    4. An error occurred during the signature verification [Gelöst]
    • N
      Naturfreund last edited by Naturfreund
      ich wollte heute ein update machen, folgendes spuckt die Konsole aus:
      pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:5 https://repos.influxdata.com/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not av                                            ailable: NO_PUBKEY D8FF8E1F7DF8B07E
      Fetched 51.1 kB in 2s (26.9 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      20 packages can be upgraded. Run 'apt list --upgradable' to see them.
      W: An error occurred during the signature verification. The repository is not up                                            dated and the previous index files will be used. GPG error: https://repos.influx                                            data.com/debian bullseye InRelease: The following signatures couldn't be verifie                                            d because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease                                              The following signatures couldn't be verified because the public key is not ava                                            ilable: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used                                             instead.
      Wie kann ich denn die Signaturen aktualisieren?
        Thomas Braun Most Active @Naturfreund last edited by Thomas Braun
        @naturfreund
        Leg das influx-Repository neu an.
        Alte .list-Datei in /etc/apt/sources.list.d zuvor löschen.
        Hier gibt's weiteres dazu:
        https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
        • N
          Naturfreund @Thomas Braun last edited by
          Hab die alten influx keys entfernt.
          Wie komme ich an die neuen ran?
          Die Adressen unten stimmen für influx sicher nicht 😉
          sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
          echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
            @naturfreund sagte in An error occurred during the signature verification:
            Das Influx-Repo noch mal über deren Installer reinholen. Da kommen die Keys dann mit.
            Alternativ: Schau mal nach meinem Beitrag 'Phantastische Repos und wo sie zu finden sind'
            (Oder so ähnlich). Da steht es auch drin.
            • N
              Naturfreund @Thomas Braun last edited by Naturfreund
              Link auf phantastische-repositories-und-wo-sie-zu-finden-sind
              pi@raspberrypi:~ $ apt-key list | grep -i influx | wc -l
              Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
              0
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:7 https://apt.grafana.com stable InRelease
              Ign:8 https://repos.influxdata.com/debian $(lsb_release InRelease
              Err:9 https://repos.influxdata.com/debian $(lsb_release Release
                404  Not Found [IP: 99.84.88.81 443]
              E: The repository 'https://repos.influxdata.com/debian $(lsb_release Release' does not have a Release file.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
                @naturfreund
                Der Eintrag
                Ist auch falsch. Da muss statt der Variable der entsprechende Release Name rein. Das passiert eigentlich automatisch wenn man das Skript bzw die Zeile ausführt und nicht einfach nur in die Datei kopiert.
                • N
                  pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/influxdb.list
                  hab ich geändert auf:
                  deb https://repos.influxdata.com/debian bullseye stable
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
                  Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Err:7 https://repos.influxdata.com/debian bullseye InRelease
                    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  Fetched 7,040 B in 2s (3,499 B/s)
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  Thomas Braun 3 Replies Last reply Reply Quote 0
                    @naturfreund
                    echad@chet:~ $ cat /etc/apt/sources.list.d/influxdata.list
                    deb [signed-by=/etc/apt/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                    echad@chet:~ $
                    Key muss natürlich in /etc/apt/keyrings deponiert sein.
                      @naturfreund
                      Lösch die influx*.list und dann diese vier Zeilen in dein Terminal kopieren:
                      sudo rm /etc/apt/sources.list.d/infl*
                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                        @naturfreund
                        Und wenn das passt die 20 Updates auf das System schaufeln.
                        • N
                          Danke @Thomas-Braun , ist alles sauber durchgelaufen
                          Hit:4 https://repos.influxdata.com/debian stable InRelease
                          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                          All packages are up to date.
                          1316
