    2. English
    4. Node-Red Adapter SSH Key generation not possible
      huibuh420 last edited by
      |Systemdata|
      |Hardwaresystem: Raspberry Pi 4
      |Arbeitsspeicher:| 2GB |
      |Festplattenart:| SD-Karte
      |Betriebssystem:| Raspbian
      |Node-Version:| 3.0.2
      |Nodejs-Version:| 10.x.x |
      |NPM-Version:| 6.x.x |
      I would like to connect my flow with github.
      To connect the flow with a github repo I need to generate a SSH key.
      The problem is now, that it's not showing any key after pressing "Schlüssel generieren".
      In the logs I can't find any errors.
      What is the root cause?
      • Marc Berg
        Marc Berg Most Active @huibuh420 last edited by
        @huibuh420 sagte in Node-Red Adapter SSH Key generation not possible:
        You have not installed the package "openssh-client".
          huibuh420 @Marc Berg last edited by
          @marc-berg I already did. It seems like to me, that the command is inside iobroker not accessible. Maybe this is an issue with the docker build?
          With the exec node I tried to execute ssh-keygen inside node-red.
          => This seems like to me, that the command is not visible inside the docker container.
          mickym Marc Berg 2 Replies Last reply Reply Quote 0
          • mickym
            mickym Most Active @huibuh420 last edited by mickym
            @huibuh420 you have to install the openssh-cliient package in directory
            /opt/iobroker/iobroker-data/node.red
            • Marc Berg
              A client properly installed via the package manager is located at /usr/bin and is therefore accessible via the path environment variable. I installed the openssh-client package via the Docker environment variable "PACKAGES".
              node-red node-red adapter node-red projekt
