    4. Modbus Fehlermeldung, wie finde ich den Fehlergrund?
      SirPritz last edited by SirPritz
      Hallo Leute, ich habe eine Fehlermeldung, finde aber den Grund nicht?
      Hatt jemand eine Idee, woran das liegen kann, oder wie ich die Ursache finde, Danke?
        TT-Tom @SirPritz last edited by
        @sirpritz
        Sehr wenig infos, wo hängt der Modus dran. Was wolltest bzw. was hast du gemacht.
        Von Logausgaben keine Screenshots machen sondern in kopieren und in die Codetags packen </>
        Spontan sagt meine Glaskugel falsche Adressierung.
          SirPritz @TT-Tom last edited by
          @tt-tom Am Modbus hängt meine Solaranlage.
          2023-06-18 11:41:03.199 - info: weatherunderground.0 (2864487) starting. Version 3.4.2 (non-npm: iobroker-community-adapters/ioBroker.weatherunderground) in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
          2023-06-18 11:41:03.709 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:03.918 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:03.919 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:03.919 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:03.919 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:03.919 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:03.919 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:03.920 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:03.920 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:03.920 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:03.920 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:03.921 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:03.921 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:03.928 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:03.934 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:04.106 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:05.874 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:05.996 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3212 nach 3193.2 passe alle Startwerte an
          2023-06-18 11:41:06.095 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:06.096 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:06.096 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:06.096 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:06.096 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:06.097 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:06.137 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:06.138 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:06.138 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:06.138 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:06.138 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:06.138 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:06.139 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:06.140 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:06.140 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:06.140 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:06.140 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:06.140 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:06.145 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:06.149 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:06.174 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:06.192 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:07.792 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:08.030 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:08.031 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:08.031 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:08.031 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:08.032 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:08.032 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:08.032 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:08.033 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:08.034 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:08.035 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:08.036 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:08.037 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:08.041 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:08.043 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:08.044 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:08.045 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:08.045 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:08.046 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:08.058 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:08.059 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:08.105 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:08.211 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:09.853 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:10.010 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3203.8 nach 3179.7 passe alle Startwerte an
          2023-06-18 11:41:10.110 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:10.111 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:10.111 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:10.111 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:10.111 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:10.111 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:10.123 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:10.124 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:10.124 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:10.124 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:10.124 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:10.125 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:10.125 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:10.126 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:10.126 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:10.126 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:10.126 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:10.127 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:10.177 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:10.178 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:10.179 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:10.214 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:12.177 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:12.395 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:12.396 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:12.397 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:12.397 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:12.397 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:12.397 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:12.398 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:12.399 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:12.399 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:12.399 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:12.399 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:12.399 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:12.400 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:12.401 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:12.401 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:12.401 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:12.402 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:12.402 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:12.414 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:12.456 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:12.458 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:12.615 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:13.059 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5729 nach 5710 passe alle Startwerte an
          2023-06-18 11:41:14.330 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:14.445 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3217.2 nach 3200.4 passe alle Startwerte an
          2023-06-18 11:41:14.543 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:14.545 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:14.545 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:14.545 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:14.545 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:14.545 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:14.564 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:14.565 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:14.565 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:14.566 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:14.566 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:14.566 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:14.566 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:14.568 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:14.568 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:14.568 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:14.568 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:14.568 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:14.573 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:14.590 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:14.632 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:14.717 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:16.360 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:16.579 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:16.580 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:16.580 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:16.580 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:16.581 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:16.581 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:16.581 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:16.581 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:16.582 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:16.582 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:16.582 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:16.582 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:16.591 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:16.592 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:16.598 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:16.600 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:16.601 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:16.601 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:16.601 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:16.601 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:16.653 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:16.872 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:17.300 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5710 nach 5704 passe alle Startwerte an
          2023-06-18 11:41:18.593 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:18.832 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:18.833 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:18.834 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:18.834 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:18.834 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:18.834 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:18.834 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:18.835 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:18.835 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:18.835 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:18.835 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:18.836 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:18.836 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:18.837 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:18.837 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:18.837 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:18.837 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:18.838 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:18.847 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:18.857 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:18.859 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:19.042 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:20.698 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:20.814 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3220.2 nach 3201 passe alle Startwerte an
          2023-06-18 11:41:20.911 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:20.912 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:20.912 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:20.913 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:20.913 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:20.913 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:20.913 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:20.914 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:20.914 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:20.914 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:20.914 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:20.915 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:20.922 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:20.924 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:20.924 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:20.924 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:20.926 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:20.926 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:20.940 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:20.948 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:20.950 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:21.114 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:22.847 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:22.900 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Solarpower_Aktuell wurde scheinbar resetet! Reset von 8924.2 nach 8907.7 passe alle Startwerte an
          2023-06-18 11:41:22.976 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3201 nach 3185.7 passe alle Startwerte an
          2023-06-18 11:41:23.073 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:23.075 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:23.075 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:23.075 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:23.075 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:23.075 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:23.081 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:23.082 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:23.082 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:23.082 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:23.082 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:23.082 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:23.083 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:23.083 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:23.084 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:23.084 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:23.086 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:23.086 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:23.098 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:23.140 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:23.141 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:23.227 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:23.715 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5723 nach 5718 passe alle Startwerte an
          2023-06-18 11:41:24.917 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:25.166 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:25.167 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:25.167 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:25.167 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:25.168 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:25.168 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:25.168 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:25.169 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:25.169 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:25.169 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:25.169 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:25.169 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:25.178 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:25.184 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:25.279 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:26.944 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:27.083 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3185.7 nach 3162.7 passe alle Startwerte an
          2023-06-18 11:41:27.161 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:27.162 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:27.163 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:27.163 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:27.163 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:27.163 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:27.163 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:27.164 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:27.164 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:27.165 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:27.165 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:27.165 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:27.176 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:27.187 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:27.189 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:27.189 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:27.189 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:27.189 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:27.190 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:27.192 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:27.273 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:27.299 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:29.052 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:29.311 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:29.313 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:29.313 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:29.314 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:29.314 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:29.314 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:29.314 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:29.315 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:29.315 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:29.315 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:29.315 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:29.315 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:29.329 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:29.331 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:29.476 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:29.955 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5750 nach 5724 passe alle Startwerte an
          2023-06-18 11:41:31.074 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:31.307 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:31.308 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:31.309 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:31.309 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:31.309 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:31.309 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:31.310 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:31.311 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:31.311 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:31.311 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:31.311 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:31.311 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:31.317 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:31.319 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:31.319 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:31.320 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:31.321 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:31.322 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:31.329 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:31.331 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:31.341 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:31.413 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:33.077 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:33.307 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:33.309 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:33.310 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:33.310 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:33.311 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:33.311 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:33.344 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:33.346 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:33.347 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:33.348 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:33.349 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:33.349 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:33.349 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:33.351 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:33.352 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:33.353 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:33.354 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:33.354 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:33.360 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:33.366 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:33.408 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:33.507 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:34.043 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5724 nach 5720 passe alle Startwerte an
          2023-06-18 11:41:35.450 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:35.564 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3214.4 nach 3200 passe alle Startwerte an
          2023-06-18 11:41:35.664 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:35.665 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:35.665 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:35.665 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:35.665 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:35.665 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:35.701 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:35.703 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:35.703 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:35.703 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:35.703 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:35.703 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:35.703 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:35.705 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:35.705 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:35.705 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:35.705 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:35.705 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:35.715 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:35.719 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:35.761 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:35.809 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:37.546 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Solarpower_Aktuell wurde scheinbar resetet! Reset von 8933.4 nach 8933.2 passe alle Startwerte an
          2023-06-18 11:41:37.603 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:37.751 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:37.910 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:37.752 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:37.752 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:37.752 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:37.752 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:37.752 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:37.801 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:37.809 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:37.810 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:37.811 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:37.811 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:37.811 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:37.811 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:37.812 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:37.813 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:37.813 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:37.813 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:37.813 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:37.814 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:37.823 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:37.864 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:38.165 - info: weatherunderground.0 (2864487) Terminated (NO_ERROR): Without reason
          2023-06-18 11:41:38.425 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5720 nach 5717 passe alle Startwerte an
          2023-06-18 11:41:38.694 - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          2023-06-18 11:41:39.650 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:39.783 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3230.2 nach 3192.8 passe alle Startwerte an
          2023-06-18 11:41:39.884 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:39.885 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:39.885 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:39.885 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:39.885 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:39.885 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:39.885 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:39.886 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:39.886 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:39.887 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:39.887 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:39.887 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:39.889 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:39.890 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:39.890 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:39.891 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:39.891 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:39.891 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:39.898 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:39.941 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:39.942 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:39.953 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:41.686 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:41.807 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Solarpower_Aktuell wurde scheinbar resetet! Reset von 8933.2 nach 8923.8 passe alle Startwerte an
          2023-06-18 11:41:41.955 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:41.956 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:41.957 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:41.957 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:41.957 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:41.957 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:41.957 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:41.958 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:41.958 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:41.958 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:41.958 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:41.958 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:41.962 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:41.964 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:41.964 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:41.964 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:41.964 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:41.965 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:42.002 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:42.004 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:42.023 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:42.093 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:43.729 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:43.896 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:43.897 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:43.898 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:43.898 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:43.898 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:43.898 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:43.908 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:43.936 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:43.937 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:43.937 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:43.938 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:43.938 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:43.938 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:43.938 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:43.939 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:43.939 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:43.939 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:43.939 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:43.939 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:43.950 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:43.992 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:44.075 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:44.578 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 5719 nach 5701 passe alle Startwerte an
          2023-06-18 11:41:45.822 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:45.996 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:45.997 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:45.997 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:45.997 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:45.997 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:45.997 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:46.032 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:46.033 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:46.033 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:46.033 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:46.033 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:46.033 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:46.033 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:46.034 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:46.034 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:46.034 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:46.034 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:46.034 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:46.038 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:46.054 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:46.097 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:46.199 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:47.874 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:47.965 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3239.7 nach 3232.6 passe alle Startwerte an
          2023-06-18 11:41:48.065 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.StromProduktion_0" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:48.299 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          2023-06-18 11:41:48.066 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:48.066 - warn: javascript.0 (338701) at Object. (script.js.Solar.Auswertung.Strom_0:9:7)
          2023-06-18 11:41:48.066 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:48.066 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:48.066 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:48.082 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:48.083 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:48.083 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:48.083 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:48.083 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:48.083 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:48.084 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:48.084 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:48.085 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:48.085 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:48.085 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:48.085 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:48.090 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.StromProduktion_0" has to be type "string" but received type "number"
          2023-06-18 11:41:48.105 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:48.149 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:49.834 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
          2023-06-18 11:41:50.047 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Kauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:50.048 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:50.049 - warn: javascript.0 (338701) at Object. (script.js.Solar.Kauf_Kompett:8:5)
          2023-06-18 11:41:50.049 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:50.049 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:50.049 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:50.049 - warn: javascript.0 (338701) You are assigning a number to the state "0_userdata.0.energy.solarinverter.Verkauf_komplett" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
          2023-06-18 11:41:50.050 - warn: javascript.0 (338701) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
          2023-06-18 11:41:50.050 - warn: javascript.0 (338701) at Object. (script.js.Solar.Verkauf_Kompett:8:5)
          2023-06-18 11:41:50.050 - warn: javascript.0 (338701) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2575:34)
          2023-06-18 11:41:50.050 - warn: javascript.0 (338701) at listOnTimeout (node:internal/timers:559:17)
          2023-06-18 11:41:50.050 - warn: javascript.0 (338701) at processTimers (node:internal/timers:502:7)
          2023-06-18 11:41:50.059 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Kauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:50.060 - info: javascript.0 (338701) State value to set for "0_userdata.0.energy.solarinverter.Verkauf_komplett" has to be type "string" but received type "number"
          2023-06-18 11:41:50.196 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
          DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
          • DJMarc75
            DJMarc75 @SirPritz last edited by
            @sirpritz sagte in Fehler, finde aber den Grund nicht:
            Zeig mal Dein dazugehörendes Skript bitte.
              SirPritz @DJMarc75 last edited by SirPritz
              @djmarc75 Hier.
              Man muss wissen, ich habe zwei Wechselrichter.
              • DJMarc75
                @sirpritz Na da wird halt Dein eigener DP
                ein String und keine number sein 😉
                  @djmarc75
                  Danke)
                    @djmarc75 Irgendwie habe ich immer noch einen Fehler.
                    2023-06-18 12:13:47.773 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                    2023-06-18 12:13:49.547 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
                    2023-06-18 12:13:49.660 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Hausverbrauch wurde scheinbar resetet! Reset von 3309.4 nach 3303 passe alle Startwerte an
                    2023-06-18 12:13:49.938 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                    2023-06-18 12:13:50.390 - warn: valuetrackerovertime.0 (339501) 0_userdata.0.energy.solarinverter.Strom_ins_Netz wurde scheinbar resetet! Reset von 6582 nach 6563 passe alle Startwerte an
                    2023-06-18 12:13:51.799 - warn: modbus.1 (2860558) [DevID_1/holdingRegs/40207] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 206 !
                    2023-06-18 12:13:52.227 - error: modbus.1 (2860558) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                    • DJMarc75
                      Habe kein Modbus aber hier könntest Du eine Lösung finden:
                      https://github.com/ioBroker/ioBroker.modbus/issues/78
                      EtzeSte13 created this issue in ioBroker/ioBroker.modbus
                      closed Read/Write Multible Registers #78
                        SirPritz @TT-Tom last edited by SirPritz
                        @tt-tom Leider konnte ich den Fehler immer noch nicht finden.
                        Hat jemand eine Idee?
                        2023-06-24 17:22:14.120 - error: modbus.1 (1797117) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                        2023-06-24 17:22:17.376 - error: modbus.1 (1797117) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                        2023-06-24 17:22:20.045 - error: modbus.1 (1797117) Cannot write multiple registers_: {"errorCode":144,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                          Homoran Global Moderator Administrators @SirPritz last edited by
                          du hast irgendwo eine falsche Registeradresse angegeben
                          die kenne ich aber nicht
                            Homoran Global Moderator Administrators @SirPritz last edited by Homoran
                            stand im alten log.
                            da würde ich mal mit anfangen
                              SirPritz @Homoran last edited by
                              @homoran und wie finde ich die Adresse raus. Wo kann ich die Adresse sehen?
                                welche jetzt?
                                da wo du sie eingegeben hast. im modbus Adapter
                                  @homoran sind etwa 50 Einträge, aber ich erkenne nicht welcher Eintrag den Fehler verursacht.
                                    dann musst du 49 löschen und alle einzeln hinzufügen bis der Fehler kommt
                                    oder du suchst den Eintrag für die Registeradresse die im log stand
                                    @homoran sagte in Fehler, finde aber den Grund nicht:
                                    stand im alten log.
                                    • OliverIO
                                      OliverIO @Homoran last edited by
                                      Die 50% Methode ist ggfs schneller.
                                      Zuerst die Hälfte deaktivieren
                                      Tritt der Fehler immer noch auf dann wieder von den verbleibenden 50% deaktivieren usw.
                                      Tritt der Fehler einmal nicht mehr dann die aktuellen deaktivieren und die vorherig deaktivierte Hälfte wieder aktivieren.
                                      50
                                      25
                                      12
                                      Im Idealfall ist man in 6 Schritten fertig. Im schlechtesten Fall benötigt man aber keine 49 versuche.
                                      • DJMarc75
                                        könnte aber trotzdem mal der TE @SirPritz den Titel hier sinnvoller gestalten?
                                          SirPritz @OliverIO last edited by
                                          @oliverio Danke, so konnte ich den Fehler schnell finden, Drei Schritte waren nötig.
                                          Im Register 40084 kam es zum Fehler, obwohl die Daten richtig ausgegeben wurden.
                                            @djmarc75 Finde leider nicht, wo ich den Titel ändern kann, kannst du mir sagen, wie ich das mache?
                                            1136
