    4. Phantomjs lässt sich nicht installieren
      Jautze last edited by
      ich habe Probleme phantomjs zu installieren:
      pi@raspberrypi:/opt/iobroker $ sudo npm install https://github.com/ioBroker/ioBroker.phantomjs/tarball/master --production
      > usb@1.2.0 install /opt/iobroker/node_modules/usb
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! Tried to download: https://github.com/tessel/node-usb/releases/download/1.2.0/usb_bindings-v1.2.0-node-v51-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for usb@1.2.0 and node@7.10.0 (node-v51 ABI) (falling back to source compile with node-gyp)
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/7.10.0"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/usb/build'
      make: *** No rule to make target '../.node-gyp/7.10.0/include/node/common.gypi', needed by 'Makefile'.  Schluss.
      make: Leaving directory '/opt/iobroker/node_modules/usb/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
      gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:194:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      gyp ERR! System Linux 4.9.24-v7+
      gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"
      gyp ERR! cwd /opt/iobroker/node_modules/usb
      gyp ERR! node -v v7.10.0
      gyp ERR! node-gyp -v v3.6.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
      node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:194:7)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:899:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      node-pre-gyp ERR! System Linux 4.9.24-v7+
      node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
      node-pre-gyp ERR! node -v v7.10.0
      node-pre-gyp ERR! node-pre-gyp -v v0.6.30
      node-pre-gyp ERR! not ok
      > phantomjs-prebuilt@2.1.14 install /opt/iobroker/node_modules/phantomjs-prebuilt
      > node install.js
      PhantomJS not found on PATH
      Unexpected platform or architecture: linux/arm
      It seems there is no binary available for your platform/architecture
      Try to install PhantomJS globally
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.2.0 (node_modules/usb):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.2.0 install: `node-pre-gyp install --fallback-to-build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm ERR! Linux 4.9.24-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.phantomjs/tarball/master" "--production"
      npm ERR! node v7.10.0
      npm ERR! npm  v4.2.0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! phantomjs-prebuilt@2.1.14 install: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the phantomjs-prebuilt@2.1.14 install script 'node install.js'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the phantomjs-prebuilt package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node install.js
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs phantomjs-prebuilt
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls phantomjs-prebuilt
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /root/.npm/_logs/2017-06-19T11_38_33_715Z-debug.log</anonymous>
      Wer kann mir helfen?
      Danke und viele Grüße
      Marcel Jaud
        Versuch es mal bitte als root.
        Ps node v7 ist evtl. Auch nicht optimal
          lubeda last edited by
          ich habe das Problem am Sonntag auch gehabt.
          Auf meinem OrangePi habe ich diese Version installiert:
          https://raw.githubusercontent.com/fg2it … _armhf.deb
          Beim ersten Versuch den Adapter zu installieren hatte ich dieselbe bzw eine ähnliche Meldung. Dann habe ich die Instanz nochmal gelöscht und es neu versucht. danach ging es bei mir.
          Ludger
          • apollon77
            apollon77 last edited by
            @Jautze:
            Try to install PhantomJS `
            Passt zu was woran ich mich erinnere. Phantomjs und raspi/arm verträgt sich teilweise nicht so gut. Und ja Node 7 kann auch schuld sein.
            Google mal …
              was meint ihr welche Version die beste ist?
              Marcel Jaud
                Im Moment empfehlen wir nodejs v6.xx
                Die 7er ist eh nur ein Zwischenschritt zur kommenden 8er.
                • AlCalzone
                  @Homoran:
                  Die 7er ist eh nur ein Zwischenschritt zur kommenden 8er. `
                  Btw, Version 8 wurde inzwischen released.
                    auch mit Node 6.11 bekomme ich es nicht installiert.
                    Ich habe aber folgende Anleitung gefunden:
                    https://www.bitpi.co/2015/02/10/install … pberry-pi/
                    Bekommt man das dann irgendwie in IOBroker?
                    Marcel Jaud
                      ich habe jetzt mal auf der Konsole getestet eine Website flot chart in ein Bild umzuwandeln.
                      Er wandelt seit über 30min.
                      Also nicht wirklich zu gebrauchen…
                      Schade.
                      Viele Grüße
                      Marcel Jaud
                      81.0k
