    5. full zigbee2tasmota integration
      randomuser123 last edited by
      Re: [JSON](Zigbee und ein undefined)
      I recently bought a zigbee2tasmota device. I managed to set it up with the iobroker.sonoff adapter which allows me to read zigbee sensor values nicely.
      But with the sonoff adapter I can not send control commands, for example to turn on a light or a socket.
      To do that I understand that I have to send a mqtt command, but that is not possible with the sonoff adapter (afaik).
      I can use another mqtt client, but then I don't have the feature of the sonoff adapter that splits up the mqtt json string into separate iobroker objects 😕
      Here's what I would like to achieve:
      • receive tasmota mqtt messages and split them up into separate objects
      • send an mqtt command to tasmota. Ideally by setting for example "myFancyMqtt.0.ZigbeeLight.power = true" will send the appropriate command to my zigbee2tasmota device that will turn on the ZigbeeLight.
      Is there any out-of-the-box solution available as of 2023?
        Maybe this script https://forum.iobroker.net/topic/48945/tasmota-steckdosen-per-mqtt-javascript-direkt-ansteuern/23 can help, but I don't want to modify a script every time I add a new zigbee device...
          Ok, I finally had time to find a solution. Thanks to chatGPT 🙂
          The zigbee2tasmota device is connected to a "regular" mqtt client in iobroker (not the sonoff adapter). When a zigbee message arrives it gets forwarded via mqtt to my iobroker as a json string.
          My script parses that json and creates separate states for each of the key:value pairs in the json.
          For sending commands I automatically add an additional state "PowerSet" to devices that have a "Power" state. When I update the PowerSet state, a script creates a json string and writes it into the "mqtt.0.cmnd.ZigbeeGateway.ZbSend" state (see https://tasmota.github.io/docs/Zigbee/#sending-device-commands)
          The advantage of this approach is that I have nothing to do on the iobroker side when I add new zigbee devices, they are handled automatically.
          That's it 🙂 Seems to work well so far. Here's the script in case anyone has a similar problem with zigbee2tasmota:
          // ############## user config
          // where the mqtt messages arrive
          const zigbee2tasmotaSensorObjectId = 'mqtt.0.tele.ZigbeeGateway.SENSOR';
          // where the states of the zigbee devices should appear
          const zbBaseFolder = '0_userdata.0.zigbee2tasmota';
          // ZbSend state, see https://tasmota.github.io/docs/Zigbee/#sending-device-commands
          const zbsendObjId = 'mqtt.0.cmnd.ZigbeeGateway.ZbSend';
          // ############## end user config
          const regexPowerSetStr = `${zbBaseFolder}\\..*PowerSet$`;
          const regexPowerSet = new RegExp(regexPowerSetStr);
          // receive
          on(zigbee2tasmotaSensorObjectId, (obj) => {
            const jsonString = obj.state.val;
            const jsonData = JSON.parse(jsonString);
            // log(`Received JSON string: ${jsonString}`);
            function createObjectsRecursively(parent, data) {
              for (const key in data) {
                const obj = data[key];
                const stateName = `${parent}.${key}`;
                if (typeof obj === 'object') {
                  createObjectsRecursively(stateName, obj);
                } else {
                  let value = obj;
                  // custom handling of special data types
                  if (key.toLowerCase() == 'time') {
                    value = new Date(obj);
                    log("found time")
                  // Check if the state already exists. If it does, just update the value.
                  // If it does not exist (-> new zigbee device), create the states.
                  if (!existsState(stateName)) {
                    // If the state does not exist, create it and set the value
                    createState(stateName, value, {
                      type: typeof value,
                      role: "value",
                      read: true,
                      write: true
                    log(`Created state ${stateName}`);
                    // create additional state to set a new value that will be sent to the zigbee device.
                    // If I use the normal "Power" state, I am afraid it will trigger the zbSend command
                    // everytime it gets updated from the zigbee device itself.
                    if (stateName.endsWith("Power")) {
                      let powerSetStateName = stateName + "Set"
                      createState(powerSetStateName, !!value, {
                        name: key + "Set",
                        type: "boolean",
                        role: "value",
                        read: true,
                        write: true
                      log(`Created state ${powerSetStateName}`);
                    // potentially add more custom handling for dimmer values, etc
                  } else {
                    setState(stateName, value);
                  // log(`set state ${parent}.${key} with value ${value}`);
            createObjectsRecursively(zbBaseFolder, jsonData);
          // send power on/off
          on(regexPowerSet, (obj) => {
            const objId = obj.id;
            // probably regex is not needed and we can just take .Device or .Name
            // Define a regular expression to match the substring between "ZbReceived" and "PowerSet"
            const regex = /ZbReceived\.(.*?)\.PowerSet/;
            // Use the regular expression to extract the substring
            const match = objId.match(regex);
            if (match) {
              const zbname = match[1];
              let newValue = obj.state.val;
              let zbsendstring = "\{\"Device\": \"" + zbname + "\"\,\"Send\"\:\{\"Power\"\: "+newValue+"\}}"
              log("zbsend: " + zbsendstring)
              setState(zbsendObjId, zbsendstring)
            } else {
              log(`The substring between "ZbReceived" and "PowerSet" not found in ${objId}`);
          PS: sending zigbee commands is only supported for power on/off. I don't have any zigbee devices that have dimmer or hue values or anything else. I guess the script can be adapted to work with those kind of devices, too.
