    3. Tester
    4. [Aufruf] Bitte js-controller 1.0.3 + admin 1.7.6 testen
      Es gibt neue Versionen von js-controller und admin und bevor die ins stable verschoben werden, währe es toll wenn jemand die testet.
      Die Änderungen tragen kosmetischer Character und die Vorbereitungen für admin-neo
      js-controller 1.0.3 (2017-06-01)
      (bluefox) getHostInfo for new admin
      (bluefox) allow using of files for certificates
      (bluefox) always install zwave with unsafe-perm option
      (apollon77) add handling for undefined
      (apollon77) uptime is a number only and no String/List/Array beside the fact that also with a number a "toString" should exist, or it's undefined because an old host is listed with no value ...
      admin
      1.7.6 (2017-06-01)
      (bluefox) Fix edit of the enum name
      1.7.5 (2017-05-20)
      (bluefox) catch error if translated object is not text
      (bluefox) update selectID.js
      (bluefox) do not open configuration dialog for instances with no config
      (Steiger04) select multiple auch bei data-name="[eigner-name]"
        Marcolotti last edited by
        Hallo Bluefox,
        bei der Admin Installation kommt folgender Fehler:
        root@iobroker2:/opt/iobroker# npm install iobroker.admin
        > mdns@2.3.3 install /opt/iobroker/node_modules/mdns
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/mdns/build'
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
        In file included from ../src/dns_sd.cpp:1:0:
        ../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
         #include <dns_sd.h>^
        compilation terminated.
        dns_sd_bindings.target.mk:149: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
        make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/mdns/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        gyp ERR! stack     at emitTwo (events.js:106:13)
        gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
        gyp ERR! System Linux 3.16.0-4-686-pae
        gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/mdns
        gyp ERR! node -v v6.10.3
        gyp ERR! node-gyp -v v3.4.0
        gyp ERR! not ok
        iobroker.core@0.1.0 /opt/iobroker
        └── (empty)
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: `node-gyp rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        npm ERR! code 1</dns_sd.h>
          Aber geht trotzdem alles. :?
          JS-Controller auf 1.0.3 und admin auf 1.7.6.
            der Include fehlt…hat einer vergessen was hochzuladen...
              @arteck:
              der Include fehlt…hat einer vergessen was hochzuladen... `
              Mehr Info.
              Ist nicht klar wo was fehlt.
              • Thisoft
                Thisoft last edited by
                Habe gestern alle Updates eingespielt. Bis jetzt läuft alles problemlos 😄
                Hatte auch keine auffälligen Fehlermeldungen. Mal abgesehen von dem Slave auf dem noch node 0.6 drauf ist, aber da ists ja klar…
                • rantanplan
                  rantanplan last edited by
                  Updates auf Win10 durchgeführt.
                  Keine Probleme.
                  • lobomau
                    lobomau last edited by
                    Ich habe auf Pi3 geupdatet ohne Probleme danach, nur paar Fehlermeldungen (npm ERR) während der Installation.
                    Beim brix lief es nicht so gut. Habe dabei auch ein apt-get update und upgrade durchgeführt (8 ubuntu updates).
                    root@brix-3150:/opt/iobroker# sudo iobroker status
                    module.js:471
                        throw err;
                        at Function.Module._resolveFilename (module.js:469:15)
                        at Function.Module._load (module.js:417:25)
                        at Module.runMain (module.js:604:10)
                        at run (bootstrap_node.js:390:7)
                        at startup (bootstrap_node.js:150:9)
                        at bootstrap_node.js:505:3
                    EDIT: es reichte folgendes aus. Scheint erstmal normal zu laufen
                    root@brix-3150:/opt/iobroker# npm install iobroker.js-controller --production
                      Kueppert last edited by
                      Hallo in die Runde,
                      habe mich auch getraut und wollte meinen Beitrag zum Test leisten. System läuft seit paar Minuten unauffällig. Hatte nur bei der installation auf meinem Raspberry Pi3 unten angehangene Fehlermeldung via Putty:
                      root@raspberrypi3:/opt/iobroker# sudo iobroker upgrade self
                      npm install iobroker.js-controller@1.0.3 –production --prefix "/opt/iobroker" (System call)
                      Cannot save file /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json'
                      Host "raspberrypi3" (linux) updated
                      Execute: chmod 777 -R /opt/iobroker
                      Chmod finished. Restart controller
                      Starting node restart.js
                      VG kueppert
                      PS: gerade festgestellt, dass beim Adapter fritz.box die history Einträge jetzt leer sind… Keine Ahnung, ob das nach einem Neustart immer so ist?!
                      • Jeeper.at
                        Jeeper.at last edited by
                        Hier auch alles OK.
                        Update auf einem Windows 10 System.
                        Lg
                        Günther
                        • Dutchman
                          Läuft seit 12 Stunden ohne sichtbare Probleme
                          Send from mobile device
                            Turbo last edited by
                            Verdammt - bei mir läuft es natürlich wieder mal nicht…
                            Habe gerade zuerst admin und dann js-controller upgedatet. Danach verabschiedete sich iobroker...
                            Habe jetzt schon einiges versucht, inkl. iobroker Neuinstallation - keine Reaktion, nur npm Fehler...
                            root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller --production
                            npm ERR! Linux 4.4.43-v7+
                            npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
                            npm ERR! node v4.7.2
                            npm ERR! npm  v2.15.11
                            npm ERR! file /root/.npm/iobroker.js-controller/1.0.3/package/package.json
                            npm ERR! code EJSONPARSE
                            npm ERR! Failed to parse json
                            npm ERR! No data, empty input at 1:1
                            npm ERR!
                            npm ERR! ^
                            npm ERR! File: /root/.npm/iobroker.js-controller/1.0.3/package/package.json
                            npm ERR! Failed to parse package.json data.
                            npm ERR! package.json must be actual JSON, not just JavaScript.
                            npm ERR!
                            npm ERR! This is not a bug in npm.
                            npm ERR! Tell the package author to fix their package.json file. JSON.parse
                            npm ERR! Please include the following file with any support request:
                            npm ERR!     /opt/iobroker/npm-debug.log
                            root@raspberrypi:/opt/iobroker# sudo npm install iobroker --unsafe-perm
                            npm ERR! not a package /opt/iobroker/iobroker
                            npm ERR! addLocal Could not install /opt/iobroker/iobroker
                            npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker" "--unsafe-perm"
                            npm ERR! path /tmp/npm-1585-16846667/unpack-82b0f14b7517/package.json
                            npm ERR! code ENOENT
                            npm ERR! errno -2
                            npm ERR! syscall open
                            npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-1585-16846667/unpack-82b0f14b7517/package.json'
                            npm ERR! enoent This is most likely not a problem with npm itself
                            npm ERR! enoent and is related to npm not being able to find a file.
                            npm ERR! enoent
                            Kann mir bitte mal jemand helfen?
                              was sagt der
                                root@raspberrypi:/opt/iobroker# /opt/iobroker/npm-debug.log
                                -bash: /opt/iobroker/npm-debug.log: Keine Berechtigung
                                :shock:
                                Habe jetzt nochmal downgegradet - mit den alten Versionen läuft alles wieder…
                                • Jeeper.at
                                  Immer zuerst den Controller, dann Admin updaten.
                                  Lg
                                  Günther
                                    Jippie - läuft! Vielen Dank. Jetzt muss ich nur noch mein web.1 (SSL Zugriff) wieder zum Laufen bringen.
                                    Was zur Hölle ist "greenlock"?!?
                                    host.raspberrypi	2017-06-05 19:48:18.722	error	instance system.adapter.web.1 terminated with code 0 (OK)
                                    web.1	2017-06-05 19:48:18.314	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                    web.1	2017-06-05 19:48:18.314	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                    web.1	2017-06-05 19:48:18.314	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:639:21)
                                    web.1	2017-06-05 19:48:18.314	error	at /opt/iobroker/node_modules/iobroker.web/main.js:166:29
                                    web.1	2017-06-05 19:48:18.314	error	at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:507:28)
                                    web.1	2017-06-05 19:48:18.314	error	at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:13:25)
                                    web.1	2017-06-05 19:48:18.314	error	at require (internal/module.js:12:17)
                                    web.1	2017-06-05 19:48:18.314	error	at Module.require (module.js:353:17)
                                    web.1	2017-06-05 19:48:18.314	error	at Function.Module._load (module.js:276:25)
                                    web.1	2017-06-05 19:48:18.314	error	at Function.Module._resolveFilename (module.js:325:15)
                                    web.1	2017-06-05 19:48:18.314	error	Error: Cannot find module 'greenlock'
                                    web.1	2017-06-05 19:48:18.294	error	uncaught exception: Cannot find module 'greenlock'
                                      Guten Morgen,
                                      was mir heute aufgefallen ist, da ich nun 2 ModBus-Instanzen habe. Die erste Instanz ist knapp 2 Jahre alt und die neue ein paar Tage.
                                      Schaut mal. (Einstellungen unter ModBus sind identisch außer die Adressen) Es gibt in der letzten Instanz Input-Level und Output-Level. Ist das so geplant?
                                      Jetzt bekomme ich ab und an auch mal den gleichen Fehler wie Apollon:
                                      modbus.1	2017-06-10 06:14:30.985	warn	Poll error count: 6 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:30.969	warn	Poll error count: 5 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:30.508	warn	Poll error count: 4 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:30.380	warn	Poll error count: 3 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:30.360	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:30.211	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:29.589	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:27.973	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:27.950	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:25.665	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:24.954	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:24.787	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:24.767	warn	Poll error count: 3 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:24.609	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:24.325	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:24.178	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:21.907	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:21.769	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:18.751	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:18.584	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:18.421	warn	Poll error count: 1 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:18.122	warn	Poll error count: 3 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:17.975	warn	Poll error count: 2 code: "App Timeout"
                                      modbus.1	2017-06-10 06:14:17.823	warn	Poll error count: 1 code: "App Timeout"
                                      Daten kommen trotzdem.
                                      Gruß Marco
                                      17
                                      2669
