    4. USB Prots nach Update nicht mehr erreichbar
      Rushmed Most Active last edited by
      habe mein PI4 8GB Raspibain aktualisiert.
      pi@Smartazamba:~ $ iobroker stop && sudo apt update && sudo apt full-upgrade --yes && sudo reboot
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists... Done
      Building dependency tree... Done
      32 packages can be upgraded. Run 'apt list --upgradable' to see them.
      Calculating upgrade... Done
      The following packages will be upgraded:
        avahi-daemon base-files debian-archive-keyring grep influxdb2 influxdb2-cli isc-dhcp-client isc-dhcp-common
        libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3
        libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libncurses6 libncursesw6 libpam-systemd
        libsystemd0 libtinfo6 libudev-dev libudev1 libxpm4 ncurses-base ncurses-bin ncurses-term systemd systemd-sysv
        systemd-timesyncd tzdata udev
      32 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 54.5 MB/65.1 MB of archives.
      After this operation, 115 kB of additional disk space will be used.
      Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb2 arm64 2.7.1-1 [43.8 MB]
      Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.7.3-1 [10.7 MB]
      Fetched 54.5 MB in 8s (6820 kB/s)
      apt-listchanges: Reading changelogs...
      Extracting templates from packages: 100%
      Preconfiguring packages ...
      (Reading database ... 59871 files and directories currently installed.)
      Preparing to unpack .../base-files_11.1+deb11u7_arm64.deb ...
      Unpacking base-files (11.1+deb11u7) over (11.1+deb11u6) ...
      Setting up base-files (11.1+deb11u7) ...
      Installing new version of config file /etc/debian_version ...
      Preparing to unpack .../grep_3.6-1+deb11u1_arm64.deb ...
      Unpacking grep (3.6-1+deb11u1) over (3.6-1) ...
      Setting up grep (3.6-1+deb11u1) ...
      Preparing to unpack .../ncurses-bin_6.2+20201114-2+deb11u1_arm64.deb ...
      Unpacking ncurses-bin (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      Setting up ncurses-bin (6.2+20201114-2+deb11u1) ...
      Preparing to unpack .../ncurses-base_6.2+20201114-2+deb11u1_all.deb ...
      Unpacking ncurses-base (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      Setting up ncurses-base (6.2+20201114-2+deb11u1) ...
      Preparing to unpack .../systemd-sysv_247.3-7+deb11u2_arm64.deb ...
      Unpacking systemd-sysv (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Preparing to unpack .../libpam-systemd_247.3-7+deb11u2_arm64.deb ...
      Unpacking libpam-systemd:arm64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Preparing to unpack .../libudev-dev_247.3-7+deb11u2_arm64.deb ...
      Unpacking libudev-dev:arm64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Preparing to unpack .../libsystemd0_247.3-7+deb11u2_arm64.deb ...
      Unpacking libsystemd0:arm64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Setting up libsystemd0:arm64 (247.3-7+deb11u2) ...
      Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u2_arm64.deb ...
      Unpacking systemd-timesyncd (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Preparing to unpack .../systemd_247.3-7+deb11u2_arm64.deb ...
      Unpacking systemd (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Preparing to unpack .../udev_247.3-7+deb11u2_arm64.deb ...
      Unpacking udev (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Preparing to unpack .../libudev1_247.3-7+deb11u2_arm64.deb ...
      Unpacking libudev1:arm64 (247.3-7+deb11u2) over (247.3-7+deb11u1) ...
      Setting up libudev1:arm64 (247.3-7+deb11u2) ...
      Preparing to unpack .../0-avahi-daemon_0.8-5+deb11u2_arm64.deb ...
      Unpacking avahi-daemon (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../1-libavahi-core7_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-core7:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../2-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../3-libavahi-client-dev_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-client-dev:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../4-libavahi-compat-libdnssd1_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-compat-libdnssd1:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../5-libavahi-client3_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-client3:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../6-libavahi-common-dev_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-common-dev:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../7-libavahi-common3_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-common3:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../8-libavahi-common-data_0.8-5+deb11u2_arm64.deb ...
      Unpacking libavahi-common-data:arm64 (0.8-5+deb11u2) over (0.8-5+deb11u1) ...
      Preparing to unpack .../9-debian-archive-keyring_2021.1.1+deb11u1_all.deb ...
      Unpacking debian-archive-keyring (2021.1.1+deb11u1) over (2021.1.1) ...
      Setting up debian-archive-keyring (2021.1.1+deb11u1) ...
      Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-automatic.gpg ...
      Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-security-automatic.gpg ...
      Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-stretch-stable.gpg ...
      Preparing to unpack .../libncurses6_6.2+20201114-2+deb11u1_arm64.deb ...
      Unpacking libncurses6:arm64 (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      Preparing to unpack .../libncursesw6_6.2+20201114-2+deb11u1_arm64.deb ...
      Unpacking libncursesw6:arm64 (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      Preparing to unpack .../libtinfo6_6.2+20201114-2+deb11u1_arm64.deb ...
      Unpacking libtinfo6:arm64 (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      Setting up libtinfo6:arm64 (6.2+20201114-2+deb11u1) ...
      Preparing to unpack .../0-tzdata_2021a-1+deb11u10_all.deb ...
      Unpacking tzdata (2021a-1+deb11u10) over (2021a-1+deb11u9) ...
      Preparing to unpack .../1-isc-dhcp-client_4.4.1-2.3+deb11u2_arm64.deb ...
      Unpacking isc-dhcp-client (4.4.1-2.3+deb11u2) over (4.4.1-2.3+deb11u1) ...
      Preparing to unpack .../2-isc-dhcp-common_4.4.1-2.3+deb11u2_arm64.deb ...
      Unpacking isc-dhcp-common (4.4.1-2.3+deb11u2) over (4.4.1-2.3+deb11u1) ...
      Preparing to unpack .../3-ncurses-term_6.2+20201114-2+deb11u1_all.deb ...
      Unpacking ncurses-term (6.2+20201114-2+deb11u1) over (6.2+20201114-2) ...
      Preparing to unpack .../4-influxdb2_2.7.1-1_arm64.deb ...
      Unpacking influxdb2 (2.7.1-1) over (2.7.0-1) ...
      Preparing to unpack .../5-influxdb2-cli_2.7.3-1_arm64.deb ...
      Unpacking influxdb2-cli (2.7.3-1) over (2.7.1-2) ...
      Preparing to unpack .../6-libxpm4_1%3a3.5.12-1.1~deb11u1_arm64.deb ...
      Unpacking libxpm4:arm64 (1:3.5.12-1.1~deb11u1) over (1:3.5.12-1) ...
      Setting up libxpm4:arm64 (1:3.5.12-1.1~deb11u1) ...
      Setting up influxdb2 (2.7.1-1) ...
      Config file /etc/influxdb/config.toml already exists, writing defaults to /etc/influxdb/config.toml.defaults
      Setting up isc-dhcp-client (4.4.1-2.3+deb11u2) ...
      Setting up systemd (247.3-7+deb11u2) ...
      Setting up tzdata (2021a-1+deb11u10) ...
      Current default time zone: 'Europe/Berlin'
      Local time is now:      Mon May  1 05:58:39 CEST 2023.
      Universal Time is now:  Mon May  1 03:58:39 UTC 2023.
      Run 'dpkg-reconfigure tzdata' if you wish to change it.
      Setting up libavahi-common-data:arm64 (0.8-5+deb11u2) ...
      Setting up libncurses6:arm64 (6.2+20201114-2+deb11u1) ...
      Setting up systemd-timesyncd (247.3-7+deb11u2) ...
      Setting up udev (247.3-7+deb11u2) ...
      Setting up libudev-dev:arm64 (247.3-7+deb11u2) ...
      Setting up libncursesw6:arm64 (6.2+20201114-2+deb11u1) ...
      Setting up isc-dhcp-common (4.4.1-2.3+deb11u2) ...
      Setting up influxdb2-cli (2.7.3-1) ...
      Setting up ncurses-term (6.2+20201114-2+deb11u1) ...
      Setting up systemd-sysv (247.3-7+deb11u2) ...
      Setting up libavahi-common3:arm64 (0.8-5+deb11u2) ...
      Setting up libavahi-common-dev:arm64 (0.8-5+deb11u2) ...
      Setting up libpam-systemd:arm64 (247.3-7+deb11u2) ...
      Setting up libavahi-core7:arm64 (0.8-5+deb11u2) ...
      Setting up libavahi-client3:arm64 (0.8-5+deb11u2) ...
      Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
      Setting up libavahi-compat-libdnssd1:arm64 (0.8-5+deb11u2) ...
      Setting up avahi-daemon (0.8-5+deb11u2) ...
      Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
      Processing triggers for dbus (1.12.24-0+deb11u1) ...
      Processing triggers for initramfs-tools (0.140) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
      Processing triggers for man-db (2.9.4-2) ...
      Danach werden die Ports der USB Geräte (Smartmeter und Zigbee) nichmehr gefunden.
      Die Gräte hängen an einem USB Hub, die Festplatten am anderen Port funktionieren.
      iobroker fix
      Hat auch nichts gebracht.
      Über die Console bekomme ich folgende Ausgaben:
      pi@Smartazamba:~ $ ls -l /dev/serial/by-id
      ls: cannot access '/dev/serial/by-id': No such file or directory
      Den USB Hub hatte ich erfolglos gegen eine anderen ausgetauscht. Nach wiederhestellen eines Iages des SSD funktioniert alles wieder.
      Das lief bei einem Update am Samstag genauso wie heute Morgen. Was Kann ich noch tun?
      • crunchip
        crunchip Forum Testing Most Active @Rushmed last edited by
        @rushmed https://forum.iobroker.net/post/985508
          Rushmed Most Active @crunchip last edited by
          @crunchip Danke!
          port update usb
