    4. Installation
    5. Raspi hängt sich 2x täglich auf
      Theophilus last edited by
      Moin, moin,
      ich habe iobroker jetzt erfolgreich auf meinem RaspberryPi 3 installiert. Es läuft auch alles fein, aber leider hängt er sich regelmäßig auf. Hier das Log von heute Nacht:
      2023-05-31 02:27:32.418 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
      2023-05-31 02:27:32.430 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-05-31 02:27:32.433 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
      2023-05-31 02:27:32.434 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
      2023-05-31 02:27:36.821 - info: host.raspberrypi connected to Objects and States
      2023-05-31 02:27:36.906 - info: host.raspberrypi added notifications configuration of host
      2023-05-31 02:27:37.933 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
      2023-05-31 02:27:37.947 - info: host.raspberrypi 8 instances found
      2023-05-31 02:27:37.983 - info: host.raspberrypi starting 8 instances
      2023-05-31 02:27:38.182 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
      2023-05-31 02:27:38.285 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 627
      2023-05-31 02:27:38.302 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
      2023-05-31 02:27:38.380 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
      2023-05-31 02:27:38.457 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
      2023-05-31 02:27:38.532 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
      2023-05-31 02:27:38.606 - info: host.raspberrypi Some obsolete host states deleted.
      2023-05-31 02:27:42.077 - info: host.raspberrypi instance system.adapter.history.0 started with pid 634
      2023-05-31 02:27:42.857 - error: admin.0 (627) admin.0 already running
      2023-05-31 02:27:42.867 - warn: admin.0 (627) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-05-31 02:27:43.522 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-05-31 02:27:43.524 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2023-05-31 02:27:45.452 - error: history.0 (634) history.0 already running
      2023-05-31 02:27:45.461 - warn: history.0 (634) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-05-31 02:27:46.082 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 649
      2023-05-31 02:27:46.126 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-05-31 02:27:46.129 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
      2023-05-31 02:27:50.084 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 656
      2023-05-31 02:27:53.471 - error: javascript.0 (649) javascript.0 already running
      2023-05-31 02:27:53.480 - warn: javascript.0 (649) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-05-31 02:27:53.677 - error: mqtt.0 (656) mqtt.0 already running
      2023-05-31 02:27:53.685 - warn: mqtt.0 (656) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-05-31 02:27:54.111 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 671
      2023-05-31 02:27:54.162 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-05-31 02:27:54.164 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      2023-05-31 06:57:59.959 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_AL
      Das gleiche gestern um 14:17 Uhr und auch in der Nacht um 2:31 Uhr. Was treibt der Raspi da?
        arteck Developer Most Active @Theophilus last edited by arteck
        @theophilus sagte in Raspi hängt sich 2x täglich auf:
        steht doch da
        ich würde eher wissen wollen was du da treibst.. warum alles doppelt läuft
          Theophilus @arteck last edited by Theophilus
          @arteck ich treibe gar nichts ... Das macht der Raspi ganz von alleine!
          		     v.2023-04-16
          Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
          Kernel: 		6.1.21-v8+
          Installation: 		Native
          Timezone: 		Europe/Berlin (CEST, +0200)
          User-ID: 		1000
          X-Server: 		false
          Boot Target: 		multi-user.target
          Pending OS-Updates: 	0
          Pending iob updates: 	0
          Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
          			/usr/bin/node 		v18.16.0
          			/usr/bin/npm 		9.5.1
          			/usr/bin/npx 		9.5.1
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            909M        632M        120M        0.0K        156M        218M
          Swap:            99M         89M         10M
          Total:          1.0G        721M        131M
          Active iob-Instances: 	9
          Active repo(s): stable
          ioBroker Core: 		js-controller 		4.0.24
          			admin 			6.3.5
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects: 		706
          States: 		628
          Size of iob-Database:
          40M	/opt/iobroker/iobroker-data/objects.jsonl
          6.7M	/opt/iobroker/iobroker-data/states.jsonl
          arteck Thomas Braun 2 Replies Last reply Reply Quote 0
            von alleine passiert erstmal nix..
            wie hast du den iobroker installiert ? und wir brauchen das LOG vor dem aufhängen nicht danach
            T 3 Replies Last reply Reply Quote 0
              @arteck nach der Anleitung hier im Forum
                @arteck Davor ist erstmal 20 Minuten lang nix passiert:
                2023-05-31 00:00:00.056 - info: sourceanalytix.0 (811) Reset start values for : 0_userdata.0.Stromkasten.Verbrauch_Total
                2023-05-31 00:00:00.097 - info: sourceanalytix.0 (811) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Verbrauch_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"cumulativeValue":11694.8968,"start_day":11678,"start_month":11389,"start_quarter":0,"start_week":11678,"start_year":9777,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
                2023-05-31 00:00:00.149 - info: sourceanalytix.0 (811) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Verbrauch_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"start_day":11694.8968,"start_month":11389,"start_quarter":0,"start_week":11678,"start_year":9777,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":11694.8968},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
                2023-05-31 00:00:00.150 - info: sourceanalytix.0 (811) Reset start values for : 0_userdata.0.Stromkasten.Einspeisung_Total
                2023-05-31 00:00:00.151 - info: sourceanalytix.0 (811) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Einspeisung_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"cumulativeValue":103.0017,"start_day":101,"start_month":53,"start_quarter":16,"start_week":98,"start_year":0,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
                2023-05-31 00:00:00.175 - info: sourceanalytix.0 (811) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Einspeisung_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"start_day":103.0017,"start_month":53,"start_quarter":16,"start_week":98,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":103.0017},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
                2023-05-31 02:02:04.727 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
                2023-05-31 02:02:29.769 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
                2023-05-31 02:03:14.773 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (5): connection timed out
                2023-05-31 02:04:19.776 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (7): connection timed out
                2023-05-31 02:04:20.689 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Connect locally to device
                2023-05-31 02:04:20.690 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt Init with IP=192.168.178.122, Key=2149e76c6ae6295f, Version=3.3
                2023-05-31 02:04:25.698 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
                2023-05-31 02:04:50.700 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
                2023-05-31 02:05:35.704 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (5): connection timed out
                2023-05-31 02:06:40.708 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (7): connection timed out
                2023-05-31 02:06:45.642 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Connect locally to device
                2023-05-31 02:06:45.644 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt Init with IP=192.168.178.122, Key=2149e76c6ae6295f, Version=3.3
                2023-05-31 02:06:50.648 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
                2023-05-31 02:07:15.651 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
                T ? 2 Replies Last reply Reply Quote 0
                  Theophilus @Theophilus last edited by
                  @theophilus Gestern 14.17
                  2023-05-30 13:29:30.562 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.178.42
                  2023-05-30 13:42:55.653 - info: admin.0 (831) <== Disconnect system.user.admin from ::ffff:192.168.178.42 admin
                  2023-05-30 14:18:26.657 - info: admin.0 (831) Request actual repository...
                  2023-05-30 14:18:28.004 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                  2023-05-30 14:17:14.307 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                  2023-05-30 14:17:14.322 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-05-30 14:17:14.325 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                  2023-05-30 14:17:14.326 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
                  2023-05-30 14:17:17.489 - info: host.raspberrypi connected to Objects and States
                  2023-05-30 14:17:17.566 - info: host.raspberrypi added notifications configuration of host
                  2023-05-30 14:17:18.525 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                  2023-05-30 14:17:18.539 - info: host.raspberrypi 8 instances found
                  2023-05-30 14:17:18.576 - info: host.raspberrypi starting 8 instances
                  2023-05-30 14:17:18.695 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                  2023-05-30 14:17:18.724 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                  2023-05-30 14:17:18.761 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 626
                  2023-05-30 14:17:18.847 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                  2023-05-30 14:17:18.920 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                  2023-05-30 14:17:18.994 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                  2023-05-30 14:17:19.066 - info: host.raspberrypi Some obsolete host states deleted.
                  2023-05-30 14:17:22.683 - info: host.raspberrypi instance system.adapter.history.0 started with pid 633
                  2023-05-30 14:17:23.253 - error: admin.0 (626) admin.0 already running
                  2023-05-30 14:17:23.262 - warn: admin.0 (626) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-05-30 14:17:23.907 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-05-30 14:17:23.909 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                  2023-05-30 14:17:26.052 - error: history.0 (633) history.0 already running
                  2023-05-30 14:17:26.061 - warn: history.0 (633) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-05-30 14:17:26.679 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 648
                  2023-05-30 14:17:26.725 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-05-30 14:17:26.727 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
                  2023-05-30 14:17:30.698 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 655
                  2023-05-30 14:17:34.002 - error: javascript.0 (648) javascript.0 already running
                  2023-05-30 14:17:34.009 - warn: javascript.0 (648) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-05-30 14:17:34.213 - error: mqtt.0 (655) mqtt.0 already running
                  2023-05-30 14:17:34.222 - warn: mqtt.0 (655) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2023-05-30 14:17:34.669 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-05-30 14:17:34.670 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
                  2023-05-30 14:17:34.808 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 670
                  2023-05-30 14:17:34.855 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2023-05-30 14:17:34.857 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
                    hier wird probiert alles nochmal zu starten...
                    machst du da backup vielleicht.. und das geht in die hose..
                      A Former User @Theophilus last edited by
                      Moin,
                      ich ehe einfach mal davon aus, dass Dir der Speicher bei irgendeiner Aktion ausgeht und das System crasht.
                      MEMORY:
                      Swap:            99M         89M         10M
                      Wie viele Adapter hast Du denn installiert und wie viele sind aktiv?
                      Zeig doch mal die Langfassung von iob diag und aus dem journal die Einträge zur Zeit der Abstürze, hier mal Beispiele:
                      Vor 1 Stunde bis jetzt
                      $ journalctl --since "1 hour ago"
                      Von vor 2 Tagen bis jetzt
                      $ journalctl --since "2 days ago"
                      Zwischen zwei Zeiten*
                      $ journalctl --since "2015-06-26 23:15:00" --until "2015-06-26 23:20:00"
                      Oder schau mal, ob Du oom, kill im Log hast
                      $ journalctl | grep -iE 'oom|kill'
                      VG
                      Bernd
                        Thomas Braun Most Active @Theophilus last edited by Thomas Braun
                        @theophilus
                        Gib mal die Langfassung von iob diag
                        Und schau zu den Zeiten in das Journal rein.
                        Edit: Zu langsam und zu ungenau gewesen... 🙂
                          Thomas Braun Most Active @Guest last edited by
                          @dp20eic
                          Könnte für 1GB RAM schon zu viel sein.
                          ? T 2 Replies Last reply Reply Quote 0
                            @arteck sagte in Raspi hängt sich 2x täglich auf:
                            Das Log entstand unmittelbar vor dem Aufhängen. Es waren quasi seine letzten Lebenszeichen.
                              A Former User @Thomas Braun last edited by
                              @thomas-braun sagte in Raspi hängt sich 2x täglich auf:
                              Moin,
                              oh, danke, war wohl zu früh oder ich brauche doch eine Brille, wenn ich am Laptop arbeite 🙂
                              VG
                              Bernd
                              P.S.: also Betriebssystem, nodejs, iobroker, adapter, mir schwebt da eine Aussage vor den Augen, dass da so zwischen 60 - 100 MB pro Adapter zu veranschlagen ist, dann vielleicht noch Backup oder Scripte die da etwas machen, dann kann es eng werden.
                                Theophilus @Thomas Braun last edited by
                                @thomas-braun Erweitern kann man beim Raspi nichts, oder?
                                • DJMarc75
                                  DJMarc75 @Theophilus last edited by
                                  RAM ? Natürlich nicht
                                    Thomas Braun Most Active @DJMarc75 last edited by
                                    @djmarc75
                                    Der McGiver-Ansatz:
                                    https://www.pcgameshardware.de/Raspberry-Pi-Hardware-257637/News/4-RAM-Chip-16-GB-Upgrade-1418168/
                                    DJMarc75 1 Reply Last reply Reply Quote 1
                                    • DJMarc75
                                      DJMarc75 @Thomas Braun last edited by
                                      Der McGiver-Ansatz:
                                      ein Streicholz und ein Kaugummipapier 😂
                                      konnte damit schon viele LinuxProbleme lösen 😀 👍
                                        @djmarc75
                                        Ja, die universell einsetzbaren libmatches und libbubblegum
                                          Heute nachmittag hat er sich nicht aufgehängt. War wohl Zufall, dass es gestern 2 Uhr und 14 Uhr war.
                                            @theophilus Er bleibt bei. Alles läuft super, dann kommt dieser ominöse Neustart und der Raspi hängt sich auf.
                                            2023-06-05 07:17:15.426 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                            2023-06-05 07:17:15.439 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                            2023-06-05 07:17:15.441 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                            2023-06-05 07:17:15.443 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
                                            2023-06-05 07:17:19.097 - info: host.raspberrypi connected to Objects and States
                                            2023-06-05 07:17:19.194 - info: host.raspberrypi added notifications configuration of host
                                            2023-06-05 07:17:20.208 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                            2023-06-05 07:17:20.221 - info: host.raspberrypi 9 instances found
                                            2023-06-05 07:17:20.262 - info: host.raspberrypi starting 9 instances
                                            2023-06-05 07:17:20.399 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                            2023-06-05 07:17:20.436 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                            2023-06-05 07:17:20.475 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 632
                                            2023-06-05 07:17:20.509 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                            2023-06-05 07:17:20.543 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                            2023-06-05 07:17:20.617 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                            2023-06-05 07:17:20.646 - info: host.raspberrypi Some obsolete host states deleted.
                                            2023-06-05 07:17:24.495 - info: host.raspberrypi instance system.adapter.history.0 started with pid 639
                                            2023-06-05 07:17:25.903 - info: admin.0 (632) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                                            2023-06-05 07:17:26.028 - info: admin.0 (632) requesting all states
                                            2023-06-05 07:17:26.030 - info: admin.0 (632) requesting all objects
                                            2023-06-05 07:17:28.610 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 666
                                            2023-06-05 07:17:29.621 - info: admin.0 (632) received all objects
                                            2023-06-05 07:17:30.198 - info: history.0 (639) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v18.16.0, js-controller: 4.0.24
                                            2023-06-05 07:17:30.369 - info: history.0 (639) enabled logging of 0_userdata.0.Solar.Solar_Aktuell (Count=1), Alias=false
                                            2023-06-05 07:17:30.372 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Aktuell (Count=2), Alias=false
                                            2023-06-05 07:17:30.375 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Total (Count=3), Alias=false
                                            2023-06-05 07:17:30.377 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Einspeisung_Total (Count=4), Alias=false
                                            2023-06-05 07:17:31.502 - info: admin.0 (632) Request actual repository...
                                            2023-06-05 07:17:31.655 - info: admin.0 (632) http server listening on port 8081
                                            2023-06-05 07:17:31.658 - info: admin.0 (632) Use link "http://localhost:8081" to configure.
                                            2023-06-05 07:17:31.703 - info: admin.0 (632) socket.io server listening on port 8081
                                            2023-06-05 07:17:33.587 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                            2023-06-05 07:17:33.770 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 681
                                            2023-06-05 07:17:35.155 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
                                            2023-06-05 07:17:35.438 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
                                            2023-06-05 07:17:36.396 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 688
                                            2163
