    4. (Gelöst)Mist gebaut beim entfernen von Pihole
    • Damrak2022
      Damrak2022 last edited by Damrak2022
      Ich habe mein Pihole runtergeworfen, da ich damit nicht so ganz klar kam.
      Also habe ich den Befehl "Pihole uninstall" genutzt und alle Abfragen mit Yes bestätigt, was wohl falsch war.
      Jetzt wollte ich mein wöchentliches Update machen - also iob stop, sudo apt update usw. und habe mir nun diese Fehler eingehandelt:
      pi@homebridge:~ $ iobroker stop
      pi@homebridge:~ $ sudo apt update
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 http://deb.debian.org/debian bullseye InRelease
      OK:3 http://deb.debian.org/debian bullseye-updates InRelease
      OK:4 http://security.debian.org/debian-security bullseye-security InRelease
      Fehl:5 https://download.docker.com/linux/debian bullseye InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2240:f400:3:db06:4200:93a1 443]
      Fehl:6 https://apt.grafana.com stable InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
      Fehl:7 https://repos.influxdata.com/debian stable InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:ca00:11:fe8d:7d40:93a1 443]
      Fehl:8 https://deb.nodesource.com/node_16.x bullseye InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:280:3::213:788d 443]
      Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6900:6b28:6a2f:3ff1:92e4 443]
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Alle Pakete sind aktuell.
      W: https://repos.influxdata.com/debian/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://download.docker.com/linux/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://apt.grafana.com/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
      W: Fehlschlag beim Holen von https://download.docker.com/linux/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2240:f400:3:db06:4200:93a1 443]
      W: Fehlschlag beim Holen von https://apt.grafana.com/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
      W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:ca00:11:fe8d:7d40:93a1 443]
      W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:280:3::213:788d 443]
      W: Fehlschlag beim Holen von https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6900:6b28:6a2f:3ff1:92e4 443]
      W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
      Wie bekomme ich das wieder hin?
      haselchen OliverIO 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Damrak2022 last edited by
        @damrak2022
        Hattest du in deinem Router die Einträge für den DNS Server verändert ?
        Damrak2022 1 Reply Last reply Reply Quote 0
        • Damrak2022
          Damrak2022 @haselchen last edited by
          @haselchen Ja, aber ich bin der Meinung das es danach noch ging. Aber ich werde in Zukunft die Finger von solchen Experimenten wie PiHole lassen. da fehlt mir einfach das Hintergrundwissen. Hauptsachen ich bekomme meine normale Installation mal wieder so hin, das alles sauber läuft.
          • haselchen
            @damrak2022
            Hatte auch ähnliche Probleme nach der Deinstallation. Hat mir alles zerschossen danach .
            Deshalb habe ich auch Pihole ad acta gelegt .
            • Damrak2022
              @haselchen Hast Du eine Ahnung wie ich das wieder hinbekomme?
              • haselchen
                @damrak2022
                Ich hatte einige IP in den DNS Server Einstellungen geändert .
                Hab das auf die Router IP geändert und Router neugestartet. Ich meine , dann war alles wieder okay.
                • Damrak2022
                  @haselchen Nein, bei mir leider nicht, denn ich habe die Abfragen alle bestätigt beim entfernen vom Pihole.
                  • OliverIO
                    OliverIO @Damrak2022 last edited by
                    @damrak2022
                    Steht da nicht schon die Lösung?
                    Das Paket ca-certificates enthält die wichtigsten Root Zertifikate für die ssl Kommunikation
                    • Damrak2022
                      Damrak2022 @OliverIO last edited by
                      @oliverio Eventuell, und wie mache ich das. Ja es war von mir eine blöde Idee pihole zu installieren. Wie kann ich das Paket installieren?
                      OliverIO Thomas Braun 2 Replies Last reply Reply Quote 0
                      • OliverIO
                        @damrak2022
                        sudo apt-get update
                        sudo apt-get install ca-certificates
                        Probier das mal. Wenn es dann noch nicht geht evtl noch einen weiteren Befehl den ich gleich raussuche
                        • Damrak2022
                          @oliverio sagte in Mist gebaut beim entfernen von Pihole:
                          Ich glaube das sieht schon ziemlich gut aus:
                          pi@homebridge:~ $ sudo apt-get update
                          OK:1 http://deb.debian.org/debian bullseye InRelease
                          OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                          Fehl:3 https://apt.grafana.com stable InRelease
                          OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          OK:5 http://security.debian.org/debian-security bullseye-security InRelease
                          Fehl:6 https://download.docker.com/linux/debian bullseye InRelease
                            Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
                            Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
                            Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
                            Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
                          W: Fehlschlag beim Holen von https://download.docker.com/linux/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
                          W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
                          W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
                          W: Fehlschlag beim Holen von https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
                          pi@homebridge:~ $ sudo apt-get install ca-certificates
                          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                            alsa-topology-conf alsa-ucm-conf alsa-utils bluez bluez-firmware dos2unix git-man libasound2 libasound2-data libatopology2 liberror-perl libfftw3-single3 libsamplerate0
                            libsodium23 libxslt1.1 python3-distro python3-idna python3-six python3-toml python3-urllib3 raspinfo rfkill triggerhappy
                          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                          Die folgenden NEUEN Pakete werden installiert:
                            ca-certificates
                          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 158 kB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 391 kB Plattenplatz zusätzlich benutzt.
                          Holen:1 http://deb.debian.org/debian bullseye/main arm64 ca-certificates all 20210119 [158 kB]
                          Es wurden 158 kB in 0 s geholt (1.696 kB/s).
                          Vorkonfiguration der Pakete ...
                          Vormals nicht ausgewähltes Paket ca-certificates wird gewählt.
                          (Lese Datenbank ... 53798 Dateien und Verzeichnisse sind derzeit installiert.)
                          Vorbereitung zum Entpacken von .../ca-certificates_20210119_all.deb ...
                          Entpacken von ca-certificates (20210119) ...
                          ca-certificates (20210119) wird eingerichtet ...
                          Updating certificates in /etc/ssl/certs...
                          129 added, 0 removed; done.
                          Trigger für man-db (2.9.4-2) werden verarbeitet ...
                          Trigger für ca-certificates (20210119) werden verarbeitet ...
                          0 added, 0 removed; done.
                          Running hooks in /etc/ca-certificates/update.d...
                          done.
                          pi@homebridge:~ $ iob stop
                          OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                          OK:5 https://repos.influxdata.com/debian stable InRelease
                          OK:6 https://download.docker.com/linux/debian bullseye InRelease
                          OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                          OK:8 https://apt.grafana.com stable InRelease
                          OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                          pi@homebridge:~ $ sudo apt full-upgrade
                          Paketaktualisierung (Upgrade) wird berechnet… Fertig
                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          pi@homebridge:~ $
                            Thomas Braun Most Active @Damrak2022 last edited by
                            @damrak2022
                            Betrifft nur ThirdParty-Repos, wenn ich das richtig sehe.
                            cat /etc/apt/sources.list.d/*
                            sagt?
                            • Damrak2022
                              Damrak2022 @Thomas Braun last edited by
                              @thomas-braun sagte in Mist gebaut beim entfernen von Pihole:
                              pi@homebridge:~ $ cat /etc/apt/sources.list.d/*
                              deb [arch=arm64 signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian bullseye stable
                              deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
                              deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                              # this file was generated by packagecloud.io for
                              # the repository at https://packagecloud.io/ookla/speedtest-cli
                              deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                              deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                              deb http://archive.raspberrypi.org/debian/ bullseye main
                              # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                              #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                                @damrak2022
                                Funktioniert ja wieder.
                                Damrak2022 2 Replies Last reply Reply Quote 0
                                • OliverIO
                                  @damrak2022
                                  Das letzt apt update hat ja fehlerfrei funktioniert.
                                  Ich glaub aber nicht das es mit pihole zu tun hatte.
                                  Evtl ist eines der root Zertifikate abgelaufen auf die einige basierten
                                  • Damrak2022
                                    @thomas-braun Danke an Dich und die anderen. Ich denke mein Fehler war das ich bei dem Befehl "Phiole uninstall" alle Abfragen was er löschen soll, mit "ja" beantwortet habe. Somit waren wohl die Zertifikate weg.
                                    Geändert hat sich jetzt, das ich bei einem sudo apt update nochmal erneut mein Passwort eingeben muss, was ich ja vorher bei der Anmeldung via ssh schon eingegeben hatte. Kann ich das auch korrigieren?
                                    OliverIO Quarkmax 2 Replies Last reply Reply Quote 0
                                    • OliverIO
                                      OliverIO @Damrak2022 last edited by OliverIO
                                      @damrak2022
                                      Du musst da dein Passwort nicht eingeben wegen neuer Anmeldung, sondern wegen Bestätigung, dass du auch sudo berechtigt bist
                                      Sudo merkt sich einige Zeit das Passwort und verlangt es dann erneut. Da gibt es eine time out Einstellungen aber die würde ich jetzt nicht verändern. Sudo ist ja kein alltäglicher Befehl
                                      Und man wird selbst darauf hingewiesen, dass man jetzt etwas macht, was ins System eingreift und etwas wichtiger Ist
                                      • DJMarc75
                                        DJMarc75 last edited by
                                        Prinzipiell sollte sich jeder selbst die Frage stellen WARUM man PiHole installiert...
                                        Ich selbst rein wegen den vielen, vielen Werbeteilen im Browser.
                                        Aber dazu stelle ich im Router ja nix um (!) sondern gebe halt meinen PCs den dementsprechenden Eintrag in den Netzwerkeinstellungen mit.
                                        PiHole ist für mich ein reiner WerbeBlocker in der GUI - nicht mehr und nicht weniger.
                                        OliverIO Marc Berg 2 Replies Last reply Reply Quote 0
                                        • Quarkmax
                                          Quarkmax @Damrak2022 last edited by
                                          @damrak2022
                                          sudo visudo /etc/sudoers
                                          am Ende einfügen
                                          pi ALL=(ALL:ALL) NOPASSWD:ALL
                                          Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Quarkmax last edited by Thomas Braun
                                            @quarkmax
                                            Dafür gibt es die Datei
                                            /etc/sudoers.d/010_pi-nopasswd
                                            Da steht das drin:
                                            user_der_ausgenommen_ist ALL=(ALL) NOPASSWD: ALL
                                            142
                                            13488
