    4. Adapter smartgarden Fehler 403
      reutli last edited by
      erhalte seit heute Fehler im Adapter/Instanz.
      Habe soeben nochmals credentials gecheckt, die er ja wohl auch mit
      smartgarden.0
      	2023-05-03 14:17:14.242	info	1/ Connection: successful: response.statusCode / statusMessage=200 / OK
      akzeptiert, oder?
      Rest sieht dann so aus:
      smartgarden.0
      	2023-05-03 14:17:14.446	info	1/ getConnection: trying to connect again in 300 seconds
      smartgarden.0
      	2023-05-03 14:17:14.445	info	1/ getConnection: returned connection error: request returned 403 Forbidden
      smartgarden.0
      	2023-05-03 14:17:14.444	error	Error: request returned 403 Forbidden
      smartgarden.0
      	2023-05-03 14:17:14.444	info	1/ get_locations failure:..return with error
      smartgarden.0
      	2023-05-03 14:17:14.443	info	1/ get_locations failure: response.statusCode/Message=403/Forbidden
      smartgarden.0
      	2023-05-03 14:17:14.244	info	1/ get_locations ...
      smartgarden.0
      	2023-05-03 14:17:14.244	info	1/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
      smartgarden.0
      	2023-05-03 14:17:14.243	info	1/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
      smartgarden.0
      smartgarden.0
      	2023-05-03 14:17:13.976	info	1/ connect ... using client credentials grant
      smartgarden.0
      	2023-05-03 14:17:13.975	info	1/ connect ... empty password
      smartgarden.0
      	2023-05-03 14:17:13.973	info	1/ connect ... empty username
      smartgarden.0
      	2023-05-03 14:17:13.973	info	1/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
      smartgarden.0
      	2023-05-03 14:17:13.972	info	1/ connecting to Gardena Smart System Service ...
      smartgarden.0
      	2023-05-03 14:17:13.971	info	1/ connectToGardena...
      smartgarden.0
      	2023-05-03 14:17:13.970	info	1/ getConnection...
      smartgarden.0
      	2023-05-03 14:17:13.932	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v18.16.0, js-controller: 4.0.24
      Hat API einen Hänger?
      O sambaole Rene Lausenhammer K 4 Replies Last reply Reply Quote 0
      • O
        oFbEQnpoLKKl6mbY5e13 @reutli last edited by
        @reutli
        Ist bei mir auch so.
          reutli @oFbEQnpoLKKl6mbY5e13 last edited by reutli
          @ofbeqnpolkkl6mby5e13
          ok, danke, also API?
          • O
            oFbEQnpoLKKl6mbY5e13 @reutli last edited by oFbEQnpoLKKl6mbY5e13
            @reutli
            Schätze, ja, mal abwarten...
            • sambaole
              sambaole @reutli last edited by
              @reutli Habe das gleiche Problem. Lief bis gestern problemlos. API bei Husqvarna geändert?
                reutli @sambaole last edited by
                @sambaole
                Habe keine Ahnung. Ich mach mal noch einen GitHub Issue auf....
                Edit: gibt's schon : https://github.com/jpgorganizer/ioBroker.smartgarden/issues/56
                svenover created this issue in jpgorganizer/ioBroker.smartgarden
                closed Error: request returned 403 Forbidden #56
                  Hallo Leute,
                  für alle die in den issue rennen:
                  Ich habe einen neuen Account (APP-Key und - Secret) erstellt und damit hat es funktioniert.
                  Es scheint, dass Accounts/API-connects gesperrt wurde.
                  Könnt' Ihr das bestätigen?
                    Dominic151617 @reutli last edited by
                    @reutli Danke für den Tipp und ja, mit einer ganz neuen Application läuft es auch bei mir wieder.
                      reutli @Dominic151617 last edited by
                      @jpgorganizer kannst Du da mal schauen, was Sache ist. Die scheinen die accounts gesperrt zu haben...
                      D P 3 Replies Last reply Reply Quote 0
                        @reutli @jpgorganizer Also nicht die Accounts in dem Sinne, sondern die Applications. Habe in dem vorhanden Account die Application entsprechend der Anleitung neu angelegt.
                        O G 2 Replies Last reply Reply Quote 1
                          Pino72 @reutli last edited by
                          Hab auch nen neue Application erstellt und wollte die neuen keys einsetzen aber ich kann im IOBroker kein application secret mehr reinschreiben...Feld ist ausgegraut und lässt sich nicht editieren?
                            Dominic151617 @Pino72 last edited by
                            @pino72 sagte in Adapter smartgarden Fehler 403:
                            Benutzernamen und Passwort löschen
                              Pino72 @Dominic151617 last edited by
                              @dominic151617 DAnke! Das wars 🙂
                                @reutli @jpgorganizer Zur Info: bis heute lief der Adapter bei mir mit Benutzernamen und Passwort. Das hat ja wohl schon voher Probleme bereitet. Aber Key und Scret aus der vorhanden Application funktionierten nicht.
                                  Läuft jetzt wieder ohne Benutzername und PAsswort aber mit neuen Keys.
                                  • O
                                    oFbEQnpoLKKl6mbY5e13 @Dominic151617 last edited by
                                    @dominic151617 sagte in Adapter smartgarden Fehler 403:
                                    Das war auch bei mir die Lösung.
                                      Na wenigstens haben wir eine Lösung, auch wenn ich gerne den "root cause" wüsste...
                                      • Rene Lausenhammer
                                        Rene Lausenhammer @reutli last edited by Rene Lausenhammer
                                        API Neuanlegen dann läufts wieder
                                        • N
                                          netfriend @Rene Lausenhammer last edited by
                                          Ja stimmt, damit geht's wieder. 👍
                                          War ja letztes Jahr die gleiche Freakshow...irgendwie nervt das. Bei Gardena/Husqvarna spielt man gerne am laufenden System rum. Danach geht irgendwie nix mehr, man merkt es auch nicht sofort. Und im ersten Moment vermutet man, es liegt am eigenen System. Man könnte die registrierten Kunden ja auch mal per eMail informieren, dass es ein Problem gibt oder was geändert wurde und man ne neue Application anlegen muss.
                                          • G
                                            Gonzokalle @Dominic151617 last edited by
                                            @dominic151617
                                            Hast du einen Link zur Anleitung? Ist schon lange her, wo ich das gemacht habe. 😊
                                            33
                                            5497
