    4. javascript bleibt rot bei iob Neustart
    • bahnuhr
      wenn ich iob komplett neu starten, wird die Instanz von javascript nicht grün. Die Folge ist, dass meine ganzen Scripte nicht starten.
      Im log steht folgendes:
      host.iobroker
      2023-03-04 08:36:54.584	info	Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.iobroker
      2023-03-04 08:36:54.584	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-03-04 08:36:54.584	error	Caught by controller[0]: }
      host.iobroker
      2023-03-04 08:36:54.584	error	Caught by controller[0]: ]
      host.iobroker
      2023-03-04 08:36:54.584	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-03-04 08:36:54.583	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-03-04 08:36:54.583	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-03-04 08:36:54.583	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-03-04 08:36:54.583	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12) {
      host.iobroker
      2023-03-04 08:36:54.582	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
      host.iobroker
      2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
      host.iobroker
      2023-03-04 08:36:54.582	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
      host.iobroker
      2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:426:4)
      host.iobroker
      2023-03-04 08:36:54.582	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js:18:15)
      host.iobroker
      2023-03-04 08:36:54.581	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
      host.iobroker
      2023-03-04 08:36:54.581	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
      host.iobroker
      2023-03-04 08:36:54.581	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
      host.iobroker
      2023-03-04 08:36:54.581	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
      host.iobroker
      2023-03-04 08:36:54.581	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-03-04 08:36:54.580	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-03-04 08:36:54.580	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-03-04 08:36:54.580	error	Caught by controller[0]: Error: Cannot find module './sourcemap'
      host.iobroker
      2023-03-04 08:36:54.580	error	Caught by controller[0]: ^
      host.iobroker
      2023-03-04 08:36:54.579	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-03-04 08:36:54.579	error	Caught by controller[0]: node:internal/modules/cjs/loader:998
      host.iobroker
      2023-03-04 08:36:54.221	info	instance system.adapter.javascript.0 started with pid 13204
      Dort steht zum Schluss dann:
      Also in putty ausgeführt:
      cd /opt/iobroker/
      npm install javascript --production
      Danach die Intanz wieder neu gestartet und alles läuft wieder.
      Frage:
      Warum ist das so?
      und warum wird die Instanz nicht bei einem iob Neustart gleich grün ?
      Und: Wie kann ich dies beheben.
      Achja: überall auf stable; mit 1 oder 2 Ausnahmen (web, ws) wg. dort ws problem. Dort bin ich auf beta.
      mfg
      Dieter
      Homoran bahnuhr 3 Replies Last reply Reply Quote 0
        @bahnuhr sagte in javascript bleibt rot bei iob Neustart:
        ich bin jetzt nicht ganz sicher, ob du damit das
        wirklich umgesetzt hast.
        ich verstehe das so, dass du noch tiefer in die Struktur bis zum js-Adapter musst, und dort nicht
        eingeben sollst
          hattest du ein node Update gemacht?
          wird eigentlich nach einer node Änderung angestoßen.
          • bahnuhr
            bahnuhr Forum Testing Most Active @Homoran last edited by
            @homoran sagte in javascript bleibt rot bei iob Neustart:
            Ne, das ist mir schon öfters passiert mit dem js adapter
            heute nacht um 03:00 iob neu getartet und dann ging nichts mehr
            nach
            ging es ja wieder (kann doch dann nicht ganz falsch gewesen sein)
              vielleicht sogar besser, und der Adapter hat es auf dem "richtigen" Weg nicht geschafft 😂
              • bahnuhr
                so, hab jetzt mal
                im Ordner: node-modules/iobroker.javascript
                ausgeführt und danach iob komplett neu gestartet.
                Jetzt ist auch JS sofort grün.
                Komisch; aber scheint nun korrekt zu laufen.
                Danke @Homoran für den Schubser in die offensichtlich richtige Richtung.
                Gargano Thomas Braun 2 Replies Last reply Reply Quote 0
                • Gargano
                  Gargano @bahnuhr last edited by
                  Danke, hatte das gleiche Problem mit der 7.01
                    Thomas Braun Most Active @bahnuhr last edited by
                    Ist obsolet mit aktuellen npm Versionen.
                    Es soll nun
                    npm install --omit=dev
                    verwendet werden.
                    bahnuhr Gargano 2 Replies Last reply Reply Quote 0
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @Thomas Braun last edited by bahnuhr
                      Das kann man aber nicht wissen.
                      Zumal im log ja was anderes stand.
                      Aber Danke für die Info.
                      Muss ich mir mal aufschreiben.
                        Thomas Braun Most Active @bahnuhr last edited by Thomas Braun
                        Im Log steht eigentlich genau das drin, wenn man --production verwendet.
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @bahnuhr last edited by
                          @Thomas-Braun
                          das stand im log
                          • Gargano
                            Gargano @Thomas Braun last edited by
                            Was ist die empfohlene npm und nodejs Version aktuell ?
                            Ist das irgendwo immer aktuell beshrieben ? Hab leider nichts gefunden
                            bahnuhr Thomas Braun 2 Replies Last reply Reply Quote 0
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @Gargano last edited by
                              @gargano sagte in javascript bleibt rot bei iob Neustart:
                              steht doch bei Info drin:
                                Thomas Braun Most Active @Gargano last edited by
                                @gargano
                                Nodejs@16, die bringt die passende npm@8 gleich richtig mit.
                                Wenn nodejs denn richtig installiert wurde.
                                Gargano 1 Reply Last reply Reply Quote 0
                                • Gargano
                                  @bahnuhr
                                  Danke , dann habe ich die aktuellste
                                  Manchmal sieht man halt den Wald vor lauter Bäumen nicht. 🙄
                                    @gargano
                                    iob diag
                                    sagt? Die Summary reicht.
                                    • Gargano
                                                           v.2023-01-02
                                      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                                      Installation:           Native
                                      Timezone:               Europe/Berlin
                                      User-ID:                1000
                                      X-Server:               false
                                      Pending OS-Updates:     0
                                      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                              /usr/bin/node           v16.19.1
                                                              /usr/bin/npm            8.19.3
                                                              /usr/bin/npx            8.19.3
                                      ioBroker Core:          js-controller           4.0.24
                                                              admin                   6.3.6
                                      At least one iobroker host is running.
                                      Objects type: redis
                                      States  type: redis
                                      Status admin:
                                      Pending iob updates:    1
                                      Active repo(s): Beta (latest)
                                      Objects:                19917
                                      States:                 18221
                                      Size of iob-Database:
                                      5.2M    /opt/iobroker/iobroker-data/objects.json.bak
                                      40K     /opt/iobroker/iobroker-data/states.json.bak
                                        @gargano
                                        Passt grundsätzlich.
                                        Schaufel das Update beim iobroker noch rein und stell das RunLevel / Boot Target auf Multi-User um.
                                        • Gargano
                                          Das pending Update ist der Gerätemanager, der ist noch auf 1.1.1 , weil der 1.1.2 buggy ist und nicht funktioniert.
                                          Warum boot Target auf multi User ?
                                            @gargano
                                            Weil Multi-User/ RunLevel 3 für den Betrieb als Server die richtige Einstellung ist.
                                            iob neutstart javascript
                                            682
