    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Управление GPIO в orange pi zero
      leikocid last edited by
      Доброго дня, подскажите кто знает при помощи чего можно реализовать управление GPIO orange pi zero к которой будут подключены релейные модули для управления светом, спасибо
        Alekseym6 last edited by
        ! var gpio = require("gpio");
        ! var gpioSensDoor = 87;
        ! var gpioRelLamp1 = 88;
        ! var gpioSensMotion = 89;
        ! var gpioRelLamp2 = 94;
        ! createState('SensDoor','',{type:'boolean',role:'indicator.state',read:true});
        ! createState('RelLamp1','',{type:'boolean',role:'indicator.state',read:true});
        ! createState('RelLamp2','',{type:'boolean',role:'indicator.state',read:true});
        ! createState('SensMotionVestibul','',{type:'boolean',role:'indicator.state',read:true});
        ! var gpioObjsCount1, gpioObjsCount2, gpioObjsCount3, gpioObjsCount4, gpioObjsCount5, gpioObjsCount6,
        ! gpioObjsCount7, gpioObjsCount8, gpioObjsCount9, gpioObjsCount10, gpioObjsCount11, gpioObjsCount12,
        ! gpioObjsCount13, gpioObjsCount14, gpioObjsCount15, gpioObjsCount16, gpioObjsCount17;
        ! // Calling export with a pin number will export that header and return a gpio header instance
        ! var gpio87 = gpio.export(gpioSensDoor, {
        ! // When you export a pin, the default direction is out. This allows you to set
        ! // the pin value to either LOW or HIGH (3.3V) from your program.
        ! direction: 'in',
        ! // set the time interval (ms) between each read when watching for value changes
        ! // note: this is default to 100, setting value too low will cause high CPU usage
        ! interval: 100,
        ! // Due to the asynchronous nature of exporting a header, you may not be able to
        ! // read or write to the header right away. Place your logic in this ready
        ! // function to guarantee everything will get fired properly
        ! ready: function() {
        ! var gpio88 = gpio.export(gpioRelLamp1, {
        ! direction: 'out',
        ! var gpio89 = gpio.export(gpioSensMotion, {
        ! direction: 'in',
        ! var gpio94 = gpio.export(gpioRelLamp2, {
        ! direction: 'out',
        ! // bind to the "change" event
        ! gpio87.on("change", function(val) {
        ! // value will report either 1 or 0 (number) when the value changes
        ! if ( val == 1 ) {
        ! setState('SensDoor', true, true);
        ! } else {
        ! setState('SensDoor', false, true);
        ! gpio89.on("change", function(val) {
        ! if ( val == 1 ) {
        ! setState('SensMotionVestibul', true, true);
        ! } else {
        ! setState('SensMotionVestibul', false, true);
        ! on("RelLamp1", function (obj) {
        ! if ( obj.newState.val == 1 ) {
        ! gpio88.set();
        ! } else {
        ! gpio88.set(0);
        ! on("RelLamp2", function (obj) {
        ! gpio94.set();
        ! } else {
        ! gpio94.set(0);
