    4. Javaskript Fehler Ausgabe Was bedeutet Sie?
      Langer last edited by Langer
      Nach Umzug auf einen anderen Rechner:
      AMD Phenom(tm) II X6 1090T Processor mit 24GB RAM
      Node.js = 16.19.1
      NPM: 8.19.3
      js-controller: 4.0.24
      bekam ich nach Start eines Skriptes folgende Fehlermeldung im Protokoll:
       javascript.0
      2023-03-01 09:00:54.044	error	Exception-Code: EPIPE: write EPIPE
      javascript.0
      2023-03-01 09:00:54.044	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at Log.error (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/log.ts:45:21) at Object.error (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:33) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9341:44) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.043	error	uncaught exception: write EPIPE
      javascript.0
      2023-03-01 09:00:54.041	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.041	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      javascript.0
      2023-03-01 09:00:54.040	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9371:16) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      javascript.0
      javascript.0
      2023-03-01 09:00:54.039	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.039	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      javascript.0
      2023-03-01 09:00:54.038	error	Exception-Code: EPIPE: write EPIPE
      javascript.0
      javascript.0
      javascript.0
      2023-03-01 09:00:54.038	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at Log.error (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/log.ts:45:21) at Object.error (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:33) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9341:44) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.037	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.037	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      javascript.0
      2023-03-01 09:00:54.036	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9371:16) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      javascript.0
      2023-03-01 09:00:54.037	error	uncaught exception: write EPIPE
      javascript.0
      javascript.0
      2023-03-01 09:00:54.035	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.035	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      javascript.0
      2023-03-01 09:00:54.034	error	Exception-Code: EPIPE: write EPIPE
      javascript.0
      javascript.0
      javascript.0
      2023-03-01 09:00:54.034	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at Log.error (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/log.ts:45:21) at Object.error (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:33) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9341:44) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.033	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      2023-03-01 09:00:54.033	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      javascript.0
      2023-03-01 09:00:54.032	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9371:16) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
      javascript.0
      javascript.0
      2023-03-01 09:00:54.033	error	uncaught exception: write EPIPE
      javascript.0
      javascript.0
      2023-03-01 09:00:54.031	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      Es wird im Skript auch kein log ausgegeben.
      Frage 1: was stimmt da nicht?
      Frage 2: Es sind 24 GB RAM installiert, im Host wird folgende ausgegeben:
      CPU 7.07% RAM: 92.3%, heißt das jetzt,
      obwohl noch keine VIS läuft, nur ein kleines Script gelaufen ist, das bis auf 7.7% der gesamte Speicher in
      Benutzung ist?
      MfG
      Wastl
      Thomas Braun crunchip Codierknecht 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Langer last edited by
        @langer
        Schau mit
        iob diag
        nach. Das wertet u.a. auch den Speicher aus.
        • crunchip
          crunchip Forum Testing Most Active @Langer last edited by
          @langer sagte in Bin wieder mal mit meinem Latein am Ende:
          Benutzung ist?
          nein, das 92.3% frei sind
          • Codierknecht
            Codierknecht Developer Most Active @Langer last edited by
            @langer
            1.) Ändere bitte den Titel in etwas sinnvolleres. Unter dem aktuellen Titel kann sich wohl kaum jemand etwas vorstellen.
            2.) Packe die Logausgabe bitte in Code-Tags </> - auch hinter einem Spoiler. Das kann man so wie es ist kaum entziffern.
            https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
              Langer @Codierknecht last edited by
              @codierknecht
              Danke für die Anregung, wurde geändert.
              @crunchip
              @Thomas-Braun
              Dank für die Info's.
              Aber was sagt die Fehlermeldung aus?
              MfG
              Wastl
              Thomas Braun crunchip 2 Replies Last reply Reply Quote 1
                @langer
                Das hier ein Prozess nicht richtig mit einem anderen Prozess kommunizieren kann. Dazu werden 'Pipes' benutzt. Bei dir ist offenbar aber die Pfeiffe verstopft.
                • crunchip
                  @langer schwer zu sagen ohne das man das script kennt
