    4. Adapter upgrade klappt nicht
    • werner2000x
      werner2000x last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      Ich kann drei adapter nicht mehr upgraden. Folgender Fehler kommt mit iob upgrade --debug
      iob upgrade --debug
      Update vw-connect from @0.0.62 to @0.0.67
      NPM version: 9.5.1
      Installing iobroker.vw-connect@0.0.67... (System call)
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
      npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
      npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
      npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
      npm ERR!     /home/iobroker/.npm/_logs/2023-04-18T11_57_07_123Z-debug-0.log
      upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
      upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
      upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
      upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
      upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
      Update vis-icontwo from @0.90.0 to @0.93.0
      NPM version: 9.5.1
      Installing iobroker.vis-icontwo@0.93.0... (System call)
      npm ERR!     /home/iobroker/.npm/_logs/2023-04-18T11_57_32_606Z-debug-0.log
      Adapter "system.adapter.vis.0" restarted.
      upload [1347] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
      upload [1300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/sensor_window_red.png Alarm/sensor_window_red.png image/png
      upload [1250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Automobile/defogger2.png Automobile/defogger2.png image/png
      upload [1200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/80.jpg Backgrounds/Seamless/80.jpg image/jpeg
      upload [1150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/raspberry.png Brands/raspberry.png image/png
      upload [1100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Awning/awning4_50.png Devices/Awning/awning4_50.png image/png
      upload [1050] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Computers/pc_rep.png Devices/Computers/pc_rep.png image/png
      upload [1000] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Cooling/fan2_mode_timer.png Devices/Cooling/fan2_mode_timer.png image/png
      upload [950] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Network/offline.png Devices/Network/offline.png image/png
      upload [900] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Sounds/radio_cb.png Devices/Sounds/radio_cb.png image/png
      upload [850] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/microwave.png Devices/microwave.png image/png
      upload [800] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/Shutter/blinds2_50.png Doors_Windows/Shutter/blinds2_50.png image/png
      upload [750] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Drinks_Food/beans.png Drinks_Food/beans.png image/png
        Thomas Braun Most Active @werner2000x last edited by Thomas Braun
        @werner2000x sagte in Adapter upgrade klappt nicht:
        Node.js 18 is currently NOT supported because the used OAuth library does not support it!
        Und das blockiert die anderen Updates mit. Vielleicht hier erstmal mit nodejs16 weiterfahren.
        Oder hier mal eine Beta installieren. Die dürfte auch funktionieren.
        werner2000x 1 Reply Last reply Reply Quote 0
        • werner2000x
          werner2000x @Thomas Braun last edited by
          @thomas-braun Vielen Dank für die Antwort 🙂
          Ich warte noch etwas mit einer Umstellung, da ich ohne Upgrade (noch) keine Probleme habe.
          Vielleicht löst sich der Fehler bald von selbst.
            Der löst sich, wenn eine nodejs18-kompatible Version über das bei dir eingestellte Repo (vermutlich 'stable') verfügbar ist.
            upgrade adpater
