.0.0:*               LISTEN
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
                  tcp        0      0 192.168.198.39:1880     0.0.0.0:*               LISTEN
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN
                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
                  tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
                  tcp6       0      0 :::8086                 :::*                    LISTEN
                  tcp6       0      0 ::1:3350                :::*                    LISTEN
                  tcp6       0      0 ::1:631                 :::*                    LISTEN
                  tcp6       0      0 :::3000                 :::*                    LISTEN
                  tcp6       0      0 :::3389                 :::*                    LISTEN
                  tcp6       0      0 :::445                  :::*                    LISTEN
                  tcp6       0      0 :::139                  :::*                    LISTEN
                  tcp6       0      0 :::5900                 :::*                    LISTEN
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*
                  udp        0      0 0.0.0.0:68              0.0.0.0:*
                  udp        0      0 0.0.0.0:631             0.0.0.0:*
                  udp        0      0 192.168.198.255:137     0.0.0.0:*
                  udp        0      0 192.168.198.39:137      0.0.0.0:*
                  udp        0      0 192.168.198.42:137      0.0.0.0:*
                  udp        0      0 0.0.0.0:137             0.0.0.0:*
                  udp        0      0 192.168.198.255:138     0.0.0.0:*
                  udp        0      0 192.168.198.39:138      0.0.0.0:*
                  udp        0      0 192.168.198.42:138      0.0.0.0:*
                  udp        0      0 0.0.0.0:138             0.0.0.0:*
                  udp        0      0 0.0.0.0:58511           0.0.0.0:*
                  udp        0      0 0.0.0.0:38566           0.0.0.0:*
                  udp        0      0 192.168.198.39:1194     0.0.0.0:*
                  udp6       0      0 :::41388                :::*
                  udp6       0      0 :::546                  :::*
                  2023-02-23 18:19:09.154  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                  2023-02-23 18:19:59.080  - info: influxdb.0 (1263) No Data
                  2023-02-23 18:19:59.173  - info: influxdb.0 (1263) No Data
                  2023-02-23 18:19:59.478  - info: influxdb.0 (1263) No Data
                  2023-02-23 18:20:00.146  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                  2023-02-23 18:20:00.610  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                  2023-02-23 18:20:08.693  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                  2023-02-23 18:20:09.351  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                  2023-02-23 18:20:24.470  - info: meross.0 (1531) Can not get Data for Device 211
                  2023-02-23 18:20:24.471  - warn: meross.0 (1531) Can not get Data for Device 211
                  2023-02-23 18:20:59.142  - info: influxdb.0 (1263) No Data
                  2023-02-23 18:20:59.565  - info: influxdb.0 (1263) No Data
                  2023-02-23 18:21:08.868  - debug: daikin-cloud.0 (1579) update state: 09d81369-d
                  2023-02-23 18:21:08.881  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                  2023-02-23 18:21:08.889  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                  2023-02-23 18:21:08.895  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                  2023-02-23 18:21:09.659  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
                  2023-02-23 18:21:09.660  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
                  2023-02-23 18:21:09.667  - warn: daikin-cloud.0 (1579) State "daikin-cloud.0.f7b
                  2023-02-23 18:21:09.675  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                  2023-02-23 18:21:09.679  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                  2023-02-23 18:21:09.688  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                  2023-02-23 18:21:11.789  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                  2023-02-23 18:21:12.173  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                  iob diag has finished.
                    Thomas Braun Most Active @werner2000x last edited by Thomas Braun
                    @werner2000x
                    Die Lösung dazu findet sich in den oben festgepinnten Threads.
                    https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                    Und npm wird nicht von Hand aktualisiert!
                    Dein Betriebssystem ist abgekündigt, installiert da das aktuelle stabile Release 'Bullseye'.
                    • ostseereiter
                      ostseereiter last edited by
                      Ich habe das schon seit ein viertel Jahr das sich kein Adapter mehr aktualisieren kann. Es ist aber erst seid Node JS 16 wenn man auf die 14 zurückgehrt dann klappt das wieder habe ich gelesen. Nu sind es bei mir schon fast 40 Adapter die aktualiersiert werden möchten. Ich lass es jetzt einfach so System läuft trotzdem super.Wenn es meine Zeit zuläßt werde ich dann Iobroker neu installieren. Solange es läuft ist es gut und das andere ist alles flickschusterei denke ich, denn der festgepinnte Thred haut auch nicht hin weil bei mir nur der Fehler 0 kommt.
                        Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                        @ostseereiter sagte in Problem beim Update von Adaptern/Modulen/Controller:
                        Das nur die Meldung 0 kommt glaube ich nicht.
                        Aber deine Beschreibung ist auch etwas dünn.
                        Wenigstens mal ein
                        iob diag
                        oder wenigstens
                        iob update
                        iob upgrade ADAPTER --debug
                        wäre fein. So kann man nichts weiter dazu sagen.
                        • werner2000x
                          Ich habe jetzt das Problem, dass der Javascript adapter nicht mehr startet (rot).
                          Wenn ich den Befehl "iob upgrade ADAPTER --debug" aufrufen, dann kommt: Adapter "ADAPTER" is not installed.
                          Ich habe auch schon javascript neu installiert und gebootet - leider keine Abhilfe.
                          Gibt es eine Lösung oder nur mit "Bullseye"?
                            @werner2000x
                            Du hast aber schon gesehen, dass 'ADAPTER' nur ein Platzhalter ist und durch den Adapternamen ersetzt werden muss?
                            iobroker upgrade javascript --debug
                            werner2000x 1 Reply Last reply Reply Quote 0
                            • werner2000x
                              werner2000x @Thomas Braun last edited by
                              @thomas-braun Ja, Danke das katte ich übersehen.
                              Nun habe ich den Adapter javascript deinstalliert und er erscheint auch nicht mehr in der Instance Liste.
                              Wenn ich nun den folgenden Befehl aurufe:
                              iob upgrade javascript --debug
                              Adapter "javascript"     is not installed.
                              erhalt ich die Meldung wie vorstehend. Wie kann ich denn den Adapter neu installieren?
                                @werner2000x
                                iobroker add javascript --debug
                                • werner2000x
                                  Dann kommt folgendes:
                                  NPM version: 9.5.0
                                  Installing iobroker.javascript@7.0.1... (System call)
                                  npm ERR! code ENOTEMPTY
                                  npm ERR! syscall rename
                                  npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                                  npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-02-24T14_10_51_991Z-debug-0.log
                                  host.raspberrypi Cannot install iobroker.javascript@7.0.1: 217
                                    Homoran Global Moderator Administrators @werner2000x last edited by
                                    @werner2000x sagte in Problem beim Update von Adaptern/Modulen/Controller:
                                    warum?
                                    dann geht natürlich kein upgrade mehr
                                      217
                                      • werner2000x
                                        werner2000x @Homoran last edited by werner2000x
                                        @homoran Ich habe ihn deinstalliert weil er immer Rot in den instancen war.
                                          NPM version: 9.5.0
                                          Von Hand dran herumgefummelt.
                                          NICHT machen.
                                          nodejs (inkl. npm) neuinstallieren.
                                          Beta-Software:
                                          javascript@7.0.1
                                          Ich denke im Beta-Repository bist du vollkommen falsch aufgehoben.
                                            warum fummelt man an der Installation rum während andere versuchen zu helfen?
                                            Der Wissensstand der helfenden ist damit ständig veraltet.
                                            https://forum.iobroker.net/post/884324
                                            1970
