    4. Problem mit Adapter "javascript"
    • bahnuhr
      habe immer mal wieder das Problem wenn ich node updaten (so wie eben von 18.15. auf 18.16), dass dann der Adapter
      Javascript nicht wieder grün wird.
      Im log kommt sowas :
      host.iobroker
      2023-04-17 18:36:29.167	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
      host.iobroker
      2023-04-17 18:23:12.858	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:23:12.858	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:23:12.857	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:23:12.857	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:23:12.857	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:23:12.857	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:23:12.857	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:23:12.856	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:23:12.856	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:23:12.856	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:23:12.856	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:23:12.855	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:23:12.855	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:23:12.855	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:23:12.855	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:23:12.855	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:23:12.855	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:23:12.854	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:23:12.854	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:23:12.854	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:23:12.854	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:23:12.854	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:23:12.853	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:23:12.853	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:23:12.853	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:23:12.853	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:23:12.852	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:23:09.424	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.iobroker
      2023-04-17 18:22:39.076	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
      host.iobroker
      2023-04-17 18:22:39.075	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:22:39.074	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:22:39.074	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:22:39.074	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:22:39.074	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:22:39.074	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:22:39.073	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:22:39.073	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:22:39.073	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:22:39.073	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:22:39.073	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:22:39.072	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:22:39.072	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:22:39.072	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:22:39.072	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:22:39.072	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:22:39.071	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:22:39.071	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:22:39.071	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:22:39.071	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:22:39.071	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:22:39.071	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:22:39.070	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:22:39.070	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:22:39.070	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:22:39.069	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:22:39.069	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:22:37.192	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.iobroker
      2023-04-17 18:20:47.236	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGBUS
      host.iobroker
      2023-04-17 18:20:22.872	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
      host.iobroker
      2023-04-17 18:20:22.871	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:20:22.871	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:20:22.871	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:20:22.871	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:20:22.871	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:20:22.870	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:20:22.870	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:20:22.870	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:20:22.870	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:20:22.870	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:20:22.869	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:20:22.869	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:20:22.869	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:20:22.868	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:20:22.868	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:20:22.868	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:20:22.868	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:20:22.868	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:20:22.867	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:20:22.867	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:20:22.867	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:20:22.867	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:20:22.867	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:20:22.866	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:20:22.866	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:20:22.866	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:20:22.866	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:20:21.232	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.iobroker
      2023-04-17 18:20:09.378	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGSEGV
      admin.0
      2023-04-17 18:18:13.778	error	Automatic repository update is not allowed more than once a hour
      host.iobroker
      2023-04-17 18:18:09.532	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.iobroker
      2023-04-17 18:18:09.530	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:18:09.530	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:18:09.530	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:18:09.529	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:18:09.529	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:18:09.529	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:18:09.529	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:18:09.529	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:18:09.528	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:18:09.528	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:18:09.528	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:18:09.528	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:18:09.528	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:18:09.527	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:18:09.527	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:18:09.527	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:18:09.527	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:18:09.527	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:18:09.526	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:18:09.526	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:18:09.526	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:18:09.526	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:18:09.526	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:18:09.526	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:18:09.525	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:18:09.525	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:18:09.524	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:15:09.671	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:15:09.671	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:15:09.670	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:15:09.670	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:15:09.670	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:15:09.670	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:15:09.670	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:15:09.669	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:15:09.669	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:15:09.669	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:15:09.669	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:15:09.668	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:15:09.668	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:15:09.668	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:15:09.668	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:15:09.668	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:15:09.667	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:15:09.667	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:15:09.667	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:15:09.666	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:15:09.666	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:15:09.666	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:15:09.666	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:15:09.665	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:15:09.665	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:15:09.665	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:15:09.664	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:12:38.070	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:12:38.011	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:12:38.011	error	Caught by controller[1]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:12:38.011	error	Caught by controller[1]: }
      host.iobroker
      2023-04-17 18:12:38.011	error	Caught by controller[1]: ]
      host.iobroker
      2023-04-17 18:12:38.010	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:12:38.010	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:12:38.010	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:12:38.010	error	Caught by controller[1]: requireStack: [
      host.iobroker
      2023-04-17 18:12:38.010	error	Caught by controller[1]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:12:38.010	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:12:38.009	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:12:38.009	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:12:38.009	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:12:38.009	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:12:38.009	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:12:38.008	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:12:38.007	error	Caught by controller[1]: Require stack:
      host.iobroker
      2023-04-17 18:12:38.007	error	Caught by controller[1]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:12:38.007	error	Caught by controller[1]: ^
      host.iobroker
      2023-04-17 18:12:38.007	error	Caught by controller[1]: throw err;
      host.iobroker
      2023-04-17 18:12:38.007	error	Caught by controller[1]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:12:38.007	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:12:38.006	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:12:38.006	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:12:38.006	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:12:38.006	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:12:38.006	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:12:38.006	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:12:38.005	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:12:38.005	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:12:38.005	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:12:38.005	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:12:38.005	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:12:38.004	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:12:38.004	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:12:38.004	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:12:38.004	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:12:38.003	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:12:38.003	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:12:38.003	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:12:38.003	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:12:38.003	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:12:38.003	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:12:38.002	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:12:38.002	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:12:38.002	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:12:38.001	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:12:37.504	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:12:37.503	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:12:37.502	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:12:37.502	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:12:37.502	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:12:37.501	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:12:37.501	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:12:37.501	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:12:37.500	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:12:37.500	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:12:37.499	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:12:37.499	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:12:37.498	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:12:37.498	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:12:37.498	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:12:37.497	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:12:37.497	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:12:37.497	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:12:37.496	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:12:37.496	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:12:37.496	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:12:37.495	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:12:37.495	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:12:37.494	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:12:37.494	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:12:37.494	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:12:37.493	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:12:33.886	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.iobroker
      2023-04-17 18:10:15.516	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:10:15.516	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:10:15.516	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:10:15.515	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:10:15.515	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:10:15.515	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:10:15.515	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:10:15.514	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:10:15.514	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:10:15.514	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:10:15.514	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:10:15.513	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:10:15.513	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:10:15.513	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:10:15.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:10:15.512	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:10:15.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:10:15.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:10:15.511	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:10:15.511	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:10:15.511	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:10:15.510	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:10:15.510	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:10:15.510	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:10:15.510	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:10:15.509	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:10:15.508	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:10:15.095	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
      host.iobroker
      2023-04-17 18:10:15.093	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:10:15.092	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:10:15.092	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:10:15.092	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:10:15.092	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:10:15.091	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:10:15.091	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:10:15.091	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:10:15.090	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:10:15.090	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:10:15.090	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:10:15.090	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:10:15.090	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:10:15.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:10:15.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:10:15.089	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:10:15.089	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:10:15.088	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:10:15.088	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:10:15.088	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:10:15.088	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:10:15.087	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:10:15.086	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:10:15.086	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:10:15.086	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:10:15.086	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:10:15.085	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:10:11.165	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.iobroker
      2023-04-17 18:09:34.132	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
      daswetter.0
      2023-04-17 18:09:33.401	warn	Terminated (UNKNOWN_ERROR): Without reason
      daswetter.0
      2023-04-17 18:09:33.396	error	force terminate
      musiccast.0
      2023-04-17 18:09:24.786	warn	192.168.243.203:80 not reachable!
      musiccast.0
      2023-04-17 18:09:21.718	warn	192.168.243.203:80 not reachable!
      musiccast.0
      2023-04-17 18:09:18.643	warn	192.168.243.203:80 not reachable!
      musiccast.0
      2023-04-17 18:09:15.571	warn	192.168.243.203:80 not reachable!
      musiccast.0
      2023-04-17 18:09:12.503	warn	192.168.243.203:80 not reachable!
      musiccast.0
      2023-04-17 18:09:09.427	warn	192.168.243.203:80 not reachable!
      musiccast.0
      2023-04-17 18:09:06.358	warn	192.168.243.203:80 not reachable!
      cloud.0
      2023-04-17 18:08:26.500	error	Cloud says: timeout
      cloud.0
      2023-04-17 18:07:56.839	error	Cloud says: timeout
      host.iobroker
      2023-04-17 18:07:06.280	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:07:06.279	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:07:06.279	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:07:06.278	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:07:06.278	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:07:06.278	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:07:06.277	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:07:06.277	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:07:06.276	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:07:06.275	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:07:06.275	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:07:06.274	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:07:06.274	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:07:06.274	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:07:06.273	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:07:06.273	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:07:06.265	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:07:06.264	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:07:06.264	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:07:06.264	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:07:06.263	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:07:06.263	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:07:06.262	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:07:06.262	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:07:06.262	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:07:06.261	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:07:06.260	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:07:04.710	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
      host.iobroker
      2023-04-17 18:07:04.708	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:07:04.708	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:07:04.708	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:07:04.707	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:07:04.707	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:07:04.707	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:07:04.706	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:07:04.706	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:07:04.706	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:07:04.705	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:07:04.705	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:07:04.705	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:07:04.704	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:07:04.704	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:07:04.704	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:07:04.703	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:07:04.703	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:07:04.702	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:07:04.702	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:07:04.702	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:07:04.701	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:07:04.701	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:07:04.700	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:07:04.700	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:07:04.699	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:07:04.699	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:07:04.698	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:06:53.088	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.iobroker
      2023-04-17 18:06:22.361	warn	too delayed answer for system.host.Pi-Strom-Wasser
      info.0
      2023-04-17 18:05:49.626	warn	slow connection to objects DB. Still waiting ...
      host.iobroker
      2023-04-17 18:04:26.136	warn	instance system.adapter.komoot.0 terminated due to SIGBUS
      host.iobroker
      2023-04-17 18:03:56.958	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:03:56.957	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:03:56.957	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:03:56.957	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:03:56.956	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:03:56.956	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:03:56.956	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:03:56.956	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:03:56.955	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:03:56.955	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:03:56.955	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:03:56.955	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:03:56.954	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:03:56.954	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:03:56.954	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:03:56.954	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:03:56.953	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:03:56.952	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:03:56.952	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:03:56.952	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:03:56.952	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:03:56.951	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:03:56.951	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:03:56.951	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:03:56.950	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:03:56.950	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:03:56.949	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      host.iobroker
      2023-04-17 18:03:52.907	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.iobroker
      2023-04-17 18:03:52.904	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-04-17 18:03:52.904	error	Caught by controller[0]: Node.js v18.16.0
      host.iobroker
      2023-04-17 18:03:52.903	error	Caught by controller[0]: }
      host.iobroker
      2023-04-17 18:03:52.903	error	Caught by controller[0]: ]
      host.iobroker
      2023-04-17 18:03:52.903	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.iobroker
      2023-04-17 18:03:52.902	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js',
      host.iobroker
      2023-04-17 18:03:52.902	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js',
      host.iobroker
      2023-04-17 18:03:52.902	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-04-17 18:03:52.901	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-04-17 18:03:52.901	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12) {
      host.iobroker
      2023-04-17 18:03:52.900	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
      host.iobroker
      2023-04-17 18:03:52.900	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
      host.iobroker
      2023-04-17 18:03:52.900	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
      host.iobroker
      2023-04-17 18:03:52.900	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:1166:4)
      host.iobroker
      2023-04-17 18:03:52.899	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js:7:9)
      host.iobroker
      2023-04-17 18:03:52.898	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-04-17 18:03:52.898	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
      host.iobroker
      2023-04-17 18:03:52.898	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
      host.iobroker
      2023-04-17 18:03:52.898	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
      host.iobroker
      2023-04-17 18:03:52.897	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.iobroker
      2023-04-17 18:03:52.896	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script.js
      host.iobroker
      2023-04-17 18:03:52.896	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/lexer.js
      host.iobroker
      2023-04-17 18:03:52.895	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-04-17 18:03:52.894	error	Caught by controller[0]: Error: Cannot find module './rewriter'
      host.iobroker
      2023-04-17 18:03:52.894	error	Caught by controller[0]: ^
      host.iobroker
      2023-04-17 18:03:52.892	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-04-17 18:03:52.891	error	Caught by controller[0]: node:internal/modules/cjs/loader:1078
      Könnt ihr damit was anfangen ?
      Gelöst bekomme ich es nur indem ich die Instanzen und den Adapter komplett deinstallieren und dann wieder neu installiere.
      DP dann wieder eingelesen und es geht wieder.
      Ist aber doch nicht normal.
      jemand eine Idee ?
        Thomas Braun Most Active @bahnuhr last edited by
        @bahnuhr sagte in Problem mit Adapter "javascript":
        Nein, ist es nicht.
        iob diag
        sagt?
        Und
        cd /opt/iobroker
        npm ls
        schaut wie aus?
        • bahnuhr
          bahnuhr Forum Testing Most Active @Thomas Braun last edited by
          Danke für deine schnelle Antwort.
          anbei:
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Architecture    : x86_64
          Docker          : false
          Virtualization  : kvm
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           19:14:07 up 2 days, 16:03,  1 user,  load average: 2.06, 1.57, 1.43
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Mon 2023-04-17 19:14:08 CEST
                     Universal time: Mon 2023-04-17 17:14:08 UTC
                           RTC time: Mon 2023-04-17 17:14:08
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          dieter
          /home/dieter
          dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            5.9G        3.9G        206M        0.0K        1.8G        1.8G
          Swap:           974M         49M        925M
          Total:          6.9G        3.9G        1.1G
                   5940 M total memory
                   3899 M used memory
                    650 M active memory
                   4682 M inactive memory
                    206 M free memory
                    200 M buffer memory
                   1634 M swap cache
                    974 M total swap
                     49 M used swap
                    925 M free swap
          *** FILESYSTEM ***
          Filesystem                Type      Size  Used Avail Use% Mounted on
          udev                      devtmpfs  2.9G     0  2.9G   0% /dev
          tmpfs                     tmpfs     595M  500K  594M   1% /run
          /dev/sda1                 ext4       31G   12G   18G  39% /
          tmpfs                     tmpfs     3.0G     0  3.0G   0% /dev/shm
          tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
          //192.168.243.100/1_Sound cifs      238G  123G  115G  52% /mnt
          tmpfs                     tmpfs     595M     0  595M   0% /run/user/1000
          [Sat Apr 15 03:10:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Sat Apr 15 03:10:34 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          Show mounted filesystems (real ones only):
          TARGET SOURCE                    FSTYPE OPTIONS
          /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
          `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=Dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
          /var:
          2.0G    /var/
          1.2G    /var/log/journal/4ef936d6ff8a4b6ab4f50f3038582f64
          1.2G    /var/log
          560M    /var/cache
          Archived and active journals take up 104.0M in the file system.
          /opt/iobroker/backups:
          2.6G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          638M    /opt/iobroker/iobroker-data/files
          298M    /opt/iobroker/iobroker-data/files/vis.0
          248M    /opt/iobroker/iobroker-data/files/vis.0/wav
          222M    /opt/iobroker/iobroker-data/sqlite
          222M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
          154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
          47M     /opt/iobroker/iobroker-data/states.jsonl
          40M     /opt/iobroker/iobroker-data/objects.jsonl
          34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.16.0
          /usr/bin/node           v18.16.0
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.0-deb-1nodesource1
            Candidate: 18.16.0-deb-1nodesource1
            Version table:
           *** 18.16.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u3 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          Adapters from github:   8
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
          + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
          + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
            system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
          + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
          + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
            system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
          + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
          + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled, port: 0
          + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled, port: 0
          + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled, port: 0
            system.adapter.sayit.5                  : sayit                 : iobroker                                 - disabled, port: 0
            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
          + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
          + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 20020, bind: 0.0.0.0, run as: admin
            system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
          + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
          Adapter    "backitup"     : 2.6.16   , installed 2.6.16
          Adapter    "bmw"          : 2.5.7    , installed 2.5.7
          Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
          Adapter    "cloud"        : 4.3.0    , installed 4.3.1
          Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
          Adapter    "doorio"       : 2.1.4    , installed 2.1.4
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "email"        : 1.1.4    , installed 1.1.4
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "flot"         : 1.11.0   , installed 1.12.0
          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
          Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
          Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
          Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
          Adapter    "ical"         : 1.13.2   , installed 1.13.2
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "info"         : 1.9.19   , installed 1.9.20
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "libre"        : 0.0.4    , installed 0.0.4
          Adapter    "linux-control": 1.1.3    , installed 1.1.3
          Adapter    "logparser"    : 2.1.1    , installed 2.1.1
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "musiccast"    : 0.1.5    , installed 1.0.6
          Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
          Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
          Adapter    "parser"       : 1.1.8    , installed 1.1.8
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
          Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
          Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
          Adapter    "sayit"        : 1.12.3   , installed 1.12.3
          Adapter    "shelly"       : 6.3.1    , installed 6.3.1
          Adapter    "socketio"     : 4.2.0    , installed 6.1.4
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
          Adapter    "tuya"         : 3.13.1   , installed 3.13.1
          Adapter    "viessmann"    : 1.4.3    , installed 1.4.3
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
          Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "web"          : 4.3.0    , installed 5.2.0
          Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
          Adapter    "ws"           : 1.3.0    , installed 2.3.4
          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Objects and States
          Objects:        23146
          States:         18938
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1576003    93575/iobroker.js-c
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1575992    93575/iobroker.js-c
          tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        15548      380/asterisk
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11357      1/init
          tcp        0      0 192.168.243.10:2001     0.0.0.0:*               LISTEN      1001       1576184    93741/io.hm-rpc.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14414      457/sshd: /usr/sbin
          tcp        0      0 192.168.243.10:2010     0.0.0.0:*               LISTEN      1001       1576223    93870/io.hm-rpc.2
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1579378    93921/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1579456    93980/io.mqtt.2
          tcp        0      0 192.168.243.10:8701     0.0.0.0:*               LISTEN      1001       1571405    93853/io.hm-rpc.1
          tcp6       0      0 :::111                  :::*                    LISTEN      0          10204      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1571205    93606/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1580315    95430/io.web.0
          tcp6       0      0 :::20020                :::*                    LISTEN      1001       1580529    95642/io.web.1
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1580251    95531/io.ws.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14425      457/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1581081    95294/io.simple-api
          udp        0      0 0.0.0.0:50276           0.0.0.0:*                           108        15557      380/asterisk
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12399      1/init
          udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       1583133    95219/io.musiccast.
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1597724    102434/io.mihome-va
          udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        12777      380/asterisk
          udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        12776      380/asterisk
          udp6       0      0 :::43642                :::*                                108        15558      380/asterisk
          udp6       0      0 :::111                  :::*                                0          1329       1/init
          2023-04-17 19:14:00.087  - info: javascript.0 (103023) script.js.Scripte.Geraete.Maehroboter: Timer.next: date und time nicht gesetzt - Diese Werte sind im json nicht vorhanden.
          2023-04-17 19:14:07.083  - info: javascript.0 (103023) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
          2023-04-17 19:14:07.792  - info: javascript.0 (103023) script.js.Scripte.Geraete.Spuelmaschine: Auslöser Spülmaschine
          2023-04-17 19:14:28.275  - info: javascript.0 (103023) script.js.Scripte.Geraete.Spuelmaschine: Auslöser Spülmaschine
          2023-04-17 19:14:32.878  - info: javascript.0 (103023) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
          2023-04-17 19:14:32.900  - info: javascript.0 (103023) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
          2023-04-17 19:14:44.261  - info: javascript.0 (103023) script.js.Scripte.Geraete.Spuelmaschine: Auslöser Spülmaschine
          2023-04-17 19:15:00.058  - info: javascript.0 (103023) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
          2023-04-17 19:15:00.119  - info: javascript.0 (103023) script.js.Scripte.System.View_wechseln: View auf 'Titel' gewechselt.
          2023-04-17 19:15:00.139  - info: javascript.0 (103023) script.js.Scripte.Heizung.Bad_EG: Auslöser Schedule
          2023-04-17 19:15:00.141  - info: javascript.0 (103023) script.js.Scripte.Heizung.Bad_EG: Heizung wird auf 5°C gesetzt.
          2023-04-17 19:15:00.234  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 80 %.
          2023-04-17 19:15:00.237  - info: host.iobroker instance system.adapter.dwd.0 started with pid 104725
          2023-04-17 19:15:00.243  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 90 %.
          2023-04-17 19:15:00.287  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 90 %.
          2023-04-17 19:15:00.317  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
          2023-04-17 19:15:00.405  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
          2023-04-17 19:15:00.416  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 51 %.
          2023-04-17 19:15:04.537  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 104744
          2023-04-17 19:15:07.254  - info: dwd.0 (104725) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
          2023-04-17 19:15:09.887  - info: daswetter.0 (104744) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24
          2023-04-17 19:15:15.633  - info: dwd.0 (104725) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-04-17 19:15:16.214  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-04-17 19:15:32.365  - info: ws.0 (95531) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
          2023-04-17 19:15:32.367  - info: ws.0 (95531) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
          iob diag has finished.
          Press any key for a summary
                               v.2023-04-16
          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
          Kernel:                 5.10.0-21-amd64
          Installation:           kvm
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            5.9G        3.9G        348M        0.0K        1.7G        1.8G
          Swap:           974M         49M        925M
          Total:          6.9G        3.9G        1.3G
          Active iob-Instances:   51
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects:                23146
          States:                 18935
          Size of iob-Database:
          51M     /opt/iobroker/iobroker-data/states.jsonl
          dieter@iobroker:~$ cd /opt/iobroker
          dieter@iobroker:/opt/iobroker$ npm ls
          iobroker.inst@3.0.0 /opt/iobroker
          ├── @types/caseless@0.12.2 extraneous
          ├── @types/request@2.48.8 extraneous
          ├── @types/tough-cookie@4.0.2 extraneous
          ├── coffeescript@1.12.7 extraneous
          ├── iobroker.admin@6.3.5
          ├── iobroker.alias-manager@1.2.4
          ├── iobroker.asterisk@1.0.6
          ├── iobroker.backitup@2.6.16
          ├── iobroker.bmw@2.5.7
          ├── iobroker.bosch-ebike@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.bosch-ebike.git#6574234e8316a5047908dab12baac363e9f505c3)
          ├── iobroker.cloud@4.3.1 (git+ssh://git@github.com/ioBroker/ioBroker.cloud.git#4e96866d5c7e012cb8890b2d0a9721162bfe650f)
          ├── iobroker.contact@1.1.3 (git+ssh://git@github.com/WLAN-Kabel/ioBroker.contact.git#006a1ab146246cbaf729609c46855bcd65cf5aaf)
          ├── iobroker.daswetter@3.1.7
          ├── iobroker.doorio@2.1.4
          ├── iobroker.dwd@2.8.3
          ├── iobroker.email@1.1.4
          ├── iobroker.feiertage@1.1.0
          ├── iobroker.flot@1.12.0
          ├── iobroker.fritzbox@0.2.1
          ├── iobroker.fritzdect@2.2.6
          ├── iobroker.hm-rega@3.0.46
          ├── iobroker.hm-rpc@1.15.16
          ├── iobroker.ical@1.13.2
          ├── iobroker.icons-material-png@0.1.0
          ├── iobroker.icons-mfd-png@1.1.0
          ├── iobroker.icons-open-icon-library-png@0.1.2
          ├── iobroker.info@1.9.20 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#681b473b9602d3f4b9eed91338041b616a25a305)
          ├── iobroker.javascript@6.1.4
          ├── iobroker.js-controller@4.0.24
          ├── iobroker.komoot@0.3.7 (git+ssh://git@github.com/basti4557/ioBroker.komoot.git#eb2838cfd6c926a61a9262d4e8417d6315018d1f)
          ├── iobroker.libre@0.0.4 (git+ssh://git@github.com/TA2k/ioBroker.libre.git#ee0908307e3320d06b4b62987b85777e33e2f918)
          ├── iobroker.linux-control@1.1.3
          ├── iobroker.logparser@2.1.1
          ├── iobroker.mihome-vacuum@3.9.5
          ├── iobroker.mihome@1.4.0
          ├── iobroker.modbus@5.0.11
          ├── iobroker.mqtt@4.0.7
          ├── iobroker.musiccast@1.0.6 (git+ssh://git@github.com/foxthefox/ioBroker.musiccast.git#33b1029dd22b9dbd351b9cf70074df54c6fdbaed)
          ├── iobroker.octoprint@4.0.0
          ├── iobroker.openligadb@1.2.4
          ├── iobroker.parser@1.1.8
          ├── iobroker.ping@1.5.3
          ├── iobroker.pollenflug@1.0.6
          ├── iobroker.proxmox@1.3.4
          ├── iobroker.rest-api@1.0.4
          ├── iobroker.rssfeed@2.6.1
          ├── iobroker.sayit@1.12.3 (git+ssh://git@github.com/Jey-Cee/ioBroker.sayit.git#8b613efce437d18ba4f4c320655c7b8323d25270)
          ├── iobroker.shelly@6.3.1
          ├── iobroker.simple-api@2.7.2
          ├── iobroker.sourceanalytix@0.4.14
          ├── iobroker.sql@2.2.0
          ├── iobroker.tankerkoenig@3.3.7
          ├── iobroker.telegram@1.15.2
          ├── iobroker.tr-064@4.2.18
          ├── iobroker.tuya@3.13.1
          ├── iobroker.viessmann@1.4.3
          ├── iobroker.vis-bars@0.1.4
          ├── iobroker.vis-canvas-gauges@1.0.1
          ├── iobroker.vis-colorpicker@1.2.0
          ├── iobroker.vis-fancyswitch@1.1.0
          ├── iobroker.vis-google-fonts@1.0.4
          ├── iobroker.vis-history@1.0.0
          ├── iobroker.vis-hqwidgets@1.3.0
          ├── iobroker.vis-icontwo@0.93.0
          ├── iobroker.vis-inventwo@3.3.1
          ├── iobroker.vis-jqui-mfd@1.0.12
          ├── iobroker.vis-justgage@1.0.2
          ├── iobroker.vis-keyboard@0.0.2
          ├── iobroker.vis-lcars@1.0.4
          ├── iobroker.vis-map@1.0.4
          ├── iobroker.vis-metro@1.2.0
          ├── iobroker.vis-players@0.1.6
          ├── iobroker.vis-plumb@1.0.2
          ├── iobroker.vis-rgraph@0.0.2
          ├── iobroker.vis-timeandweather@1.2.2
          ├── iobroker.vis@1.4.16
          ├── iobroker.web@5.2.0
          ├── iobroker.wiobrowser@2.0.1
          ├── iobroker.ws@2.3.4
          ├── iobroker.yamaha@0.5.3
          ├── iobroker.zigbee@1.8.10
          ├── javascript@1.0.0
          ├── jsonata@1.8.6 extraneous
          ├── node-inspect@2.0.0 extraneous
          ├── picocolors@1.0.0 extraneous
          ├── production@0.0.2
          ├── suncalc2@1.8.1 extraneous
          ├── typescript@4.7.4 extraneous
          ├── virtual-tsc@0.6.2 extraneous
          ├── wake_on_lan@1.0.0 extraneous
          └── which@2.0.2
            @bahnuhr
            Das gehört da nicht hin:
            javascript@1.0.0
            • bahnuhr
              Und was tun.
              cd /opt/iobroker
              npm uninstall javascript@1.0.0
              richtig ?
                @bahnuhr Ja, würde ich sagen.
                • bahnuhr
                  Hab ich gemacht.
                  ist auch durchgelaufen
                  Bei npm ls ist es aber noch da:
                  └── which@2.0.2
                    @bahnuhr
                    Alles was nicht mit iobroker. anfängt gehört da nicht hin.
                    • bahnuhr
                      Und wo kommt dieser Kram her ?
                      └── which@2.0.2
                      Und wie bekomme ich den weg ?
                      Thomas Braun bahnuhr 2 Replies Last reply Reply Quote 0
                        @bahnuhr
                        Woher soll ich das wissen? Das System wird von dir administriert.
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @bahnuhr last edited by
                            @bahnuhr
                            Mit
                            npm uninstall MODULNAME
                            geht es nicht?
                            • bahnuhr
                              hab ich ja probiert. Deinstall läuft durch.
                              Aber wird weiterhin angezeigt.
                              Soll ich es mit den anderen auch mal probieren, also
                              npm uninstall production@0.0.2
                              npm uninstall which@2.0.2
                                Thomas Braun Most Active @bahnuhr last edited by Thomas Braun
                                @bahnuhr Jo, mach mal.
                                Ich weiß nicht man auch mehrere Module in einem Kommando rauswerfen kann.
                                • bahnuhr
                                  so, das lief auch durch:
                                  dieter@iobroker:/opt/iobroker$ npm uninstall production@0.0.2
                                  up to date in 16s
                                  158 packages are looking for funding
                                    run `npm fund` for details
                                  dieter@iobroker:/opt/iobroker$ npm uninstall which@2.0.2
                                  up to date in 17s
                                  Und bei npm ls kommt:
                                  └── which@2.0.2
                                  Fazit: immer noch da !?
                                  komisch
                                  • bahnuhr
                                    nun isses weg.
                                    falsch war: npm uninstall production@0.0.2
                                    richtig war: npm uninstall production
                                    nun wird dies bei npm ls nicht mehr angezeigt.
                                    adapter
                                    425
