    4. Probleme Backitup laufen zu bekommen
    • O
      Oldschool last edited by
      Started iobroker ...
      [DEBUG] [mount] - Wake on LAN wait 25 Seconds for NAS!
      [DEBUG] [mount] - Wake on LAN MAC-Address: 00-11-32-44-25-C9
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//10.10.10.8","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":true,"macAd":"00-11-32-44-25-C9","wolTime":"25","smb":"vers=2.0","sudo":true,"cifsDomain":"DISKSTATION","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/66er Haus/Diverse/Smart Home/iobroker/Backup","dirMinimal":"/66er Haus/Diverse/Smart Home/iobroker/Backup","user":"Backup","pass":"****","ignoreErrors":false}
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups
      mount: bad usage
      Try 'mount --help' for more information.
      [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,domain=DISKSTATION,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //10.10.10.8/66er Haus/Diverse/Smart Home/iobroker/Backup /opt/iobroker/backups
      mount: bad usage
      Try 'mount --help' for more information.```
      Ich bin leider auch nicht gerade der erfahrenste User, aber vielleicht hat ja wer einen Tipp für mich.
      Bin für jede Hilfe dankbar
        Homoran Global Moderator Administrators @Oldschool last edited by
        @oldschool sagte in Probleme Backitup laufen zu bekommen:
        cifs-mount
        ist wie konfiguriert?
        mount: bad usage
        auch die Zusatzpakete installiert?
        Glaskugelmodus ist nicht wirklich einfach
        • Marc Berg
          Marc Berg Most Active @Homoran last edited by Marc Berg
          @homoran sagte in Probleme Backitup laufen zu bekommen:
          Darf man denn mehrere Quellverzeichnisse angeben?
            Homoran Global Moderator Administrators @Marc Berg last edited by Homoran
            @marc-berg sagte in Probleme Backitup laufen zu bekommen:
            deswegen wollte ich sehen wo das herkommt
            oder ist es ein Pfad mit Leerzeichen?
            • Marc Berg
              Ja, wenn man die Bestandteile zusammen nimmt, sieht das so aus.
                @marc-berg wer kommt denn auf so eine ... Idee, Leerzeichen in einem Pfad zu verwenden?
                @Oldschool bitte unbedingt die Konfig zeigen!
                  Thomas Braun Most Active @Oldschool last edited by Thomas Braun
                  mount: bad usage
                  Das liegt an den Leerzeichen im Pfad. Ersetz die im gesamten Pfad
                  /66er Haus/Diverse/Smart Home/iobroker/Backup mit z. B. Unterstrichen.
                  Und dann mal schauen ob der SMB-Server wirklich nur SMB 2.0 spricht. Besser 3.1.1. verwenden.
                  O 1 Reply Last reply Reply Quote 1
                  • O
                    Oldschool @Thomas Braun last edited by
                    @thomas-braun Danke für deinen Tipp, habe neuen Pfad angelegt und es damit wirklich hinbekommen. Läuft perfekt.
                    @Homoran und @Marc-Berg also den Ton hier muss ich erst gewohnt werden ;-). Ich bin leider einer der Nutzer die vieles aus dem Netz zusammenkopieren und auch teilweise YouTube Videos für solche Tools hernehmen. Daher bitte um etwas Nachsicht mit mir.
                    da_Woody Homoran Marc Berg 3 Replies Last reply Reply Quote 0
                    • da_Woody
                      da_Woody @Oldschool last edited by
                      was gefällt dir an dem ton hier nicht? in anderen foren würdest du schon ganz andere probs haben.
                      gerade anfänger werden da gut aufgenommen. hinweis auf informellere postings sind nicht böse gemeint...
                      du knallst da ein log rein, aber kein infos.
                      ergo: willkommen.gif
                        welchen Ton?
                        Fragen stellen um der Ursache auf den Grund zu gehen darf man doch noch, oder?
                        • Marc Berg
                          Marc Berg Most Active @Oldschool last edited by Marc Berg
                          Aha. Zeigst Du mir bitte ein Zitat von mir, als Beispiel? Ich bin ja bereit, an mir zu arbeiten.
                          135
