    4. Lightcontrol Adapter Konfiguration *gelöst*
    • G
      gluecksmann last edited by gluecksmann
      Hallo es mag komisch klingen...aber nach der Installation sieht mein Lightcontroladapter nicht so aus wie in der Anleitung. Wo soll ich denn dieLampen einbinden?
      den in der Anleitung gezeigten Einsetllung finde ich nicht...
        Thomas Braun Most Active @gluecksmann last edited by
        @gluecksmann
        System fit?
        Die Zusammenfassung von
        iob diag
        sagt?
        • G
          gluecksmann @Thomas Braun last edited by
          nach Installation sieht es so aus:
            @gluecksmann
            iob diag
            • G
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Architecture    : armv7l
              Docker          : false
              Virtualization  : none
              Distributor ID: Raspbian
              Description:    Raspbian GNU/Linux 10 (buster)
              Release:        10
              Codename:       buster
              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
              NAME="Raspbian GNU/Linux"
              VERSION_ID="10"
              VERSION="10 (buster)"
              VERSION_CODENAME=buster
              ID=raspbian
              ID_LIKE=debian
              HOME_URL="http://www.raspbian.org/"
              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
              Systemuptime and Load:
               08:45:33 up 31 days, 10:28,  1 user,  load average: 0.70, 0.63, 0.57
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=63.7'C
              volt=0.8500V
              *** Time and Time Zones ***
                             Local time: Thu 2023-05-18 08:45:33 CEST
                         Universal time: Thu 2023-05-18 06:45:33 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           7.9G        2.3G        4.4G        435M        1.2G        5.3G
              Swap:           99M         99M        0.0K
              Total:         8.0G        2.4G        4.4G
                       7898 M total memory
                       2263 M used memory
                        557 M active memory
                       2732 M inactive memory
                       4420 M free memory
                        155 M buffer memory
                       1058 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       29G   11G   18G  38% /
              devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
              tmpfs          tmpfs     3.9G  436M  3.5G  12% /run
              tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
              [Sun Apr 16 22:17:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Sun Apr 16 22:17:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Sun Apr 16 22:17:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sun Apr 16 22:17:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              Show mounted filesystems (real ones only):
              TARGET        SOURCE         FSTYPE OPTIONS
              /             /dev/mmcblk0p2 ext4   rw,noatime
              |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
              `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              378M    /var/
              117M    /var/lib
              82M     /var/log
              76M     /var/cache
              69M     /var/lib/apt/lists
              Archived and active journals take up 434.9M in the file system.
              /opt/iobroker/backups:
              85M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              565M    /opt/iobroker/iobroker-data/
              271M    /opt/iobroker/iobroker-data/files
              141M    /opt/iobroker/iobroker-data/backup-objects
              87M     /opt/iobroker/iobroker-data/sonosCache
              51M     /opt/iobroker/iobroker-data/files/javascript.admin
              33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
              22M     /opt/iobroker/iobroker-data/states.jsonl
              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
              17M     /opt/iobroker/iobroker-data/objects.jsonl
              12M     /opt/iobroker/iobroker-data/objects.json.migrated
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v16.19.1
              /usr/bin/node           v16.19.1
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Installed: 16.19.1-deb-1nodesource1
                Candidate: 16.19.1-deb-1nodesource1
                Version table:
               *** 16.19.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                      100 /var/lib/dpkg/status
                   10.24.0~dfsg-1~deb10u3 500
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              MULTIHOSTSERVICE/enabled: false
              Core adapters versions
              js-controller:  4.0.24
              admin:          6.3.5
              javascript:     6.1.4
              npm ERR! code ELSPROBLEMS
              npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
              npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
              npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
              npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
              npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
              npm ERR! invalid: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
              npm ERR! invalid: iobroker.lightcontrol@0.2.16 /opt/iobroker/node_modules/iobroker.lightcontrol
              npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
              npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
              npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
              npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
              npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
              npm ERR!     /home/pi/.npm/_logs/2023-05-18T06_46_02_385Z-debug-0.log
              Adapters from github:   3
              Adapter State
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
              + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
              + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                system.adapter.divera247.0              : divera247             : raspberrypi                              - disabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
              + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
              + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
                system.adapter.history.0                : history               : raspberrypi                              - disabled
              + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.lightcontrol.0           : lightcontrol          : raspberrypi                              -  enabled
              + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
              + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
                system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
              + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
              + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
              + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
              + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
              + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
              + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
              + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.3.5    , installed 6.3.5
              Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
              Adapter    "alias-manager": 1.2.4    , installed 1.2.6
              Adapter    "backitup"     : 2.6.19   , installed 2.6.19
              Adapter    "ble"          : 0.13.0   , installed 0.13.0
              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
              Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
              Adapter    "devices"      : 1.1.2    , installed 1.1.2
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "divera247"    : 0.2.0    , installed 0.2.0
              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
              Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
              Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hue"          : 3.7.1    , installed 3.7.1
              Adapter    "ical"         : 1.13.2   , installed 1.13.2
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "info"         : 1.9.26   , installed 1.9.26
              Adapter    "iot"          : 1.14.2   , installed 1.14.2
              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
              Controller "js-controller": 4.0.24   , installed 4.0.24
              Adapter    "lightcontrol" : 0.2.16   , installed 0.2.16
              Adapter    "meross"       : 1.14.0   , installed 1.14.0
              Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
              Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
              Adapter    "musiccast"    : 0.1.5    , installed 0.2.2
              Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
              Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
              Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "shelly"       : 6.3.1    , installed 6.3.1
              Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
              Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
              Adapter    "socketio"     : 4.2.0    , installed 6.1.7
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "sonos"        : 2.2.3    , installed 2.2.3
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "tuya"         : 3.13.1   , installed 3.13.1
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
              Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
              Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
              Adapter    "web"          : 4.3.0    , installed 5.2.3
              Adapter    "ws"           : 1.3.0    , installed 2.1.2
              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
              Objects and States
              Objects:        11282
              States:         9247
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
              Reading package lists...
              Pending Updates: 14
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17935      651/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          231629012  8398/cupsd
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20949      1045/io.sonoff.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19578      642/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18195      642/iobroker.js-con
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18264      721/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       77503666   24238/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          17937      651/sshd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          231629011  8398/cupsd
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       20101      1029/io.sonos.0
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21777      1076/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21778      1076/io.tuya.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16097      640/dhcpcd
              udp        0      0 0.0.0.0:37491           0.0.0.0:*                           1001       222345857  21441/io.philips-ai
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          231629959  8399/cups-browsed
              udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       22505      1369/io.musiccast.0
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       27576      2786/io.broadlink2.
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14981      387/avahi-daemon: r
              udp        0      0 0.0.0.0:47902           0.0.0.0:*                           108        14983      387/avahi-daemon: r
              udp        0      0 0.0.0.0:37188           0.0.0.0:*                           1001       29782      2786/io.broadlink2.
              udp        0      0 0.0.0.0:57698           0.0.0.0:*                           1001       222346710  21658/io.philips-ai
              udp6       0      0 :::546                  :::*                                0          16109      640/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        14982      387/avahi-daemon: r
              udp6       0      0 :::46429                :::*                                108        14984      387/avahi-daemon: r
              2023-05-18 08:46:21.106  - info: philips-air.0 (21441) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
              2023-05-18 08:46:21.122  - info: philips-air.0 (21441) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
              2023-05-18 08:46:21.128  - info: philips-air.0 (21441) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
              2023-05-18 08:46:21.142  - info: philips-air.0 (21441) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
              2023-05-18 08:46:21.206  - info: philips-air.0 (21441) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
              2023-05-18 08:46:21.211  - info: philips-air.0 (21441) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
              2023-05-18 08:46:39.854  - info: philips-air.0 (21441) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
              2023-05-18 08:46:39.909  - info: philips-air.0 (21441) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
              2023-05-18 08:46:39.938  - info: philips-air.0 (21441) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
              2023-05-18 08:46:39.986  - info: philips-air.0 (21441) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
              2023-05-18 08:46:41.229  - info: philips-air.0 (21441) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
              2023-05-18 08:46:41.328  - info: philips-air.0 (21441) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
              2023-05-18 08:46:41.402  - info: philips-air.0 (21441) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
              2023-05-18 08:46:41.413  - info: philips-air.0 (21441) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
              2023-05-18 08:46:41.471  - info: philips-air.0 (21441) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
              2023-05-18 08:46:41.478  - info: philips-air.0 (21441) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
              2023-05-18 08:46:41.484  - info: philips-air.0 (21441) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
              2023-05-18 08:47:05.075  - error: gruenbeck.0 (28135) AxiosError: Request failed with status code 404
              2023-05-18 08:47:05.161  - error: gruenbeck.0 (28135) https://prod-eu-gruenbeck-api.azurewebsites.net/api/devices/softliQ.C/BS00072047/realtime/enter?api-version=2020-08-03
              2023-05-18 08:47:05.161  - error: gruenbeck.0 (28135) AxiosError: Request failed with status code 404
              2023-05-18 08:47:05.162  - error: gruenbeck.0 (28135) Failed enter SD
              2023-05-18 08:47:05.162  - info: gruenbeck.0 (28135) Relogin
              2023-05-18 08:47:05.563  - info: gruenbeck.0 (28135) Login step 1
              2023-05-18 08:47:06.138  - info: gruenbeck.0 (28135) Login step 2
              2023-05-18 08:47:06.692  - info: gruenbeck.0 (28135) Login successful
              • G
                gluecksmann @gluecksmann last edited by
                @gluecksmann
                fürchte aber das Problem sitzt vor dem Rechner 😉
                  @gluecksmann
                  Buster auf Bullseye bringen, nodejs auf v18 bringen, Lightcontrol nochmal richtig installieren.
                  Die anderen Adapter mit npm Error 'invalid' auch.
                  • G
                    Wenn ich alles das verstehen würde, was du geschrieben hast, hätte ich das Problem wahrscheinlich nicht...
                      @gluecksmann
                      Dann anders:
                      Installier deine Kiste komplett neu, diesmal in der 64bit-Version.
                      Dann iobroker komplett frisch aufsetzen, Backup einspielen.
                        Homoran Global Moderator Administrators @gluecksmann last edited by
                        @gluecksmann sagte in Lightcontrol Adapter Konfiguration:
                        was hast du denn jetzt installiert?
                        • Glasfaser
                          Glasfaser last edited by Glasfaser
                          Welche Anleitung !?
                          die auf Github !?
                          https://github.com/Schmakus/ioBroker.lightcontrol/blob/main/docs/de/lightcontrol.md
                          und was soll jetzt fehlen !?
                          • G
                            gluecksmann @Glasfaser last edited by
                            @glasfaser
                            siehe meinen ersten Eintrag... zusätzlich finde ich nicht so ich nun die Lampen einbinde...
                            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                              @gluecksmann
                              Bei den drei Adaptern klemmt es offenbar.
                              • G
                                Ah, ok... werde mal testweise neu installieren...
                                Danke für den konkreten Hinweis... auch für mich DAU
                                  @gluecksmann
                                  Der andere konkrete Hinweis ist:
                                  Dein Betriebssystem ist abgekündigt, tot, hat sein End Of Life erreicht.
                                  Muss aktualisiert werden.
                                  • G
                                    Ohje... ich fürchte das bekomme ich nicht auf die Reihe...
                                      Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
                                      @gluecksmann
                                      Du hast den verstorbenen 'Buster' ja auch irgendwie installiert.
                                      Mach es damit:
                                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                      'Bullseye' 64bit-Version 'Lite'.
                                      • Glasfaser
                                        Glasfaser @gluecksmann last edited by
                                        @glasfaser
                                        Das steht doch in der Anleitung bzw. ist bebildert.
                                        Datenpunkt auswählen dann auf das Zahnrad ... :
                                        Oder ist es nicht bei dir vorhanden .
                                        Deine Antworten sind zweideutig !!!
                                        G Glasfaser 2 Replies Last reply Reply Quote 0
                                        • G
                                          @glasfaser
                                          OK, probiere es später...danke für die Mühe
                                          • G
                                            So Kleinigkeiten wie Datensicherung ist in der Anleitung leider nicht enthalten...
                                            681
