    4. [gelöst]JavaScript Adapter bleibt rot
    • heinhan
      heinhan last edited by heinhan
      Hallo, nach dem ich meinen Raspi neu starten musste (Stromunterbrechung) bliebt der JavaScript Adapter rot. IOB fix brachte nix. Altes Backup eingespielt auch nicht. Hier die LOG:
      host.Iobroker
      2023-03-27 09:21:37.464	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Iobroker
      2023-03-27 09:21:37.464	error	Caught by controller[0]: Node.js v18.15.0
      host.Iobroker
      2023-03-27 09:21:37.464	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
      host.Iobroker
      2023-03-27 09:21:37.464	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      host.Iobroker
      2023-03-27 09:21:37.464	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12)
      host.Iobroker
      2023-03-27 09:21:37.464	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.Iobroker
      2023-03-27 09:21:37.463	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.Iobroker
      2023-03-27 09:21:37.463	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1218:27)
      host.Iobroker
      2023-03-27 09:21:37.463	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1176:20)
      host.Iobroker
      2023-03-27 09:21:37.463	error	Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
      host.Iobroker
      2023-03-27 09:21:37.463	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
      host.Iobroker
      2023-03-27 09:21:37.463	error	Caught by controller[0]: ���� � }
      host.Iobroker
      2023-03-27 09:21:37.462	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/main.js:2397
      System ist auf neusten Stand. Was kann ich noch machen?
      arteck Thomas Braun 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @heinhan last edited by
        @heinhan sagte in JavaScript Adapter bleibt rot:
        javascript
        welche Version ist installiert ?
          Thomas Braun Most Active @heinhan last edited by
          host.Iobroker
          Schaut wie eine korrupte Datei aus.
          iob diag
          sagt? Adapter neuinstallieren und hoffen das die defekte Speicherzelle da nicht wieder reinspuckt.
          heinhan 1 Reply Last reply Reply Quote 0
          • heinhan
            heinhan @Thomas Braun last edited by
            @thomas-braun Hier Auszugsweise die LOG vom diag mit den errors:
            2023-03-27 09:58:41.745  - error: javascript.0 (27510) Cannot install cmoment-duration-format: 1
            2023-03-27 09:58:41.748  - info: javascript.0 (27510) npm install cmoment-duration-format --omit=dev (System call)
            2023-03-27 09:58:53.478  - error: javascript.0 (27510) npm
            2023-03-27 09:58:53.481  - error: javascript.0 (27510)
            2023-03-27 09:58:53.483  - error: javascript.0 (27510) ERR!
            2023-03-27 09:58:53.486  - error: javascript.0 (27510)  code E404
            2023-03-27 09:58:53.496  - error: javascript.0 (27510) npm
            2023-03-27 09:58:53.498  - error: javascript.0 (27510)  ERR! 404 Not Found - GET https://registry.npmjs.org/cmoment-duration-format - Not found
            npm ERR!
            2023-03-27 09:58:53.501  - error: javascript.0 (27510) 404
            npm ERR! 404  'cmoment-duration-format@*' is not in this registry.
            2023-03-27 09:58:53.503  - error: javascript.0 (27510) npm ERR! 404
            npm ERR! 404 Note that you can also install from a
            npm ERR! 404 tarball, folder, http url, or git url.
            2023-03-27 09:58:53.508  - error: javascript.0 (27510)
            2023-03-27 09:58:53.511  - error: javascript.0 (27510) npm ERR! A complete log of this run can be found in:
            npm ERR!     /home/iobroker/.npm/_logs/2023-03-27T07_58_48_138Z-debug-0.log
            2023-03-27 09:58:53.537  - error: javascript.0 (27510) Cannot install cmoment-duration-format: 1
            2023-03-27 09:58:53.538  - info: javascript.0 (27510) npm install cmoment-duration-format --omit=dev (System call)
            Warte Deinen Kommentar dazu ab, bevor ich den Adater neu installiere
              @heinhan
              Zeig mal den vollständigen Output.
              heinhan 2 Replies Last reply Reply Quote 0
              • heinhan
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Model : Raspberry Pi 4 Model B Rev 1.1
                Architecture: aarch64
                Docker: false
                Virtualization: none
                Distributor ID: Debian
                Description: Debian GNU/Linux 11 (bullseye)
                Release: 11
                Codename: bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Systemuptime and Load:
                10:15:37 up 1:24, 3 users, load average: 1.45, 1.23, 0.85
                CPU threads: 4
                *** Time and Time Zones ***
                Mon Mar 27 08:15:37 UTC 2023
                Mon Mar 27 10:15:37 CEST 2023
                CEST +0200
                Europe/Berlin
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server: true
                Desktop:
                Terminal: tty
                Boot Target: graphical.target
                *** MEMORY ***
                total used free shared buff/cache available
                Mem: 3.8G 2.7G 271M 20M 816M 936M
                Swap: 99M 2.0M 97M
                Total: 3.9G 2.7G 368M
                     3794 M total memory
                     2706 M used memory
                     1214 M active memory
                     1950 M inactive memory
                      271 M free memory
                        6 M buffer memory
                      809 M swap cache
                       99 M total swap
                        2 M used swap
                       97 M free swap
                *** FILESYSTEM ***
                Filesystem Type Size Used Avail Use% Mounted on
                /dev/root ext4 59G 9.8G 47G 18% /
                devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
                tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
                tmpfs tmpfs 759M 1.3M 758M 1% /run
                tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
                /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot
                tmpfs tmpfs 380M 24K 380M 1% /run/user/1000
                Messages in dmesg:
                [Mon Mar 27 08:51:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1024x768M@60D smsc95xx.macaddr=DC:A6:32:21:7F:6F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=fbeefd61-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Mon Mar 27 08:51:26 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                [Mon Mar 27 08:51:26 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                [Mon Mar 27 08:51:28 2023] EXT4-fs (mmcblk0p2): recovery complete
                [Mon Mar 27 08:51:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Mon Mar 27 08:51:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Mon Mar 27 08:51:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                Show mounted filesystems (real ones only):
                TARGET SOURCE FSTYPE OPTIONS
                / /dev/mmcblk0p2 ext4 rw,noatime
                `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                2.1G /var/
                946M /var/log
                937M /var/log/journal/ab9475037d6146b8b11526850eaf194c
                666M /var/cache
                /opt/iobroker/backups:
                697M /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                632M /opt/iobroker/iobroker-data/
                490M /opt/iobroker/iobroker-data/files
                89M /opt/iobroker/iobroker-data/backup-objects
                78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                72M /opt/iobroker/iobroker-data/files/telegram.admin
                28M /opt/iobroker/iobroker-data/objects.jsonl
                20M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
                19M /opt/iobroker/iobroker-data/states.jsonl
                19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                18M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs v18.15.0
                /usr/bin/node v18.15.0
                /usr/bin/npm 9.5.0
                /usr/bin/npx 9.5.0
                nodejs:
                Installed: 18.15.0-deb-1nodesource1
                Candidate: 18.15.0-deb-1nodesource1
                Version table:
                *** 18.15.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
                12.22.12~dfsg-1~deb11u3 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States type: jsonl
                Core adapters versions
                js-controller: 4.0.24
                admin: 6.4.1
                javascript: 7.0.3
                Adapters from github: 3
                Adapter State
                • system.adapter.admin.0 : admin : Iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                • system.adapter.alarm.0 : alarm : Iobroker - enabled
                  system.adapter.alexa-timer-vis.0 : alexa-timer-vis : Iobroker - disabled
                • system.adapter.alexa2.0 : alexa2 : Iobroker - enabled
                • system.adapter.backitup.0 : backitup : Iobroker - enabled
                  system.adapter.broadlink2.0 : broadlink2 : Iobroker - disabled
                • system.adapter.cloud.0 : cloud : Iobroker - enabled
                  system.adapter.daswetter.0 : daswetter : Iobroker - enabled
                • system.adapter.deconz.0 : deconz : Iobroker - enabled, port: 80
                • system.adapter.device-reminder.0 : device-reminder : Iobroker - enabled
                • system.adapter.discovery.0 : discovery : Iobroker - enabled
                • system.adapter.easee.0 : easee : Iobroker - enabled
                • system.adapter.fb-checkpresence.0 : fb-checkpresence : Iobroker - enabled
                • system.adapter.firetv.0 : firetv : Iobroker - enabled
                  system.adapter.flot.0 : flot : Iobroker - enabled
                • system.adapter.fully-tablet-control.0 : fully-tablet-control : Iobroker - enabled
                • system.adapter.fullybrowser.0 : fullybrowser : Iobroker - enabled
                • system.adapter.history.0 : history : Iobroker - enabled
                • system.adapter.hm-rega.0 : hm-rega : Iobroker - enabled
                • system.adapter.hm-rpc.0 : hm-rpc : Iobroker - enabled, port: 18701
                • system.adapter.hm-rpc.1 : hm-rpc : Iobroker - enabled, port: 12001
                • system.adapter.hm-rpc.2 : hm-rpc : Iobroker - enabled, port: 12010
                • system.adapter.hm-rpc.3 : hm-rpc : Iobroker - enabled, port: 0
                  system.adapter.ical.0 : ical : Iobroker - enabled
                  system.adapter.ical.1 : ical : Iobroker - enabled
                  system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : Iobroker - enabled
                  system.adapter.icons-icons8.0 : icons-icons8 : Iobroker - enabled
                  system.adapter.icons-mfd-png.0 : icons-mfd-png : Iobroker - enabled
                  system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Iobroker - enabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Iobroker - enabled
                • system.adapter.influxdb.0 : influxdb : Iobroker - enabled, port: 443
                • system.adapter.influxdb.1 : influxdb : Iobroker - enabled, port: 8086
                • system.adapter.info.0 : info : Iobroker - enabled
                • system.adapter.iot.0 : iot : Iobroker - enabled
                • system.adapter.javascript.0 : javascript : Iobroker - enabled
                  system.adapter.logparser.0 : logparser : Iobroker - disabled
                • system.adapter.mercedesme.0 : mercedesme : Iobroker - enabled
                  system.adapter.mobile.0 : mobile : Iobroker - enabled
                  system.adapter.netatmo-crawler.0 : netatmo-crawler : Iobroker - enabled
                • system.adapter.netatmo.0 : netatmo : Iobroker - enabled
                • system.adapter.pollenflug.1 : pollenflug : Iobroker - enabled
                • system.adapter.pushover.0 : pushover : Iobroker - enabled
                • system.adapter.rpi2.0 : rpi2 : Iobroker - enabled
                • system.adapter.sayit.0 : sayit : Iobroker - enabled
                • system.adapter.socketio.0 : socketio : Iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin
                • system.adapter.sonoff.0 : sonoff : Iobroker - enabled, port: 1883, bind: 192.168.178.28
                • system.adapter.sonos.0 : sonos : Iobroker - enabled
                  system.adapter.sourceanalytix.0 : sourceanalytix : Iobroker - disabled
                • system.adapter.telegram.0 : telegram : Iobroker - enabled, port: 8443, bind: 0.0.0.0
                • system.adapter.text2command.0 : text2command : Iobroker - enabled
                • system.adapter.tr-064.0 : tr-064 : Iobroker - enabled
                • system.adapter.trashschedule.0 : trashschedule : Iobroker - enabled
                  system.adapter.tvspielfilm.0 : tvspielfilm : Iobroker - disabled
                • system.adapter.upnp.0 : upnp : Iobroker - enabled
                  system.adapter.vis-bars.0 : vis-bars : Iobroker - enabled
                  system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Iobroker - enabled
                  system.adapter.vis-fancyswitch.0 : vis-fancyswitch : Iobroker - enabled
                  system.adapter.vis-google-fonts.0 : vis-google-fonts : Iobroker - enabled
                  system.adapter.vis-history.0 : vis-history : Iobroker - enabled
                  system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Iobroker - enabled
                • system.adapter.vis-inventwo.0 : vis-inventwo : Iobroker - enabled
                  system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Iobroker - enabled
                  system.adapter.vis-justgage.0 : vis-justgage : Iobroker - enabled
                  system.adapter.vis-map.0 : vis-map : Iobroker - enabled
                  system.adapter.vis-materialdesign.0 : vis-materialdesign : Iobroker - enabled
                  system.adapter.vis-metro.0 : vis-metro : Iobroker - enabled
                  system.adapter.vis-players.0 : vis-players : Iobroker - enabled
                  system.adapter.vis-plumb.0 : vis-plumb : Iobroker - enabled
                  system.adapter.vis-timeandweather.0 : vis-timeandweather : Iobroker - enabled
                  system.adapter.vis-weather.0 : vis-weather : Iobroker - enabled
                  system.adapter.vis.0 : vis : Iobroker - enabled
                  system.adapter.weatherunderground.0 : weatherunderground : Iobroker - enabled
                • system.adapter.web.0 : web : Iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.yr.0 : yr : Iobroker - enabled
                • instance is alive
                ioBroker-Repositories
                stable : http://download.iobroker.net/sources-dist.json
                beta : http://download.iobroker.net/sources-dist-latest.json
                Active repo(s): beta
                Installed ioBroker-Instances
                Used repository: beta
                Adapter "admin" : 6.4.1 , installed 6.4.1
                Adapter "alarm" : 3.3.9 , installed 3.3.9
                Adapter "alexa-timer-vis": 0.1.14 , installed 0.1.14
                Adapter "alexa2" : 3.23.2 , installed 3.23.2
                Adapter "backitup" : 2.6.14 , installed 2.6.14
                Adapter "broadlink2" : 2.1.5 , installed 2.1.5
                Adapter "cloud" : 4.3.1 , installed 4.3.1
                Adapter "daswetter" : 3.1.7 , installed 3.1.7
                Adapter "deconz" : 1.3.21 , installed 2.0.5
                Adapter "device-reminder": 1.2.9 , installed 1.2.9
                Adapter "discovery" : 3.1.0 , installed 3.1.0
                Adapter "easee" : 1.0.7 , installed 1.0.7
                Adapter "fb-checkpresence": 1.1.25, installed 1.1.25
                Adapter "firetv" : 1.0.0 , installed 1.0.0
                Adapter "flot" : 1.12.0 , installed 1.12.0
                Adapter "fullybrowser" : 2.1.2 , installed 2.1.2
                Adapter "history" : 2.2.4 , installed 2.2.4
                Adapter "hm-rega" : 3.0.44 , installed 3.0.44
                Adapter "hm-rpc" : 1.15.16 , installed 1.15.16
                Adapter "ical" : 1.13.2 , installed 1.13.2
                Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
                Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
                Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
                Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter "influxdb" : 3.2.0 , installed 3.2.0
                Adapter "info" : 1.9.26 , installed 1.9.26
                Adapter "iot" : 1.14.5 , installed 1.14.5
                Adapter "javascript" : 7.0.3 , installed 7.0.3
                Controller "js-controller": 4.0.24 , installed 4.0.24
                Adapter "logparser" : 2.1.0 , installed 2.1.0
                Adapter "mercedesme" : 0.1.1 , installed 0.1.1
                Adapter "mobile" : 1.0.1 , installed 1.0.1
                Adapter "netatmo" : 3.1.0 , installed 3.1.0
                Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
                Adapter "pollenflug" : 1.0.6 , installed 1.0.6
                Adapter "pushover" : 3.0.3 , installed 3.0.3
                Adapter "rpi2" : 1.3.2 , installed 1.3.2
                Adapter "sayit" : 2.1.1 , installed 2.1.1
                Adapter "simple-api" : 2.7.2 , installed 2.7.2
                Adapter "socketio" : 6.3.5 , installed 6.3.5
                Adapter "sonoff" : 2.5.1 , installed 2.5.1
                Adapter "sonos" : 2.3.1 , installed 2.3.1
                Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
                Adapter "telegram" : 1.15.6 , installed 1.15.6
                Adapter "text2command" : 3.0.2 , installed 3.0.2
                Adapter "tr-064" : 4.2.18 , installed 4.2.18
                Adapter "trashschedule": 2.2.0 , installed 2.2.0
                Adapter "tvspielfilm" : 2.0.5 , installed 2.0.5
                Adapter "upnp" : 1.0.21 , installed 1.0.21
                Adapter "vis" : 1.4.16 , installed 1.4.16
                Adapter "vis-bars" : 0.1.4 , installed 0.1.4
                Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
                Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
                Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
                Adapter "vis-history" : 1.0.0 , installed 1.0.0
                Adapter "vis-hqwidgets": 1.3.1 , installed 1.3.1
                Adapter "vis-icontwo" : 0.90.0 , installed 0.90.0
                Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
                Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
                Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
                Adapter "vis-map" : 1.0.4 , installed 1.0.4
                Adapter "vis-materialdesign": 0.5.9, installed 0.5.94
                Adapter "vis-metro" : 1.2.0 , installed 1.2.0
                Adapter "vis-players" : 0.1.6 , installed 0.1.6
                Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
                Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
                Adapter "vis-weather" : 2.5.6 , installed 2.5.6
                Adapter "weatherunderground": 3.4.2, installed 3.4.2
                Adapter "web" : 5.5.3 , installed 5.5.3
                Adapter "ws" : 2.3.6 , installed 2.3.6
                Adapter "yr" : 5.3.0 , installed 5.3.0
                Objects and States
                Objects: 30514
                States: 26104
                Hit:1 https://apt.grafana.com stable InRelease
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
                Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                Hit:5 http://deb.debian.org/debian bullseye InRelease
                Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:7 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:8 https://repos.influxdata.com/debian stable InRelease
                Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15781 641/vncserver-x11-c
                tcp 0 0 192.168.178.28:12010 0.0.0.0:* LISTEN 1001 144371 9955/io.hm-rpc.2
                tcp 0 0 192.168.178.28:12001 0.0.0.0:* LISTEN 1001 146477 9938/io.hm-rpc.1
                tcp 0 0 192.168.178.28:1883 0.0.0.0:* LISTEN 1001 145073 10131/io.sonoff.0
                tcp 0 0 192.168.178.28:2001 0.0.0.0:* LISTEN 1001 144941 10007/io.hm-rpc.3
                tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 15759 627/cupsd
                tcp 0 0 192.168.178.28:18701 0.0.0.0:* LISTEN 1001 144304 9882/io.hm-rpc.0
                tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 143564 9575/iobroker.js-co
                tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 142926 9575/iobroker.js-co
                tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 12173 414/deCONZ
                tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15749 646/sshd: /usr/sbin
                tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14818 414/deCONZ
                tcp6 0 0 :::8000 :::* LISTEN 1001 231971 11167/io.upnp.0
                tcp6 0 0 :::5900 :::* LISTEN 0 15780 641/vncserver-x11-c
                tcp6 0 0 :::8081 :::* LISTEN 1001 143887 9632/io.admin.0
                tcp6 0 0 :::8082 :::* LISTEN 1001 207741 11152/io.web.0
                tcp6 0 0 :::8084 :::* LISTEN 1001 174788 10993/io.socketio.0
                tcp6 0 0 :::8086 :::* LISTEN 999 17797 636/influxd
                tcp6 0 0 :::3500 :::* LISTEN 1001 146885 10227/io.sonos.0
                tcp6 0 0 :::3000 :::* LISTEN 116 16964 628/grafana
                tcp6 0 0 ::1:631 :::* LISTEN 0 15758 627/cupsd
                tcp6 0 0 :::22 :::* LISTEN 0 15751 646/sshd: /usr/sbin
                udp 0 0 0.0.0.0:631 0.0.0.0:* 0 12202 657/cups-browsed
                udp 0 0 0.0.0.0:49789 0.0.0.0:* 108 11994 408/avahi-daemon: r
                udp 0 0 0.0.0.0:33468 0.0.0.0:* 1001 201102 11167/io.upnp.0
                udp 0 0 192.168.178.26:5353 0.0.0.0:* 1001 146141 10244/io.tr-064.0
                udp 0 0 192.168.178.28:5353 0.0.0.0:* 1001 146140 10244/io.tr-064.0
                udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11992 408/avahi-daemon: r
                udp 0 0 0.0.0.0:52871 0.0.0.0:* 1001 201101 11167/io.upnp.0
                udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 209349 11167/io.upnp.0
                udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 209348 11167/io.upnp.0
                udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 146384 10483/io.deconz.0
                udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 146380 10483/io.deconz.0
                udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 14871 414/deCONZ
                udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12194 509/dhcpcd
                udp6 0 0 :::546 :::* 0 16577 509/dhcpcd
                udp6 0 0 :::41988 :::* 108 11995 408/avahi-daemon: r
                udp6 0 0 :::5353 :::* 108 11993 408/avahi-daemon: r
                udp6 0 0 :::1900 :::* 1001 146387 10483/io.deconz.0
                udp6 0 0 :::1900 :::* 1001 146386 10483/io.deconz.0
                udp6 0 0 :::1900 :::* 1001 146385 10483/io.deconz.0
                udp6 0 0 :::1900 :::* 1001 146383 10483/io.deconz.0
                udp6 0 0 :::1900 :::* 1001 146382 10483/io.deconz.0
                udp6 0 0 :::1900 :::* 1001 146381 10483/io.deconz.0
                2023-03-27 10:12:14.590 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.23h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:14.760 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.24h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:14.954 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.25h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:15.091 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.26h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:15.249 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.27h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:15.453 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.28h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:15.595 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:15.756 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:15.882 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:16.077 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:16.190 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:16.302 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:16.441 - info: weatherunderground.0 (33093) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
                2023-03-27 10:12:18.525 - info: weatherunderground.0 (33093) Terminated (NO_ERROR): Without reason
                2023-03-27 10:12:19.102 - info: host.Iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                2023-03-27 10:13:02.571 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ff175.group" has to be type "number" but received type "string"
                2023-03-27 10:13:02.614 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ff175.group" has to be type "number" but received type "string"
                2023-03-27 10:13:13.884 - info: easee.0 (10569) undefined is not a valid state value for id "easee.0.EHCL6ZL7.status.latestFirmware"
                2023-03-27 10:15:00.104 - info: host.Iobroker instance system.adapter.netatmo-crawler.0 started with pid 35549
                2023-03-27 10:15:04.515 - info: netatmo-crawler.0 (35549) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.15.0, js-controller: 4.0.24
                2023-03-27 10:15:04.588 - info: netatmo-crawler.0 (35549) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                2023-03-27 10:15:05.147 - info: host.Iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-03-27 10:15:24.291 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ac2c9.group" has to be type "number" but received type "string"
                2023-03-27 10:15:24.335 - info: deconz.0 (10483) State value to set for "deconz.0.sensors.00178801086ac2c9.group" has to be type "number" but received type "string"
                2023-03-27 10:16:14.381 - info: easee.0 (10569) undefined is not a valid state value for id "easee.0.EHCL6ZL7.status.latestFirmware"
                iob diag has finished.
                Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                Installation:           Native
                Timezone:               Europe/Berlin
                User-ID:                1000
                X-Server:               true
                Pending OS-Updates:     0
                Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                        /usr/bin/npm            9.5.0
                                        /usr/bin/npx            9.5.0
                ioBroker Core:          js-controller           4.0.24
                                        admin                   6.4.1
                Objects type: jsonl
                States  type: jsonl
                Status admin:
                + system.adapter.admin.0                  : admin                 : Iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                Pending iob updates:    0
                Objects:                30514
                States:                 26104
                Size of iob-Database:
                20M     /opt/iobroker/iobroker-data/states.jsonl
                • heinhan
                  @thomas-braun Jetzt läuft der Adapter wie von Geisteshand!! Nichts gemacht außer DIAG.
                    @heinhan
                    Knips den Desktop aus und geh da nicht per VNC sondern über die Kommandozeile per SSH auf die Kiste.
                    • heinhan
                      @thomas-braun mache ich, hatte diesen mal für Testzwecke aktiviert.
                      javascript.0
