    4. Gelöst: Schedule einer Funktion
      Butschek last edited by Butschek
      ich versuche alle 15 Minuten mir den neuen RSS Feed der Tagesschau zu laden. Manuell klappt dies, aber nicht zeit gesteuert. Kann mir hier jemand einen Tip geben, was ich falsch mache. Folgend mein Code in Javascript. Es tauchen auch keine Meldungen im Protokoll auf.
      VG Holger
      schedule('*/15 * * * *', function () {getTagesschauRssFeed();})
      const fetch = require("node-fetch");
      const { parseString } = require("xml2js");
      async function getTagesschauRssFeed() {
        const response = await fetch("https://www.tagesschau.de/xml/rss2");
        const xmlText = await response.text();
        return xmlText;
        .then((xmlText) => {
          parseString(xmlText, (err, result) => {
            if (err) {
              console.error(err);
              return;
            const items = result.rss.channel[0].item;
            // Create datapoints
            var datapoint_Timestamp = '0_userdata.0.RSS.general.timestamp';
            createState(datapoint_Timestamp);
            // Set datapoints
            //const currDate = require("javascript.0.scriptEnabled.common.Date-Functions.currDate");
            setState(datapoint_Timestamp, currLocalDate());    /*scriptEnabled common Date-Functions currDate*/
              console.log (currLocalDate());
            for (let i = 0; i < 10; i++) {
              const content = items[i]["content:encoded"][0];
              var content_Enc;
              const imgRegex = /<img.*?src="(.*?)"/;
              const imgMatch = content.match(imgRegex);
              const counter = i +1;
              var RSSItemLink = items[i].link[0];
              var RSSItemTitle = items[i].title[0];
              var RSSItemImage = imgMatch[1] ;
              var RSSItemDescription = items[i].description[0];
              // Create datapoints;
              var datapoint_Title = '0_userdata.0.RSS.' + counter + '.Title';
              var datapoint_Image = '0_userdata.0.RSS.' + counter + '.Image';
              var datapoint_Description = '0_userdata.0.RSS.' + counter + '.Description';
              var datapoint_ContentEnc = '0_userdata.0.RSS.' + counter + '.ContentEnc';
              // Set datapoints;
              //console.log(`Item ${counter} title: ${items[i].title[0]}`);
              createState(datapoint_Title);
              setState(datapoint_Title, RSSItemTitle);
              //console.log(`Item ${i + 1} image URL: ${imgMatch ? imgMatch[1] : "None"}`);
              createState(datapoint_Image);
              setState(datapoint_Image, RSSItemImage);
              //console.log(`Item ${i + 1} description: ${RSSItemDescription}`);
              createState(datapoint_Description);
              setState(datapoint_Description, RSSItemDescription);
              //console.log(`Item ${i + 1} description: ${content}`);
              createState(datapoint_ContentEnc);
              content_Enc = "<p><a target='_blank' href='"  + RSSItemLink + "'>" + RSSItemTitle + "</a><br>" + RSSItemDescription + "</p>";
              setState(datapoint_ContentEnc, content_Enc);
        .catch((err) => console.error(err));
      • liv-in-sky
        liv-in-sky @Butschek last edited by
        @butschek
        probier mal (axios muss in den javascript settings angegeben worden sein:
        const axios=require('axios');
        //const { parseString } = require("xml2json");
           let counter = i +1;
               let datapoint_Title = '0_userdata.0.RSS.' + counter + '.Title';
               let datapoint_Image = '0_userdata.0.RSS.' + counter + '.Image';
               let datapoint_Description = '0_userdata.0.RSS.' + counter + '.Description';
               let datapoint_ContentEnc = '0_userdata.0.RSS.' + counter + '.ContentEnc';
            makedp(datapoint_Image)
            makedp(datapoint_Description)
            makedp(datapoint_ContentEnc)
            makedp(datapoint_Title)
        makedp(datapoint_Timestamp)
        schedule('*/15 * * * *', async function () { getTagesschauRssFeed()})
         axios.get('https://www.tagesschau.de/xml/rss2', {
                           headers: { 'User-Agent':`Mozilla/5.0 (X11; CrOS x86_64 8172.45.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.64 Safari/537.36` }
        }).then( async function(response) { //fetch("https://www.tagesschau.de/xml/rss2");
         const xmlText =  response.data; //log(response.data)
        parseString(xmlText, {explicitArray: true,  mergeAttrs: true, normalize: true, compact: true, spaces: 2 }, (err, result) => { //log(result)
             if (err) {
               console.error(err);
               return;}
         //log(result.rss.channel[0])
             // Set datapoints
             setState(datapoint_Timestamp,formatDate(getDateObject((new Date().getTime())), "JJJJ.MM.TT SS:mm:ss.sss"));    /*scriptEnabled common Date-Functions currDate*/
               //console.log (currLocalDate());
               var content_Enc;
               // Set datapoints;
             //  createState(datapoint_ContentEnc);
         } //schleife
           }); //parsing
        } // async func
        async function makedp(point){
            if (!await existsStateAsync(point)) {
               await createStateAsync(point, "",{type: "string", role: "value", read: true, write: true, } ); }
          Butschek @liv-in-sky last edited by
          Die Klammersetzung ist natürlich falsch.
          Habe nun des gesamte Slript quasi in die Schedule Funktion aufgenommen. Dann klappt es auch problemlos.
          VG
          Holger
