    4. Installation Vis schlägt fehl
      TM8 last edited by
      Hallo, vielleicht kann mir wer weiterhelfen. Nach einem Stromausfall funktionierte VIS nicht mehr richtig, Ich kam nicht mehr in den Editor. Ich habe den Adapter deinstalliert, wenn ich diesen jetzt installieren möchte, kommt folgende Fehlermeldung.
      $ ./iobroker add vis
      npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
      SyntaxError: Error parsing /usr/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror/package.json: Unexpected token v    at Object.parse (native)
          at readPackage (module.js:81:52)
          at tryPackage (module.js:91:13)
          at Function.Module._findPath (module.js:153:20)
          at Function.Module._resolveFilename (module.js:323:25)
          at Function.Module._load (module.js:276:25)
          at Module.require (module.js:353:17)
          at require (internal/module.js:12:17)
          at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/jsprim/lib/jsprim.js:9:18)
          at Module._compile (module.js:409:26)
      npm
       ERR!
       Linux 4.9.24-v7+npm
       ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.vis" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.3
      npm ERR!
       npm  v2.15.11npm ERR! path /usr/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror/package.json
      npm ERR! Error parsing /usr/lib/node_modules/npm/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror/package.json: Unexpected token vnpm ERR!
      npm ERR! If you need help, you may report this error at:
      npm ERR!     <https: github.com/npm/issues="">
      host.HS-ioBroker-Server install adapter vis
      npm
       ERR!
       Linux 4.9.24-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.vis" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.3
      npm ERR! npm  v2.15.11
      npm
      npm ERR! Linux 4.9.24-v7+
      npm ERR!
      ERROR: host.HS-ioBroker-Server Cannot install vis
      ERROR: process exited with code 13</https:></anonymous></https:></anonymous></https:></anonymous>
      Vielleicht kann mir jemand weiterhelfen.
      Oder soll ich gleich einen neue Installation von ioBroker aufsetzen, der läuft jetzt schon seit 1 1/2 Jahren.
      Danke für eure Hilfe.
        @TM8:
        Ich habe den Adapter deinstalliert `
        Hast du wirklich den gesamten Adapter deinstalliert oder nur die Instanz?
          TM8 last edited by
          Nur die Instanz, da habe ich mich nicht richtig ausgedrückt. Wenn ich jetzt eine neuen Instanz installieren möchte, funktioniert das nicht. Ausgabe siehe oben.
            @TM8:
            Nur die Instanz, `
            so sah das auch aus.
            dann bitte den gesamten Adapter löschen und anschließend über die Konsole:
            cd /opt/iobroker
            npm cache clean
            sudo iobroker stop
            npm add iobroker.vis
            sudo iobroker upload vis
            sudo iobroker start
            und viel Glück
              TM8 last edited by
              Ich erhalte schon bei "npm cache clean" Fehler.
              root@HS-ioBroker-Server:/opt/iobroker# npm cache clean
              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "cache" "clean"
              npm ERR!
              root@HS-ioBroker-Server:/opt/iobroker#</https:></anonymous>
              Setze gerade einen zweiten Raspberry neu auf. Ich denke das ist mal wieder nötig.
                mafe68 last edited by
                Versuche mal ein
                sudo apt-get autoclean && sudo apt-get autoremove
                damit werde mal deine ganze Altlasten entsorgt und versuche es nochmal so wie oben schon mal beschrieben.
                  @TM8:
                  npm ERR!
                  Setze gerade einen zweiten Raspberry neu auf. Ich denke das ist mal wieder nötig. `
                  Dein npm ist kaputt… Um npm zu reparieren brauchst du .... npm .
                  sudo apt-get install nodejs npm node-semver --reinstall
