    4. Tägliches Problem mit Unifi Adapter
      Kuddel last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: ESX-Host 32 GB / VM 3,5GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu 18.04.6
      Node-Version: 16.18.0
      Nodejs-Version: 16.18.0
      NPM-Version: 8.19.2
      Installationsart: Manuell
      Hallo zusammen, ich bekomme jeden Tag um 02:00 Uhr den gleiche Fehler bzgl. des Unifi-Adapters.
      unifi.0 2023-02-16 02:00:18.481	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      unifi.0 2023-02-16 02:00:18.473	error	Cannot read properties of undefined (reading 'captureException')
      unifi.0 2023-02-16 02:00:18.473	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:218:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:22) at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
      unifi.0 2023-02-16 02:00:18.472	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      unifi.0 2023-02-16 02:00:18.472	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      unifi.0 2023-02-16 02:00:18.456	error	[updateUnifiData-login site undefined] error: Request failed with status code 503, stack: AxiosError: Request failed with status code 503 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:1268:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:2446:11) at IncomingMessage.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
      Der Verdacht liegt nahe, dass es das tägliche Unifi-Controller Backup um 2 Uhr ist.
      Allerdings kommt der Fehler auch, wenn das Backup deaktiviert ist.
      • V
        valbuz @Kuddel last edited by
        @kuddel
        Ich verwende für meine Abwesenheitserkennung die Handys, welche im WLan eingebucht sind.
        Ztw. kommte es vor, dass alle Handys um 02:00 die Verbindung kurz verlieren und sich dann wieder einbuchen.
        Ich habe das Problem bis anhin in Unifi nicht gefunden.... 😕
        Patrick
