    4. ESP HOME --- keine Installation möglich
    • Matthias 4
      Matthias 4 last edited by wendy2702
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Manuell
      Image genutzt: Ja
      nach dem Update auf die BETA ( in der Freigebenden Version ging leider nichts mehr) bekomme ich keine Daten mehr auf den ESP.
      Fehlermeldung:
      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-a19cfd.yaml...
      INFO Generating C++ source...
      INFO Compiling app...
      Traceback (most recent call last):
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/bin/esphome", line 8, in <module>
          sys.exit(main())
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 825, in main
          return run_esphome(sys.argv)
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 812, in run_esphome
          rc = POST_CONFIG_ACTIONS[args.command](args, config)
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 369, in command_run
          exit_code = compile_program(args, config)
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/__main__.py", line 186, in compile_program
          rc = platformio_api.run_compile(config, CORE.verbose)
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 106, in run_compile
          return run_platformio_cli_run(config, verbose)
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 102, in run_platformio_cli_run
          return run_platformio_cli(*command, **kwargs)
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 93, in run_platformio_cli
          patch_structhash()
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/esphome/platformio_api.py", line 23, in patch_structhash
          from platformio.commands.run import helpers, command
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/commands/run/command.py", line 25, in <module>
          from platformio.commands.device.command import device_monitor as cmd_device_monitor
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/commands/device/command.py", line 24, in <module>
          from platformio.commands.device import helpers as device_helpers
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/commands/device/helpers.py", line 23, in <module>
          from platformio.package.manager.tool import ToolPackageManager
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/manager/tool.py", line 15, in <module>
          from platformio.package.manager.base import BasePackageManager
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/manager/base.py", line 26, in <module>
          from platformio.package.manager._download import PackageManagerDownloadMixin
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/manager/_download.py", line 21, in <module>
          from platformio.package.download import FileDownloader
        File "/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.7/site-packages/platformio/package/download.py", line 22, in <module>
          import requests
        File "/usr/lib/python3/dist-packages/requests/__init__.py", line 95, in <module>
          from urllib3.contrib import pyopenssl
        File "/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.py", line 46, in <module>
          import OpenSSL.SSL
        File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
          from OpenSSL import crypto, SSL
        File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1553, in <module>
          class X509StoreFlags(object):
        File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1573, in X509StoreFlags
          CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
      AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
      Ich hoffe es Kann mir jemand helfen.
      MOD EDIT: LOG IN CODE TAGS </> GESETZT
      • wendy2702
        wendy2702 last edited by
        @matthias-4 https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge?_=1676979372654
        Log unvollständig
        Tabelle unvollständig
          Ahnungsbefreit @Matthias 4 last edited by
          @matthias-4 Lösch mal komplett die jetzige Instanz und den Adapter, dann neu von GitHub laden
          Matthias 4 1 Reply Last reply Reply Quote 0
          • Matthias 4
            Matthias 4 @Ahnungsbefreit last edited by
            @ahnungsbefreit: Hab ich grad gemacht - brachte keinen Erfolg
            • wendy2702
              wendy2702 @Matthias 4 last edited by
              @matthias-4 Du solltest dann davon das/die Logs zeigen. Sonst kann die hier vermutlich niemand helfen.
              • Matthias 4
                Matthias 4 @wendy2702 last edited by
                @wendy2702 : Das Angeführte ist das Log des ESP Home Dashboard - oder gibt es noch ein anderes?
                • wendy2702
                  @matthias-4 Ja. Installation des Adapters der Instanz z.B.
                  was kommt denn bei
                  iob diag
                  • Matthias 4
                    @wendy2702 sagte in ESP HOME --- keine Installation möglich:
                    iob diag
                    OK.. wieder was dazugelernt,.. Danke 🙂
                    		     v.2023-01-02
                    Operatingsystem: 	Debian GNU/Linux 10 (buster)
                    Installation: 		Native
                    Timezone: 		Europe/Berlin
                    User-ID: 		1000
                    X-Server: 		true
                    Boot Target: 		graphical.target
                    Pending OS-Updates: 	28
                    Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                    			/usr/bin/node 		v16.19.0
                    			/usr/bin/npm 		8.19.3
                    			/usr/bin/npx 		8.19.3
                    ioBroker Core: 		js-controller 		4.0.24
                    			admin 			6.3.5
                    ioBroker Status: 	iobroker is running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    Status admin:
                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 1435, bind: 0.0.0.0, run as: admin
                    Pending iob updates: 	8
                    Active repo(s): beta
                    Objects: 		2530
                    States: 		2270
                    Size of iob-Database:
                    44M	/opt/iobroker/iobroker-data/objects.jsonl
                    3.9M	/opt/iobroker/iobroker-data/objects.json.migrated
                    3.9M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                    0	/opt/iobroker/iobroker-data/objects.json.broken
                    8.1M	/opt/iobroker/iobroker-data/states.jsonl
                    460K	/opt/iobroker/iobroker-data/states.json.migrated
                    460K	/opt/iobroker/iobroker-data/states.json.bak.migrated
                    0	/opt/iobroker/iobroker-data/states.json.broken
                    Thomas Braun wendy2702 3 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @Matthias 4 last edited by
                      @matthias-4
                      Patch die Kiste durch.
                      Sowohl Betriebssystem wie auch den ioBroker.
                      Desktop ausknipsen.
                      • wendy2702
                        @matthias-4 Und zeige danach die angefragten logs.
                          Thomas Braun Most Active @Thomas Braun last edited by
                          @thomas-braun sagte in ESP HOME --- keine Installation möglich:
                          @Matthias-4
                          Seh ich gerade erst. 'Buster' ist tot und muss durch das aktuelle Stable-Release namens 'Bullseye' ersetzt werden.
                          • wendy2702
                            @matthias-4 Bitte Chat lesen, Testen und Feedback geben ob du wieder Posten kannst.
                            • Matthias 4
                              @wendy2702 Ich hab alles neu aufgesetzt,.. jetzt geht es.. Danke 🙂
                              • wendy2702
                                @matthias-4 sagte in ESP HOME --- keine Installation möglich:
                                Bitte Editiere deinen ersten Beitrag und setze ein [Gelöst] vor den Titel
                                699
