    4. Support Adapter Energiefluss-erweitert v0.7.7
      Homoran Global Moderator Administrators @SKB last edited by
      @skb War's das mit Urlaub? 😢
      was genau muss ich machen?
      SKB 1 Reply Last reply Reply Quote 0
      • SKB
        SKB Developer Most Active @Homoran last edited by
        @homoran Mission Vacation: completed 🙂
        Einfach aus dem Datenpunkt "configuration" das JSON in einem deiner Anzeige-Tools öffnen und den Bereich "datasources" mitteilen. Das ist alles.
          Homoran Global Moderator Administrators @SKB last edited by Homoran
          @skb
              "datasources": {
                  "0": {
                      "source": "Messwerte.0.Solaranlage.Momentanwerte.Leistung_AC_aktuell",
                      "alias": "Solarproduktion "
                  "1": {
                      "source": "modbus.0.inputRegisters.1.30053_Total_Power",
                      "alias": "EVU"
                  "2": {
                      "source": "modbus.1.inputRegisters.100.842_Battery_power",
                      "alias": "Batterie "
                  "3": {
                      "source": "modbus.1.inputRegisters.100.843_SOC",
                      "alias": "Batterie_SoC"
                  "4": {
                      "source": "Messwerte.0.Batterie.Fertig",
                      "alias": "Batterie_fertig"
                  "5": {
                      "source": "Messwerte.0.Energiefluss.Haus_netto",
                      "alias": "Haus_netto"
                  "6": {
                      "source": "Messwerte.0.Energiefluss.DG_netto",
                      "alias": "DG_netto"
                  "7": {
                      "source": "Messwerte.0.Energiefluss.UV-Keller_netto",
                      "alias": "UV-Keller_netto"
                  "8": {
                      "source": "hm-rpc.0.REQ0777349.2.POWER",
                      "alias": "Auto"
                  "9": {
                      "source": "hm-rpc.0.NEQ0116043.2.POWER",
                      "alias": "Klima"
                  "10": {
                      "source": "zoe2.0.V.charge_level",
                      "alias": "Auto_SoC"
                  "11": {
                      "source": "hm-rpc.0.KEQ0967747.2.POWER",
                      "alias": "Waschmaschine "
                  "12": {
                      "source": "hm-rpc.0.NEQ0386317.2.POWER",
                      "alias": "Trockner"
                  "13": {
                      "source": "hm-rpc.0.KEQ0966548.2.POWER",
                      "alias": "Spuelmaschine"
                  "14": {
                      "source": "Messwerte.0.Stromzaehler.Momentanwerte.akt_Verbrauch",
                      "alias": "Hausverbrauch"
                  "15": {
                      "source": "modbus.0.inputRegisters.2.30053_Total_Power_Keller",
                      "alias": "UV-Keller"
                  "16": {
                      "source": "modbus.0.inputRegisters.3.30053_Total_Power_DG",
                      "alias": "DG_total"
                  "17": {
                      "source": "Messwerte.0.Solaranlage.Momentanwerte.Solarestimate2",
                      "alias": "Estimate"
                  "18": {
                      "source": "zoe2.0.VF1AG000766995834.remaining_range",
                      "alias": "Reichweite"
                  "19": {
                      "source": "hm-rpc.0.LTK0124191.2.POWER",
                      "alias": "Backofen"
                  "20": {
                      "source": "modbus.0.inputRegisters.2.30015_L2_Keller",
                      "alias": "Poolpumpe"
                  "21": {
                      "source": "hm-rpc.0.LEQ0773306.2.TEMPERATURE",
                      "alias": "Pooltemperatur"
                  "22": {
                      "source": "Messwerte.0.Energiefluss.Solar_Haus",
                      "alias": "Solar->Haus"
                  "24": {
                      "source": "Messwerte.0.Pool.Druck_real",
                      "alias": "Sandfilter"
            @skb sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
            Ich denke, der Fehler, der dort mit der ID kommt, kommt aus dem Bereich.
            Ich müsste es nochmal zesten, aber der Fehler kommt beim Anlegen eines neuen Objekts oder Linie ohne dass ich dort eine source hinterlegt habe
            • SKB
              @homoran Wenn Du Zeit findest, einfach nochmals drüber installieren und nochmal zurückmelden, bitte 🙂
                bitte!
                upgrade (immer noch alpha7?? oder node 14 Fehler?)
                neues Element
                neue Linie
                -> kein Fehler im log!
                • SKB
                  @homoran Scheint also in Ordnung zu sein?!
                    jepp!
                    dann ran an den Speck!
                    Hab neue Käferchen.
                    • Threshold in Werten funktioniert nicht
                    • Threshold in Animationen funktioniert nicht überall.
                      • wahrscheinlich nicht bei Nutzung von reduce
                    Wünsche:
                    Bei der Batterie musste ich das Objekt vergrößern um alles (?) unterzubringen.
                    Beim letzten Wert (State of Health) hab ich die Kurzbezeichnung in der Einheit versteckt.
                    Kann man auch etwas voranstellen?
                    Was positives zum vorläufigen Schluss:
                    Nachdem die Sicherung der Konfiguration über die Instanzen Konfiguration beim letzten Mal nicht den gewünschten Effekt hatte, habe ich jetzt mal eine zweite Instanz erzeugt und dort einfach die beiden JSONs in die entsprechenden Datenpunkte kopiert.
                    Dadurch konnte ich zwei Wege der "Entwicklung" parallel weiterführen.
                    Leider waren die DPs nicht beschreibbar. Vielleicht könntest du das zum Zwecke des Clonens/Restores RW machen
                    DANKE!
                    • SKB
                      @homoran Danke für die Rückmeldung.
                      Threshold schaue ich mir an.
                      Könntest Du deine Wünsche genauer Beschreiben? Bei der Batterie musst du welches Objekt vergrößern?
                      Letzter Wert "State of Health" die Zeit mienst Du? Aktuell kannst du ein Text Element "davor" setzen - innerhalb des Textes kann man (noch) nichts einsetzen. Schaue ich mir auch an.
                      Vielleicht eine Grafik, die dies verdeutlicht?
                      Klar kann man die Objekte schreibbar machen 🙂
                        alles gut!
                        sollte nur die Erklärung für die Form des Batterie-Objects sein. ist jetzt ein Rechteck, weil so viele Infos nicht im Quadtrat passten 😉
                        nein die 100
                        Einheit % SoH
                        eleganter wäre IMHO SoH 100%
                        • SKB
                          @homoran was hälst Du von:
                          Anzeige ist dann so:
                          Also Prepend ist vor dem Wert, Append danach und am Ende wäre dann die Unit.
                            klasse!
                            entspricht dann auchvder Konfiguration vieler widgets in vis.
                            wobei append bei beibehaltener Unit eigentlich nicht nötig wäre
                            • SKB
                              @homoran Ich habe einfach beides genommen. So kann der User die Texte gestalten, wie er möchte.
                              Möglich wäre ja auch:
                              "Heute" 15 "Einheiten" kW (Wobei Heute und Einheiten dann eben prepend und append wären - etwas sinnbefreit, aber ok 😉 )
                                @SKB
                                SORRY!!
                                host.iobroker-VM03
                                	2023-06-15 11:24:12.944	error	instance system.adapter.energiefluss-erweitert.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	2023-06-15 11:24:12.191	error	Cannot read property 'id' of undefined
                                	2023-06-15 11:24:12.191	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
                                	2023-06-15 11:24:12.191	error	uncaught exception: Cannot read property 'id' of undefined
                                	2023-06-15 11:24:12.189	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	2023-06-15 11:24:12.187	error	Cannot read property 'id' of undefined
                                	2023-06-15 11:24:12.186	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
                                	2023-06-15 11:24:12.186	error	uncaught exception: Cannot read property 'id' of undefined
                                	2023-06-15 11:24:12.172	error	Cannot read property 'id' of undefined
                                	2023-06-15 11:24:12.171	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
                                	2023-06-15 11:24:12.169	error	uncaught exception: Cannot read property 'id' of undefined
                                host.iobroker-VM03
                                	2023-06-15 11:02:55.204	error	instance system.adapter.energiefluss-erweitert.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                	2023-06-15 11:02:54.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                	2023-06-15 11:02:54.338	error	Cannot read property 'id' of undefined
                                	2023-06-15 11:02:54.338	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
                                	2023-06-15 11:02:54.337	error	uncaught exception: Cannot read property 'id' of undefined
                                	2023-06-15 11:02:54.326	error	Cannot read property 'id' of undefined
                                	2023-06-15 11:02:54.326	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
                                	2023-06-15 11:02:54.325	error	uncaught exception: Cannot read property 'id' of undefined
                                	2023-06-15 11:02:54.317	error	Cannot read property 'id' of undefined
                                	2023-06-15 11:02:54.317	error	TypeError: Cannot read property 'id' of undefined at EnergieflussErweitert.onStateChange (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:154:45) at EnergieflussErweitert.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5712:38) at processImmediate (internal/timers.js:464:21)
                                	2023-06-15 11:02:54.314	error	uncaught exception: Cannot read property 'id' of undefined
                                Ich hab 4 neue sources angelegt und 4 neue Datenpunkte (Text with Datasource).
                                leider erst später in das log gesehen 😢
                                Was kann ich dir jetzt schicken?
                                • SKB
                                  SKB Developer Most Active @Homoran last edited by SKB
                                  @homoran Es würde mir helfen, wenn Du kurz die Schritte beschreiben könntest.
                                  Also, Text with Datasource auf den Workspace gelegt - wie ging es dann weiter?
                                  Direkt gespeichert - oder etwas zugewiesen?
                                    würde mir auch helfen 😁
                                    Soweit ich mich erinnern kann:
                                    • 2 sources angelegt
                                    • 2 "Datenpunkte" angelegt und jeweils sofort Sources zugewiesen, Farben, Ausrichtung Position und Nachkommastellen zugewiesen
                                    • save and exit
                                    • erneut editiert
                                    • erst jetzt finetuning der Positionen, da aus Datasourcexxx jetzt erst der Wert entstanden ist.
                                    • save&exit
                                    Anschließend das selbe nochmal mit 2 weiteren Sources
                                      @SKB
                                      tut mir leid, ich hab es bis jetzt nicht wieder reproduziert bekommen.
                                      Jedenfalls nicht, indem ich jetzt nach jedem Schritt gespeichert und dann im log nachgesehen habe.
                                      ich bleib dran!
                                      • E
                                        erwini last edited by
                                        Habe den energiefluss adapter in Betrieb und bin nun auf diesen Adapter gestolpert und will diesen nun ausprobieren.
                                        Installiert mit
                                        npm install https://github.com/SKB-CGN/ioBroker.energiefluss-erweitert
                                        added 4 packages in 8s
                                        und
                                        iob upload energiefluss-erweitert
                                        No alive host found which has the adapter energiefluss-erweitert installed! No upload possible. Skipped.
                                        Als normaler user (nicht root).
                                        Was habe ich vergessen ? Kenne die Feinheiten von iobroken da noch nicht gut genug.
                                        • BananaJoe
                                          BananaJoe Most Active last edited by BananaJoe
                                          @erwini warum auch immer du den Adapter über die CLI statt GUI installierst:
                                          Du musst noch eine Instanz hinzufügen:
                                          Also in die Adapter Ansicht, die Kachel des Energiefluss - erweitert suchen, auf die 3 ... klicken das die Kachel sich umdreht und dann auf das + unten links.
                                          Danach taucht der Adapter unterhalb von Instanzen links auf und ist nutzbar sofern dieser gestartet ist.
                                          Den CLI Befehl dafür habe ich gerade nicht parat.
                                          • E
                                            erwini @BananaJoe last edited by
                                            @bananajoe said in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
                                            Mhh, weil der in der Adapterliste nicht auftaucht ... warum auch immer. Deswegen via CLI. Und er taucht in der Adpaterliste immer noch nicht auf nach dem
                                            npm install ....
                                            vis
                                            187
                                            4256
                                            5301683
