    2. English
    3. ioBroker general
    4. Node.js update
    Node.js update
      ap2017 last edited by ap2017
      I decided to update node.js 16 to node.js 18 using the following script:
      sudo apt-get --purge remove node
      sudo apt-get --purge remove nodejs
      sudo apt-get autoremove
      sudo reboot
      curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
      sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
      sudo reboot
      cd /opt/iobroker
      npm rebuild
      iobroker start
      The system refused to do npm rebuild complaining that rebuild command not found.
      Now I am not able to start ioBroker. What should I do?
      Found another script for node.js update:
      cd /opt/iobroker
      iobroker stop
      sudo apt purge --autoremove nodejs* npm node-*
      curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash –
      sudo apt install -y nodejs
      iobroker fix
      iobroker start
      But after curl command getting:
      ap@AP-Tiny:/opt/iobroker$ curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash –
      bash: –: No such file or directory
      curl: (23) Failed writing body (0 != 16146)
        Thomas Braun Most Active @ap2017 last edited by Thomas Braun
        @ap2017
        Check the situation:
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        For even more details on your system use
        iob diag
        If you can understand German, please also check the instructions regarding nodejs in my signature.
        A 2 Replies Last reply Reply Quote 1
          ap2017 @Thomas Braun last edited by
          @thomas-braun said in Node.js update:
          iob diag
          *** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the ``` characters at start and end.
          It helps us to help you!
          Press any key to continue
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Architecture    : x86_64
          Docker          : false
          Virtualization  : none
          Distributor ID: LinuxMint
          Description:    Linux Mint 19.1 Tessa
          Release:        19.1
          Codename:       tessa
          NAME="Linux Mint"
          VERSION="19.1 (Tessa)"
          ID=linuxmint
          ID_LIKE=ubuntu
          PRETTY_NAME="Linux Mint 19.1"
          VERSION_ID="19.1"
          HOME_URL="https://www.linuxmint.com/"
          SUPPORT_URL="https://forums.linuxmint.com/"
          BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
          PRIVACY_POLICY_URL="https://www.linuxmint.com/"
          VERSION_CODENAME=tessa
          UBUNTU_CODENAME=bionic
          Systemuptime and Load:
           16:21:23 up 20:38,  2 users,  load average: 0.10, 0.05, 0.02
          CPU threads: 4
          *** Time and Time Zones ***
                                Local time: Tue 2023-06-13 16:21:23 EDT
                            Universal time: Tue 2023-06-13 20:21:23 UTC
                                  RTC time: Tue 2023-06-13 20:21:23
                                 Time zone: America/New_York (EDT, -0400)
          systemd-timesyncd.service active: yes
                           RTC in local TZ: no
          *** User and Groups ***
          ap
          /home/ap
          ap adm dialout cdrom sudo dip plugdev lpadmin sambashare iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:           3.9G        494M        1.2G         45M        2.2G        3.0G
          Swap:          2.1G          0B        2.1G
          Total:         6.0G        494M        3.3G
                   3768 M total memory
                    483 M used memory
                   1418 M active memory
                    567 M inactive memory
                   1155 M free memory
                    666 M buffer memory
                   1462 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          udev           devtmpfs  1.9G     0  1.9G   0% /dev
          tmpfs          tmpfs     377M  1.2M  376M   1% /run
          /dev/sda1      ext4      220G  131G   78G  63% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
          tmpfs          tmpfs     377M   20K  377M   1% /run/user/1000
          [Mon Jun 12 19:42:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Jun 12 19:42:49 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          Show mounted filesystems (real ones only):
          findmnt: unrecognized option '--real'
          Try 'findmnt --help' for more information.
          /var:
          3.8G    /var/
          1.9G    /var/lib
          1.7G    /var/log/journal/82929df7ee394b73b81252fe3b4e5020
          1.7G    /var/log
          Archived and active journals take up 1.6G in the file system.
          /opt/iobroker/backups:
          24M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          56G     /opt/iobroker/iobroker-data/
          55G     /opt/iobroker/iobroker-data/history
          429M    /opt/iobroker/iobroker-data/files
          125M    /opt/iobroker/iobroker-data/history/20210321
          125M    /opt/iobroker/iobroker-data/history/20210320
          23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.de9334af.js.map
          20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
          17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.52d0ccae.js.map
          *** NodeJS-Installation ***
          /home/iobroker/.diag.sh: line 166: nodejs: command not found
          /home/iobroker/.diag.sh: line 167: node: command not found
          /home/iobroker/.diag.sh: line 168: npm: command not found
          /home/iobroker/.diag.sh: line 169: npx: command not found
          /home/iobroker/.diag.sh: line 175: nodejs: command not found
          /home/iobroker/.diag.sh: line 176: node: command not found
          /home/iobroker/.diag.sh: line 177: npm: command not found
          /home/iobroker/.diag.sh: line 178: npx: command not found
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: (none)
            Candidate: 18.16.0-deb-1nodesource1
            Version table:
               18.16.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bionic/main amd64 Packages
               8.10.0~dfsg-2ubuntu0.4 500
                  500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
               8.10.0~dfsg-2ubuntu0.2 500
                  500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
               8.10.0~dfsg-2 500
                  500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          sudo: node: command not found
          Core adapters versions
          js-controller:
          admin:
          javascript:
          /home/iobroker/.diag.sh: line 248: npm: command not found
          Adapters from github:   0
          Adapter State
          ioBroker-Repositories
          Installed ioBroker-Instances
          Objects and States
          Objects:        0
          States:         0
          Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
          Hit:2 http://archive.canonical.com/ubuntu bionic InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
          Ign:4 http://packages.linuxmint.com tessa InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
          Hit:6 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
          Hit:7 https://deb.nodesource.com/node_18.x bionic InRelease
          Hit:8 http://packages.linuxmint.com tessa Release
          Hit:9 http://phoscon.de/apt/deconz bionic InRelease
          Reading package lists...
          Pending Updates: 133
          *** Listening Ports ***
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        17852      677/systemd-resolve
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30232      818/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          494799     13412/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          30234      818/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          494798     13412/cupsd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          494804     13414/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        24257      690/avahi-daemon: r
          udp        0      0 0.0.0.0:57102           0.0.0.0:*                           115        24259      690/avahi-daemon: r
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        17851      677/systemd-resolve
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          28412      1091/dhclient
          udp6       0      0 :::48359                :::*                                115        24260      690/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                115        24258      690/avahi-daemon: r
          2023-06-12 19:29:38.392  - debug: zigbee.0 (13952) DeviceAvailability:Publish available for 0xa4c138375c1e064d = false
          2023-06-12 19:29:38.394  - debug: zigbee.0 (13952) DeviceAvailability:Publish LQ for 0xa4c138375c1e064d = 0
          2023-06-12 19:29:38.397  - debug: zigbee.0 (13952) DeviceAvailability:Publish available for 0xa4c13855ba4e66b6 = false
          2023-06-12 19:29:38.399  - debug: zigbee.0 (13952) DeviceAvailability:Publish LQ for 0xa4c13855ba4e66b6 = 0
          2023-06-12 19:29:38.403  - info: zigbee.0 (13952) Zigbee: disabling joining new devices.
          2023-06-12 19:29:38.799  - info: zigbee.0 (13952) Got terminate signal TERMINATE_YOURSELF
          2023-06-12 19:29:38.884  - info: zwave2.0 (14596) terminating
          2023-06-12 19:29:38.885  - info: host.AP-Tiny instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:38.896  - info: zigbee.0 (13952) terminating
          2023-06-12 19:29:38.897  - debug: zigbee.0 (13952) Plugin sentry destroyed
          2023-06-12 19:29:38.898  - info: zigbee.0 (13952) Terminated (NO_ERROR): Without reason
          2023-06-12 19:29:38.950  - info: host.AP-Tiny instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:38.998  - info: host.AP-Tiny instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:39.031  - info: host.AP-Tiny instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:39.077  - info: host.AP-Tiny instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:39.157  - info: host.AP-Tiny instance system.adapter.zwave2.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:39.247  - info: host.AP-Tiny instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:39.324  - info: host.AP-Tiny stopInstance system.adapter.zigbee.0 killing pid 13952
          2023-06-12 19:29:39.370  - warn: host.AP-Tiny instance system.adapter.zigbee.0 terminated due to SIGTERM
          2023-06-12 19:29:39.370  - info: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code null ()
          2023-06-12 19:29:39.789  - info: history.0 (13935) terminating
          2023-06-12 19:29:39.793  - info: history.0 (13935) Terminated (NO_ERROR): Without reason
          2023-06-12 19:29:40.348  - info: host.AP-Tiny instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
          2023-06-12 19:29:40.349  - info: host.AP-Tiny All instances are stopped.
          2023-06-12 19:29:40.422  - info: host.AP-Tiny terminated
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
                               v.2023-04-16
          Operatingsystem:        Linux Mint 19.1 Tessa
          Kernel:                 4.15.0-65-generic
          Installation:           Native
          Timezone:                zone: America/New_York (EDT, -0400)
          User-ID:                1000
          X-Server:               true
          Pending OS-Updates:     133
          Pending iob updates:    0
          /home/iobroker/.diag.sh: line 340: nodejs: command not found
          Nodejs-Installation:
          /home/iobroker/.diag.sh: line 341: node: command not found
          /home/iobroker/.diag.sh: line 342: npm: command not found
          /home/iobroker/.diag.sh: line 343: npx: command not found
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:           3.9G        496M        1.2G         45M        2.2G        3.0G
          Swap:          2.1G          0B        2.1G
          Total:         6.0G        496M        3.3G
          Active iob-Instances:   0
          ioBroker Core:          js-controller
                                  admin
          ioBroker Status:
          Objects:                0
          States:                 0
          Size of iob-Database:
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          6.9M    /opt/iobroker/iobroker-data/objects.json.migrated
          6.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
          9.0M    /opt/iobroker/iobroker-data/states.jsonl
          424K    /opt/iobroker/iobroker-data/states.json.migrated
          424K    /opt/iobroker/iobroker-data/states.json.bak.migrated
          0       /opt/iobroker/iobroker-data/states.json.broken
            ap2017 @Thomas Braun last edited by ap2017
            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            Not sure what you mean by checking situation. I am not getting any response from the system after running line 1 and 2
              @ap2017
              Too old.
              Keep your OS Up-to-date.
              Node@18 won't build on Bionic based Distributions.
                @ap2017
                Try
                sudo apt install nodejs
                A Duffy 2 Replies Last reply Reply Quote 0
                  @ap2017
                  https://github.com/nodesource/distributions#deb
                  Linux Mint 19.1 "Tessa" (via Ubuntu 18.04 LTS) WARNING: BUILD SYSTEM CURRENTLY BROKEN FOR NODEJS 18+
                    ap@AP-Tiny:~$ sudo apt install nodejs
                    Reading package lists... Done
                    Building dependency tree
                    Some packages could not be installed. This may mean that you have
                    requested an impossible situation or if you are using the unstable
                    distribution that some required packages have not yet been created
                    or been moved out of Incoming.
                    The following information may help to resolve the situation:
                    The following packages have unmet dependencies:
                     nodejs : Depends: libc6 (>= 2.28) but 2.27-3ubuntu1.6 is to be installed
                    N: Ignoring file 'deconz.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                    N: Ignoring file 'deconz.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                    N: Ignoring file 'deconz.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                    E: Unable to correct problems, you have held broken packages.
                    ap@AP-Tiny:~$
                      @thomas-braun Do I need to downgrade node.js to 16?
                        @ap2017
                        No, you really really need to upgrade your operating system.
                          @thomas-braun I updated OS within current release 19.1 - did not help, waiting for instructions from Mint on how to update to newer release.
                          In the mean time, I installed node.js 16 and everything started to work, I was able to log in to system from web interface. I started updating ADMIN adapter and lost ability to log in via web browser again. Interestingly, the control script is working - I see responses to sensors, but I am not able to get into system via browser, Any ideas?
                            @ap2017 sagte in Node.js update:
                            Run
                            iob diag
                            again so I can see where you are at now.
                              iob diag
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        19.1
                              Codename:       tessa
                              NAME="Linux Mint"
                              ID=linuxmint
                              ID_LIKE=ubuntu
                              VERSION_ID="19.1"
                               14:21:35 up 47 min,  2 users,  load average: 0.07, 0.04, 0.05
                              CPU threads: 4
                                                    Local time: Wed 2023-06-14 14:21:36 EDT
                                                Universal time: Wed 2023-06-14 18:21:36 UTC
                                                      RTC time: Wed 2023-06-14 18:21:36
                                               RTC in local TZ: no
                              ap
                              /home/ap
                              X-Server:       true
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Mem:           3.9G        1.3G        478M        118M        2.1G        2.2G
                              Swap:          2.1G        262K        2.1G
                              Total:         6.0G        1.3G        2.6G
                                       3768 M total memory
                                       1253 M used memory
                                       2134 M active memory
                                        810 M inactive memory
                                        467 M free memory
                                        136 M buffer memory
                                       1910 M swap cache
                                       2047 M total swap
                                          0 M used swap
                                       2047 M free swap
                              *** FILESYSTEM ***
                              tmpfs          tmpfs     377M  1.3M  376M   1% /run
                              /dev/sda1      ext4      220G  132G   77G  64% /
                              tmpfs          tmpfs     377M   28K  377M   1% /run/user/1000
                              [Wed Jun 14 13:34:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                              [Wed Jun 14 13:34:27 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                              /var:
                              4.2G    /var/
                              1.9G    /var/lib
                              1.7G    /var/log
                              20M     /opt/iobroker/iobroker-data/objects.jsonl
                              /usr/bin/nodejs         v16.20.0
                              /usr/bin/node           v16.20.0
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
                              nodejs:
                                Installed: 16.20.0-deb-1nodesource1
                                Candidate: 16.20.0-deb-1nodesource1
                                Version table:
                               *** 16.20.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   8.10.0~dfsg-2 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              MULTIHOSTSERVICE/enabled: false
                              js-controller:  5.0.2
                              admin:          6.5.7
                              javascript:     7.0.8
                              Adapter State
                                system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
                                system.adapter.admin.0                  : admin                 : AP-Tiny                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
                                system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
                                system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
                              + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
                                system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
                                system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
                              + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
                              + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
                              + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
                                system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
                              + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                system.adapter.socketio.0               : socketio              : AP-Tiny                                  - disabled, port: 8084, bind: 192.168.1.74, run as: admin
                                system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
                                system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
                                system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
                                system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
                                system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
                              + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                              + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
                              + instance is alive
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Active repo(s): Beta (latest)
                              Used repository: Beta (latest)
                              Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                              Adapter    "admin"        : 6.5.8    , installed 6.5.7  [Updatable]
                              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                              Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                              Adapter    "echarts"      : 1.5.1    , installed 1.4.15 [Updatable]
                              Adapter    "history"      : 2.2.4    , installed 2.2.4
                              Adapter    "info"         : 1.9.26   , installed 1.9.26
                              Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
                              Controller "js-controller": 5.0.3    , installed 5.0.2  [Updatable]
                              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                              Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
                              Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                              Adapter    "vis"          : 1.4.16   , installed 1.4.16
                              Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                              Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                              Adapter    "web"          : 5.5.3    , installed 5.5.3
                              Adapter    "ws"           : 2.3.6    , installed 2.3.6
                              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                              Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                              Objects and States
                              Objects:        3955
                              States:         3402
                              Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
                              Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
                              Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                              Hit:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
                              Hit:6 https://deb.nodesource.com/node_16.x bionic InRelease
                              Hit:7 http://packages.linuxmint.com tessa Release
                              Hit:8 http://archive.canonical.com/ubuntu bionic InRelease
                              Pending Updates: 0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27152      807/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27102      807/iobroker.js-con
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22290      630/systemd-resolve
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27647      816/sshd
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23220      712/cupsd
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33556      1983/io.web.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          32769      816/sshd
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33684      2397/io.simple-api.
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23219      712/cupsd
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25966      695/avahi-daemon: r
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22289      630/systemd-resolve
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29500      1120/dhclient
                              udp        0      0 0.0.0.0:32983           0.0.0.0:*                           115        25968      695/avahi-daemon: r
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23232      747/cups-browsed
                              udp6       0      0 :::5353                 :::*                                115        25967      695/avahi-daemon: r
                              udp6       0      0 :::58743                :::*                                115        25969      695/avahi-daemon: r
                              2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                              2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                              2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                              2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                              2023-06-14 14:20:54.262  - debug: zigbee.0 (1725) Publish {"state":"OFF"} to "00124b0022419f47"
                              2023-06-14 14:20:54.266  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854266,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                              2023-06-14 14:20:54.267  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                              2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                              2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                              2023-06-14 14:20:54.269  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                              2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13895a0a783f8 TS0207 was last seen '5077.171' seconds ago.
                              2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00044678ff lumi.sensor_switch.aq3 was last seen '3689232.264' seconds ago.
                              2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00124b0022658a2b WB01 was last seen '304.075' seconds ago.
                              2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00045a362e lumi.sensor_wleak.aq1 was last seen '703.242' seconds ago.
                              2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x04cf8cdf3c79009e lumi.sen_ill.mgl01 was last seen '177.775' seconds ago.
                              2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006ea578f lumi.sensor_wleak.aq1 was last seen '1047.042' seconds ago.
                              2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e9796b lumi.sensor_wleak.aq1 was last seen '1620.726' seconds ago.
                              2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e97800 lumi.sensor_wleak.aq1 was last seen '917.723' seconds ago.
                              2023-06-14 14:21:22.555  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006f93fb0 lumi.sensor_wleak.aq1 was last seen '561.83' seconds ago.
                              2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138206a165e63 TS0207 was last seen '1379.288' seconds ago.
                              2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13808caa1c4e6 TS0207 was last seen '4434.999' seconds ago.
                              2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138375c1e064d TS0207 was last seen '2260.278' seconds ago.
                              2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13855ba4e66b6 TS0207 was last seen '8996.791' seconds ago.
                              2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c1388acbf249aa TS0011 was last seen '14447731.067' seconds ago.
                                @thomas-braun I guess I need to execute admin adapter right?
                                  @ap2017
                                  iob start admin
                                    Homoran Global Moderator Administrators @ap2017 last edited by Homoran
                                    yes, iob start admin
                                    but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
                                      ap2017 @Homoran last edited by
                                      @homoran said in Node.js update:
                                      iob start admin
                                      Thank you, I am back in business (till the next time)...
                                        iob start admin
                                        please read my edit!
                                          @ap2017
                                          Now check how to upgrade your operating system to the current release.
                                          'Tessa' is out of any support.
                                          19.1 'Tessa' (LTS)
                                          Security Support Ended 2 months and 2 weeks ago
                                          (01 Apr 2023)
                                          And run your iob on 'stable' not beta-stage.
                                            @thomas-braun Here is what I received from Mint support:
                                            Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
                                            The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
                                            CODE: SELECT ALL
                                            curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
                                            sudo apt-get install -y nodejs
                                            To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
                                            It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
                                            I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
                                            node.js
                                            4918
