    4. Fehler mit "neuer" Jarvis Installation
      M-A-X last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: QNAP Virtualisation Station
      Arbeitsspeicher: 3GB
      Festplattenart: virtuell
      Betriebssystem: Debian
      Laut folgendem Thread soll ich das hier posten 🙂
      https://forum.iobroker.net/topic/59201/jarvis-v3-1-x-just-another-remarkable-vis/547
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Architecture:   x86_64
      Docker:         false
      Virtualization: kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       17:51:06 up 5 days,  7:03,  3 users,  load average: 0.32, 0.25, 0.36
      CPU threads: 2
      *** Time and Time Zones ***
      Mon Feb 27 16:51:06 UTC 2023
      Mon Feb 27 17:51:06 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      max
      /home/max
      max cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.0G        2.2G        233M        0.0K        538M        605M
      Swap:           2.0G        316M        1.7G
      Total:          5.0G        2.5G        2.0G
               2987 M total memory
               2215 M used memory
               1588 M active memory
                956 M inactive memory
                233 M free memory
                154 M buffer memory
                384 M swap cache
               2044 M total swap
                316 M used swap
               1728 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  1.5G     0  1.5G   0% /dev
      tmpfs          tmpfs     299M  516K  299M   1% /run
      /dev/vda1      ext4      244G   15G  217G   7% /
      tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     299M     0  299M   0% /run/user/1000
      Messages in dmesg:
      [Wed Feb 22 10:47:40 2023] EXT4-fs (vda1): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Feb 22 10:47:46 2023] EXT4-fs (vda1): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems (real ones only):
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/vda1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.7G    /var/
      1.6G    /var/cache
      1.5G    /var/cache/apt/archives
      1.5G    /var/cache/apt
      993M    /var/log
      /opt/iobroker/backups:
      572M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      494M    /opt/iobroker/iobroker-data/
      281M    /opt/iobroker/iobroker-data/files
      131M    /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      44M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e8e2aac0.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.fe83292c.js.map
      16M     /opt/iobroker/iobroker-data/states.jsonl
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.1
      /usr/bin/node           v16.19.1
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.6
      javascript:     6.2.0
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.melcloud.0               : melcloud              : iobroker                                 -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.miio.0                   : miio                  : iobroker                                 - disabled
      + system.adapter.rct.0                    : rct                   : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Beta (latest)
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.3.6    , installed 6.3.6
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "backitup"     : 2.6.4    , installed 2.6.4
      Adapter    "ble"          : 0.13.3   , installed 0.13.3
      Adapter    "cloud"        : 4.3.1    , installed 4.3.1
      Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "ems-esp"      : 1.26.0   , installed 1.25.0 [Updatable]
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hm-rega"      : 3.0.44   , installed 3.0.44
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.4   , installed 1.14.3 [Updatable]
      Adapter    "jarvis"       : 3.1.3    , installed 3.1.3
      Adapter    "javascript"   : 7.0.1    , installed 6.2.0  [Updatable]
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "melcloud"     : 1.2.1    , installed 1.2.1
      Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
      Adapter    "miio"         : 0.0.13   , installed 0.0.13
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "rct"          : 1.0.1    , installed 1.0.1
      Adapter    "socketio"     : 6.3.3    , installed 6.3.3
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "web"          : 5.5.1    , installed 5.5.1
      Adapter    "ws"           : 2.3.5    , installed 2.3.5
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        9745
      States:         8302
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12776      505/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12770      505/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          767        1/init
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1049054    16881/io.jarvis.0
      tcp        0      0 192.168.9.77:42001      0.0.0.0:*               LISTEN      1001       1039305    16373/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12645      525/sshd: /usr/sbin
      tcp        0      0 192.168.9.77:42010      0.0.0.0:*               LISTEN      1001       1040362    16358/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14324      766/io.sonoff.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       15518      835/io.harmony.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          771        1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          13638      542/apache2
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12930      616/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       713934     11534/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12647      525/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       14639      946/io.simple-api.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13434      398/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          768        1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       14468      751/io.mihome-vacuu
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       15519      835/io.harmony.0
      udp6       0      0 :::111                  :::*                                0          774        1/init
      2023-02-27 17:23:34.950  - info: admin.0 (616) <== Disconnect system.user.admin from ::ffff:192.168.9.101 admin
      2023-02-27 17:25:24.562  - info: rct.0 (927) State value to set for "rct.0.fault.3_flt" has to be type "number" but received type "string"
      2023-02-27 17:27:14.547  - info: rct.0 (927) State value to set for "rct.0.g_sync.p_acc_lp" has to be type "number" but received type "string"
      2023-02-27 17:27:44.485  - info: rct.0 (927) State value to set for "rct.0.dc_conv.dc_conv_struct_1_p_dc_lp" has to be type "number" but received type "string"
      2023-02-27 17:28:54.547  - info: rct.0 (927) State value to set for "rct.0.dc_conv.dc_conv_struct_1_enabled" has to be type "number" but received type "string"
      2023-02-27 17:29:54.511  - info: rct.0 (927) State value to set for "rct.0.fault.3_flt" has to be type "number" but received type "string"
      2023-02-27 17:30:00.235  - info: host.iobroker instance system.adapter.ical.0 started with pid 18117
      2023-02-27 17:30:04.069  - info: ical.0 (18117) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.1, js-controller: 4.0.24
      2023-02-27 17:30:04.916  - info: ical.0 (18117) processing URL: Muell https://calendar.google.com/calendar/ical/73laqkpgt6l81ulvjff7685crc%40group.calendar.google.com/public/basic.ics
      2023-02-27 17:30:05.429  - info: javascript.0 (632) script.js.Müll: Start update
      2023-02-27 17:30:05.430  - info: javascript.0 (632) script.js.Müll: Rest: 2023-03-01
      2023-02-27 17:30:05.431  - info: javascript.0 (632) script.js.Müll: Gelb: 2023-03-03
      2023-02-27 17:30:05.431  - info: javascript.0 (632) script.js.Müll: Papier: 2023-03-14
      2023-02-27 17:30:10.538  - info: ical.0 (18117) Terminated (NO_ERROR): Without reason
      2023-02-27 17:30:11.082  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-02-27 17:31:54.586  - info: rct.0 (927) State value to set for "rct.0.fault.3_flt" has to be type "number" but received type "string"
      2023-02-27 17:35:07.333  - info: javascript.0 (632) script.js.Temperaturen.ZeitZuLueften: Temperatur hat sich geändert, Script startet:
      2023-02-27 17:35:07.335  - info: javascript.0 (632) script.js.Temperaturen.ZeitZuLueften: Timer läuft schon
      2023-02-27 17:41:44.680  - info: rct.0 (927) State value to set for "rct.0.g_sync.p_ac_load_sum_lp" has to be type "number" but received type "string"
      2023-02-27 17:45:44.762  - info: rct.0 (927) State value to set for "rct.0.g_sync.p_ac_grid_sum_lp" has to be type "number" but received type "string"
      2023-02-27 17:47:44.755  - info: rct.0 (927) State value to set for "rct.0.g_sync.p_ac_load_sum_lp" has to be type "number" but received type "string"
      2023-02-27 17:50:44.802  - info: rct.0 (927) State value to set for "rct.0.fault.2_flt" has to be type "number" but received type "string"
      2023-02-27 17:50:50.322  - info: admin.0 (616) ==> Connected system.user.admin from ::ffff:192.168.9.52
      2023-02-27 17:51:39.357  - info: javascript.0 (632) script.js.Temperaturen.ZeitZuLueften: Temperatur hat sich geändert, Script startet:
      2023-02-27 17:51:39.359  - info: javascript.0 (632) script.js.Temperaturen.ZeitZuLueften: Timer läuft schon
      M Thomas Braun 2 Replies Last reply Reply Quote 0
        MCU @M-A-X last edited by MCU
        @m-a-x Habe jetzt auch mal ein komplett neues System aufgesetzt und bekomme die Meldung.
        admin.0
        2023-02-27 18:15:20.340	warn	Active repository "stable" cannot be read
        admin.0
        2023-02-27 18:15:20.339	warn	Repository cannot be read: Active repo - stable
        Hast du die Meldung auch im LOG?
          Thomas Braun Most Active @M-A-X last edited by
          @m-a-x
          Bis auf ausstehenede Updates, dem aktiven Beta-Kanal und allgemein eng geschneiderten Systemressourcen (Nur 2 CPU-Kerne und magere 3 GB RAM) sind da keine groben Fehler zu sehen.
          Ich vermute die Maschine hat zu wenig Hubraum.
            Thomas Braun Most Active @MCU last edited by
            @mcu sagte in Fehler mit "neuer" Jarvis Installation:
            Wie ist denn das angelegt?
            iob repo list
              MCU @Thomas Braun last edited by
              @thomas-braun sagte in Fehler mit "neuer" Jarvis Installation:
              iob repo list
                @mcu
                Passt. Manchmal hat der Server aber auch Schluckauf. Später nochmal probieren.
                  M-A-X @Thomas Braun last edited by
                  @MCU
                  host.iobroker
                  	2023-02-27 18:38:33.092	info	Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                  Das bekomme ich wenn ich auf stable umstelle
                  die Updates (Skript Adapter und zwei weitere) habe ich absichtlich noch nicht gemacht. Skript ist mir noch zu heikel auf die 7.x zu gehen 🙂 und die anderen updates sind "erst" seit heute oder gestern online.
                  Beta Kanal ist aktiv, ja. Ich riskiere das immer mal und spiele notfalls ein Backup ein. Leider sind einige meiner Adapter nur im Beta zu gebrauchen (finde ich). Oder ich müsste die manuell über die "katze" holen.
                  Die Kerne und Ram kann ich bei Bedarf (da virtuelle Maschine) erhöhen. Was empfiehlst du? Ich habe noch weitere VMs laufen und möchte das Basissystem nicht UNNÖTIG in die Knie zwingen;)
                    Thomas Braun Most Active @M-A-X last edited by Thomas Braun
                    @m-a-x sagte in Fehler mit "neuer" Jarvis Installation:
                    Das habe ich gesehen.
                    Naja, was soll ich sagen. Ein Raspberry4 (4GB) ist besser ausgestattet.
                    Der werkelt mit 4 CPU-Threads und 4 GB RAM.
                      Skript ist mir noch zu heikel auf die 7.x zu gehen und die anderen updates sind "erst" seit heute oder gestern online.
                      Dann fahr besser stable. Ist ja nicht der Sinn und Zweck des Beta-Repos. Da soll ja gerade der 'heiße Scheiß' getestet werden.
                        M-A-X @Thomas Braun last edited by M-A-X
                        Hab die VM auf 4 Kerne (mehr hat mein NAS nicht) und 4 GB RAM erhöht. Läuft wirklich gefühlt etwas besser. Den Fehler mit der nicht angezeigten Stable Version von Jarvis ist weg. Entweder lag es also an der unpotenten VM oder da hat was gehangen (musste iobroker neu starten zum Erweitern der Kerne und des RAM).
                        Ich probiere gerne Betas aus, da ich dabei immer wieder was lerne und neue Features benutzen kann 😉 Nur beim Skript Adapter habe ich immer Angst, da dieser "zu wichtig" für mich ist. Ja, ich weiß, deshalb sollte man ein Test und ein Primärsystem haben...
                        "Gesamte RAM-Auslastung: 2601 Mb / Frei: 49% = 1943 Mb" vorher (mit 2 GB RAM) hatte ich 800 Mb Frei.. er nimmt sich wohl mehr, wenn er mehr hat 🙂
                          Natürlich. Ist das normale Verhalten eine Linux-Systems. Warum soll der sich auch mit weniger begnügen, wenn wertvoller Arbeitsspeicher zur Verfügung steht? Nur genutztes RAM ist gutes RAM.
                          534
