    4. Tuya Zigbee Warung
    Tuya Zigbee Warung
    • Stefan Kaupel
      Stefan Kaupel last edited by Stefan Kaupel
      Guten morgen,
      ich habe im Logg immer folgende Warnung:
      tuya.1
      2023-05-26 08:56:25.990	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:56:20.234	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:56:15.329	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:56:15.328	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:55:25.988	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:55:20.234	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:55:10.277	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:55:10.276	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:54:24.295	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:54:16.695	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:54:05.221	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:54:05.220	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:53:20.984	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:53:15.230	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:53:00.150	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:53:00.149	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:52:19.293	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:52:11.692	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:51:55.093	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:51:55.093	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:51:15.982	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:51:10.227	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:50:50.029	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:50:50.028	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:50:14.289	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:50:06.688	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:49:44.972	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:49:44.972	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:49:10.978	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:49:05.222	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:48:39.913	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:48:39.912	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:48:09.287	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:48:01.684	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:47:34.849	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:47:34.848	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:47:05.977	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:47:00.221	warn	bf13cd387a5fd4e0f5fw7s error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:46:29.788	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:46:29.788	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:46:04.284	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:45:56.681	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:45:24.729	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:45:24.728	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:45:04.283	warn	bfb606d79ceccc947c4ujs error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:44:56.681	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:44:19.668	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:44:19.668	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:44:04.074	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:43:55.974	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:43:14.625	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:43:14.624	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:43:04.072	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:42:55.973	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:42:09.569	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:42:09.568	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:42:04.072	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:41:55.971	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:41:04.504	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:41:04.504	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:41:02.986	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:40:54.629	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:40:04.444	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:40:04.444	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:39:59.069	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:39:50.968	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:38:59.377	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:38:59.376	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:38:57.984	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:38:49.628	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:37:59.325	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:37:59.324	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:37:54.066	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:37:45.964	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:36:54.272	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:36:54.272	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:36:52.982	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:36:44.624	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:35:54.213	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:35:54.212	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:35:49.063	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:35:44.622	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:35:40.961	warn	bf19013944ef35b340tu84 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:34:47.977	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:34:44.621	warn	bfe68640991a25be52veah error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:33:47.977	warn	bf4a533ab6a774458czwnq error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:33:44.061	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:33:29.073	info	bf94604840f71479d7tuuq Init with IP=192.168.178.41, Key=a91474be67472a67, Version=3.3
      tuya.1
      2023-05-26 08:33:29.072	info	bf94604840f71479d7tuuq: Connect locally to device
      tuya.1
      2023-05-26 08:32:45.758	warn	bf4aa437a5727857deyabn error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      tuya.1
      2023-05-26 08:32:44.059	warn	bfc2d5bf13e5f4249ctpwr error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
      Es handelt sich hierbei um die Tuya Zigbee Geräte inkl. Gateway. Kann mir jemand was dazu sagen?
      Gruß Stefan
      arteck K 2 Replies Last reply Reply Quote 0
        arteck Developer Most Active @Stefan Kaupel last edited by
        @stefan-kaupel so und jetzt nochmal aber richtig
        LOGS im Tag einpacken
          kimukao @Stefan Kaupel last edited by kimukao
          @stefan-kaupel same here... Hast Du das Problem zwischenzeitlich lösen können?
          tuya.0
          2023-06-05 13:31:55.619	warn	bf98506c8e6089f6c9ayje error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
          tuya.0
          2023-06-05 13:30:55.575	warn	bfae48d545cf9d2929sbl4 error on refresh: A set command is already in progress. Can not issue a second one that also should return a response.
            da antwortet was nicht.. ist vielleicht ein WLAN Signal der es überlagert in der nähe?
              warp-it @arteck last edited by
              Ich habe alle 2 Minuten die gleiche Warnung für zwei Sensoren (Erschütterung und T&H-Sensor), wobei eigentlich alles zu funktionieren scheint. Da kommt doch folgender Verdacht auf, obwohl der dazugehörige Haken nicht gesetzt ist. ?!
              arteck ? 2 Replies Last reply Reply Quote 0
                arteck Developer Most Active @warp-it last edited by
                @warp-it was hat der tuya adapter mit dem zigbee zu tun ..genau .. NIX
                  @arteck said in Tuya Zigbee Warung:
                  Sorry, deine Antwort verstehe ich nicht.
                    A Former User @warp-it last edited by
                    @warp-it
                    ja, der Fehler ist bekannt, gibt ein issue dazu - der Tuya-Adapter bekommt die Commands, waehrend einer noch aktiv ist, liegt wohl am delay der Cloud.. bei lokalen Devices ist das nicht.. zumindest hier..
                    @arteck
                    doch, Tuya-Adapter, Tuya-Devices, hat nix mit Zigbee zu tun, diesmal.. ( nur im Thread-Titel so benannt, warum weiss nur der @Stefan-Kaupel ..)
                    W 2 Replies Last reply Reply Quote 0
                      warp-it @Guest last edited by
                      @arteck
                      Wenn man nach dem beschriebenen Fehler sucht, landet man hier. Der Titel des Threads ist falsch.
                        @ilovegym
                        Danke für die Info.
                        959
