    4. Fehler im ioBroker
    Fehler im ioBroker
      Tomme last edited by Homoran
      moin moin Jungs und Mädels!
      ich bin Frischling und hab da mal ne Frage ...
      ich habe folgende Fehler in meiner iobroker Installation und weiß nicht ob die problematisch sind ... kann jemand dazu was sagen? kann ich das so lassen oder muß ich irgendwas neu installieren?
      pi@ioBrokerPi:/opt/iobroker $ npm prune
      npm WARN skipping integrity check for git dependency ssh://git@github.com/motuditli/ioBroker.solarwetter.git
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      removed 863 packages, and changed 71 packages in 4m
      145 packages are looking for funding
        run `npm fund` for details
      pi@ioBrokerPi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.solarwetter@1.0.2 /opt/iobroker/node_modules/iobroker.solarwetter
      npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      ├── iobroker.reolink@0.1.1 (git+ssh://git@github.com/aendue/ioBroker.reolink.git#b78aab6744cdb81b360fd947a9c6e2fd6808bab1)
      ├── iobroker.solarwetter@1.0.2 invalid: "github:motuditli/ioBroker.solarwetter#c5d340e2b3e021951a88c44a89f6219624c97a15" from the root project
      npm ERR!     /home/iobroker/.npm/_logs/2023-04-27T19_10_17_300Z-debug-0.log
      Ich hoffe ich muß ihn nicht neu installieren ... für eure Bemühungen vielen Dank!
      es grüßt der Tomme!
      T Codierknecht 2 Replies Last reply Reply Quote 0
        Tomme @Tomme last edited by
        und das kommt bei npm audit dazu
        pi@ioBrokerPi:/opt/iobroker $ npm audit fix --force
        npm WARN using --force Recommended protections disabled.
        npm WARN audit Updating iobroker.js-controller to 1.3.0, which is a SemVer major change.
        npm WARN audit No fix available for iobroker.javascript@*
        npm WARN audit Updating iobroker.backitup to 0.2.7, which is a SemVer major change.
        npm WARN audit No fix available for iobroker.nina@*
        npm WARN audit No fix available for iobroker.solarwetter@*
        npm WARN audit Updating iobroker.cloud to 4.0.10, which is a SemVer major change.
        npm WARN audit Updating iobroker.discovery to 0.4.0, which is a SemVer major change.
        npm WARN audit Updating iobroker.loxone to 2.2.3, which is a SemVer major change.
        npm WARN audit Updating iobroker.node-red to 1.2.0, which is a SemVer major change.
        npm WARN audit Updating iobroker.samsung to 0.2.9, which is a SemVer major change.
        npm WARN audit Updating iobroker.yahka to 0.16.0, which is a SemVer major change.
        removed 863 packages, changed 61 packages, and audited 1450 packages in 3m
        # npm audit report
        axios  <=0.21.1
        Severity: high
        Axios vulnerable to Server-Side Request Forgery - https://github.com/advisories/GHSA-4w2v-q235-vp99
        axios Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-cph5-m8f7-6c5x
        Depends on vulnerable versions of follow-redirects
        fix available via `npm audit fix --force`
        Will install iobroker.loxone@2.2.3, which is a breaking change
        node_modules/lxcommunicator/node_modules/axios
          lxcommunicator  *
          Depends on vulnerable versions of axios
            iobroker.loxone  >=3.0.0
            Depends on vulnerable versions of lxcommunicator
            node_modules/iobroker.loxone
        debug  <=2.6.8
        Severity: high
        debug Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-9vvw-cc9w-f27h
        Regular Expression Denial of Service in debug - https://github.com/advisories/GHSA-gxpj-cx7g-858c
        Depends on vulnerable versions of ms
        Will install iobroker.discovery@0.4.0, which is a breaking change
        node_modules/engine.io-client/node_modules/debug
        node_modules/engine.io/node_modules/debug
        node_modules/mdns-discovery/node_modules/debug
        node_modules/socket.io-adapter/node_modules/debug
        node_modules/socket.io-client/node_modules/debug
        node_modules/socket.io-parser/node_modules/debug
        node_modules/socket.io/node_modules/debug
          engine.io  <=3.6.0
          Depends on vulnerable versions of debug
            socket.io  <=2.4.1
            Depends on vulnerable versions of engine.io
            Depends on vulnerable versions of socket.io-adapter
            Depends on vulnerable versions of socket.io-client
            Depends on vulnerable versions of socket.io-parser
              node-red-contrib-polymer  *
              node_modules/node-red-contrib-polymer
                iobroker.node-red  >=1.4.0
                Depends on vulnerable versions of node-red
                Depends on vulnerable versions of node-red-contrib-polymer
                Depends on vulnerable versions of node-red-node-feedparser
                Depends on vulnerable versions of node-red-node-twitter
                node_modules/iobroker.node-red
          engine.io-client  <=3.1.1
          Depends on vulnerable versions of parsejson
            socket.io-client  1.0.0-pre - 2.1.1
            Depends on vulnerable versions of engine.io-client
              iobroker.cloud  <=2.4.6 || 2.8.0 - 3.0.2 || >=4.0.11
              node_modules/iobroker.cloud
          mdns-discovery  >=0.1.1
            iobroker.discovery  >=0.4.4
            Depends on vulnerable versions of mdns-discovery
            node_modules/iobroker.discovery
          socket.io-adapter  <=1.1.0
          socket.io-parser  <=3.3.2
        follow-redirects  <=1.14.7
        Severity: high
        Exposure of Sensitive Information to an Unauthorized Actor in follow-redirects - https://github.com/advisories/GHSA-pw2r-vq6v-hr8c
        Exposure of sensitive information in follow-redirects - https://github.com/advisories/GHSA-74fj-2j2h-c42q
        node_modules/lxcommunicator/node_modules/follow-redirects
        jsonwebtoken  <=8.5.1
        Severity: moderate
        jsonwebtoken unrestricted key type could lead to legacy keys usage  - https://github.com/advisories/GHSA-8cf7-32gw-wr33
        jsonwebtoken's insecure implementation of key retrieval function could lead to Forgeable Public/Private Tokens from RSA to HMAC - https://github.com/advisories/GHSA-hjrf-2m68-5959
        jsonwebtoken vulnerable to signature validation bypass due to insecure default algorithm in jwt.verify() - https://github.com/advisories/GHSA-qwph-4952-7xr6
        No fix available
        node_modules/jsonwebtoken
          @iobroker/js-controller-adapter  <=5.0.0-alpha.0-20221230-c7ef56a8
          Depends on vulnerable versions of @iobroker/db-objects-file
          Depends on vulnerable versions of @iobroker/db-objects-jsonl
          Depends on vulnerable versions of @iobroker/db-objects-redis
          Depends on vulnerable versions of @iobroker/db-states-file
          Depends on vulnerable versions of @iobroker/db-states-jsonl
          Depends on vulnerable versions of @iobroker/db-states-redis
          Depends on vulnerable versions of @iobroker/js-controller-common
          Depends on vulnerable versions of jsonwebtoken
          node_modules/@iobroker/js-controller-adapter
            iobroker.js-controller  *
            Depends on vulnerable versions of @iobroker/js-controller-adapter
            Depends on vulnerable versions of @iobroker/js-controller-cli
            Depends on vulnerable versions of @iobroker/js-controller-common-db
            Depends on vulnerable versions of le-acme-core
            Depends on vulnerable versions of request
            node_modules/iobroker.js-controller
          @iobroker/js-controller-common  <=5.0.0-alpha.0-20221230-c7ef56a8
          node_modules/@iobroker/js-controller-common
            @iobroker/db-base  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/db-base
              @iobroker/db-objects-file  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
              Depends on vulnerable versions of @iobroker/db-base
              node_modules/@iobroker/db-objects-file
              @iobroker/db-objects-jsonl  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
              node_modules/@iobroker/db-objects-jsonl
              @iobroker/db-objects-redis  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
              node_modules/@iobroker/db-objects-redis
              @iobroker/db-states-file  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
              node_modules/@iobroker/db-states-file
              @iobroker/db-states-jsonl  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
              node_modules/@iobroker/db-states-jsonl
              @iobroker/db-states-redis  4.0.0-alpha.1-20210830-d9828cd3 - 4.1.0-alpha.3-20220302-91ae5b6c
              node_modules/@iobroker/db-states-redis
            @iobroker/js-controller-cli  <=4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/js-controller-cli
            @iobroker/js-controller-common-db  <=4.1.0-alpha.3-20220302-91ae5b6c
            node_modules/@iobroker/js-controller-common-db
        moment-timezone  0.1.0 - 0.5.34
        Severity: moderate
        Command Injection in moment-timezone - https://github.com/advisories/GHSA-56x4-j7p9-fcf9
        Cleartext Transmission of Sensitive Information in moment-timezone - https://github.com/advisories/GHSA-v78c-4p63-2j6c
        Will install iobroker.node-red@1.10.1, which is a breaking change
        node_modules/moment-timezone
          @node-red/util  1.2.4 - 3.0.2
          Depends on vulnerable versions of moment-timezone
          node_modules/@node-red/util
            @node-red/editor-api  1.2.4 - 3.0.2
            Depends on vulnerable versions of @node-red/util
            node_modules/@node-red/editor-api
            @node-red/registry  1.2.4 - 3.0.2
            node_modules/@node-red/registry
            @node-red/runtime  1.2.4 - 3.0.2
            Depends on vulnerable versions of @node-red/registry
            node_modules/@node-red/runtime
            node-red  >=0.20.0-beta.2
            Depends on vulnerable versions of @node-red/editor-api
            Depends on vulnerable versions of @node-red/nodes
            Depends on vulnerable versions of @node-red/runtime
        ms  <2.0.0
        Severity: moderate
        Vercel ms Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-w9mr-4mfr-499f
        node_modules/engine.io-client/node_modules/ms
        node_modules/engine.io/node_modules/ms
        node_modules/mdns-discovery/node_modules/ms
        node_modules/socket.io-adapter/node_modules/ms
        node_modules/socket.io-client/node_modules/ms
        node_modules/socket.io-parser/node_modules/ms
        node_modules/socket.io/node_modules/ms
        node-forge  <=1.2.1
        Severity: high
        Prototype Pollution in node-forge debug API. - https://github.com/advisories/GHSA-5rrq-pxf6-6jx5
        Prototype Pollution in node-forge util.setPath API - https://github.com/advisories/GHSA-wxgw-qj99-44c2
        URL parsing in node-forge could lead to undesired behavior. - https://github.com/advisories/GHSA-gf8q-jrpm-jvxq
        Improper Verification of Cryptographic Signature in `node-forge` - https://github.com/advisories/GHSA-2r2c-g63r-vccr
        Open Redirect in node-forge - https://github.com/advisories/GHSA-8fr3-hfg3-gpgp
        Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-cfm4-qjh2-4765
        Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-x4jg-mjrx-434g
        Prototype Pollution in node-forge - https://github.com/advisories/GHSA-92xj-mqp7-vmcj
        fix available via `npm audit fix`
        node_modules/rsa-compat/node_modules/node-forge
          rsa-compat  <=1.9.4
          Depends on vulnerable versions of node-forge
        parsejson  *
        Severity: high
        Regular Expression Denial of Service in parsejson - https://github.com/advisories/GHSA-q75g-2496-mxpp
        Will install iobroker.cloud@4.0.10, which is a breaking change
        node_modules/parsejson
        request  *
        Severity: moderate
        Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
        No fix available
        node_modules/request
          dropbox-v2-api  *
          node_modules/dropbox-v2-api
          iobroker.backitup  >=0.3.0
          Depends on vulnerable versions of dropbox-v2-api
          node_modules/iobroker.backitup
          iobroker.javascript  *
          node_modules/iobroker.javascript
          iobroker.nina  *
          node_modules/iobroker.nina
          iobroker.solarwetter  *
          le-acme-core  *
          Depends on vulnerable versions of rsa-compat
          node_modules/le-acme-core
          node-red-node-feedparser  *
          node_modules/node-red-node-feedparser
          node-red-node-twitter  >=0.0.4
          node_modules/node-red-node-twitter
          request-promise  >=0.0.2
          Depends on vulnerable versions of request-promise-core
          node_modules/request-promise
            samsungtv
            node_modules/samsungtv
              iobroker.samsung  >=0.5.1
              Depends on vulnerable versions of samsungtv
              node_modules/iobroker.samsung
          request-promise-core  *
          node_modules/request-promise-core
        xml2js  <0.5.0
        Severity: moderate
        xml2js is vulnerable to prototype pollution  - https://github.com/advisories/GHSA-776f-qx25-q3cc
        Will install iobroker.yahka@0.16.0, which is a breaking change
        node_modules/xml2js
          @homebridge/dbus-native  *
          Depends on vulnerable versions of xml2js
          node_modules/@homebridge/dbus-native
            hap-nodejs  >=0.10.0-beta.0
            Depends on vulnerable versions of @homebridge/dbus-native
            node_modules/hap-nodejs
              iobroker.yahka  0.15.0 || >=0.17.0
              Depends on vulnerable versions of hap-nodejs
              node_modules/iobroker.yahka
          @node-red/nodes  *
          node_modules/@node-red/nodes
        57 vulnerabilities (5 low, 38 moderate, 13 high, 1 critical)
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues possible (including breaking changes), run:
        Some issues need review, and may require choosing
        a different dependency.
        *** Fehlercode: 1 ***
        • Codierknecht
          Codierknecht Developer Most Active @Tomme last edited by
          @tomme sagte in Fehler im ioBroker:
          Wie hast Du den denn installiert?
          Das sieht mir schon äußerst suspekt aus.
          T Thomas Braun 3 Replies Last reply Reply Quote 1
            Tomme @Codierknecht last edited by Tomme
            @codierknecht
            ich habe bei dieser xten Version in der ich alles neu aufgesetzt habe nur das skript geladen und ausgeführt lief bisher optisch alles fehlerfrei durch auch die adapterinstallationen ... der Großteil läuft auch ...
            # node installieren für iobroker
            sudo apt-get update && sudo apt-get upgrade
            cd
            curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash - # Ungerade Node.js Versionen dürfen nicht verwendet werden.
            sudo apt-get install -y nodejs
            sudo apt-get install npm
            cd
            . .bashrc # liest die user bashrc in der geöffneten Konsole neu ein
            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null # listet die Verzeichnisse auf
            uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            sudo apt-get update && sudo apt-get upgrade && sudo apt-get full-upgrade && sudo npm audit fix --force
            curl -sLf https://iobroker.net/install.sh | bash - # ioBroker Installationsskript
            cd
              @codierknecht
              und dann die adapter installiert mit ihren instanzen und davor gab es keine Fehler npm audit ist ohne Fehler durch gelaufen
              pi@ioBrokerPi:/opt/iobroker $ iob update
              Used repository: stable
              Adapter    "admin"        : 6.3.5    , installed 6.3.5
              Adapter    "alarm"        : 3.3.9    , installed 3.3.9
              Adapter    "backitup"     : 2.6.19   , installed 2.6.19
              Adapter    "bmw"          : 2.5.7    , installed 2.5.7
              Adapter    "cloud"        : 4.3.0    , installed 4.4.1
              Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
              Adapter    "geofency"     : 1.2.4    , installed 1.2.4
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "homekit-controller": 0.5.8, installed 0.5.8
              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
              Controller "js-controller": 4.0.24   , installed 4.0.24
              Adapter    "landroid"     : 1.0.3    , installed 1.0.3
              Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
              Adapter    "loxone"       : 3.0.1    , installed 3.0.1
              Adapter    "nina"         : 0.0.25   , installed 0.0.25
              Adapter    "node-red"     : 4.0.0    , installed 4.0.3
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "samsung"      : 0.5.11   , installed 0.5.11
              Adapter    "solarwetter"  : 1.0.0    , installed 1.0.2
              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
              Adapter    "worx"         : 2.1.3    , installed 2.1.3
              Adapter    "yahka"        : 0.17.0   , installed 0.17.0
              • Codierknecht
                @tomme
                Was sagt denn
                iob diag
                T 3 Replies Last reply Reply Quote 1
                  Tomme @Codierknecht last edited by Homoran
                  @codierknecht said in Fehler im ioBroker:
                  iob diag
                  Teil 1
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Architecture    : aarch64
                  Docker          : false
                  Virtualization  : none
                  Distributor ID: Debian
                  Description:    Debian GNU/Linux 11 (bullseye)
                  Release:        11
                  Codename:       bullseye
                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                  NAME="Debian GNU/Linux"
                  VERSION_ID="11"
                  VERSION="11 (bullseye)"
                  VERSION_CODENAME=bullseye
                  ID=debian
                  HOME_URL="https://www.debian.org/"
                  SUPPORT_URL="https://www.debian.org/support"
                  BUG_REPORT_URL="https://bugs.debian.org/"
                  Systemuptime and Load:
                   21:58:49 up 1 day, 20:28,  4 users,  load average: 0.46, 0.33, 0.34
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  Other values than 0x0 hint to temperature/voltage problems
                  temp=54.0'C
                  volt=0.9260V
                  *** Time and Time Zones ***
                                 Local time: Thu 2023-04-27 21:58:50 CEST
                             Universal time: Thu 2023-04-27 19:58:50 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            7.8G        2.5G        1.5G         78M        3.7G        5.0G
                  Swap:           3.7G          0B        3.7G
                  Total:           11G        2.5G        5.2G
                           7811 M total memory
                           2550 M used memory
                           3142 M active memory
                           2003 M inactive memory
                           1513 M free memory
                            328 M buffer memory
                           3418 M swap cache
                           3683 M total swap
                              0 M used swap
                           3683 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  Filesystem               Type      Size  Used Avail Use% Mounted on
                  /dev/root                ext4       24G  8.1G   15G  36% /
                  devtmpfs                 devtmpfs  3.6G     0  3.6G   0% /dev
                  tmpfs                    tmpfs     3.9G     0  3.9G   0% /dev/shm
                  tmpfs                    tmpfs     1.6G  1.4M  1.6G   1% /run
                  tmpfs                    tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                  /dev/sda1                vfat      255M   31M  225M  13% /boot
                  tmpfs                    tmpfs     782M   36K  782M   1% /run/user/1000
                  /dev/sda4                fuseblk  1000M  321M  680M  33% /media/pi/Austausch-USB
                  /dev/mmcblk0p4           ext4       12G  312M   11G   3% /media/pi/Austausch-SD
                  /dev/mmcblk0p2           ext4       14G   11G  2.1G  84% /media/pi/writable
                  /dev/mmcblk0p1           vfat      253M  120M  133M  48% /media/pi/system-boot
                  //192.168.7.1/BackItUp   cifs      238G  183G   55G  77% /opt/iobroker/backups
                  //192.168.7.1/BackItUp/  cifs      238G  183G   55G  77% /opt/iobroker/backups
                  //192.168.7.1/ioBrokerPi cifs      238G  183G   55G  77% /mnt/LaptopIoBrokerPi
                  [Wed Apr 26 01:30:03 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:0A:D6:44 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=ee423409-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Wed Apr 26 01:30:06 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Wed Apr 26 01:30:06 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Wed Apr 26 01:30:08 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  [Wed Apr 26 01:30:33 2023] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Quota mode: none.
                  [Wed Apr 26 01:30:34 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  Show mounted filesystems (real ones only):
                  TARGET                    SOURCE                   FSTYPE  OPTIONS
                  /                         /dev/sda2                ext4    rw,noatime
                  |-/boot                   /dev/sda1                vfat    rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  |-/mnt/LaptopIoBrokerPi   //192.168.7.1/ioBrokerPi cifs    rw,relatime,vers=2.1,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                  |-/media/pi/Austausch-USB /dev/sda4                fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096
                  |-/media/pi/Austausch-SD  /dev/mmcblk0p4           ext4    rw,nosuid,nodev,relatime,errors=remount-ro
                  |-/media/pi/writable      /dev/mmcblk0p2           ext4    rw,nosuid,nodev,relatime,errors=remount-ro
                  |-/media/pi/system-boot   /dev/mmcblk0p1           vfat    rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
                  `-/opt/iobroker/backups   //192.168.7.1/BackItUp   cifs    rw,relatime,vers=2.1,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                    `-/opt/iobroker/backups //192.168.7.1/BackItUp/  cifs    rw,relatime,vers=2.0,cache=strict,username=Tomme,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.7.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                  /var:
                  1.2G    /var/
                  491M    /var/cache
                  482M    /var/cache/apt
                  381M    /var/cache/apt/archives
                  326M    /var/log
                  Archived and active journals take up 304.1M in the file system.
                  /opt/iobroker/backups:
                  6.2M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  269M    /opt/iobroker/iobroker-data/
                  132M    /opt/iobroker/iobroker-data/node-red/node_modules
                  91M     /opt/iobroker/iobroker-data/files
                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                  14M     /opt/iobroker/iobroker-data/objects.jsonl
                  11M     /opt/iobroker/iobroker-data/states.jsonl
                  7.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.52e68e8c.js
                  6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.16.0
                  /usr/bin/node           v18.16.0
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Installed: 18.16.0-deb-1nodesource1
                    Candidate: 18.16.0-deb-1nodesource1
                    Version table:
                   *** 18.16.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                          100 /var/lib/dpkg/status
                       12.22.12~dfsg-1~deb11u3 500
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.5~dfsg-2~11u1 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  No problems detected
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  MULTIHOSTSERVICE/enabled: false
                  Core adapters versions
                  js-controller:  4.0.24
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapters from github:   2
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : ioBrokerPi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alarm.0                  : alarm                 : ioBrokerPi                               -  enabled
                  + system.adapter.backitup.0               : backitup              : ioBrokerPi                               -  enabled
                  + system.adapter.bmw.0                    : bmw                   : ioBrokerPi                               -  enabled
                  + system.adapter.cloud.0                  : cloud                 : ioBrokerPi                               -  enabled
                    system.adapter.daswetter.0              : daswetter             : ioBrokerPi                               -  enabled
                  + system.adapter.discovery.0              : discovery             : ioBrokerPi                               -  enabled
                    system.adapter.dwd.0                    : dwd                   : ioBrokerPi                               -  enabled
                  + system.adapter.geofency.0               : geofency              : ioBrokerPi                               -  enabled, port: 7999, bind: 0.0.0.0
                  + system.adapter.homeconnect.0            : homeconnect           : ioBrokerPi                               -  enabled
                  + system.adapter.homekit-controller.0     : homekit-controller    : ioBrokerPi                               -  enabled
                  + system.adapter.javascript.0             : javascript            : ioBrokerPi                               -  enabled
                    system.adapter.landroid.0               : landroid              : ioBrokerPi                               - disabled
                  + system.adapter.lg-thinq.0               : lg-thinq              : ioBrokerPi                               -  enabled
                  + system.adapter.loxone.0                 : loxone                : ioBrokerPi                               -  enabled, port: 80
                  + system.adapter.net-tools.0              : net-tools             : ioBrokerPi                               -  enabled
                  + system.adapter.nina.0                   : nina                  : ioBrokerPi                               -  enabled
                  + system.adapter.node-red.0               : node-red              : ioBrokerPi                               -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.ping.0                   : ping                  : ioBrokerPi                               -  enabled
                    system.adapter.reolink.0                : reolink               : ioBrokerPi                               - disabled
                  + system.adapter.reolink.1                : reolink               : ioBrokerPi                               - disabled
                  + system.adapter.reolink.2                : reolink               : ioBrokerPi                               -  enabled
                    system.adapter.reolink.3                : reolink               : ioBrokerPi                               - disabled
                    system.adapter.reolink.4                : reolink               : ioBrokerPi                               - disabled
                    system.adapter.reolink.5                : reolink               : ioBrokerPi                               - disabled
                  + system.adapter.samsung.0                : samsung               : ioBrokerPi                               -  enabled
                  + system.adapter.simple-api.0             : simple-api            : ioBrokerPi                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    system.adapter.solarwetter.0            : solarwetter           : ioBrokerPi                               -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerPi                               -  enabled
                    system.adapter.weatherunderground.1     : weatherunderground    : ioBrokerPi                               -  enabled
                  + system.adapter.worx.0                   : worx                  : ioBrokerPi                               -  enabled
                  + system.adapter.yahka.0                  : yahka                 : ioBrokerPi                               -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Objects and States
                  Objects:        10450
                  States:         8419
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:5 https://linux.teamviewer.com/deb stable InRelease
                  Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                  Hit:7 https://repo.homebridge.io stable InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:39619         0.0.0.0:*               LISTEN      116        1027712    218340/homebridge:
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       612208     218206/node-red
                  tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          734        623/vncserver-x11-c
                  tcp        0      0 0.0.0.0:5938            0.0.0.0:*               LISTEN      0          1017263    406348/teamviewerd
                  tcp        0      0 127.0.0.1:44549         0.0.0.0:*               LISTEN      1001       616532     218875/io.yahka.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          638        656/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:40435         0.0.0.0:*               LISTEN      116        612338     218278/homebridge
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       610697     216843/iobroker.js-
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       612593     216843/iobroker.js-
                  tcp        0      0 0.0.0.0:44083           0.0.0.0:*               LISTEN      1001       614202     218875/io.yahka.0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15354      921/exim4
                  tcp        0      0 127.0.0.1:36971         0.0.0.0:*               LISTEN      116        1025518    218278/homebridge
                  tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          1017265    406348/teamviewerd
                  tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1000       1356322    608524/sshd: pi@pts
                  tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       1356914    608219/sshd: pi@pts
                  tcp        0      0 127.0.0.1:46197         0.0.0.0:*               LISTEN      116        1026919    218278/homebridge
                  tcp6       0      0 :::54900                :::*                    LISTEN      116        612034     218346/homebridge:
                  tcp6       0      0 :::5900                 :::*                    LISTEN      0          733        623/vncserver-x11-c
                  tcp6       0      0 :::5938                 :::*                    LISTEN      0          1017261    406348/teamviewerd
                  tcp6       0      0 :::34623                :::*                    LISTEN      116        612084     218340/homebridge:
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15355      921/exim4
                  tcp6       0      0 ::1:6011                :::*                    LISTEN      1000       1356321    608524/sshd: pi@pts
                  tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       1356913    608219/sshd: pi@pts
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          640        656/sshd: /usr/sbin
                  tcp6       0      0 :::41095                :::*                    LISTEN      116        611079     218339/homebridge:
                  tcp6       0      0 :::8581                 :::*                    LISTEN      116        613689     216910/hb-service
                  tcp6       0      0 :::40463                :::*                    LISTEN      116        613864     218358/homebridge:
                  tcp6       0      0 :::7999                 :::*                    LISTEN      1001       611931     218198/io.geofency.
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       616493     218783/io.simple-ap
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       611773     216947/io.admin.0
                  tcp6       0      0 :::56771                :::*                    LISTEN      116        611115     218347/homebridge:
                  tcp6       0      0 :::51619                :::*                    LISTEN      116        613763     218278/homebridge
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16458      520/dhcpcd
                  udp        0      0 0.0.0.0:58508           0.0.0.0:*                           108        15402      442/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       614207     218875/io.yahka.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       614206     218875/io.yahka.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       615470     218634/io.homekit-c
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       613242     218206/node-red
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        613686     216910/hb-service
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15400      442/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        15401      442/avahi-daemon: r
                  udp6       0      0 :::59619                :::*                                108        15403      442/avahi-daemon: r
                  2023-04-27 21:40:24.303  - info: bmw.0 (413780) Found 1 bmw vehicles
                  2023-04-27 21:42:58.735  - info: worx.0 (218834) No payload found
                  2023-04-27 21:45:00.055  - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 620555
                  2023-04-27 21:45:02.739  - info: dwd.0 (620555) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                  2023-04-27 21:45:04.095  - info: host.ioBrokerPi instance system.adapter.daswetter.0 started with pid 620582
                  2023-04-27 21:45:04.828  - info: dwd.0 (620555) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-04-27 21:45:05.383  - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-27 21:45:06.599  - info: daswetter.0 (620582) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24
                  2023-04-27 21:45:07.765  - info: daswetter.0 (620582) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2023-04-27 21:45:08.284  - info: daswetter.0 (620582) cleaned everything up...
                  2023-04-27 21:45:08.303  - info: host.ioBrokerPi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-27 21:45:25.456  - info: bmw.0 (413780) Found 1 bmw vehicles
                  2023-04-27 21:50:00.046  - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 621711
                  2023-04-27 21:50:02.542  - info: dwd.0 (621711) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                  2023-04-27 21:50:04.536  - info: dwd.0 (621711) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-04-27 21:50:05.121  - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-27 21:50:24.777  - info: bmw.0 (413780) Found 1 bmw vehicles
                  2023-04-27 21:50:36.029  - info: homekit-controller.0 (218634) IP-7A:0C:6C:53:B1:DF (Bungalow) found without known pairing data and already paired: ignoring
                  2023-04-27 21:52:46.685  - info: admin.0 (216947) ==> Connected system.user.admin from ::ffff:192.168.7.1
                  2023-04-27 21:52:58.784  - info: worx.0 (218834) No payload found
                  2023-04-27 21:55:00.047  - info: host.ioBrokerPi instance system.adapter.dwd.0 started with pid 623022
                  2023-04-27 21:55:02.716  - info: dwd.0 (623022) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                  2023-04-27 21:55:04.411  - info: dwd.0 (623022) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-04-27 21:55:05.000  - info: host.ioBrokerPi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-27 21:55:24.661  - info: bmw.0 (413780) Found 1 bmw vehicles
                  iob diag has finished.
                  Press any key for a summary
                    @codierknecht
                    Copy text starting here:
                                         v.2023-04-16
                    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                    Kernel:                 6.1.21-v8+
                    Installation:           Native
                    User-ID:                1000
                    X-Server:               true
                    Pending OS-Updates:     0
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                    Recommended versions are nodejs 18.x.y and npm 9.x.y
                    MEMORY:
                    Mem:            7.8G        2.5G        1.5G         78M        3.8G        5.0G
                    Swap:           3.7G          0B        3.7G
                    Active iob-Instances:   23
                    ioBroker Core:          js-controller           4.0.24
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                10450
                    States:                 8419
                    Size of iob-Database:
                    12M     /opt/iobroker/iobroker-data/states.jsonl
                      @codierknecht
                      iwi fehlt da immer der reolink adapter ... davon habe ich 6 instanzen ... aber wird nicht angezeigt ich schau mal ob die gelöscht sind ;/
                      ... sind noch da
                      • Codierknecht
                        Codierknecht Developer Most Active last edited by
                        @tomme
                        Da läuft ein Desktop. Der hat auf 'nem Server nix verloren.
                        Und das Boot-Target sollte dann auch gleich auf multi-user.target umgestellt werden.
                        T 2 Replies Last reply Reply Quote 1
                          @codierknecht
                          den desktop schalte ich aus wenn alles läuft
                          und von dem anderen habe ich keine ahnung ... leider
                            @codierknecht
                            hab ich jetzt was falsch gemacht?
                            pi@ioBrokerPi:/opt/iobroker $ iob setup
                            Successfully migrated 10450 objects to Redis Sets
                            object 0_userdata.0.example_state yet exists
                            object 0_userdata.0 yet exists
                            object alias.0 yet exists
                            object system.certificates yet exists
                            object system.licenses yet exists
                            object system.repositories yet exists
                            object system.config yet exists
                            object enum.functions yet exists
                            object enum.rooms yet exists
                            object system.group.user yet exists
                            object system.group.administrator yet exists
                            object _design/system updated
                            • Codierknecht
                              Wenn Du den nur ausschaltest, schleppst Du den Kram ja trotzdem weiterhin mit.
                              Nur damit da keine falsche Hoffnung aufkommt: Ich auch nicht wirklich - ich nutze an der Ecke einen fertigen Container.
                              Vielleicht kann ja mal @Thomas-Braun hier drüberschauen?
                                woher weißt du wie ich heiße??? ist ja witzig 👍
                                  @codierknecht
                                  an docker habe ich mich noch nicht ran getraut ... wollte erstmal hiermit klar kommen
                                    Thomas Braun Most Active @Tomme last edited by
                                    @tomme
                                    Finger weg von
                                    Das zieht dir ggfls. unwiederbringlich die Installation auf Links.
                                    Und ein Desktop inkl. Teamviewer hat auf einem Server nic verloren.
                                    Installier es neu, diesmal gescheit.
                                      Tomme @Thomas Braun last edited by Tomme
                                      moin,
                                      alles neu?
                                      kriegen wir wenigstens das backup vorher zum laufen???
                                      teamviewer ist schnell gelöscht
                                        @tomme
                                        Hast du etwa keins von vor dem Blödsinn?
                                        T 2 Replies Last reply Reply Quote 0
                                          na nee darum bin ich ja hier ... 🤕
                                            du heißt übrigens genau wie ich ... das ist sehr löblich 😉
                                            15496
