    4. Lovelace themen
    Lovelace themen
    • zeverox
      zeverox last edited by
      Hallo ich breucht bitte etwas unterstüzung.
      ich habe Lovelace als vis und ich möchte ein Themen nutzen aber wüste nicht wie.
      Das Themen---> https://github.com/basnijholt/lovelace-ios-themes
      mfG Erik.W
      • David G.
        David G. @zeverox last edited by David G.
        @zeverox sagte in Lovelace themen:
        mfG Erik.W
        Enfach bei den Settings vom Adapter unter Theme reinkopieren. Dann kannst du es etwas weiter oben auswählen.
        Mein Theme hab ich "normal" genannt......
        • zeverox
          @David-G okay und der code wäre für mich der ?
          Render themes, creates them as separate files and as
          one combined file ios-themes.yaml.
          Part of https://github.com/basnijholt/lovelace-ios-themes
          from pathlib import Path
          import jinja2
          import yaml
          from PIL import Image
          from PIL import ImageColor
          with open("settings-light-dark.yaml", "r") as f:
          all_settings = yaml.safe_load(f)
          def parse(x):
          return x if "#" not in x else f'"{x}"'
          def average_color(fname):
          color = Image.open(fname).resize((1, 1)).getpixel((0, 0))
          hex_color = "#{:02x}{:02x}{:02x}".format(*color)
          rgb_color = ImageColor.getrgb(hex_color)
          return "rgba({}, {}, {}, 0.4)".format(*rgb_color)
          BACKGROUND_COLORS = {
          # Suggested by @okets in issue #42
          "blue-red": "rgba(30, 2, 61, 0.4)",
          "dark-blue": "rgba(48, 69, 124, 0.4)",
          "dark-green": "rgba(48, 89, 71, 0.4)",
          "light-blue": "rgba(1, 195, 220, 0.4)",
          "light-green": "rgba(114, 188, 139, 0.4)",
          "orange": "rgba(255, 229, 116, 0.4)",
          "red": "rgba(234, 88, 63, 0.4)",
          folder_fname = [
          ("hacsfiles", Path("themes/ios-themes.yaml")),
          ("local", Path("manual-install/ios-themes.yaml")),
          for folder, fname in folder_fname:
          fname.parent.mkdir(parents=True, exist_ok=True)
          with fname.open("w") as f:
          f.write("---\n# From https://github.com/basnijholt/lovelace-ios-themes")
          for background in Path("themes").glob("homekit-bg-*.jpg"):
          color = background.stem.split("homekit-bg-")[-1]
          if color in BACKGROUND_COLORS:
          app_header_background_color = BACKGROUND_COLORS[color]
          else:
          app_header_background_color = average_color(background)
          for which in ["light", "dark"]:
          for state_icon_yellow in [False, True]:
          settings = {k: parse(v[which]) for k, v in all_settings.items()}
                      if state_icon_yellow:
                          settings["state_icon_active_color"] = "rgba(255, 214, 10, 1)"
                          suffix = ""
                      else:
                          suffix = "-alternative"
                      with open("template.jinja2") as f:
                          template = jinja2.Template("".join(f.readlines()))
                      result = template.render(
                          **settings,
                          folder=folder,
                          which=which,
                          app_header_background_color=app_header_background_color,
                          background_jpg=str(background.name),
                          color=color,
                          suffix=suffix,
                      with fname.open("a") as f:
                          f.write("\n" + result + "\n")
          • David G.
            @zeverox
            Dich interessiert nur der Inhalt dieser Datei
            https://github.com/basnijholt/lovelace-ios-themes/blob/master/themes/ios-themes.yamlt
            zum einfügen in den Settings.
            Die Bilder musst du wenn gewünscht auch in den Settings von Lovelace unter "Eigene Karten" hochladen.
            Dann im Theme aber überall wo
            /hacsfiles/themes/ios-themes/xxxxx.jpg')"
            zu
            /cards/xxxxx.jpg')"
            abändern
            zeverox 1 Reply Last reply Reply Quote 0
            • zeverox
              zeverox @David G. last edited by
              @david-g
              hmm irgendwas mache ich falsch.....
              • David G.
                @zeverox
                Was mehr Infos was nichtig klappt wäre gut ^^.
                Hab es bei mir eingefügt und kann direkt die Themes wählen:
                • zeverox
                  zeverox last edited by zeverox
                  Ich kann das themen namen nicht ändern wenn ich den code einfüge pasirt nicht
                  • David G.
                    @zeverox
                    Und du hast keinen c&p-Fehler?
                    Hast auf git ja das Symbol zum kopieren.
                    • zeverox
                      @david-g
                      Ja genau so habe ich es gemacht.
                      • David G.
                        @zeverox
                        Gespeichert und Instanz neu gestartet?
                        Aktuelle Lovelace Version?
                        Mehr wüsste ich jetzt auch nicht.
                        zeverox 2 Replies Last reply Reply Quote 0
                        • zeverox
                          @david-g
                          jezt hat es geklapt perfekt
                          danke dir vielmals
                          • zeverox
                            @david-g
                            Eine frgae häte ich noch wie geht es mit den karten? also wie füge ich das ein z.B.
                            https://github.com/Deejayfool/hass-shutter-card
                            • David G.
                              @zeverox
                              Sehr gut.
                              Da hochladen wo man die Bilder hoch lädt.
                              Wie der Name schon sagt "Eigene Karten".
                              In deinem Fall die hass-shutter-card.js.
                              Die Karten sind IMMER die .js Dateien.
                              Wie man diese benutzt sieht man in der Doku der jeweiligen Karten. Haben meistens keine grafische Konfiguration.
                              • zeverox
                                @david-g
                                hi kann ich hier einparr fragen stellen?
                                • David G.
                                  @zeverox
                                  Kannst du gerne machen.
                                  Als kleiner Hinweis, dort findet man einiges:
                                  https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                                  Und hier der offizielle Thread:
                                  https://forum.iobroker.net/topic/59435/test-lovelace-3-x/230?_=1685256375828
                                  • zeverox
                                    @david-g
                                    wo kann ich am besten fragen stellen?
                                    • David G.
                                      @zeverox
                                      Hier oder im zweiten link von eben.
                                      Im offiziellen Thread lesen mehr Leute mit die helfen können.
                                      • Eny
                                        Eny last edited by
                                        Halli Hallo.
                                        Ich hänge mich gerne mal hier mit an.
                                        Ich habe auch probleme mit dem Theme Ios.
                                        artet Lovelace nicht mehr zb. David.
                                        Auswählen von dem Thema, fehlanzeige, es wird nur Standart angezeigt.
                                        host.Tower
                                        2025-10-07 21:01:09.255	info	Restart adapter system.adapter.lovelace.0 because enabled
                                        host.Tower
                                        2025-10-07 21:01:09.255	error	instance system.adapter.lovelace.0 terminated with code 2 (INVALID_ADAPTER_CONFIG)
                                        lovelace.0
                                        2025-10-07 21:01:08.705	info	http server listening on port 8091
                                        lovelace.0
                                        2025-10-07 21:01:08.702	warn	Terminated (INVALID_ADAPTER_CONFIG): Without reason
                                        lovelace.0
                                        2025-10-07 21:01:08.702	error	Initialization error: YAMLException: end of the stream or a document separator is expected (6:1) 3 | # 4 | # iOS Light Mode Theme - blue-red 5 | # 6 | ios-light-mode-blue-red-alternative: -----^ 7 | # Global 8 | background-image: "center / co ...
                                        lovelace.0
                                        2025-10-07 21:01:08.687	info	starting. Version 5.0.1 in /opt/iobroker/node_modules/iobroker.lovelace, node: v22.19.0, js-controller: 7.0.6
                                        host.Tower
                                        2025-10-07 21:01:05.992	info	instance system.adapter.lovelace.0 in version "5.0.1" started with pid 2842898
                                        Knall ich oben am Code Standart: rein. Startet Lovelace, aber Thema ist "Standart"
                                        Installierte Version: 5.0.1 ( Auch bei älteren Versionen )
                                        Jemand eine Idee wo ich anfangen soll zu suchen 🙂 ?
                                        Bin wieder für jeden Tipp dankbar 🙂
                                        • David G.
                                          David G. @Eny last edited by David G.
                                          @eny
                                          Laut log hast du einen Fehler in deiner yaml
                                          Falls ich es richtig unterpretiere in Zeile 6.
                                          Gib in Google mal Yaml tester oder ähnlich ein. Gibt einige Seiten zum validieren.
                                          Es kommt wirklich aus jede Leerstelle an.
                                          Eny 1 Reply Last reply Reply Quote 0
                                          • Eny
                                            Eny @David G. last edited by
                                            @david-g
                                            Vielen dank für die Antwort.
                                            Habe nun die Background Bilkder hochgeladen, nun startet er ohne fehler.
                                            Leider aber unter Themen nichts auswählbar, Auch an sich siehts der code in meinen Augen nicht so aus wie es sollte, alles Grau 🙂
                                            Habe die ymal testen lassen, Originale von github wie auch ich sie benutzen würde. Alles IO.
                                            Irgend etwas mache ich falsch oder übersehe ich^^
                                            1916
