    3. Entwicklung
    4. Fehler bei Test und Release Workflows
    • Z
      zap Developer last edited by
      die Test und Release Workflows in Github schlagen für meinen Adapter regelmäßig fehl (https://github.com/zapccu/ioBroker.sma-ev-charger).
      Die Fehlermeldungen beim Adapter Test (Ubuntu) lauten:
      npm ERR! code ENOTSUP
      264
      npm ERR! notsup Unsupported engine for iobroker.js-controller@5.0.1-alpha.0-20230525-c580eb7e: wanted: {"node":">=16.4.0"} (current: {"node":"14.21.3","npm":"6.14.18"})
      265
      npm ERR! notsup Not compatible with your version of node/npm: iobroker.js-controller@5.0.1-alpha.0-20230525-c580eb7e
      266
      267
      npm ERR! notsup Required: {"node":">=16.4.0"}
      268
      npm ERR! notsup Actual:   {"npm":"6.14.18","node":"14.21.3"}
      Das kommt mehrfach. Dann noch dieser Fehler hier (vielleicht ein Folgefehler):
      1) Adapter integration tests
      299
             "before all" hook: prepareTests in "Adapter integration tests":
      300
           Error: /tmp/test-iobroker.sma-ev-charger/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/tmp/test-iobroker.sma-ev-charger/iobroker-data/iobroker.json'
      301
            at Object.openSync (fs.js:498:3)
      302
            at Object.readFileSync (fs.js:394:35)
      303
            at readFileSync (node_modules/jsonfile/index.js:50:22)
      304
            at DBConnection.getSystemConfig (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:115:44)
      305
            at DBConnection.get objectsType [as objectsType] (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:102:21)
      306
            at DBConnection.createObjectsDB (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:175:34)
      307
            at DBConnection.start (node_modules/@iobroker/testing/build/tests/integration/lib/dbConnection.js:149:20)
      308
            at Context.prepareTests (node_modules/@iobroker/testing/build/tests/integration/index.js:66:28)
      309
            at processTicksAndRejections (internal/process/task_queues.js:95:5)
      Leider habe ich keine Erfahrung mit ioBroker Entwicklung. Ist mein erster Adapter. Also sorry schonmal, wenn das eine blöde Frage ist.
        A Former User @zap last edited by
        @zap hi,
        Die node version 14x wird bei Test & release nicht mehr unterstützt. Dies musst du händisch selbst änder in der datei .github/workflows/test-and-release.yml
        Dort kannst du die node versionen wo nur eine version bei dir drin steht (bei der ersten ist es bei dir node v16.x und bei der ganz unten node v14.x) kannst auf node v16.x oder auf v18.x ändern und bei der wo drei versionen drin steht (das in der mitte ca.) nimmst du das v14.x raus und machst daraus
        node-version: [16.x, 18.x, 20.x]
        • Z
          zap Developer @Guest last edited by
          @ciddi89 Das wars. Tests laufen nun fehlerfrei durch. Vielen Dank!
          1.0k
